Mitsubishi Heat Pump
Using custom widget for ACs (based on [SOLVED] UI Widget: Intesis aircon controller; No commands send to items, thx to @hmerk and others) :
ezgif-4-3699f4add539
widget yaml:
uid: air_conditioner
tags: []
props:
  parameters:
    - description: Title
      label: Title
      required: false
      type: TEXT
    - context: prefix
      description: The name prefix of widget items
      label: Prefix
      required: false
      type: TEXT
  parameterGroups: []
timestamp: Jan 8, 2021, 1:40:45 PM
component: f7-block
  class:
    - no-padding
slots:
  default:
    - component: Label
        text: =props.title
        style:
          text-align: center
          font-size: 16px
    - component: f7-row
        class:
          - margin
          - align-items-center
      slots:
        default:
          - component: oh-link
              action: toggle
              actionItem: =props.prefix + "_Power"
              actionCommand: ON
              actionCommandAlt: OFF
              class:
                - display-flex
                - flex-direction-column
            slots:
              default:
                - component: f7-icon
                    f7: power
                    color: '=items[props.prefix + "_Power"].state === "OFF" ? "red" : "green"'
                - component: Label
                    class:
                      - margin-top-half
                    text: ON/OFF
                    style:
                      color: var(--f7-text-color)
                      font-size: var(--f7-badge-in-icon-font-size)
          - component: Label
              text: =items[props.prefix + "_RoomTemperature"].state.displayState || items[props.prefix + "_RoomTemperature"].state
    - component: f7-row
        class:
          - justify-content-center
      slots:
        default:
          - component: oh-knob
              min: 16
              max: 31
              stepSize: 1
              item: =[props.prefix + '_SetTemperature']
    - component: f7-row
        class:
          - margin-half
      slots:
        default:
          - component: oh-repeater
              fragment: true
              for: mode
              in:
                - value: AUTO
                  icon: arrow_2_circlepath
                - value: HEAT
                  icon: thermometer_sun
                - value: DRY
                  icon: drop
                - value: FAN
                  icon: wind
                - value: COOL
                  icon: thermometer_snowflake
            slots:
              default:
                - component: f7-col
                  slots:
                    default:
                          class:
                            - display-flex
                          action: command
                          actionItem: =props.prefix + "_Mode"
                          actionCommand: =loop.mode.value
                        slots:
                          default:
                                style:
                                  color: '=(items[props.prefix + "_Mode"].state === loop.mode.value) ? "green" : "gray"'
                                f7: =loop.mode.icon
                            - component: Label
                                class:
                                  - margin-top-half
                                text: =loop.mode.value
                                style:
    - component: f7-row
        class:
          - padding-top-half
          - margin-half
      slots:
        default:
              fragment: true
              for: setting
              filter: items[props.prefix + loop.setting.suffix].state != "-"
              in:
                - suffix: _Fan
                  icon: chart_bar
                  iconColor: yellow
                - suffix: _Vane
                  icon: arrow_up_down_circle
                  iconColor: teal
                - suffix: _WideVane
                  icon: arrow_left_right_circle
                  iconColor: teal
            slots:
              default:
                - component: f7-col
                  slots:
                    default:
                          action: options
                          actionItem: =props.prefix + loop.setting.suffix
                          class:
                            - display-flex
                        slots:
                          default:
                                color: =loop.setting.iconColor
                                f7: =loop.setting.icon
                            - component: Label
                                class:
                                  - margin-top-half
                                text: =items[props.prefix + loop.setting.suffix].state
                                style:
one needs to append following suffixes as below when defining items:
  _RoomTemperature
  _SetTemperature
  _Power
  _Mode
  _Fan
  _Vane
  _WideVane
for example, my living room AC (label/name pairs):
Air Conditioner (gGF_Living_AC)
  Room Temperature (gGF_Living_AC_RoomTemperature)
  Set Temperature (gGF_Living_AC_SetTemperature)
