evilaid
(Eddy Ćsterberg)
July 1, 2017, 8:36pm
121
Finally, i managed to run the command:
212 | Installed | 80 | 2.2.0.201706290942 | ZWave Binding | org.openhab.binding.zwave
And before i run it i donwloaded the latest snapshot and moved it to addon folder, then restarted my raspberry.
Paper Ui still says version 2.0.0
Thanks for your effort and patience
Dim
(Angelos)
July 1, 2017, 8:39pm
122
Yeah, PaperUI will display the āstandardā binding. You wonāt see the manually deployed snapshot version in PaperUI.
When using a manual installation method for your bindings (placing them in the addons folder), you should NOT install the binding from PaperUI (to avoid having 2 conflicting bindings installed).
Important note : The binding state is: Installed
To make it Active, issue the following command in the OH2 console: feature:install openhab-transport-serial
(this is an one time step, no need to perform this again later)
evilaid
(Eddy Ćsterberg)
July 1, 2017, 8:45pm
123
Alright, i ran the command and it seems ok. Now how do i install this binding 2.2.0 so i can add my things again?
Dim
(Angelos)
July 1, 2017, 8:47pm
124
It is now properly installed (check again with list -s |grep -i ZWave
if it shows as Active)
Your things should be already there (changing the binding doesnāt remove your existing things).
You can delete the PAT02-1B sensor thing and re-add it using PaperUI discovery
Remember that with battery power devices, initialization could take some time. Wake up the device manually several times to speed up this process and have OH2 recognize it faster.
evilaid
(Eddy Ćsterberg)
July 1, 2017, 8:50pm
125
Dude!!!
you gotāa be the most awesome person i know!!
It works, thanks a lot. Now i will move on understanding Openhab
Have a great day!
Dim
(Angelos)
July 1, 2017, 8:51pm
126
You should thank @chris for making the Z-Wave binding, maintaining a top class device database, updating code, etc, etcā¦ without all thatā¦ we would be all scratching our heads
evilaid
(Eddy Ćsterberg)
July 1, 2017, 8:52pm
127
That dude is also awesome!
yobobby
(Bob)
July 8, 2017, 12:22am
128
Hi all, thanks @chris for the bindingā¦ really looking forward to getting devices up and running but mineās one that isnāt in the database. Iāve asked for permission on the database guide page but Iām not sure if thatās the most appropriate place to ask. Any advice fellow OpenHABāers?
chris
(Chris Jackson)
July 8, 2017, 7:57am
129
What is your username on the database? No problem to give you accessā¦
TheLexus
(Nino)
September 3, 2017, 10:22am
130
@chris Hi Chris, is there any way to add a device āprivatelyā with my own device.xml or is it necessary to add it the official way?
Background: I have a Z-Uno and I think it isnāt useful for other to have my private project at the device database. I have no problems with that of course, but if I change something I need to readd it again and it messes up the official db a little bitā¦
chris
(Chris Jackson)
September 3, 2017, 10:41am
131
The XML files are compiled in to the binding - so you can create your own binding if you like, but thatās the only way.
TheLexus:
I have a Z-Uno
There has been some discussion about creating a superset of channels to handle the Z-Uno to get around this current limitation.
I think this is something what many people were waiting for.
http://z-uno.z-wave.me/
I have seen some similar projects in the net, but no one gone to production. This looks like it is.
It would be nice to check how these things work with OH. So far OH wins against COTS platforms like Fibaro, Vera or Zipato, because those trend to support their own hardware first, and donāt like 3rd party staff.
sjcliffe
(Steve Cliffe)
September 28, 2017, 12:54am
132
@chris is the XML format for your database the same as that used by Open-ZWave? Iāve got a couple of Aeotec Wallmote (ZW129) switches that arenāt in your database but are in Open-ZWave so was wondering if I can just upload the XML file from it.
chris
(Chris Jackson)
September 28, 2017, 9:52am
133
No - itās not related to OZW at all. The XML files that you upload are automatically generated by OH - this will generate all the basic information (and this information is not contained in the OZW files anyway) and the parameters need to be manually entered.
@chris Iām struggling to generate a node.XML files from the ā/var/lib/openhab2/zwaveā folder. I have the same ZW129 as @sjcliffe above. My log from /var/log/openhab2/openhab.log is below. I saw that you sometimes need to wake up the device several times to register, but doesnāt seem to make a new node.XML. Is there some other step to do, Iāve tried using paper UI and habmin but seem to get the same result. Once I get the xml generated I can upload to your website.
2017-09-29 10:45:23.605 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:4802214c:node3' to inbox.
2017-09-29 10:45:23.607 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-09-29 10:45:23.608 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:4802214c:node4' to inbox.
2017-09-29 10:45:38.078 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-09-29 10:45:38.081 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-09-29 11:07:46.500 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-09-29 11:07:46.501 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:4802214c:node3' to inbox.
