Making your Boiler-System-Bus (BSB), Local Process Bus (LPB) and Point-to-Point (PPS) interface based heating system (used by Brötje, Elco and similar) smart with BSB LAN interface
Our fellow friends at the FHEM forum have developed a great working LAN adapter to make your heating system smart.
If your heating system is equipped with a Boiler-System-Bus (BSB), Local Process Bus (LPB) or Point-to-Point (PPS) interface (manufactured by Siemens or OEM branded) you will be able to almost fully control your system, change temperatures, change heating modes, feed temperatures from external sensors to your controller, read/store and visualize several controller parameters and monitor your system.
This can be done via openHAB or an integrated web interface.
A full list of supported heating systems can be found here:
This includes brands from Brötje, Elco, Fujitsu and many more.
As their documentation is very much in detail I will only list the openHAB specific Things, Items, Rules, Transformations at the end of this thread.
Hardware needed:
  • Arduino Mega 2560
  • Arduino Ethernet Shield
  • BSB-LPB-LAN-PCB board v2
    Parts list for the PCB board:
    1x LED (red) (VCC max. 2,8V, reverse voltage 5V) (→ D1)
    1x Diode 1N4148 (→ D2)
    1x Transistor BC547A (→ Q1)
    1x of each Resistors 560kΩ (→ R1), 1,5kΩ (→ R2), 300Ω (→ R3), 4,7kΩ (→ R4)
    2x Optocouplers 4N25 (→ U1, U2) (plus 2x optional sockets)
Pre-made PCB boards or even fully assembled LAN interface boards are available, please send an e-mail to bsb(at)code-it.de (German or English) for further information.
It is also possible to connect the BSB LAN interface via wifi or connect it to a Raspberry Pi (with another software and currently more limited functionality).
Software needed:
The documentation’s main page (German only) can be found here, English version of the documentation is here: Since the maintainer of the “BSB-LAN” project, after eight years of productive collaboration, now prefers to create his own manual, I will unfortunately no longer make my comprehensive manual for this project available here. | Manual for the BSB-LAN Hard- & Software
The software’s main page can be found here (German, English)
If you need detailed support for the Arduino code or the BSB LAN interface hardware, please write (German or English) a post here
My openHAB integration:
You need to install http, expire, mqtt2, network, max, javascript transformation.
/items/bsblan.items:
Number hz_mode_cmd <heating> //change heating mode
String hz_mode_state <heating> { http="<[http://192.168.178.88/700:10000:JS(bsbinput_string.js)]" } //read heating mode from BSB LAN Adapter
Number hz_temperature_cmd <temperature> //change target temperature
Number hz_temperature_state <temperature> { http="<[http://192.168.178.88/8741:15000:JS(bsbinput.js)]" } //read current target temperature from BSB LAN Adapter
String hz_status <heating> { http="<[http://192.168.178.88/8000:20000:JS(bsbinput_string.js)]" } //read current heating status from BSB LAN Adapter
String hz_status_water <water> { http="<[http://192.168.178.88/8003:25000:JS(bsbinput_string.js)]" } //read current hot water status from BSB LAN Adapter
Switch hz_mode_komfort <switch> { expire="1s,command=OFF" } //ONLY if Parameter 48 is available on your controller: set temporary Komfort state during Automatik mode, switch item to OFF after one second (momentary switch)
Switch hz_mode_reduziert <switch> { expire="1s,command=OFF" } //ONLY if Parameter 48 is available on your controller: set temporary Reduziert state during Automatik mode, switch item to OFF after one second (momentary switch)
Number hz_temperature_rgt <temperature> { http="<[http://192.168.178.88/8740:25000:JS(bsbinput.js)]" } //read current room temperature for remote RGT from BSB LAN Adapter
Number hz_fan_speed <fan> { http="<[http://192.168.178.88/8323:30000:JS(bsbinput.js)]" } //read current fan speed from BSB LAN Adapter
Number hz_aussentemp <temperature> { http="<[http://192.168.178.88/8700:20000:JS(bsbinput.js)]" } //read current outside temperature from BSB LAN Adapter via Javascript Transformation (not used here)
Number hz_kitchen_maxActual "MAX! Küche [%.1f °C]" {channel="max:thermostat:KEQ0565026:KEQ0648949:actual_temp"} //read temperature from MAX!