  Power (gGF_Living_AC_Power)
  Mode (gGF_Living_AC_Mode)
  Fan (gGF_Living_AC_Fan)
  Vane (gGF_Living_AC_Vane)
  Wide Vane (gGF_Living_AC_WideVane)
Note: one can omit i.e. _WideVane and it will not be rendered (not all my ACs have wide vane) …
Following above rules AC widget can be added as simple as
- component: widget:air_conditioner
    prefix: gGF_Living_AC
    title: Living Room AC
For completeness adding mqtt yaml too (please note allowedStates that contains values one can pick in the widget, as seen in the attached animated gif):
UID: mqtt:topic:homepi:acLivingRoom
label: Air Conditioner Living's Room
thingTypeUID: mqtt:topic
configuration:
  payloadNotAvailable: Connection Lost
  availabilityTopic: GF_Living_Room/status/LWT
  payloadAvailable: Connected
bridgeUID: mqtt:broker:homepi
channels:
  - id: acRoomTemperature
    channelTypeUID: mqtt:number
    label: AC Room Temperature
    description: null
    configuration:
      stateTopic: GF_Living_Room/ac/settings
      transformationPattern: JSONPATH:$.roomTemperature
      unit: °C
  - id: acSetTemperature
    label: AC Set Temperature
    description: null
    configuration:
      commandTopic: GF_Living_Room/ac/settings/cmd
      unit: °C
      formatBeforePublish: MitsubishiHP,temperature,%d
      transformationPattern: JSONPATH:$.temperature
  - id: acPower
    channelTypeUID: mqtt:switch
    label: AC Power
    description: null
    configuration:
      formatBeforePublish: MitsubishiHP,power,%s
      transformationPattern: JSONPATH:$.power
  - id: acMode
    channelTypeUID: mqtt:string
    label: AC Mode
    description: null
    configuration:
      allowedStates: HEAT,COOL,FAN,DRY,AUTO
      formatBeforePublish: MitsubishiHP,mode,%s
      transformationPattern: JSONPATH:$.mode
  - id: acFan
    label: AC Fan
    description: null
    configuration:
      allowedStates: 1,2,3,4,AUTO,QUIET
      formatBeforePublish: MitsubishiHP,fan,%s
      transformationPattern: JSONPATH:$.fan
  - id: acVane
    label: AC Vane
    description: null
    configuration:
      allowedStates: 1,2,3,4,5,SWING,AUTO
      formatBeforePublish: MitsubishiHP,vane,%s
      transformationPattern: JSONPATH:$.vane
  - id: acWideVane
    label: AC Wide Vane
    description: null
    configuration:
      allowedStates: <<,<,|,>,>>,<>,SWING
      formatBeforePublish: MitsubishiHP,wideVane,%s
      transformationPattern: JSONPATH:$.wideVane
i am using this widget as well as a popup widget for 2 thermostats so thank you all for your work here.
one question, how do you achieve this:
I would like to use this in another widget? It does not seem to be part of the posted YAML, isn“t it?
As stated above
you can see
but the same can be achieved with adding OPTIONS as metadata to item.
Thank you for this! Can you tell me how to get this in to Google home/assistant?
Hi
How are you.
I just finished transferring from arduino to ESPEasy and it does works besides one thing.
The operational status is no longer beeing received:
{ā€œroomTemperatureā€:24,ā€œoperatingā€:false}
Is it normal? I had this feature in my old systems and it was very handy to mesure the system when it’s in function. Thanks for your precious help
Plugin is returning the following info currently
{"roomTemperature":23.5,"wideVane":"|","power":"OFF","mode":"COOL","fan":"AUTO","vane":"5","iSee":true,"temperature":22.0}
I guess you mean
bool operating; // if true, the heatpump is operating to reach the desired temperature
This one is not currently part of ESPEasy plugin but should be easy to add …
Hi
That’s right.
The [SwiCago] arduine schema does include it and I used it for around 3 years.
bool HeatPump::getOperating() {
return currentStatus.operating;
JosƩ
Added support for operating and compressor frequency, test fw for ESP 8266, 4M1M can be downloaded here.
Sample output
{"roomTemperature":25.5,"wideVane":"|","power":"OFF","mode":"COOL","fan":"AUTO","vane":"AUTO","iSee":true,"operating":true,"compressorFrequency":5,"temperature":24.0}
Code
Thank you for your help
I will test it tomorrow :grinning_face:
JosƩ Cordeiro
Hi
Thanks for your help. it works :slight_smile:
Was merged so you can use ā€œofficialā€ releases, FYI.
@ crnjan Hi, I wonder this widget could be used for controlling Mitsubishi heat pump with Procon A1M Modbus card. I can control my Mitsubishi heat pumps with OH3 but would like to use your widget.
Hey! I guess you can use the widget above to control your HP (maybe some modifications will be required to suit your needs), but I moved to a customised version of Heating widget since `oh-knob’ seems a bit to sensitive (specially when being used on a phone) and set temperature changed quite often undesirably (maybe I just got thick fingers :)) …
OK, many thanks for the info. I’ll have a look at your widget and check whether I can use it. I’m also using the heating widget for controlling the underfloor heating system but I don’t know how you could use it for a HP which has different modes and the vanes.
As said, I’m using a custmized version of heating widget …
Your widget looks really cool, I wonder whether you could share your code.