2017-09-29 11:07:46.503 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-09-29 11:07:46.503 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:4802214c:node4' to inbox.
2017-09-29 11:08:01.270 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-09-29 11:08:01.272 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-09-29 11:09:45.823 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 3: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-09-29 11:09:45.825 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-10-02 10:13:32.149 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 0086:0202:0081::1.8
2017-10-02 10:13:33.161 [INFO ] [l.commandclass.ZWavePlusCommandClass] - NODE 4: unknown ZWavePlus device type: 7170
2017-10-02 10:13:33.596 [INFO ] [l.commandclass.ZWavePlusCommandClass] - NODE 4: unknown ZWavePlus device type: 7169
2017-10-02 10:13:33.787 [INFO ] [l.commandclass.ZWavePlusCommandClass] - NODE 4: unknown ZWavePlus device type: 7169
2017-10-02 10:13:39.243 [WARN ] [l.serialmessage.SendDataMessageClass] - Node 255 not found!
sjcliffe
(Steve Cliffe)
October 2, 2017, 10:27pm
135
Yes, I too tried adding my ZW129 on the weekend and ran into the same problem. Iāll turn on debug logging tonight and post my results. Iām running the 2.2 snapshot version of the binding with an Aeotec Z-stick controller.
sjcliffe
(Steve Cliffe)
October 3, 2017, 7:58am
136
Hereās my debug log:
Time Node Entry
18:24:38.131
TX REQ AddNodeToNetwork ADD_NODE_ANY HIGH POWER
18:24:38.140
RX REQ AddNodeToNetwork ADD_NODE_STATUS_LEARN_READY
18:24:44.777
RX REQ AddNodeToNetwork ADD_NODE_STATUS_NODE_FOUND
18:24:44.924 13
RX REQ AddNodeToNetwork ADD_NODE_STATUS_ADDING_SLAVE NODE 13
18:24:44.960
TX REQ AddNodeToNetwork ADD_NODE_STOP
18:24:45.015 13
RX REQ AddNodeToNetwork ADD_NODE_STATUS_DONE NODE 13
18:24:45.035 13
Stage advanced to IDENTIFY_NODE
18:24:45.040 13
TX REQ IdentifyNode
18:24:45.045 13
RX RES IdentifyNode ROUTING_SLAVE SWITCH_REMOTE2_MULTILEVEL LISTENING FLIRS250 FLIRS1000 ROUTING BEAMING
18:24:45.050 13
Stage advanced to MANUFACTURER
18:24:49.681 13
RX REQ ApplicationCommandHandler WAKE_UP_NOTIFICATION
18:24:49.710 13
Node is AWAKE
18:24:49.721 13
TX REQ SendData 131 MANUFACTURER_SPECIFIC_GET ACK AUTO_ROUTE EXPLORE
18:24:49.728 13
RX RES SendData 131 ACCEPTED BY CONTROLLER
18:24:49.748 13
RX REQ SendData 131 ACK RECEIVED from device in 27ms
18:24:49.763 13
RX REQ ApplicationCommandHandler MANUFACTURER_SPECIFIC_REPORT 0086:0202:0081
18:24:49.806 13
Stage advanced to SECURITY_REPORT
18:24:49.810 13
Stage advanced to APP_VERSION
18:24:49.820 13
TX REQ SendData 132 MANUFACTURER_SPECIFIC_GET ACK AUTO_ROUTE EXPLORE
18:24:49.828 13
RX RES SendData 132 ACCEPTED BY CONTROLLER
18:24:49.847 13
RX REQ SendData 132 ACK RECEIVED from device in 27ms
18:24:49.856 13
18:24:49.886 13
TX REQ SendData 133 VERSION_GET ACK AUTO_ROUTE EXPLORE
18:24:49.893 13
RX RES SendData 133 ACCEPTED BY CONTROLLER
18:24:49.909 13
RX REQ SendData 133 ACK RECEIVED from device in 23ms
18:24:49.923 13
RX REQ ApplicationCommandHandler VERSION_REPORT APPLICATION_VERSION VERSION 1.8
18:24:49.951 13
Stage advanced to DISCOVERY_COMPLETE
18:24:50.098 13
Stage advanced to VERSION
18:24:50.120 13
TX REQ SendData 134 VERSION_COMMAND_CLASS_GET BASIC ACK AUTO_ROUTE EXPLORE
18:24:50.126 13
RX RES SendData 134 ACCEPTED BY CONTROLLER
18:24:50.143 13
RX REQ SendData 134 ACK RECEIVED from device in 23ms
18:24:50.154 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT BASIC VERSION 2
