With 20 cameras yes I am not surprised that M3 is still an issue, I have not tested that many before but you do not need to wait for M4 as I have uploaded the jar if you wish to try it out.
That is difficult to answer as it depends on the browser and the widget. You can easily check yourself by using DEBUG log output. Sometimes it is needed to press refresh on a browser after you leave the page to stop some streams.
Your streams not starting whilst others do, are any of them hikvision with digest? if so see hereā¦
@matt1 I read that part - but I assumed that given I am talking to all cams through an NVR - same ip of NVR for all 20 cams/RTSP/different channels it isnt relevant to me? Should either work or not.
will try the new jar and revert after I read the debug info also.
thanks
Newer jar just uploaded for the hik digest bug. I have fixed a lot of bugs since M3 so you may find it now works with the newer jar. A NVR can be setup to allow each camera to be accessed via its own port, in that case it would depend on the cameras settings.
my NVR is a hybrid one - some analogue and some ip cameras. - it doesnt offer the option of port specific access. this is why i access via rtsp / channel by channel
Thanks @msexton187! This is much better than relying on openhab to perform the actual switching. I wasnāt aware of the sunrise / sunset hours being available. Indeed I could just set the time from astro and even add/subtract as I see fit.
@jimtng and @msexton187
I created a github feature request here so if you want to do some testing and give feedback, it can be captured in one place to be looked at getting added.
So ffmpeg complains about wrong loglevel settings. This is my ffmpeg version: āffmpeg version 4.1.8-0+deb10u1+rpt1ā. Is this a known problem? Binding version is 3.1.0
Looks like it is as data corruption. Make sure your card is not a counterfeit and is a quality one. Also make sure you have a UPS to protect against power outages when you have not shutdown correctly. Bad power supplies can also cause it. Do backups in case the card is failing.
I found that my Imou camera is set to be restarted every day at midnight. This process takes about 30-40 seconds, and after that camera lost connection with the binding (because I can see no more ONVIF Renew/PullMessages request in the openhab.log since then).
So is there a way to re-establish the connection or reset it frequently? Thank you!
I believe I fixed that in the latest build, you can either download it now or wait around a week for the next milestone (4?) to be released. The event streams and also if you have any open mjpeg streams will continue on after the camera reboots without needing any interaction.
Just booted my backup card and fixed apt, now everything seems to work Never had any data issues for the last 10 years but always cared for my backups. Now it finally payed off.
I like to give feedback about my current tests and local setup.
Probably it will help other.
Camera I use (just bought few days ago): Reolink 4MP Ćberwachungskamera Aussen, 2,4/5GHz WLAN CCTV IP Kamera Outdoor, Wetterfest, 30m Nachtsicht, Sicherheitskamera mit Bewegungserkennung, Audioaufzeichnung, Fernzugriff, RLC-410W Schwarz
The rstp-address to get the native stream of the camera in my network is: rtsp://admin:YOUR_PASSWORD@192.168.178.53:554//h264Preview_01_main
In my openHAB-configuration I add a new binding of āIpCamera Bindingā:
I did install the FFMPEG on the new RaspberryPi for OH 3.1 but did not per se configure and test it. Not sure if the FFMPEG is really used for what Iām doing.
Since you have a Hikvision, there was a bug that stopped them working in DIGEST mode recently and this was just fixed in the released 3.2m4 just released. So make sure your on the latest version, or you can switch to basic auth as a work around. Dropping the new jar into older cores can be done.
As for the image channel, what is the config set to that is called āupdateImageā? also have you tried the channel called āupdateImageNowā and turning that on?
I really donāt recommend using the image channel for multiple reasons, one of which is it floods the event bus with the image data. With only a few cameras and longer poll times it is fine to do but it is a feature that I have not tested in a very long time so if you still can not get it working let me know so I can run a test here. You posted you have 9 cameras and poll times of 3 seconds, I really really donāt think it is a good idea to use the image channel in this case, I would be surprised if it worked without issues.
Why do you not want to use the other methods?
jwiseman
(Mr. Wiseman (OH 4.3.5 Stable on Pi4))
2535
The version I got was off your site back in Oct, should I get it from here which is built today?
I really only want an image to be displayed (which the image gets updated between 3 - 5 seconds) on a panel I have 6 cameras showing. Really donāt need to stream video the the panel (tablets arenāt that powerful)
Hereās the ITEMS for a camera that is working with your OH 2.5 binding.