All the credits still go to the original author, I just adopted it for my needs :wink:
Widget:
uid: widget_HeatingCSS_2.0.0
tags: []
props:
  parameters:
    - context: item
      description: Item to control
      label: Setpoint Item
      required: true
      type: TEXT
      groupName: mainItems
    - context: item
      label: Item for current temperature
      required: true
      type: TEXT
    - context: item
      description: Humidity Item [Number-Item]
      label: Humidity Item
      required: false
      type: TEXT
    - description: eg. living room
      label: location and widget identifier
      required: true
      type: TEXT
      groupName: generalSettings
    - description: Minimum value
      label: minTemp
      required: true
      type: TEXT
    - description: Maximum value
      label: maxTemp
      required: true
    - description: Visual size of the control in px (default 400px), without a size the design is responsive
      label: size [px]
      required: false
      type: TEXT
    - description: Control item unit eg °C
      label: unit
      required: false
      type: TEXT
      advanced: true
    - context: item
      description: Heating Power Item [String-Item]
      label: Heating Power Item
      required: false
      type: TEXT
      groupName: extensionItems
      advanced: true
    - description: Heating power strings as array eg. AUTO,MANU,OFF. The string will be send to the Heating-Power-Item [String-Item]
      label: Heating Power Array
      required: false
      type: TEXT
      advanced: true
    - context: item
      description: Vane Item [String-Item]
      label: Vane Item
      required: false
      type: TEXT
      advanced: true
    - description: Vane strings as array eg. 1,2,3,SWING,AUTO The string will be send to the Vane-Item [String-Item]
      label: Vane Array
      required: false
      type: TEXT
      advanced: true
    - context: item
      description: Heating Mode Item [String-Item]
      label: Heating Mode Item
      required: false
      type: TEXT
      advanced: true
    - description: Heating mode strings as array eg. AUTO,MANU,OFF. The string will be send to the Heating-Mode-Item [String-Item]
      label: Heating Mode Array
      required: false
      type: TEXT
      advanced: true
    - context: item
      description: Example Mode Item [String-Item] (eg. State of heating valve)
      label: Example Mode Item
      required: false
      type: TEXT
      advanced: true
    - description: Example Mode Strings as Array eg. OFF,ON,BOOST. The string will be send to the Example-Mode-Item [String-Item]
      label: Example Mode Array
      required: false
      type: TEXT
      advanced: true
    - context: item
      description: Valve/Alarm Item [Switch-Item] (eg. State of heating valve) for Animation in the center of the widget
      label: Valve Item
      required: false
      type: TEXT
      advanced: true
    - description: eg. default 1em
      label: Custom font-size current&set-point marker
      required: false
      type: TEXT
      groupName: fonts
      advanced: true
    - description: eg. default 2em
      label: Custom font-Size center
      required: false
      type: TEXT
      groupName: fonts
      advanced: true
    - description: default 1em for eg. Living Room
      label: Custom font-size location label
      required: false
      type: TEXT
      groupName: fonts
      advanced: true
    - description: default eg. 1.8em
      label: Custom font-Size buttons
      required: false
      type: TEXT
      groupName: fonts
      advanced: true
    - description: default 1em for Heating-Label in bottom of the widget
      label: Custom font-Size footer
      required: false
      type: TEXT
      groupName: fonts
      advanced: true
    - label: Main-Color Thermostat
      required: false
      type: TEXT
      groupName: colors
      advanced: true
    - label: Color control ring
      required: false
      type: TEXT
      groupName: colors
      advanced: true
    - label: Color buttons
      required: false
      type: TEXT
      groupName: colors
      advanced: true
    - label: Color center
      required: false
      type: TEXT
      groupName: colors
      advanced: true
    - label: Color Typo
      required: false
      type: TEXT
      groupName: colors
      advanced: true
    - label: Color setPoint Marker
      required: false
      type: TEXT
      groupName: colors
      advanced: true
    - label: Color currentPoint Marker
      required: false
      type: TEXT
      groupName: colors
      advanced: true
    - label: Color bar linear gradient startPoint
      required: false
      type: TEXT
      groupName: colors
      advanced: true
    - label: Color bar linear gradient endPoint
      required: false
      type: TEXT
      groupName: colors
      advanced: true
    - description: Control if the Chart is visible
      label: Chart Swtich
      required: false
      type: BOOLEAN
      groupName: chartSettings
    - description: currently not possible -> The minimun value of axis. (eg. 10.5)
      label: yAxis min
      required: false
      type: TEXT
      advanced: true
    - description: currently not possible -> The maximum value of axis. (eg. 30.5)
      label: yAxis max
      required: false
      type: TEXT
      advanced: true
  parameterGroups:
    - name: mainItems
      label: Main Items (setpoint-temperature, current temperature, humidity)
    - name: advancedItems
      label: Advanced Items (Battery-State, ...)