18:24:50.164 13
TX REQ SendData 135 VERSION_COMMAND_CLASS_GET VERSION ACK AUTO_ROUTE EXPLORE
18:24:50.170 13
RX RES SendData 135 ACCEPTED BY CONTROLLER
18:24:50.187 13
RX REQ SendData 135 ACK RECEIVED from device in 23ms
18:24:50.198 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT VERSION VERSION 2
18:24:50.210 13
TX REQ SendData 136 VERSION_COMMAND_CLASS_GET WAKE_UP ACK AUTO_ROUTE EXPLORE
18:24:50.216 13
RX RES SendData 136 ACCEPTED BY CONTROLLER
18:24:50.232 13
RX REQ SendData 136 ACK RECEIVED from device in 22ms
18:24:50.244 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT WAKE_UP VERSION 2
18:24:50.254 13
TX REQ SendData 137 VERSION_COMMAND_CLASS_GET MULTI_INSTANCE_ASSOCIATION ACK AUTO_ROUTE EXPLORE
18:24:50.260 13
RX RES SendData 137 ACCEPTED BY CONTROLLER
18:24:50.277 13
RX REQ SendData 137 ACK RECEIVED from device in 23ms
18:24:50.288 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT MULTI_INSTANCE_ASSOCIATION VERSION 3
18:24:50.305 13
TX REQ SendData 138 VERSION_COMMAND_CLASS_GET ALARM ACK AUTO_ROUTE EXPLORE
18:24:50.311 13
RX RES SendData 138 ACCEPTED BY CONTROLLER
18:24:50.327 13
RX REQ SendData 138 ACK RECEIVED from device in 22ms
18:24:50.338 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT ALARM VERSION 4
18:24:50.347 13
TX REQ SendData 139 VERSION_COMMAND_CLASS_GET COMMAND_CLASS_ASSOCIATION ACK AUTO_ROUTE EXPLORE
18:24:50.353 13
RX RES SendData 139 ACCEPTED BY CONTROLLER
18:24:50.370 13
RX REQ SendData 139 ACK RECEIVED from device in 23ms
18:24:50.382 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT COMMAND_CLASS_ASSOCIATION VERSION 2
18:24:50.400 13
TX REQ SendData 140 VERSION_COMMAND_CLASS_GET CONFIGURATION ACK AUTO_ROUTE EXPLORE
18:24:50.406 13
RX RES SendData 140 ACCEPTED BY CONTROLLER
18:24:50.425 13
RX REQ SendData 140 ACK RECEIVED from device in 25ms
18:24:50.433 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT CONFIGURATION VERSION 1
18:24:50.462 13
TX REQ SendData 141 VERSION_COMMAND_CLASS_GET FIRMWARE_UPDATE_MD ACK AUTO_ROUTE EXPLORE
18:24:50.468 13
RX RES SendData 141 ACCEPTED BY CONTROLLER
18:24:50.486 13
RX REQ SendData 141 ACK RECEIVED from device in 24ms
18:24:50.496 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT FIRMWARE_UPDATE_MD VERSION 2
18:24:50.504 13
TX REQ SendData 142 VERSION_COMMAND_CLASS_GET MANUFACTURER_SPECIFIC ACK AUTO_ROUTE EXPLORE
18:24:50.511 13
RX RES SendData 142 ACCEPTED BY CONTROLLER
18:24:50.526 13
RX REQ SendData 142 ACK RECEIVED from device in 22ms
18:24:50.538 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT MANUFACTURER_SPECIFIC VERSION 2
18:24:50.547 13
TX REQ SendData 143 VERSION_COMMAND_CLASS_GET CENTRAL_SCENE ACK AUTO_ROUTE EXPLORE
18:24:50.553 13
RX RES SendData 143 ACCEPTED BY CONTROLLER
18:24:50.570 13
RX REQ SendData 143 ACK RECEIVED from device in 23ms
18:24:50.582 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT CENTRAL_SCENE VERSION 2
18:24:50.595 13
TX REQ SendData 144 VERSION_COMMAND_CLASS_GET ASSOCIATION_GROUP_INFO ACK AUTO_ROUTE EXPLORE
18:24:50.607 13
RX RES SendData 144 ACCEPTED BY CONTROLLER
18:24:50.619 13
RX REQ SendData 144 ACK RECEIVED from device in 24ms
18:24:50.631 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT ASSOCIATION_GROUP_INFO VERSION 1
18:24:50.653 13
TX REQ SendData 145 VERSION_COMMAND_CLASS_GET ZWAVE_PLUS_INFO ACK AUTO_ROUTE EXPLORE
18:24:50.660 13
RX RES SendData 145 ACCEPTED BY CONTROLLER
18:24:50.675 13
RX REQ SendData 145 ACK RECEIVED from device in 22ms
