Migration to v4 gives "itemRegistry" is not defined error related to blockly rules
After migrating from openhab 3.4 to openhab 4, I see these errors:
2023-07-25 00:36:06.420 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
org.graalvm.polyglot.PolyglotException: ReferenceError: "itemRegistry" is not defined
	at <js>.:program(<eval>:1) ~[?:?]
	at org.graalvm.polyglot.Context.eval(Context.java:399) ~[?:?]
	at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:458) ~[?:?]
	at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:426) ~[?:?]
	at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:262) ~[java.scripting:?]
	at org.openhab.automation.jsscripting.internal.scriptengine.DelegatingScriptEngineWithInvocableAndAutocloseable.eval(DelegatingScriptEngineWithInvocableAndAutocloseable.java:53) ~[?:?]
	at org.openhab.automation.jsscripting.internal.scriptengine.InvocationInterceptingScriptEngineWithInvocableAndAutoCloseable.eval(InvocationInterceptingScriptEngineWithInvocableAndAutoCloseable.java:78) ~[?:?]
	at org.openhab.core.automation.module.script.internal.handler.ScriptConditionHandler.isSatisfied(ScriptConditionHandler.java:54) ~[?:?]
	at org.openhab.core.automation.internal.RuleEngineImpl.calculateConditions(RuleEngineImpl.java:1158) ~[?:?]
	at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:995) ~[?:?]
	at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:87) ~[?:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
	at java.lang.Thread.run(Thread.java:833) ~[?:?]
and:
==> /log/logs/openhab.log <==
2023-07-25 00:32:00.500 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
org.graalvm.polyglot.PolyglotException: ReferenceError: "events" is not defined
	at <js>.:program(<eval>:12) ~[?:?]
	at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:71) ~[?:?]
	at java.util.Optional.ifPresent(Optional.java:178) ~[?:?]
	at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:68) ~[?:?]
	at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1188) ~[?:?]
	at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:997) ~[?:?]
2023-07-25 00:32:00.507 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'f2ad118f70' failed: org.graalvm.polyglot.PolyglotException: ReferenceError: "events" is not defined
I suspected these have something to do with rules. I have a few of them that are triggered frequently and which have actions defined in Blockly. I took one and tried running it. And it gave me one of the above errors but with a bit more text to. I then opened the blockly design, tried to run the rule from there and saw in the log:
2023-07-25 00:46:49.379 [INFO ] [openhab.event.RuleUpdatedEvent      ] - Rule '3e005b972e' has been updated.
The rule then passed fine.
So it seems that I have to go through all my rules and do this ‘open blockly code’ and ‘save it’ manually to fix the generated script?
As mentioned in the list of breaking changes and documented here you need to convert your Blockly rules to be compatible with OH4 by opening each one and saving it anew. You also need to install the JS Scripting add-on.
And the way I did it is:
  • open the Developer sidebar with Shift+Alt+D
  • search for itemRegistry
  • press the edit “pencil” on each of the rules
  • open the blockly rule
  • press save
  • (you can finally search again for itemRegistry and you are fine if you don’t find anything anymore)
Sounds a bit tedious but even with my 100+ rules it didn’t take really that long.
Thank you Rich and Stefan! I read through the release notes but did not fully understand the part about breaking changes in the Javascript automation. Afterwards when searching for a solution, I didn’t reread this part because I couldn’t find the word ‘blockly’ since in the text, the plural ‘blocklies’ is used. My fault! Thanks again!
Howdy. I also upgraded to 4.0.2 and getting both these errors. I created my rules using ECMAScript, how can I fix this error? I don’t use “blocky”
In that case you need to do one of the following:
  1. Install the JS Scripting add-on and rework your rules using the new ECMAScript 11 syntax using the openhab-js library.
  2. Install the Nashorn JS Scripting add-on and change the type of your script actions and conditions to “application/javascript:ECMAScript5.1” (I think that’s right, search the forum if not or just create a new script choosing Nashorn JS as the language and see what it uses for the type). You can find and change the type by clicking on the code tab of the rule.
I already tried that. That’s how I got the “events” not defined error. I get both errors, when I use the non Nashorn I get the itemRegistry error and when I use the Nashorn I get the events error.
Ok, found out the problem. I had to edit the _Run rule as well. It is working now. I guess I will start switching to the newer ECMAScript 11 but I need to have my Alexa working since I rely so much on it.