    - name: generalSettings
      label: General Settings
    - name: extensionItems
      label: Extension Items
    - name: moreDesign
      label: More Design Options
    - name: colors
      label: Color Settings
    - name: fonts
      label: Font Settings
    - name: chartSettings
      label: Chart Settings
timestamp: Oct 20, 2021, 10:06:30 PM
component: f7-card
  stylesheet: >
    .mylink {
      #background-color: blue !important;
      animation-name: example;
      animation-duration: 4s;
    } .mylink#####:hover {
      text-decoration: underline !important;
      transform: scale(1.5);
      transition: 0.3s all;
    @keyframes example {
      0%   {background-color: red;}
      25%  {background-color: yellow;}
      50%  {background-color: blue;}
      100% {background-color: green;}
    .thermostat {
      flex-shrink: 0;
      --f7-block-margin-vertical: 0px;
      --f7-block-padding-vertical: 0px;
      --f7-block-padding-horizontal: 0px;
      padding-left: 0px;
      border-radius: 50%;
      box-sizing: content-box;
      border: 2px solid rgb(64, 60, 77);
    .thermostat .bar {
      margin-top: 0px;
      position: absolute;
      top: 50%;
      left: 50%;
      transform: translate(-50%, -50%);
      border-radius: 50%;
    } .thermostat .bar .inner_bar {
      margin-top: 0;
      position: absolute;
      top: 50%;
      left: 50%;
      border-radius: 100%;
      z-index: 4 !important;
    } .thermostat .bar .inner_bar .block {
      content: "";
      display: block;
      position: absolute;
      width: 100%;
      height: 100%;
      left: 50%;
      transform: translate(-50%);
  title: "=(props.location) ? 'Klima ' + props.location : ''"
slots:
  default:
    - component: f7-card-content
      slots:
        default:
          - component: f7-row
              class:
              resizable-absolute: true
              resizableFixed: true
            slots:
              default:
                - component: f7-block
                    class: thermostat
                    style:
                      background: "=props.colorThermostat ? props.colorThermostat : 'var(--f7-toggle-inactive-color)'"
                      padding-top: "=props.size ? props.size + 'px': '100%'"
                      width: "=props.size ? Number(props.size)+'px' : '100%'"
                  slots:
                    default:
                          class: bar
                          style:
                            height: "=props.size ? (Number(props.size)*0.89) +'px' : '89%'"
                            width: "=props.size ? (Number(props.size)*0.89) +'px' : '89%'"
                        slots:
                          default:
                                class: inner_bar
                                style:
                                  background-color: "=props.colorThermostat ? props.colorThermostat : 'var(--f7-toggle-inactive-color)'"
                                  height: "=props.size ? (Number(props.size)*0.86) +'px' : '97%'"
                                  width: "=props.size ? (Number(props.size)*0.86) +'px' : '97%'"
                              slots:
                                default:
                                      style:
                                        background: "='conic-gradient(transparent 0deg 160deg, ' + (props.colorThermostat ? props.colorThermostat : 'var(--f7-toggle-inactive-color)') + ' 160deg 200deg, transparent 200deg 360deg)'"
                                        bottom: "=props.size ? '-7px' : '-7px'"
                                class: hold left
                                style:
                                  background-color: rgb(58, 55, 73)
                                  border-radius: 100%
                                  clip-path: "=props.size ? 'inset(0px 0px 0px ' + (Number(props.size)*0.89/2) + 'px)' : 'inset(0% 0% 0% 50%)'"
                                  height: 100%
                                  margin-top: 0px
                                  position: absolute
                                  width: 100%
                              slots:
                                default:
                                      class: fill fill1
                                      style:
                                        background: "=props.colorBarStartPoint && props.colorBarEndPoint ? '-webkit-linear-gradient(top, ' + props.colorBarEndPoint + ' 20%,' + props.colorBarEndPoint + ' 100%)' : '-webkit-linear-gradient(top, rgb(255, 73, 0) 20%,rgb(255, 73, 0) 100%)'"
                                        border-radius: 100%
                                        clip-path: "=props.size ? 'inset(0px ' + (Number(props.size)*0.89/2) + 'px 0px 0px)' : 'inset(0% 50% 0% 0%)'"
                                        height: 100%
                                        margin-top: 0px
                                        position: absolute
                                        transform: "=(items[props.setPointItem].state.split(' ')[0] >= (((Number(props.maxTemp) - Number(props.minTemp)) / 2) + Number(props.minTemp)) && items[props.setPointItem].state.split(' ')[0] <= Number(props.maxTemp) ? 'rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.setPointItem].state.split(' ')[0]-Number(props.minTemp))-160)+'deg)' : (items[props.setPointItem].state.split(' ')[0] > Number(props.maxTemp)) ? 'rotate(180deg)' : '')"
                                        transition: transform 0.6s
                                        width: 100%
                                        z-index: 1 !important
                                class: hold right
                                style:
                                  border-radius: 100%
                                  height: 100%
                                  margin-top: 0px
                                  position: absolute
                                  transform: rotate(180deg)
                                  width: 100%
                                  z-index: 3 !important
                              slots:
                                default:
                                      class: fill
                                      style:
                                        animation: right 1s linear both
                                        border-radius: 100%
                                        height: 100%
                                        margin-top: 0px
                                        position: absolute
                                        width: 100%
                                      class: fill fill2
                                      style:
                                        background: "=props.colorBarStartPoint && props.colorBarEndPoint ? '-webkit-linear-gradient(top, ' + props.colorBarEndPoint + ' 40%,' + props.colorBarStartPoint + ' 100%)' : '-webkit-linear-gradient(top, rgb(255, 73, 0) 40%,rgb(255, 158, 35) 100%)'"
                                        border-radius: 50%
                                        clip-path: "=props.size ? 'inset(0px '+ (Number(props.size)*0.89/2) + 'px 0px 0px)' : 'inset(0% 50% 0% 0%)'"
                                        height: 100%
                                        margin-top: 0px
                                        position: absolute
                                        transform: "=(items[props.setPointItem].state.split(' ')[0] <= (((Number(props.maxTemp) - Number(props.minTemp)) / 2) + Number(props.minTemp)) && items[props.setPointItem].state.split(' ')[0] >= Number(props.minTemp) ? 'rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.setPointItem].state.split(' ')[0]-Number(props.minTemp))+20)+'deg)' : (items[props.setPointItem].state.split(' ')[0] > (((Number(props.maxTemp) - Number(props.minTemp)) / 2) + Number(props.minTemp))) ? 'rotate(180deg)' :  '')"
                                        width: 100%
                                class: span
                                style:
                                  bottom: 0px
                                  color: "=props.colorTypo ? props.colorTypo : 'rgb(87, 84, 95)'"
                                  font-size: "=props.fontSizeFooter ? props.fontSizeFooter : '1em'"
