thanks,
I could start that binding and got both my cars (1 BEV, 1PHEV) into the
binding as things.
However I permanently see warnings in the log: (the 192.168.x.x has been
manually anonymized by me)
2023-09-10 19:13:14.239 [WARN ] [rcedesme.internal.server.MBWebsocket] -
IOEXception Protocol message tag had invalid wire type.
2023-09-10 19:13:14.244 [WARN ] [et.common.message.MessageInputStream] -
MessageInputStream closed without fully consuming content
WebSocketSession[websocket=JettyAnnotatedEventDriver[org.openhab.binding.mercedesme.internal.server.MBWebsocket@14f3366],behavior=CLIENT,connection=WebSocketClientConnection@1b266c::DecryptedEndPoint@694270{l=/192.168.x.x:47020,r=websocket.emea-prod.mobilesdk.mercedes-benz.com/13.94.252.146:443,OPEN,fill=-,flush=-,to=23/840000},remote=WebSocketRemoteEndpoint@1413821[batching=true],incoming=JettyAnnotatedEventDriver[org.openhab.binding.mercedesme.internal.server.MBWebsocket@14f3366],outgoing=ExtensionStack[queueSize=0,extensions=,incoming=org.eclipse.jetty.websocket.common.WebSocketSession,outgoing=org.eclipse.jetty.websocket.client.io.WebSocketClientConnection]]
2023-09-10 19:13:18.089 [INFO ] [rcedesme.internal.server.MBWebsocket] -
Message [proto.PushMessage.assigned_vehicles]
2023-09-10 19:13:18.101 [INFO ] [rcedesme.internal.server.MBWebsocket] -
Message [proto.PushMessage.apptwin_pending_command_request]
2023-09-10 19:13:18.245 [WARN ] [rcedesme.internal.server.MBWebsocket] -
IOEXception Protocol message had invalid UTF-8.
2023-09-10 19:13:18.257 [WARN ] [et.common.message.MessageInputStream] -
WebSocketSession[websocket=JettyAnnotatedEventDriver[org.openhab.binding.mercedesme.internal.server.MBWebsocket@14f3366],behavior=CLIENT,connection=WebSocketClientConnection@1b266c::DecryptedEndPoint@694270{l=/192.168.x.x:47020,r=websocket.emea-prod.mobilesdk.mercedes-benz.com/13.94.252.146:443,OPEN,fill=-,flush=-,to=32/840000},remote=WebSocketRemoteEndpoint@1413821[batching=true],incoming=JettyAnnotatedEventDriver[org.openhab.binding.mercedesme.internal.server.MBWebsocket@14f3366],outgoing=ExtensionStack[queueSize=0,extensions=,incoming=org.eclipse.jetty.websocket.common.WebSocketSession,outgoing=org.eclipse.jetty.websocket.client.io.WebSocketClientConnection]
