Are you using the Amazon Control Binding? If so there are a few topics regarding this and for now the only fix is to stop the binding. An issue has been opened on github so you may want to follow up there.
If no Amazon Binding is being used please list what binding you are using and if you’ve modified the EXTRA_JAVA_OPTS.
during the stop of openhab - using: sudo systemctl stop openhab2
The log shows:
2020-06-13 19:46:32.272 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2020-06-13 19:46:41.872 [INFO ] [control.internal.WebSocketConnection] - Web Socket error {}
java.nio.channels.AsynchronousCloseException: null
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.close(HttpConnectionOverHTTP.java:181) ~[?:?]
at java.util.ArrayList.forEach(ArrayList.java:1257) [?:1.8.0_252]
at org.eclipse.jetty.client.AbstractConnectionPool.close(AbstractConnectionPool.java:208) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.DuplexConnectionPool.close(DuplexConnectionPool.java:237) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpDestination.close(HttpDestination.java:385) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpClient.doStop(HttpClient.java:260) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.AbstractLifeCycle.stop(AbstractLifeCycle.java:93) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.ContainerLifeCycle.stop(ContainerLifeCycle.java:180) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStop(ContainerLifeCycle.java:201) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.client.WebSocketClient.doStop(WebSocketClient.java:371) [bundleFile:9.4.20.v20190813]
at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection.close(WebSocketConnection.java:159) [bundleFile:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.closeWebSocketConnection(AccountHandler.java:349) [bundleFile:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.cleanup(AccountHandler.java:272) [bundleFile:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.dispose(AccountHandler.java:237) [bundleFile:?]
at sun.reflect.GeneratedMethodAccessor90.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_252]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_252]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_252]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_252]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_252]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_252]
as you can see: there is the Web Socket error {} again!
maybe this helps to find out what is the real problem!
Sorry, I can’t answer the question about using systemd for auto restarting OH. IMHO this is not something that should be done if you have frequent errors.
Have you stopped the Amazon Control Binding and still getting web socket errors?
You can install the OH in the Alexa app and still control most of your devices as the issue is only with the control binding.
EDIT: See this post for a possible solution Web Socket Error on AmazonEchoControl binding every 65 seconds
You will need to download the jar file and place it in /usr/share/openhab2/addons then restart OH. Or you can use the console as described in the post.
Thanks to CM6.5 H102Regular for your quick response…
You are right, that this is not a normal way to restart service automaticly…
Thanks for forwarding the possible solution…
but it did not work:
here the error in the log again very 65 secounds
2020-06-15 13:40:53.993 [INFO ] [control.internal.WebSocketConnection] - Web Socket error
at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection$2.run(WebSocketConnection.java:184) [bundleFile:?]
at java.util.TimerThread.mainLoop(Timer.java:555) [?:1.8.0_252]
at java.util.TimerThread.run(Timer.java:505) [?:1.8.0_252]
I think it is better to close this topic and forward all others to
to bring all informations to the same topic, in this case the topic which works on amazon bindung which is the cuase of the crash!!!
