I’ve got a very nasty problem: Each and every time I modifiy my Default.items (where I have all my items) in a way which changes channel-item links I get a error logged, see below.
This happens every time when a item is assigned a new channel to link to or the existing relation is modified by adding a profile. The affected item-channel link is no longer working until a complete reboot of openHAB.
It occurs with channels of the KNX2 binding (which I use mostly) as well as with Modbus channels, so it does not seem to be related to a specific binding.
However, the KNX2 Binding seems to do a restart after every error logged as logged timeout-warnings (of sometimes unreadable data-points, caused by hardware and surely not related to this issue) indicate.
2022-01-09 21:38:19.466 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Default.items'
2022-01-09 21:38:20.599 [ERROR] [ore.common.registry.AbstractRegistry] - Cannot inform the listener "org.openhab.core.thing.internal.ChannelLinkNotifier@42dbdbb0" about the "UPDATED" event: null
at java.util.Objects.requireNonNull(Objects.java:221) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.getChannelTypeUID(DeviceThingHandler.java:275) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.isControl(DeviceThingHandler.java:269) ~[?:?]
at org.openhab.binding.knx.internal.handler.DeviceThingHandler.channelLinked(DeviceThingHandler.java:162) ~[?:?]
at org.openhab.core.thing.internal.ChannelLinkNotifier.lambda$3(ChannelLinkNotifier.java:72) ~[?:?]
at org.openhab.core.thing.internal.ChannelLinkNotifier.call(ChannelLinkNotifier.java:96) ~[?:?]
at org.openhab.core.thing.internal.ChannelLinkNotifier.added(ChannelLinkNotifier.java:72) ~[?:?]
at org.openhab.core.thing.internal.ChannelLinkNotifier.updated(ChannelLinkNotifier.java:88) ~[?:?]
at org.openhab.core.thing.internal.ChannelLinkNotifier.updated(ChannelLinkNotifier.java:1) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry.notifyListeners(AbstractRegistry.java:387) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry.notifyListenersAboutUpdatedElement(AbstractRegistry.java:408) ~[?:?]
at org.openhab.core.thing.link.ItemChannelLinkRegistry.notifyListenersAboutUpdatedElement(ItemChannelLinkRegistry.java:150) ~[?:?]
at org.openhab.core.thing.link.ItemChannelLinkRegistry.notifyListenersAboutUpdatedElement(ItemChannelLinkRegistry.java:1) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:314) ~[?:?]
at org.openhab.core.common.registry.AbstractRegistry.updated(AbstractRegistry.java:1) ~[?:?]
at org.openhab.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:66) ~[?:?]
at org.openhab.core.common.registry.AbstractProvider.notifyListenersAboutUpdatedElement(AbstractProvider.java:91) ~[?:?]
at org.openhab.core.model.thing.internal.GenericItemChannelLinkProvider.createItemChannelLink(GenericItemChannelLinkProvider.java:108) ~[?:?]
at org.openhab.core.model.thing.internal.GenericItemChannelLinkProvider.processBindingConfiguration(GenericItemChannelLinkProvider.java:76) ~[?:?]
at org.openhab.core.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:372) ~[?:?]
at org.openhab.core.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:341) ~[?:?]
at org.openhab.core.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:212) ~[?:?]
at org.openhab.core.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:407) ~[?:?]
at org.openhab.core.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:301) ~[?:?]
at org.openhab.core.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:139) ~[?:?]
at org.openhab.core.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:249) ~[?:?]
at org.openhab.core.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:312) ~[?:?]
at org.openhab.core.service.WatchQueueReader.lambda$3(WatchQueueReader.java:323) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
This problem began to show some time ago, I first ignored it, as I did not notice its consequences. So I now can’t track back to what change caused this.
The hex-numbers part of the “ChannelLinkNotifier” after the “@” in first error log line
is always the same, no matter which item I change, until a reboot. Then it changes to a seemingly random number, which then stays the same again, even if I continue to modifiy different item-channel links. I always get the error and it is always the same.
Example: I got the log entry above when I just changed the line
DateTime Garagentor_Zeitstempel "letzte Torbewegung [%1$tA, %1$td.%1$tm.%1$tY %1$tT]" <calendar>
to
DateTime Garagentor_Zeitstempel "letzte Torbewegung [%1$tA, %1$td.%1$tm.%1$tY %1$tT]" <calendar> { channel="knx:device:bridge:generic:Garagentor_In_Bewegung" [profile="system:timestamp-change"] }
with the intention of replacing the rule which currently updates the item by a profile.
What I’ve tried already:
- Cleared the cache https://community.openhab.org/t/clear-the-cache/36424, as suggested in this topic https://community.openhab.org/t/solved-error-ore-common-registry-abstractregistry-cannot-inform-the-listener-org-openhab-core-items-internal-itemuiregistrydelegate/93667: no effect.
- Checked my groups for “loops” (meaning group item is member of that group, i presume) as suggested here: https://community.openhab.org/t/solved-error-when-saving-a-items-config-file/65552: no effect. I do however have groups of groups and items which are members of more than one group.
And I’m really running out of ideas now. The logged error has no pointers for me, so I don’t even know where to start looking.
- Platform information:
- Hardware: Synology NAS
- OS: Offical openHAB Docker Image
- openHAB version: 3.2.0
I’m grateful for any advice.
Greetings,
Sebastian