                                  font-weight: "=props.size ? (Number(props.size)*2) +'px' : 'calc(var(--f7-list-item-title-font-weight)*2)'"
                                  margin-top: 0px
                                  position: absolute
                                  text-align: center
                                  text-transform: uppercase
                                  width: "=props.size ? (Number(props.size)*0.89) +'px' : '100%'"
                                  z-index: 99 !important
                              slots:
                                default:
                                  - component: Label
                                      style:
                                        color: white
                                      text: Heating
                          class: shadow
                          style:
                            animation: shadow 1.4s ease-out both
                            height: 86%
                            left: 50%
                            margin-top: 0px
                            position: absolute
                            text-align: center
                            top: 50%
                            transform: "=(items[props.setPointItem].state.split(' ')[0] >= Number(props.minTemp) && items[props.setPointItem].state.split(' ')[0] <= Number(props.maxTemp) ? 'translate(-50%, -50%) rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.setPointItem].state.split(' ')[0]-Number(props.minTemp))-160)+'deg)' : 'translate(-50%, -50%) rotate(0deg)')"
                            transition: 0.7s ease
                            width: "=props.size ? (Number(props.size)*0.0625) +'px' : '6.25%'"
                        slots:
                          default:
                                class: shadow-cube
                                style:
                                  box-shadow: "=props.size ? '0 0 ' + (Number(props.size)*0.1125) +'px ' + (Number(props.size)*0.0325) + 'px ' + (props.colorSetMarker ? props.colorSetMarker : 'rgba(255, 158, 35, 0.5)'): '0 0 45px 13px rgba(255, 158, 35, 0.5)'"
                                  height: 0px
                                  margin-top: 0px
                                  position: absolute
                                  top: 0
                                  width: "=props.size ? (Number(props.size)*0.0625) +'px' : '100%'"
                          class: markerContainer
                          style:
                            height: 100%
                            left: 50%
                            margin-top: 0px
                            opacity: 1
                            pointer-events: none
                            position: absolute
                            text-align: center
                            top: 50%
                            transform: "=(items[props.currentPointItem].state.split(' ')[0] >= Number(props.minTemp) && items[props.currentPointItem].state.split(' ')[0] <= Number(props.maxTemp) ? 'translate(-50%, -50%) rotate('+(320/(Number(props.maxTemp)-Number(props.minTemp))*(items[props.currentPointItem].state.split(' ')[0]-Number(props.minTemp))-160)+'deg)' : 'translate(-50%, -50%) rotate(0deg)')"
                            width: "=props.size ? (Number(props.size)*0.1) +'px' : '10%'"
                        slots:
                          default:
                                class: markerCurrent
                                style:
                                  background: "=props.colorCurrentMarker ? props.colorCurrentMarker : 'rgb(33, 150, 243)'"
                                  border-radius: 0% 50% 50% 50%
                                  box-shadow: 0 0 5px 1px rgb(48, 46, 56)
                                  height: "=props.size ? (Number(props.size)*0.1) +'px' : ''"
                                  left: 50%
                                  margin-top: 0px
                                  padding-top: "=props.size ? '' : '100%'"
                                  position: absolute
                                  top: "=props.size ? (Number(props.size)*0.14) +'px' : '15%'"
                                  transform: translate(-50%,-50%) rotate(45deg)
                                  width: "=props.size ? (Number(props.size)*0.1) +'px' : '100%'"
                              slots:
                                default:
                                      class: number
                                      style:
                                        left: 50%
                                        margin-top: 0px
                                        position: absolute
                                        text-align: center
                                        top: 50%
                                        transform: translate(-50%, -50%) rotate(-45deg)
                                    slots:
                                      default:
                                        - component: Label
                                            style:
                                              color: white
                                              font-size: "=props.fontSizeMarker ? props.fontSizeMarker : '1em'"
                                              font-weight: bold
                                            text: =items[props.currentPointItem].state.split(' ')[0]
                          style:
                            height: 100%
                            left: 50%
                            margin-top: 0px
                            opacity: 1
                            position: absolute
                            text-align: center
                            top: 50%
                        slots:
                          default:
                                class: markerSet
                                style:
                                  background: "=props.colorSetMarker ? props.colorSetMarker : 'rgb(230, 74, 25)'"
                                  border-radius: 50% 50% 50% 0
                                  left: 50%
                                  margin-top: 0px
                                  position: absolute
                                  top: "=props.size ?  (Number(props.size)*Number(-0.0125)) +'px': '-2%'"
                                  transform: translate(-50%,-50%) rotate(-45deg)
                                  z-index: 100 !important
                              slots:
                                default:
                                      class: number
                                      style:
                                        left: 50%
                                        margin-top: 0px
                                        position: absolute
                                        text-align: center
                                        top: 50%
                                        transform: translate(-50%, -50%) rotate(45deg)
                                    slots:
                                      default:
                                        - component: Label
                                            style:
                                              color: white
                                              font-weight: bold
                                            text: =items[props.setPointItem].state.split(' ')[0]
                          class: center
                          style:
                            background: "=props.colorControlRing ? props.colorControlRing : 'rgb(227, 228, 237)'"
                            border-radius: 50%
                            box-shadow: 0px 15px 35px 11px rgba(46, 44, 58,0.60)
                            height: "=props.size ? (Number(props.size)*0.65) +'px' : '65%'"
                            left: 50%
                            margin-top: 0px
                            position: absolute
                            top: 50%
                            width: "=props.size ? (Number(props.size)*0.65) +'px' : '65%'"
                        slots:
                          default:
                                class: page
