when binding configuration is changed, old NeatoHander is not shutdown correctly. As you see from the log, after configuration change there are two handlers running simultonously.
2017-04-29 20:52:13.761 [INFO ] [b.binding.neato.handler.NeatoHandler] - Will get STATE for Robot Robo
2017-04-29 20:52:13.774 [INFO ] [b.binding.neato.handler.NeatoHandler] - Will get STATE for Robot Robo
2017-04-29 20:52:14.057 [INFO ] [b.binding.neato.handler.NeatoHandler] - Successfully got and parsed new state for Robo
2017-04-29 20:52:14.251 [INFO ] [b.binding.neato.handler.NeatoHandler] - Successfully got and parsed new state for Robo
When Neato binding is fully uninstalled, NeatoHandler(s) still continues polling.
Reason for this is that you haven’t implemented dispose method. Dispose method is called by the openHAB framework automatically, before initialisation method is recalled.
Another issue is related to logging. Binding pollutes logs by “Will get STATE for Robot …” and “Successfully got and parsed new state for …” staff as logging is done in INFO level. You should change log level to DEBUG for those.
ui_alert_busy_charging=Busy Charging
ui_error_navigation_noprogress=Navigation Issue
ui_alert_recovering_location=Recovering Location
ui_error_brush_overload=Brush Overload
ui_error_dust_bin_full=Dust Bin Full
ui_error_dust_bin_emptied=Dust Bin Emptied
ui_error_brush_stuck=Brush Stuck
// Curent state of the vacuum cleaner
INVALID=Invalid
IDLE=Idle
BUSY=Busy
PAUSED=Paused
ERROR=Error
ON=Yes
OFF=No
// Current action of the vacuum cleaner
HOUSE CLEANING=Cleaning House
SPOT CLEANING=Spot Cleaning
MANUAL CLEANING=Manual Cleaning
DOCKING=Docking
USER MENU ACTIVE=User Menu Active
SUSPENDED CLEANING=Suspended Cleaning
UPDATING=Updating
COPYING LOGS=Copying Logs
RECOVERING LOCATION=Recovering Location
IEC TEST=Iec Test
// Current or last cleaning mode
CLEAN-MODE-ECO=Eco
CLEAN-MODE-TURBO=Turbo
// Modifier of current or last cleaning
CLEAN-MODIFIER-NORMAL=Normal
CLEAN-MODIFIER-DOUBLE=Double
// Current or Last category of the cleaning
CLEAN-CATEGORY-HOUSE=House Cleaning
CLEAN-CATEGORY-SPOT=Spot Cleaning
CLEAN-CATEGORY-MANUAL=Manual Cleaning
Thanks for the mapping file, i will do a translation to german …
I read, that Florian did some modification for the Kobold VR200 from the german vendor Vorwerk. The latest jar file on GitHub is unfortunately not yet generated with the new code. I have no experience in building openhab runtime modules. I tried it, but without success … Has anyone done that, and can make the jar file available?
I have a Kobold, and have been watching this thread on the sidelines for a while. I have just made the jump from Opehab1 to Openhab2, and decided to try this binding.
I am not a coder, so not too sure what is done to make a new .jar, but expected to see a new file on this link:
without success (most recent is 3 months old) - where do I go to get the file to test it here?
Please excuse my bad English! I am also not a Java programmer, but I have some experience in software development. Scripting is ok, but it’s enough.
Send me your email address, then I can send you the jar file.
Great Job.
Is your binding working with the D3 connected as well? I can only find something about the connected versions, but the d3 seems to be pretty new!?
Anyone up for taking over this binding? It looks like Patrick has not been able to work on it. There are a number of things you can do with the API that would be nice to expose to openHAB.
findMe – Issue the findMe action on the robot.
getGeneralInfo – More information like: “timeToEmpty” and “timeToFullCharge”
startCleaning – Would be nice to set eco or normal.
getLocalStats – Lot more info: “totalCleanedArea”, “totalCleaningTime”, “averageCleanedArea” and “averageCleaningTime”
maps – Really would like to see the maps in openHAB.
Any takers? Happy to buy anyone a Neato for the work!
Friend has the 960, the maps for his house were a lot worse then mine, but since they both were not the same house it may not be a 100% fair comparison.
