It did work for me until the latest API changes.
Not sure if it helps, it‘s more of trial and error, but sometimes openhab-cli clean-cache does miracles.
That’s the first thing I did after adding the capacity in the config. After that didn’t work, I removed and re-added the things including the bridge and items. That didn’t work either. After that I reported here. Do you have another idea?
I’m afraid I am at the end of my wits.
Unfortunately I cannot check if it wors in my configuration because I cannot authenticate since the recent API changes. Even though I regenerated my credentials, authentication fails.
I guess I need to wait for the next openhab milestone. I’ll try as soon as I got that back up and running.
Using the new credentials model, and the latest JAR file from @weymann 's drop location on GitHub, I see the following log errors. => Any ideas?
2022-11-22 13:19:18.759 [INFO ] [esme.internal.handler.VehicleHandler] - A250:payasyoudrive Error getting data org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
2022-11-22 13:19:18.969 [INFO ] [esme.internal.handler.VehicleHandler] - A250:fuelstatus Error getting data org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
2022-11-22 13:19:19.190 [INFO ] [esme.internal.handler.VehicleHandler] - A250:vehiclestatus Error getting data org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
2022-11-22 13:19:19.402 [INFO ] [esme.internal.handler.VehicleHandler] - A250:vehiclelockstatus Error getting data org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
I just updated the jar file as well and it didn’t fix the issue (tried the usual stuff as well including clean-cache, rebooting, …)
As the next milestone release is planned for the 27th I’ll wait for that.
Yes, I tried all the same things as you, with the same lack of result. So I will also wait for M5…
Just for info: on M5 it NOW works for me
I spent some thime to get this nice binding connecting to the MB API. Finally it turned out, that the last step of https://github.com/weymann/OH3-MercedesMe-Drops#bridge-configuration
does not work in a firefox browser but in Chrome. Maybe this helps someone else.
Binding is working again and I did some tests, so I now know what deck-lid is what you would call the hatch (I’ve got a B250e and when I open the hatch (or rear-lid or whatever you want to call it) then the deck-lid changes to open as well. Same for locking.
Still don’t know what the flap is on a car. On an aircraft it on the wing, increasing the surface hence the lift
I am using the binding with an EQA. Works great. One thing I can’t figure out, is it possible to have the vehicle’s location? I want to use it in a rule “when arriving at home”
You don‘t get that information via the free API. You have to pay for getting your own data.
There are other ways to build such rules triggered when your phone gets an IP adress through DHCP.
Thanks!
Hi, i have an EQB 300 and started the Mercedes Me Binding with the update to openHAB 3.4.0 final release. My experiences are, it’s very, very slow, and i do not get the “lights” informations, which should be included in the “Vehicle Status”. I tried to catch a trace so that you can see that the informations are missing, any ideas?
Mercedes EQB 300:vehiclestatus Response 200 [{"doorstatusfrontleft":{"value":"false","timestamp":1671642190000}},{"windowstatusrearright":{"value":"2","timestamp":1671563442000}},{"windowstatusfrontright":{"value":"2","timestamp":1671629893000}},{"windowstatusfrontleft":{"value":"2","timestamp":1671631727000}},{"windowstatusrearleft":{"value":"2","timestamp":1671563442000}},{"doorstatusrearleft":{"value":"false","timestamp":1671642249000}},{"doorstatusrearright":{"value":"false","timestamp":1671642189000}},{"doorstatusfrontright":{"value":"false","timestamp":1671642177000}},{"decklidstatus":{"value":"false","timestamp":1671642269000}}]
2022-12-21 20:14:12.107 [TRACE] [esme.internal.handler.VehicleHandler] - Mercedes EQB 300:vehiclelockstatus Response 200 [{"doorlockstatusgas":{"value":"false","timestamp":1671642263000}},{"doorlockstatusvehicle":{"value":"2","timestamp":1671642263000}},{"doorlockstatusdecklid":{"value":"false","timestamp":1671642263000}},{"positionHeading":{"value":"95.0","timestamp":1671642165000}}]
I have installed the binding few days ago and I am receiving some data.
I use text configuration, and I cant figure out what should I put as value for the image API key?
Also can anyone share his widget?