18:24:50.687 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT ZWAVE_PLUS_INFO VERSION 2
18:24:50.705 13
TX REQ SendData 146 VERSION_COMMAND_CLASS_GET MULTI_INSTANCE ACK AUTO_ROUTE EXPLORE
18:24:50.711 13
RX RES SendData 146 ACCEPTED BY CONTROLLER
18:24:50.727 13
RX REQ SendData 146 ACK RECEIVED from device in 22ms
18:24:50.739 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT MULTI_INSTANCE VERSION 4
18:24:50.754 13
TX REQ SendData 147 VERSION_COMMAND_CLASS_GET DEVICE_RESET_LOCALLY ACK AUTO_ROUTE EXPLORE
18:24:50.760 13
RX RES SendData 147 ACCEPTED BY CONTROLLER
18:24:50.776 13
RX REQ SendData 147 ACK RECEIVED from device in 22ms
18:24:50.788 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT DEVICE_RESET_LOCALLY VERSION 1
18:24:50.801 13
TX REQ SendData 148 VERSION_COMMAND_CLASS_GET POWERLEVEL ACK AUTO_ROUTE EXPLORE
18:24:50.807 13
RX RES SendData 148 ACCEPTED BY CONTROLLER
18:24:50.823 13
RX REQ SendData 148 ACK RECEIVED from device in 22ms
18:24:50.835 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT POWERLEVEL VERSION 1
18:24:50.855 13
TX REQ SendData 149 VERSION_COMMAND_CLASS_GET BATTERY ACK AUTO_ROUTE EXPLORE
18:24:50.862 13
RX RES SendData 149 ACCEPTED BY CONTROLLER
18:24:50.879 13
RX REQ SendData 149 ACK RECEIVED from device in 24ms
18:24:50.889 13
RX REQ ApplicationCommandHandler VERSION_COMMAND_CLASS_REPORT BATTERY VERSION 1
18:24:50.901 13
Stage advanced to ENDPOINTS
18:24:50.903 13
TX REQ SendData 150 MULTI_INSTANCE MULTI_CHANNEL_END_POINT_GET ACK AUTO_ROUTE EXPLORE
18:24:50.909 13
RX RES SendData 150 ACCEPTED BY CONTROLLER
18:24:50.925 13
RX REQ SendData 150 ACK RECEIVED from device in 22ms
18:24:50.937 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_END_POINT_REPORT 2 ENDPOINTS DYNAMIC
18:24:50.967 13
TX REQ SendData 151 MULTI_INSTANCE MULTI_CHANNEL_CAPABILITY_GET ACK AUTO_ROUTE EXPLORE
18:24:50.973 13
RX RES SendData 151 ACCEPTED BY CONTROLLER
18:24:50.989 13
RX REQ SendData 151 ACK RECEIVED from device in 22ms
18:24:51.004 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CAPABILITY_REPORT ENDPOINT-1 ROUTING_SLAVE SWITCH_REMOTE2_MULTILEVEL
18:24:51.023 13
TX REQ SendData 152 MULTI_INSTANCE MULTI_CHANNEL_CAPABILITY_GET ACK AUTO_ROUTE EXPLORE
18:24:51.029 13
RX RES SendData 152 ACCEPTED BY CONTROLLER
18:24:51.045 13
RX REQ SendData 152 ACK RECEIVED from device in 22ms
18:24:51.061 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CAPABILITY_REPORT ENDPOINT-2 ROUTING_SLAVE SWITCH_REMOTE2_MULTILEVEL
18:24:51.077 13
Stage advanced to UPDATE_DATABASE
18:24:51.080 13
Stage advanced to STATIC_VALUES
18:24:51.095 13
TX REQ SendData 153 WAKE_UP_INTERVAL_GET ACK AUTO_ROUTE EXPLORE
18:24:51.102 13
RX RES SendData 153 ACCEPTED BY CONTROLLER
18:24:51.117 13
RX REQ SendData 153 ACK RECEIVED from device in 22ms
18:24:51.130 13
RX REQ ApplicationCommandHandler WAKE_UP_INTERVAL_REPORT Period=0 Reporting to BROADCAST
18:24:51.138 13
TX REQ SendData 154 WAKE_UP_INTERVAL_CAPABILITIES_GET ACK AUTO_ROUTE EXPLORE
18:24:51.145 13
RX RES SendData 154 ACCEPTED BY CONTROLLER
18:24:51.160 13
RX REQ SendData 154 ACK RECEIVED from device in 22ms
18:24:51.176 13
RX REQ ApplicationCommandHandler WAKE_UP_INTERVAL_CAPABILITIES_REPORT Min=0 Max=864000 Default=0 Step=240
18:24:51.185 13
TX REQ SendData 155 MULTI_INSTANCE_ASSOCIATION_GROUPINGS_GET ACK AUTO_ROUTE EXPLORE
18:24:51.191 13
RX RES SendData 155 ACCEPTED BY CONTROLLER
18:24:51.207 13
RX REQ SendData 155 ACK RECEIVED from device in 22ms
