I assume that you mean this paragraph? I’m just wondering how the exclusion is supposed to take place if the stick is no longer connected, so how is a signal supposed to arrive at the lock?
Exclusion: Delete the lock from the app before you exclude. Otherwise it won’t work. Exclusion is successful when the green light stops lightning immediately. If you use the Aeotec Z-Stick Gen5 it is easier to exclude with the USB stick detached. Inclusion of course with the stick attached to the PC. You can use any kind of controller to exclude - no matter with which controller it has been paired before.
Yes. Up above you said you had an Aeotec stick. They all have internal battery to send exclusion signals without being connected to a server/power. I’m still stuck on the idea that the zwave info (from previous attempts with the app or with OH) has not been cleared from the lock
edit: As a side note you can generally include any device with a detached Aeotec zstick except for devices that include security (like your lock). It is not recommended because it is better to have OH perform the inclusion (sometimes using a detached Aeotec Zstick has problems with inclusion)
By the way, this is the stick I have. Does this one actually have a battery as well? It doesn’t say anything about it in the description. Is there another stick that you can recommend?
Maybe you have a different model, but there should be a button (that flashes color) hit once to get flashing blue (include) hit again to get flashing yellow (exclude). Do you have that? If yes get to the flashing yellow and poke the switch on the lock. If this works, there should be a solid yellow for a few seconds
I had all the problems described here. The danalock just didn’t want to connect “securely”. It was indeed a timing problem. The button on the danalock must be pressed in the same second as the scan button in the OH GUI.
yes, it works good. It has sometimes a delay of some seconds, but yes, it works like expected. It needs a lot of battery, I’m already at 75% after heavily testing. I think about to connect it to a 12V power supply as permanent solution.