                                style:
                                  background: transparent
                                  border-radius: 50%
                                  height: 100%
                                  left: 50%
                                  margin-top: 0px
                                  position: absolute
                                  top: 50%
                                  width: 100%
                              slots:
                                default:
                                      class: buttonContainer
                                      style:
                                        display: "=props.heatingPowerItem ? '' : 'none'"
                                        height: 100%
                                        left: 50%
                                        margin-top: 0px
                                        opacity: 1
                                        position: absolute
                                        text-align: center
                                        top: 50%
                                        width: "=props.size ? (Number(props.size)*0.15) +'px' : '15%'"
                                    slots:
                                      default:
                                        - component: oh-button
                                            popoverOpen: ='.' + props.location + '.popoverPowerMode'
                                            style:
                                              bottom: 0%
                                              color: "=props.colorButton ? props.colorButton + ' !important': ''"
                                              height: 20%
                                              left: 50%
                                              position: absolute
                                              width: 100%
                                          slots:
                                            default:
                                                  color: '=items[props.heatingPowerItem].state == "ON" ? "green" : "red"'
                                                  f7: power
                                                  style:
                                                    font-size: "=props.fontSizeButtons ? props.fontSizeButtons : '2em'"
                                                    margin-top: auto
                                                    position: absolute
                                                    top: 50%
                                              - component: f7-popover
                                                  class: =props.location + ' popoverPowerMode'
                                                slots:
                                                  default:
                                                        action: variable
                                                        actionVariable: myVar
                                                        actionVariableValue: success
                                                        class:
                                                          - popover-close
                                                        clearVariable: true
                                                        noShadow: true
                                                      slots:
                                                        default:
                                                          - component: f7-row
                                                            config: {}
                                                            slots:
                                                              default:
        - component: f7-col
        slots:
        default:
        containerStyle:
        width: 100%
        for: buttonlabel
        in: =props.heatingPowerArray.split(",")
        slots:
        default:
        action: command
        actionCommand: =loop.buttonlabel
        actionItem: "=props.heatingPowerItem ? props.heatingPowerItem : ''"
        active: "=props.heatingPowerItem ? (items[props.heatingPowerItem].state === loop.buttonlabel ? true : false) : ''"
        class: margin
        color: "=props.colorButton ? props.colorButton : ''"
        outline: true
        text: =loop.buttonlabel
                                            popoverOpen: ='.' + props.location + '.popoverVane'
                                            style:
                                              height: 20%
                                              left: 50%
                                              position: absolute
                                              top: 0%
                                              width: 100%
                                          slots:
                                            default:
                                                  f7: wind
                                                  style:
                                                    margin-top: auto
                                                    position: absolute
                                                    top: 50%
                                                  class: =props.location + ' popoverVane'
                                                slots:
                                                  default:
                                                        action: variable
                                                        class:
                                                          - popover-close
                                                        clearVariable: true
                                                        noShadow: true
                                                      slots:
                                                        default:
                                                          - component: f7-card-header
                                                            config: {}
                                                            slots:
                                                              default:
        - component: Label
        text: VANE
                                                          - component: f7-row
                                                            config: {}
                                                            slots:
                                                              default:
        - component: f7-col
        slots:
        default:
        containerStyle:
        width: 100%
        for: buttonlabel
        in: =props.vaneArray.split(",")
        slots:
        default:
        action: command
        actionItem: "=props.vaneItem ? props.vaneItem : ''"
        active: "=props.vaneItem ? (items[props.vaneItem].state === loop.buttonlabel ? true : false) : ''"
        class: margin
        outline: true
                                      style:
                                        display: "=props.heatingModeItem ? '' : 'none'"
                                        height: 100%
                                        left: 50%
                                        margin-top: 0px
                                        opacity: 1
                                        position: absolute
                                        text-align: center
                                        top: 50%
                                        transform: "=props.exampleModeItem ? 'translate(-50%, -50%) rotate(40deg)' : 'translate(-50%, -50%)'"
                                    slots:
                                      default:
                                            popoverOpen: ='.' + props.location + '.popoverHeatingMode'
                                            style:
                                              bottom: 0%
                                              height: 20%
                                              left: 50%
                                              position: absolute
                                              width: 100%
                                          slots:
                                            default:
                                                  f7: "=props.heatingModeItem ? (items[props.heatingModeItem].state == props.heatingModeArray.split(',')[0] ? 'thermometer_sun' : items[props.heatingModeItem].state == props.heatingModeArray.split(',')[1] ? 'thermometer_snowflake' : items[props.heatingModeItem].state == props.heatingModeArray.split(',')[2] ? 'wind' : items[props.heatingModeItem].state == props.heatingModeArray.split(',')[3] ? 'drop' : 'arrow_2_circlepath') : ''"
                                                  style:
                                                    margin-top: auto
                                                    position: absolute
                                                    top: 50%
                                                  class: =props.location + ' popoverHeatingMode'
                                                slots:
                                                  default:
                                                        action: variable
                                                        class:
                                                          - popover-close
                                                        clearVariable: true
                                                        noShadow: true
                                                      slots:
                                                        default:
                                                            config: {}
                                                            slots:
                                                              default:
        - component: Label
        text: MODE
                                                          - component: f7-row
                                                            config: {}
                                                            slots:
                                                              default:
        - component: f7-col
        slots:
        default:
        containerStyle:
        width: 100%
        for: buttonlabel
        in: =props.heatingModeArray.split(",")
        slots:
        default:
        action: command
        actionItem: "=props.heatingModeItem ? props.heatingModeItem : ''"
        active: "=props.heatingModeItem ? (items[props.heatingModeItem].state === loop.buttonlabel ? true : false) : ''"
        class: margin
        outline: true
                                      style:
                                        display: "=props.exampleModeItem ? '' : 'none'"
                                        height: 100%
                                        left: 50%
                                        margin-top: 0px
                                        opacity: 1
                                        position: absolute
                                        text-align: center
                                        top: 50%
                                        transform: "=props.heatingModeItem ? 'translate(-50%, -50%) rotate(-40deg)' : 'translate(-50%, -50%)'"
                                    slots:
                                      default:
                                            popoverOpen: ='.' + props.location + '.popoverExampleMode'
                                            style:
                                              bottom: 0%
                                              height: 20%
                                              left: 50%
                                              position: absolute
                                              width: 100%
                                          slots:
                                            default:
                                                  style:
                                                    margin-top: auto
                                                    position: absolute
                                                    top: 50%
                                                slots:
                                                  default:
                                                    - component: oh-icon
                                                        icon: "=props.exampleModeItem ? (items[props.exampleModeItem].state == props.exampleModeArray.split(',')[0] ? 'iconify:mdi:fan-speed-1' : items[props.exampleModeItem].state == props.exampleModeArray.split(',')[1] ? 'iconify:mdi:fan-speed-2' : items[props.exampleModeItem].state == props.exampleModeArray.split(',')[2] ? 'iconify:mdi:fan-speed-3' : items[props.exampleModeItem].state == props.exampleModeArray.split(',')[3] ? 'iconify:mdi:fan' : items[props.exampleModeItem].state == props.exampleModeArray.split(',')[4] ? 'iconify:mdi:fan-auto' : 'iconify:mdi:fan-off') : ''"
                                                  class: =props.location + ' popoverExampleMode'
                                                slots:
                                                  default:
                                                        action: variable
                                                        class:
                                                          - popover-close
                                                        clearVariable: true
                                                        noShadow: true
                                                      slots:
                                                        default:
                                                            config: {}
                                                            slots:
                                                              default:
        - component: Label
        text: FAN
                                                          - component: f7-row
                                                            config: {}
                                                            slots:
                                                              default:
        - component: f7-col
        slots:
        default:
        containerStyle:
        width: 100%
        for: buttonlabel
        in: =props.exampleModeArray.split(",")
        slots:
        default:
        action: command
        actionItem: "=props.exampleModeItem ? props.exampleModeItem : ''"
        active: "=props.exampleModeItem ? (items[props.exampleModeItem].state === loop.buttonlabel ? true : false) : ''"
        class: margin
        outline: true
                                      action: command
                                      actionCommand: "=Number(items[props.setPointItem].state.split(' ')[0]) > Number(props.minTemp) ? Number(items[props.setPointItem].state.split(' ')[0]) - 1 : ''"
                                      actionItem: =props.setPointItem
                                      style:
                                        height: 50%
                                        left: 10%
                                        margin-top: 0px
                                        position: absolute
                                        top: 50%
                                        width: 30%
                                    slots:
                                      default:
                                            f7: arrow_turn_left_down
                                            style:
                                              margin-top: auto
                                              position: absolute
                                              top: 50%
                                      action: command
                                      actionCommand: "=Number(items[props.setPointItem].state.split(' ')[0]) < Number(props.maxTemp) ? Number(items[props.setPointItem].state.split(' ')[0]) + 1 : ''"
                                      style:
                                        height: 50%
                                        left: 90%
                                        margin-top: 0px
                                        position: relative
                                        top: 50%