here is my widget
uid: widget_Mercedes_v1
tags: []
props:
parameters:
- description: Label
label: Label
required: false
type: TEXT
parameterGroups: []
timestamp: Sep 11, 2022, 1:27:04 PM
component: f7-card
backdrop: true
class:
- card-expandable-animate-width
expandable: true
style:
--f7-theme-color: var(--f7-text-color)
background-color: "=themeOptions.dark === 'light' ? 'white' : '#141414'"
height: 120px
margin: 5px
max-height: 120px
max-width: 400px
min-height: 120px
min-width: 110px
swipeToClose: true
slots:
default:
- component: f7-card-content
style:
width: 100%
slots:
default:
- component: oh-button
class:
- card-opened-fade-in
- cell-close-button
- card-close
iconF7: xmark_circle_fill
iconSize: 30px
style:
padding-bottom: 35px
padding-top: 10px
position: absolute
right: 0
top: 0
z-index: 999
- component: f7-block
class:
- no-padding
style:
height: 200px
margin: -6px
slots:
default:
- component: f7-row
style:
flex-wrap: nowrap
height: 20px
text-overflow: ellipsis
white-space: nowrap
slots:
default:
- component: f7-col
slots:
default:
- component: f7-row
class:
- justify-content-flex-start
style:
flex-wrap: nowrap
width: 100%
slots:
default:
- component: oh-icon
height: 20px
icon: iconify:simple-icons:mercedes
style:
margin-top: 0px
- component: Label
style:
font-size: 16px
font-weight: 600
margin-left: 2px
margin-top: -2px
overflow: hidden
white-space: nowrap
text: My GLC 300e
- component: f7-row
class:
style:
flex-wrap: nowrap
width: 100%
slots:
default:
- component: f7-chip
color: "=Number.parseFloat(items.GLC_BatterySoc.state.split(' ')[0]) <= 10 ? 'red' : Number.parseFloat(items.GLC_BatterySoc.state.split(' ')[0]) <= 20 ? 'orange' : 'green'"
style:
font-size: 11px
font-weight: 600
text: '="Bat: " + items.GLC_BatterySoc.state'
color: "=Number.parseFloat(items.GLC_FuelLevel.state.split(' ')[0]) <= 10 ? 'red' : Number.parseFloat(items.GLC_FuelLevel.state.split(' ')[0]) <= 20 ? 'orange' : 'green'"
style:
font-size: 11px
font-weight: 600
margin-left: 2px
text: '="Fuel: " + items.GLC_FuelLevel.state'
- component: f7-row
class:
style:
flex-wrap: nowrap
width: 100%
slots:
default:
color: "=items.GLC_DoorLock.state =='2' ? 'green' : 'red'"
style:
font-size: 11px
font-weight: 600
text: "=items.GLC_DoorLock.state =='2' ? 'locked' : 'unlocked'"
- component: f7-row
class:
style:
flex-wrap: nowrap
white-space: nowrap
slots:
default:
- component: f7-icon
color: green
material: ev_station
style:
margin-top: 16px
- component: Label
style:
font-size: 10px
font-weight: 500
margin-left: 1px
margin-top: 18px
overflow: hidden
white-space: nowrap
text: =(Number.parseFloat(items.GLC_Range_Electric.state.split(" ")[0])).toFixed(0) + ' km'
color: blue
material: local_gas_station
style:
margin-left: 2px
margin-top: 16px
- component: Label
style:
font-size: 10px
font-weight: 500
margin-left: 1px
margin-top: 18px
overflow: hidden
white-space: nowrap
text: =(Number.parseFloat(items.GLC_Range_Fuel.state.split(" ")[0])).toFixed(0) + ' km'
class:
- card-prevent-open
- card-content-padding
style:
height: 200px
slots:
default:
- component: oh-image
style:
display: block
margin-left: auto
margin-right: auto
width: 60%
url: http://192.168.178.90:8081/static/images/mb-glc300e-mini2.jpg
- component: oh-list
class:
- padding
slots:
default:
- component: Label
style:
border-bottom: 1px solid grey
color: gray
font-weight: 600
margin-top: 10px
padding: 7px
text: =props.Title?props.Title:"other States:"
- component: f7-list-item
slots:
footer:
- component: f7-row
slots:
default:
- component: Label
color: gray
style:
margin-top: 8px
text: =items.GLC_DoorLock.displayState
header:
- component: f7-row
slots:
default:
f7: lock
style:
padding: 5px
- component: Label
style:
margin-top: 10px
text: Lock-Status
slots:
footer:
- component: f7-row
slots:
default:
- component: Label
color: gray
style:
margin-top: 8px
text: =items.mbc_data_decklidstatus.state
header:
- component: f7-row
slots:
default:
f7: lock_shield
style:
padding: 5px
- component: Label
style:
margin-top: 10px
text: Latch
slots:
footer:
- component: f7-row
slots:
default:
- component: Label
style:
margin-top: 8px
text: =items.mbc_data_sunroofstatus.displayState
header:
- component: f7-row
slots:
default:
f7: sun_max
style:
padding: 5px
- component: Label
style:
margin-top: 10px
text: Sunroof
slots:
footer:
- component: f7-row
slots:
default:
- component: Label
style:
margin-top: 8px
text: =items.mbc_data_odo.state
header:
- component: f7-row
slots:
default:
f7: sum
style:
padding: 5px
- component: Label
style:
margin-top: 10px
text: Total-km
slots:
footer:
- component: f7-row
slots:
default:
- component: Label
style:
margin-top: 8px
text: =items.GLC_LastUpdate.displayState
header:
- component: f7-row
slots:
default:
f7: clock
style:
padding: 5px
- component: Label
style:
margin-top: 10px
text: last update
English please, this is an international community!
This is a little pic of my Data’s
Also the Windows are NULL/NIL.
How i get all the Data’s from the car?
I fixed the problem without your help.
Thanx.
It’s the “flap” covering the charger, so if it’s open you’re probably increasing the car’s lift by adding power to it
Can you please share what you did? I have the same issue, a lot of NULL, and I’m not understanding what is the problem
thanks
Andrea
