I tried to rewrite my old rule to use constrution “Member of”. Such construction was presented in
I created such rule:
rule “Low_battery_alarm”
Member of gLowBattery changed
logInfo( “FILE”, “Low_battery_alarm: -START-”)
I’ve got such error:
2018-08-13 23:51:56.129 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘General.rules’ has errors, therefore ignoring it: [8,3]: no viable alternative at input ‘Member’
I don’t see “Member” to be a valid trigger point according to OH2 docs. @rlkoshak please share your knowledge if you think this is supposed to work.
Now while I don’t know your application, maybe a standard ‘when Item gLowBattery changed’ will also do what you want it to (as changes to group members will change the group’s status, too).
rule "Low_battery_alarm"
Item gLowBattery received update
val sensor = gLowBattery. members.filter[sensor | sensor.lastUpdate != null].sortBy[lastUpdate].last
“Member of” is an openHAB 2.3 feature. It is not available in any current release build. It is available in snapshot builds starting with openHAB 2.3.0 Build #1212.
I resisted moving from OH1 to OH2 for various reasons, but the introduction of that method was the clincher for me. I’ve rewritten about three quarters of my rules to take advantage of it.
As 2.3 is currently stable release, go for the update.
I’ve spent weekend to migrate to 2.3 but I’m block by MCP23017 binding , it has some bugs and I wait for fix. I’ve notice also many errors during boot process e.g I have hundred error logs that persistence is not registered but after several minutes persistence works without any problem
BTW It is pity that OH release version so seldom, ok you can use snapshot version but it is little dangerous for serious installation. They should release major version once a severel month but patches every several weeks.
It was added in 2.3 and will not work in 2.1. Member of and triggeringItem do not exist in 2.1.
I don’t think I’ve explicitly stated it anywhere but the DPs are assumed to work with the latest version of OH. So they should work with whatever was out at the date/time the DP was last edited. I should probably add a little note with the version the DP was written for/last updated for.
Has that still not yet been added to the docs? Grumble. We need to change that. I just submitted a PR.