Number BSBLAN_Aussentemp <temperature> { channel="mqtt:topic:bsblan:aussentemp" } //read current outside temperature from BSB LAN Adapter via MQTT2
Number BSBLAN_Vorlauftemp <temperature> { channel="mqtt:topic:bsblan:vorlauftemp" } //read current flow temperature from BSB LAN Adapter via MQTT2
Number BSBLAN_Ruecklauftemp <temperature> { channel="mqtt:topic:bsblan:ruecklauftemp" } //read current return temperature from BSB LAN Adapter via MQTT2
Switch bsb_lan_presence <presence> { channel="network:pingdevice:192_168_178_88:online" } //check online status of BSB LAN through Network binding
Number hz_mode_party <party> //enable or disable Party mode for 1-5 hours
/rules/bsblan.rules:
var Timer PartyModeTimer = null //initialize a timer for party mode
rule "HeatingTempTarget" //change target temperature
	Item hz_temperature_cmd changed
	sendHttpGetRequest("http://192.168.178.88/S710="+hz_temperature_cmd.state.toString)
rule "HeatingMode" //change heating mode
	Item hz_mode_cmd changed
	sendHttpGetRequest("http://192.168.178.88/S700="+hz_mode_cmd.state.toString)
rule "UpdateHeatingMode" //reflect manual RGT remote changes on UI
	Item hz_mode_state changed
	hz_mode_cmd.postUpdate(transform("MAP","heatingmode.map",hz_mode_state.state.toString))
rule "SetModeKomfort" //set mode temporary to Komfort during Automatik mode
	Item hz_mode_komfort changed to ON
	sendHttpGetRequest("http://192.168.178.88/S701=0")
rule "SetModeReduziert" //set mode temporary to Reduziert during Automatik mode
	Item hz_mode_reduziert changed to ON
	sendHttpGetRequest("http://192.168.178.88/S701=1")
rule "SetPartyMode" //extends heating Komfort time for 1-5 hours
	Item hz_status changed
	// to do: read shutdown times for Absenkung Reduziert dynamically from BSB LAN Adapter
	if (hz_status.state.toString=="Absenkung Reduziert" && (now.getHourOfDay()>=22 && (now.getHourOfDay()<=23))) { //only trigger rule content during normal Reduziert shutdown times
		switch (hz_mode_party.state) {
				case 1: {
				if(PartyModeTimer!==null) {
           		PartyModeTimer.cancel
					PartyModeTimer = createTimer(now.plusHours(1)) [ |
					hz_mode_cmd.sendCommand(1)
					logInfo("BSBLAN","Party Mode disabled")
				hz_mode_cmd.sendCommand(3)
				hz_mode_party.postUpdate(0)
				logInfo("BSBLAN","Party Mode 1h")
				case 2: {
					PartyModeTimer = createTimer(now.plusHours(2)) [ |
				logInfo("BSBLAN","Party Mode 2h")
				case 3: {
					PartyModeTimer = createTimer(now.plusHours(3)) [ |
				logInfo("BSBLAN","Party Mode 3h")
				case 4: {
					PartyModeTimer = createTimer(now.plusHours(4)) [ |
				logInfo("BSBLAN","Party Mode 4h")
				case 5: {
					PartyModeTimer = createTimer(now.plusHours(5)) [ |
				logInfo("BSBLAN","Party Mode 5h")
rule "ConsiderRoomTempFromKitchen" //feed external temperatures to controller, for example MAX!
	Item hz_kitchen_maxActual changed
	sendHttpGetRequest("http://192.168.178.88/I10000="+hz_kitchen_maxActual.state.toString)
/sitemaps/bsblan.sitemap:
sitemap bsblan label="My BSB LAN"
Frame	{
			Text label="Heating" icon="heating"
				Text item=hz_mode_state label="IST Betriebsart [%s]"
				Selection item=hz_mode_cmd label="SOLL Betriebsart [%s]" mappings=[1="Automatik",3="Komfort",2="Reduziert"]
				Text item=hz_temperature_state label="Gesetzte Temperatur [%.1f °C]"
				Setpoint item=hz_temperature_cmd label="SOLL Temperatur [%.1f °C]" minValue=16 maxValue=24 step=0.5
				Text item=hz_status label="Status Heizung [%s]"
				Text item=hz_status_water label="Status Wasser [%s]"
				Switch item=hz_mode_komfort label="Präsenz Komfort"
				Switch item=hz_mode_reduziert label="Präsenz Reduziert"
				Selection item=hz_mode_party label="Partymodus [%s]" mappings=[0="Aus",1="1h",2="2h",3="3h",4="4h",5="5h"]
				Text item=hz_temperature_rgt label="Raumtemperatur RGT [%.1f °C]"
				Text item=hz_kitchen_maxActual label="MAX! Küche [%.1f °C]"
				Text item=BSBLAN_Aussentemp label="Aussentemperatur [%.1f °C]"
				Text item=BSBLAN_Vorlauftemp label="Vorlauftemperatur [%.1f °C]"
				Text item=BSBLAN_Ruecklauftemp label="Rücklauftemperatur [%.1f °C]"
				Text item=bsb_lan_presence label="BSB LAN Online Status [%s]"
				Text item=hz_fan_speed label="Gebläsedrehzahl [%d U/min]"
/transform/heatingmode.map:
Automatik=1
Reduziert=2
Komfort=3
Schutzbetrieb=0
Javascript code (thanks to acfischer42 from FHEM):
/transform/bsbinput.js:
(function(i) {
    var outputres;
	var results = [];
	value1 = i;
	// define regex to search for the line in the http response
	var regEx = 'input type=text id=\'value[0-9]+\' VALUE=\'[-]*[0-9]+\.[0-9]+';
	var re = new RegExp(regEx, 'gim');
 do {
    match = re.exec(value1);
    if (match){
        results.push(match[0]);
} while (match);
	outputres = results[0]
	//extract actual value from the output
	var output=outputres.substr(outputres.indexOf("VALUE='")+7,outputres.length);
	return output;
})(input)
/transform/bsbinput_string.js:
(function(i) {
    var outputres;
var results = [];
value1 = i;
var regEx = '<option value=\'[0-9]+\' SELECTED>.*</option>';
do {
if (match){
} while (match);
var l=outputres.indexOf("</o")-outputres.indexOf(">")-1
var output=outputres.substr(outputres.indexOf(">")+1,l);
    return output;
})(input)
BSB LAN goes international for an even better experience with openHAB.
If you have some spare time and are willing to help with translations, you can find a how to here:
https://github.com/fredlcore/bsb_lan/tree/master/localization#translate-bsb-lan-into-your-language
Looking great the integration of BSB-LAN for OpenHab!!
I am currently in the progress of making a component for BSB-LAN for Home Assistant.
Meanwhile an openHAB binding is available for BSB LAN:
There are plans for a new bulk order of the PCB, if you are interested (sorry, German language):
As the LAN adapter module draws more and more attention, the documentation is now available in English language:
