IHC Binding in 2.beta
Hi Community
Have someone tried to use the v.1 IHC binding in v.2 OH?
It seems that it does not work correctly.
from logs:
2016-01-26 10:06:19.085 [ERROR] [org.openhab.binding.ihc ] - [org.openhab.binding.ihc(182)] bind method [addBindingProvider] not found; Component will fail
2016-01-26 10:06:19.088 [ERROR] [org.openhab.binding.ihc ] - [org.openhab.binding.ihc(182)] bind method [addBindingProvider] not found
2016-01-26 10:06:19.179 [INFO ] [core.karaf.internal.FeatureInstaller] - Installed ‘openhab-binding-ihc’
I installed the binding via paper-ui, and manually edited the ihc.cfg in services folder.
/Henrik
The IHC binding needs the same fix as HTTP Binding under OH2
Thanks for the answer.
Can someone implement this? I am not a dev.
/Henrik
I will make the change and a test JAR for openhab-binding-ihc later today.
..OK, PR is here and test JAR is here. Please try the test JAR and report back here or on the pull request, and thank you.
With a 1.x binding that was installed via Paper UI, I think you must make sure the old bundle is uninstalled. Make sure it’s not installed by running bundle:list at the openhab> prompt. Then put the new test JAR in the addons folder.
Hi watou. My simple tests is ok. Binding is starting, and I see changes in log.
thanks for the fix.