18:24:51.218 13
RX REQ ApplicationCommandHandler MULTI_INSTANCE_ASSOCIATION_GROUPINGS_REPORT Supports 5 groups
18:24:51.226 13
TX REQ SendData 156 ALARM_SUPPORTED_GET ACK AUTO_ROUTE EXPLORE
18:24:51.232 13
RX RES SendData 156 ACCEPTED BY CONTROLLER
18:24:51.248 13
RX REQ SendData 156 ACK RECEIVED from device in 22ms
18:24:51.260 13
RX REQ ApplicationCommandHandler ALARM_SUPPORTED_REPORT
18:24:51.268 13
TX REQ SendData 157 ASSOCIATION_GROUPINGS_GET ACK AUTO_ROUTE EXPLORE
18:24:51.274 13
RX RES SendData 157 ACCEPTED BY CONTROLLER
18:24:51.290 13
RX REQ SendData 157 ACK RECEIVED from device in 22ms
18:24:51.302 13
RX REQ ApplicationCommandHandler ASSOCIATION_GROUPINGS_REPORT Supports 5 groups
18:24:51.309 13
TX REQ SendData 158 CENTRAL_SCENE_SUPPORTED_GET ACK AUTO_ROUTE EXPLORE
18:24:51.315 13
RX RES SendData 158 ACCEPTED BY CONTROLLER
18:24:51.332 13
RX REQ SendData 158 ACK RECEIVED from device in 23ms
18:24:51.344 13
RX REQ ApplicationCommandHandler CENTRAL_SCENE_SUPPORTED_REPORT
18:24:51.351 13
TX REQ SendData 159 ZWAVE_PLUS_INFO_GET ACK AUTO_ROUTE EXPLORE
18:24:51.357 13
RX RES SendData 159 ACCEPTED BY CONTROLLER
18:24:51.376 13
RX REQ SendData 159 ACK RECEIVED from device in 25ms
18:24:51.388 13
RX REQ ApplicationCommandHandler ZWAVE_PLUS_INFO_REPORT
18:24:51.413 13
TX REQ SendData 160 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 CENTRAL_SCENE_SUPPORTED_GET ACK AUTO_ROUTE EXPLORE
18:24:51.421 13
RX RES SendData 160 ACCEPTED BY CONTROLLER
18:24:51.437 13
RX REQ SendData 160 ACK RECEIVED from device in 24ms
18:24:51.452 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 CENTRAL_SCENE_SUPPORTED_REPORT
18:24:51.483 13
TX REQ SendData 161 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 MULTI_INSTANCE_ASSOCIATION_GROUPINGS_GET ACK AUTO_ROUTE EXPLORE
18:24:51.489 13
RX RES SendData 161 ACCEPTED BY CONTROLLER
18:24:51.506 13
RX REQ SendData 161 ACK RECEIVED from device in 23ms
18:24:51.519 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 MULTI_INSTANCE_ASSOCIATION_GROUPINGS_REPORT Supports 3 groups
18:24:51.528 13
TX REQ SendData 162 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUPINGS_GET ACK AUTO_ROUTE EXPLORE
18:24:51.534 13
RX RES SendData 162 ACCEPTED BY CONTROLLER
18:24:51.551 13
RX REQ SendData 162 ACK RECEIVED from device in 23ms
18:24:51.563 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUPINGS_REPORT Supports 3 groups
18:24:51.573 13
TX REQ SendData 163 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ZWAVE_PLUS_INFO_GET ACK AUTO_ROUTE EXPLORE
18:24:51.579 13
RX RES SendData 163 ACCEPTED BY CONTROLLER
18:24:51.596 13
RX REQ SendData 163 ACK RECEIVED from device in 23ms
18:24:51.612 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ZWAVE_PLUS_INFO_REPORT
18:24:51.622 13
TX REQ SendData 164 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-2 CENTRAL_SCENE_SUPPORTED_GET ACK AUTO_ROUTE EXPLORE
18:24:51.629 13
RX RES SendData 164 ACCEPTED BY CONTROLLER
18:24:51.645 13
RX REQ SendData 164 ACK RECEIVED from device in 23ms
18:24:51.658 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-2 -> EP-1 CENTRAL_SCENE_SUPPORTED_REPORT
18:24:51.667 13
TX REQ SendData 165 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-2 MULTI_INSTANCE_ASSOCIATION_GROUPINGS_GET ACK AUTO_ROUTE EXPLORE
18:24:51.673 13
RX RES SendData 165 ACCEPTED BY CONTROLLER
18:24:51.691 13
RX REQ SendData 165 ACK RECEIVED from device in 24ms
18:24:51.703 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-2 -> EP-1 MULTI_INSTANCE_ASSOCIATION_GROUPINGS_REPORT Supports 3 groups
18:24:51.712 13
TX REQ SendData 166 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-2 ASSOCIATION_GROUPINGS_GET ACK AUTO_ROUTE EXPLORE
18:24:51.719 13
RX RES SendData 166 ACCEPTED BY CONTROLLER
18:24:51.736 13
RX REQ SendData 166 ACK RECEIVED from device in 24ms
18:24:51.749 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-2 -> EP-1 ASSOCIATION_GROUPINGS_REPORT Supports 3 groups
18:24:51.758 13
TX REQ SendData 167 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-2 ZWAVE_PLUS_INFO_GET ACK AUTO_ROUTE EXPLORE
18:24:51.764 13
RX RES SendData 167 ACCEPTED BY CONTROLLER
18:24:51.780 13
RX REQ SendData 167 ACK RECEIVED from device in 22ms
18:24:51.796 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-2 -> EP-1 ZWAVE_PLUS_INFO_REPORT
18:24:51.836 13
TX REQ SendData 168 ALARM_EVENTSUPPORTED_GET ACK AUTO_ROUTE EXPLORE
18:24:51.842 13
RX RES SendData 168 ACCEPTED BY CONTROLLER
18:24:51.858 13
RX REQ SendData 168 ACK RECEIVED from device in 22ms
18:24:51.871 13
RX REQ ApplicationCommandHandler ALARM_EVENTSUPPORTED_REPORT
18:24:51.879 13
TX REQ SendData 169 ASSOCIATION_GROUP_INFO_NAME_GET GROUP_1 ACK AUTO_ROUTE EXPLORE
18:24:51.885 13
RX RES SendData 169 ACCEPTED BY CONTROLLER
18:24:51.901 13
RX REQ SendData 169 ACK RECEIVED from device in 22ms
18:24:51.916 13
RX REQ ApplicationCommandHandler ASSOCIATION_GROUP_INFO_NAME_REPORT GROUP_1 Lifeline
18:24:51.924 13
TX REQ SendData 170 ASSOCIATION_GROUP_INFO_GET GROUP_1 ACK AUTO_ROUTE EXPLORE
18:24:51.930 13
RX RES SendData 170 ACCEPTED BY CONTROLLER
18:24:51.947 13
RX REQ SendData 170 ACK RECEIVED from device in 23ms
18:24:51.960 13
RX REQ ApplicationCommandHandler ASSOCIATION_GROUP_INFO_REPORT GROUP_1
18:24:51.969 13
TX REQ SendData 171 ASSOCIATION_GROUP_INFO_COMMAND_GET GROUP_1 ACK AUTO_ROUTE EXPLORE
18:24:51.975 13
RX RES SendData 171 ACCEPTED BY CONTROLLER
18:24:51.991 13
RX REQ SendData 171 ACK RECEIVED from device in 22ms
18:24:52.007 13
RX REQ ApplicationCommandHandler ASSOCIATION_GROUP_INFO_COMMAND_REPORT GROUP_1
18:24:52.017 13
TX REQ SendData 172 ASSOCIATION_GROUP_INFO_NAME_GET GROUP_2 ACK AUTO_ROUTE EXPLORE
18:24:52.023 13
RX RES SendData 172 ACCEPTED BY CONTROLLER
18:24:52.039 13
RX REQ SendData 172 ACK RECEIVED from device in 22ms
18:24:52.056 13
RX REQ ApplicationCommandHandler ASSOCIATION_GROUP_INFO_NAME_REPORT GROUP_2 On/Off (Key 1)
18:24:52.066 13
TX REQ SendData 173 ASSOCIATION_GROUP_INFO_GET GROUP_2 ACK AUTO_ROUTE EXPLORE
18:24:52.072 13
RX RES SendData 173 ACCEPTED BY CONTROLLER
18:24:52.089 13
RX REQ SendData 173 ACK RECEIVED from device in 23ms
18:24:52.103 13
18:24:52.122 13
TX REQ SendData 174 ASSOCIATION_GROUP_INFO_COMMAND_GET GROUP_2 ACK AUTO_ROUTE EXPLORE
18:24:52.129 13
RX RES SendData 174 ACCEPTED BY CONTROLLER
18:24:52.146 13
RX REQ SendData 174 ACK RECEIVED from device in 24ms
18:24:52.158 13
RX REQ ApplicationCommandHandler ASSOCIATION_GROUP_INFO_COMMAND_REPORT GROUP_2
18:24:52.188 13
TX REQ SendData 175 ASSOCIATION_GROUP_INFO_NAME_GET GROUP_3 ACK AUTO_ROUTE EXPLORE
18:24:52.195 13
RX RES SendData 175 ACCEPTED BY CONTROLLER
18:24:52.212 13
RX REQ SendData 175 ACK RECEIVED from device in 24ms
18:24:52.281 13
RX REQ ApplicationCommandHandler ASSOCIATION_GROUP_INFO_NAME_REPORT GROUP_3 Dimmer (Key 1)
18:24:52.289 13
TX REQ SendData 176 ASSOCIATION_GROUP_INFO_GET GROUP_3 ACK AUTO_ROUTE EXPLORE
18:24:52.295 13
RX RES SendData 176 ACCEPTED BY CONTROLLER
18:24:52.311 13
RX REQ SendData 176 ACK RECEIVED from device in 22ms
18:24:52.326 13
18:24:52.340 13
TX REQ SendData 177 ASSOCIATION_GROUP_INFO_COMMAND_GET GROUP_3 ACK AUTO_ROUTE EXPLORE
18:24:52.347 13
RX RES SendData 177 ACCEPTED BY CONTROLLER
18:24:52.366 13
RX REQ SendData 177 ACK RECEIVED from device in 26ms
18:24:52.376 13
RX REQ ApplicationCommandHandler ASSOCIATION_GROUP_INFO_COMMAND_REPORT GROUP_3
18:24:52.396 13
TX REQ SendData 178 ASSOCIATION_GROUP_INFO_NAME_GET GROUP_4 ACK AUTO_ROUTE EXPLORE
18:24:52.410 13
RX RES SendData 178 ACCEPTED BY CONTROLLER
18:24:52.419 13
RX REQ SendData 178 ACK RECEIVED from device in 23ms
18:24:52.436 13
RX REQ ApplicationCommandHandler ASSOCIATION_GROUP_INFO_NAME_REPORT GROUP_4 On/Off (Key 2)
18:24:52.447 13
TX REQ SendData 179 ASSOCIATION_GROUP_INFO_GET GROUP_4 ACK AUTO_ROUTE EXPLORE
18:24:52.454 13
RX RES SendData 179 ACCEPTED BY CONTROLLER
18:24:52.470 13
RX REQ SendData 179 ACK RECEIVED from device in 23ms
18:24:52.484 13
18:24:52.495 13
TX REQ SendData 180 ASSOCIATION_GROUP_INFO_COMMAND_GET GROUP_4 ACK AUTO_ROUTE EXPLORE
18:24:52.500 13
RX RES SendData 180 ACCEPTED BY CONTROLLER
18:24:52.517 13
RX REQ SendData 180 ACK RECEIVED from device in 22ms
18:24:52.530 13
RX REQ ApplicationCommandHandler ASSOCIATION_GROUP_INFO_COMMAND_REPORT GROUP_4
18:24:52.539 13
TX REQ SendData 181 ASSOCIATION_GROUP_INFO_NAME_GET GROUP_5 ACK AUTO_ROUTE EXPLORE
18:24:52.545 13
RX RES SendData 181 ACCEPTED BY CONTROLLER
18:24:52.561 13
RX REQ SendData 181 ACK RECEIVED from device in 22ms
18:24:52.577 13
RX REQ ApplicationCommandHandler ASSOCIATION_GROUP_INFO_NAME_REPORT GROUP_5 Dimmer (Key 2)
18:24:52.586 13
TX REQ SendData 182 ASSOCIATION_GROUP_INFO_GET GROUP_5 ACK AUTO_ROUTE EXPLORE
18:24:52.591 13
RX RES SendData 182 ACCEPTED BY CONTROLLER
18:24:52.608 13
RX REQ SendData 182 ACK RECEIVED from device in 22ms
18:24:52.622 13
18:24:52.631 13
TX REQ SendData 183 ASSOCIATION_GROUP_INFO_COMMAND_GET GROUP_5 ACK AUTO_ROUTE EXPLORE
18:24:52.638 13
RX RES SendData 183 ACCEPTED BY CONTROLLER
18:24:52.655 13
RX REQ SendData 183 ACK RECEIVED from device in 24ms
18:24:52.666 13
RX REQ ApplicationCommandHandler ASSOCIATION_GROUP_INFO_COMMAND_REPORT GROUP_5
18:24:52.674 13
TX REQ SendData 184 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_NAME_GET GROUP_1 ACK AUTO_ROUTE EXPLORE
18:24:52.681 13
RX RES SendData 184 ACCEPTED BY CONTROLLER
18:24:52.698 13
RX REQ SendData 184 ACK RECEIVED from device in 24ms
18:24:52.718 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_NAME_REPORT GROUP_1 Key 1 via Lifeline
18:24:52.728 13
TX REQ SendData 185 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_GET GROUP_1 ACK AUTO_ROUTE EXPLORE
18:24:52.734 13
RX RES SendData 185 ACCEPTED BY CONTROLLER
18:24:52.752 13
RX REQ SendData 185 ACK RECEIVED from device in 24ms
18:24:52.768 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_REPORT GROUP_1
18:24:52.777 13
TX REQ SendData 186 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_COMMAND_GET GROUP_1 ACK AUTO_ROUTE EXPLORE
18:24:52.783 13
RX RES SendData 186 ACCEPTED BY CONTROLLER
18:24:52.801 13
RX REQ SendData 186 ACK RECEIVED from device in 24ms
18:24:52.814 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_COMMAND_REPORT GROUP_1
18:24:52.823 13
TX REQ SendData 187 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_NAME_GET GROUP_2 ACK AUTO_ROUTE EXPLORE
18:24:52.830 13
RX RES SendData 187 ACCEPTED BY CONTROLLER
18:24:52.847 13
RX REQ SendData 187 ACK RECEIVED from device in 24ms
18:24:52.864 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_NAME_REPORT GROUP_2 On/Off (Key 1)
18:24:52.874 13
TX REQ SendData 188 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_GET GROUP_2 ACK AUTO_ROUTE EXPLORE
18:24:52.881 13
RX RES SendData 188 ACCEPTED BY CONTROLLER
18:24:52.899 13
RX REQ SendData 188 ACK RECEIVED from device in 25ms
18:24:52.913 13
18:24:52.924 13
TX REQ SendData 189 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_COMMAND_GET GROUP_2 ACK AUTO_ROUTE EXPLORE
18:24:52.930 13
RX RES SendData 189 ACCEPTED BY CONTROLLER
18:24:52.948 13
RX REQ SendData 189 ACK RECEIVED from device in 24ms
18:24:52.961 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_COMMAND_REPORT GROUP_2
18:24:52.996 13
TX REQ SendData 190 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_NAME_GET GROUP_3 ACK AUTO_ROUTE EXPLORE
18:24:53.005 13
RX RES SendData 190 ACCEPTED BY CONTROLLER
18:24:53.021 13
RX REQ SendData 190 ACK RECEIVED from device in 25ms
18:24:53.040 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_NAME_REPORT GROUP_3 Dimmer (Key 1)
18:24:53.055 13
TX REQ SendData 191 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_GET GROUP_3 ACK AUTO_ROUTE EXPLORE
18:24:53.063 13
RX RES SendData 191 ACCEPTED BY CONTROLLER
18:24:53.080 13
RX REQ SendData 191 ACK RECEIVED from device in 25ms
18:24:53.096 13
18:24:53.111 13
TX REQ SendData 192 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_COMMAND_GET GROUP_3 ACK AUTO_ROUTE EXPLORE
18:24:53.119 13
RX RES SendData 192 ACCEPTED BY CONTROLLER
18:24:53.136 13
RX REQ SendData 192 ACK RECEIVED from device in 25ms
18:24:53.150 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_COMMAND_REPORT GROUP_3
18:24:53.164 13
TX REQ SendData 193 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_NAME_GET GROUP_4 ACK AUTO_ROUTE EXPLORE
18:24:53.170 13
RX RES SendData 193 ACCEPTED BY CONTROLLER
18:24:53.188 13
RX REQ SendData 193 ACK RECEIVED from device in 24ms
18:24:53.208 13
RX REQ ApplicationCommandHandler MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_NAME_REPORT GROUP_4 On/Off (Key 2)
18:24:53.224 13
TX REQ SendData 194 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_GET GROUP_4 ACK AUTO_ROUTE EXPLORE
18:24:53.231 13
RX RES SendData 194 ACCEPTED BY CONTROLLER
18:24:53.249 13
RX REQ SendData 194 ACK RECEIVED from device in 25ms
18:24:53.265 13
18:24:53.279 13
TX REQ SendData 195 MULTI_CHANNEL_CMD_ENCAP EP-1 -> EP-1 ASSOCIATION_GROUP_INFO_COMMAND_GET GROUP_4 ACK AUTO_ROUTE EXPLORE
18:24:53.286 13
RX RES SendData 195 ACCEPTED BY CONTROLLER
18:24:53.304 13
RX REQ SendData 195 ACK RECEIVED from device in 25ms
18:24:58.294 13
Message retry (2 attempts remaining)
18:25:05.846
18:25:05.902 13
chris
(Chris Jackson)
October 3, 2017, 9:10am
137
sjcliffe:
Please provide the actual log - Iāveno idea what this format is, but itās not usable for me - sorry.
sjcliffe
(Steve Cliffe)
October 3, 2017, 10:06am
138
Sorry - it was a cut/paste from the log viewer. The raw logs exceed the body size limit here and txt files arenāt allowed as attachments so the logs are here - http://www.sjcnet.id.au/ZW129-logs.txt
sjcliffe
(Steve Cliffe)
October 15, 2017, 7:03am
139
@chris just wondering if youāve had a chance to look at these logs and can offer any suggestions? Thanks.
Hi @sjcliffe did you manage your ZW129 this working? Iām about to try homeseer or something else, as they are just sitting in a draw at present.
