I have a problem limiting the number of messages a rule can send in a certain time.
I have a over 100 temp sensors which report readings via mqtt at 1s intervals each.
I have voltage, amps, power monitoring at 2s intervals, I need to be alerted of power failure.
I have smoke sesors reporting at 1s intervals.
Using simple rules I can get an almost instant Telegram alert if any of them gets triggered, BUT I keep getting the alerts over and over and over again, almost rendering my phone useless because of the message flood.
I need a piece of advice about how to limit the number of messages dispatched, something like once every 10s, or every 20s.
I don’t want them to be “one time only” since I might be busy and miss the alert, so repeating is better, but not flooding my phone at 1s intervals.
Here is one of the rules:
rule "max temp alert"
Item gTehnicalTempSensors received update
if (gTehnicalTempSensors.state as Number >= 40) {
val StringBuilder sb = new StringBuilder
gTehnicalTempSensors.allMembers.filter[ i | i.state as Number > 40 ].forEach[ i | sb.append(i.name.toString +" ")]
logError("Temperature:", "Temperatura sisteme peste 40 grade Celsius!"+sb.toString)
sendTelegram("kCritical", "Temperatura sisteme peste 40 grade Celsius! "+sb.toString)
PS. this rule also triggers a weird error every time I save the file, the rule works as expected, it’s just annoying
01:45:07.094 [ERROR] [untime.internal.engine.RuleEngineImpl] - Rule 'max temp alert': Script interpreter couldn't be obtain
