I completely agree. I don’t illusion myself that a kind of hack will solve the problem at a whole. I am just trying to workaround the initialisation not completing, cause this is driving me crazy for almost a month now! (I tried everything else except to connect main power which I’ll do soon…)
I still have hard to understand how replacing the power source feeding through the same contacts (there isn’t another socket for main power) can be detected easily, but I’m not challenging you. I’ll get to it … (this is somewhat problematic long term, as I am plannning to use the device in a place without main power source)
The opposite, no? The device is battery based but advertises itself as listening (a feature associated with main power). I’m trying to convince the zwave binding to think that it is not-listening i.e. not main power unit.
Regardless, I get your message that tweaking the reporting is a cause for trouble.
While I can sympathise, my concern is that you might get the initialisation working, but then find that this device is causing other problems. As the listening flag is a protocol level flag, the controller will still think that it is permanently listening and available for routing and there is no way to solve this (as far as I know anyway). You might spend another month trying to sort that…
Well, the Aeon device definately does it, but it’s not fed through the same contacts - it has a USB power input.
In any case, the bottom line is that the listening flag needs to change, and my understanding is that since the protocol doesn’t allow dynamic changes, you need to exclude the device to change this.
No - it’s currently incorrectly reporting that it’s always listening which means it’s (incorrectly) reporting it’s a mains device.
But this is the problem - convincing the binding is probably quite easy - but you simply can’t convince the controller (as far as I know anyway). So no matter what the binding does, the controller will still think that this device is mains powered, and it’s the controller that decides routing etc.
I have the EZMotion 3in1, which I believe is identical to HSM100. While I have issues with it, I think the only way to set it into being a battery device is through the wakeup variable. There’s no way to detect that it is powered from externally when using the battery connectors for supplying power.
Currently mine is stuck at Node Initialising DYNAMIC_VALUES. I have to have it close to the stick - if I move it away, it will not be seen in logs. The xml is generated.
I had it somewhat working for a while, according to my notes (close to the stick), but then I moved it away from the stick, and only after seeing this thread today, I thought I should give it another go.
What does the listening flag show for your device?
What is the “wakeup variable”?
Devices should report to the controller if they are always listening (ie mains powered) or not - this is done using the listening flag. The problem here is that it doesn’t seem to be possible to change the listening flag to false.
Sorry, I must been on another planet. I meant the Stay Awake. Not sure if it really means that the device becomes a listening device though. I remember reading about this when I got it, but many years has passed. It has been working great on my Vera over the years.
Just got my new AeonLab zwave stick gen 5 and checked if the behaviour is different (I was hoping that the problem is in the original zwave controller), but it is the same
Still:
I cannot get the zwave xml file to be created
I cannot change the “Stay Awake” flag (that always shows 0)
habmin shows the device as listening.
I want to apply factory reset to the HSM100 but obviously I can not do it via openhab.
Is there another free zwave software that can be installed in Linux (Ubuntu 16.04) that can be used to change the data, or apply factory reset to the HSM100?
The HSM100 manual point to HS2 from HomeSeer but this is an expensive program, and I am looking to apply a one-time factory reset to the device.
You can only do this on the device itself - openhab, or other software, can not do this. Alternatively, you can exclude the device which for most devices will also reset it. Normally there’s a button to do the reset.
To properly have EZMotion+ included in the routing tables, set
Stay Awake to a non-zero value, then reset EZMotion+
(Exclude from the network), then add it back to the network.
After I set the “Stay Awake” to non-zero (e.g. 1), exclude and reinclude, the value appears as 0 again…
The manual specifies that valid values for the 'Stay Awake" are 0,-1 but openhab can set only 0 or positive numbers…
Yes, I wanted -1 so I tried setting to 255 but the value did not stick after exclusion and re-inclusion of the device.
I then built ozwcp (open-zwave-control-panel), which is another zwave program on Linux, using these instructions.
In http://localhost:8888/ I change the value of “Stay Awake” from 0 to 255.
After excluding and re-including the device, the values persist as 255 (I had to press the physical button on the device and click the refresh button in ozwcp).
Moreover, I restarted openhab and set the “Stay Awake” to arbitrary value (252). I then excluded the device from the controller and added it again in a new node. The v
alue of Stay Awake of the new device show 252.
i.e. this means that openhab does persist the “Stay Awake” value in the device (note that openhab itself, after restart, always shows the value as 0)…
Next I changed the Stay Awake value to 0 via ozwcp, excluded, re-included and verified via ozwcp that the new value is indeed 0 (i.e. not-listening)
I then restarted openhab and added the new device.
The new progress is that the device now shows not-listening (img1), but the zwave xml file is still not created
The log (node 18) can be found here
The log doesn’t show any data being received from the device, which I think it probably wrong. Is this a full log or have you reduced it to only show certain lines?
I thought it was full enough but I will test again and upload a full log when I get home tonight. Seeing the “Listening” turned off in img1 encourages me
Thanks. I didn’t actually look at the log as a text file, but it’s clearly missing all the receive data packet information which is kind of important ;).
It looks like the device is saying it supports the WAKEUP command class in endpoints 1 and 2, but then it doesn’t respond when messages are sent to it. This might be resolvable through a database modification - is this device in the database yet?
I don’t know the answer to this question.
I found an entry for EZMotion Express in the database in here (EZMotion Express by Express Controls).
Should I look further into the database, or do anything else on my side to answer this question?
Openhab recognises the device as Z-Wave Node 18: EZMotion Express Wireless 3-in-1 Sensor.
I guess this means that the device is associated with something in the database…
The HSM100 is the same as the EZMotion+.
The user manual can be found http://www.expresscontrols.com/pdf/EZMotion+OwnerManual.pdf
Maybe EZMotion+ is not excactly the same as EZMotion Express?
I found references of xml files that describe this (or similar) device in here.
Users of openhab reported working with this (or similar) device in here and here
I contacted the founder of Express Controls, and asked if there are 2 similar products. His reply:
Apparently EZMotion Express is a typo. There was an earlier EZMotion
and then later a slightly improved version called EZMotion+.
Both were also sold under the homeseer brand as HSM100 but
they are the same product – just a different name.
I’m not sure how other users of openhab initialize the device successfully.
@chris, is there something that can be done on your side to accommodate?