                                        width: 30%
                                    slots:
                                      default:
                                            f7: arrow_turn_right_up
                                            style:
                                              margin-top: auto
                                              position: absolute
                                              top: 50%
                                      class: valveAnimation
                                      style:
                                        animation: skeleton-effect-fade 2s linear infinite
                                        background: "=props.colorSetMarker ? 'radial-gradient(' + props.colorSetMarker +' 30%, transparent 50%)' : 'radial-gradient(var(--f7-theme-color) 30%, transparent 50%)'"
                                        border-radius: 50%
                                        display: "=(props.valveItem && items[props.valveItem].state == 'ON' )? '' : 'none'"
                                        height: 100%
                                        left: 50%
                                        margin-top: 0px
                                        position: absolute
                                        top: 50%
                                        width: 100%
                                        z-index: -100 !important
                                      class: small
                                      style:
                                        animation: bound-in-small 0.6s ease forwards
                                        background: "=props.colorCenter ? props.colorCenter : 'rgb(248, 249, 250)'"
                                        border-radius: 50%
                                        box-shadow: 0px 5px 10px 5px rgba(96, 93, 111,0.19)
                                        height: "=props.size ? (Number(props.size)*0.375) +'px' : '57.6%'"
                                        left: 50%
                                        margin-top: 0px
                                        position: absolute
                                        text-align: center
                                        top: 50%
                                        width: "=props.size ? (Number(props.size)*0.375) +'px' : '57.6%'"
                                    slots:
                                      default:
                                            class: heat
                                            style:
                                              font-size: "=props.fontSizeLocation ? props.fontSizeLocation : '1em'"
                                              font-weight: 300
                                              left: 50%
                                              margin-top: 10%
                                          slots:
                                            default:
                                              - component: Label
                                                  text: =props.location
                                        - component: f7-swiper
                                            params:
                                              autoplay:
                                                delay: 1500
                                                disableOnInteraction: false
                                              direction: vertical
                                              mousewheel: true
                                              slidesPerView: 1
                                            scrollbar: false
                                            style:
                                              border-radius: 50%
                                              height: 100%
                                              left: 50%
                                              position: absolute
                                              top: 50%
                                              width: 100%
                                          slots:
                                            default:
                                              - component: f7-swiper-slide
                                                  style:
                                                    display: "=props.humItem ? '' : 'none'"
                                                slots:
                                                  default:
                                                        class: heat
                                                        style:
                                                          display: flex
                                                          font-size: "=props.fontSizeCenter ? props.fontSizeCenter : '2em'"
                                                          font-weight: 300
                                                          left: 50%
                                                          margin-top: 0
                                                          position: absolute
                                                          top: 50%
                                                      slots:
                                                        default:
                                                          - component: Label
                                                              text: =items[props.humItem].state.split(' ')[0]
                                                          - component: Label
                                                              style:
        font-size: "=props.fontSizeCenter ? 'calc(' + props.fontSizeCenter + ' * 0.2 )' : '0.6em'"
        vertical-align: top
                                                              text: =items[props.humItem].state.split(' ')[1]
                                                  style:
                                                    display: "=props.currentPointItem ? '' : 'none'"
                                                slots:
                                                  default:
                                                        class: heat
                                                        style:
                                                          display: flex
                                                          font-weight: 300
                                                          left: 50%
                                                          margin-top: 0
                                                          position: absolute
                                                          top: 50%
                                                      slots:
                                                        default:
                                                          - component: Label
                                                              text: =Number(items[props.currentPointItem].state.split(' ')[0]).toFixed(1)
                                                          - component: Label
                                                              style:
        vertical-align: top
                                                              text: "=props.unit ? props.unit : items[props.currentPointItem].state.split(' ')[1]"
Usage:
- component: widget:widget_HeatingCSS_2.0.0
    currentPointItem: gFF_EvaRoom_AC_RoomTemperature
    exampleModeArray: 1,2,3,4,AUTO,QUIET
    exampleModeItem: gFF_EvaRoom_AC_Fan
    heatingModeArray: HEAT,COOL,FAN,DRY,AUTO
    heatingModeItem: gFF_EvaRoom_AC_Mode
    heatingPowerArray: OFF,ON
    heatingPowerItem: gFF_EvaRoom_AC_Power
    humItem: gFF_EvaRoom_Hygrometer_Humidity
    maxTemp: 31
    minTemp: 16
    setPointItem: gFF_EvaRoom_AC_SetTemperature
    vaneArray: 1,2,3,4,5,SWING,AUTO
    vaneItem: gFF_EvaRoom_AC_Vane
Great, many thanks.
For some reason the icons for mode, fan and vane are missing but I need to check correct settings for my heat pump. It seems that the arrays in my case are slightly different.
Widget is highly tailored (=not generalised) for my needs so you’ll probably need to tweak it a bit …
For icons please check&adopt lines like above …
