I fail to see how my comment indicated otherwise.
How would a switch be able to tell Openhab it was currently OFF if it was not working all the time and never powered down? If Openhab reboots you do not know if the button was pushed whilst the server was rebooting if it can not report back its current state.
If a switch only tells Openhab when it is changing state and cannot be asked at any time, then I consider it only half smart. This is just my opinion.
It would be great to see a comparison of different smart globes and switches and to learn the true issues that they present when used in a large fully automated home.
Thats why I would suggest having a relay or something simular indicating the state of a switch (or latest state, if it´s an push-button). It makes things so much more easier to work with.
This is where “complex” systems like KNX come into play, really. The point is that it is a system, rather than a collection of independent units.
An alternative approach to multiple controls; one control location is the “master” which allows manual control but also has the capability to be controlled by OH. (A Sonoff dimmer for example)
The other control location is just a wallplate, with no direct infuence on the end device. It just reports to OH and OH does the thing to other dimmer.
In the event of “system” problems, you lose the remote control but can still turn the lights on.
These are difficult decisions to make.
With a new build, you should seriously consider wired solutions. Of course there are two approaches to that as well
Run all power cable - feeds to ceiling lights, cables to wallplates - back to a central cabinet. Here lives the active gubbins, dimmers etc. See DIN mount Sonoffs and so on. Choice of tech, reconfigurable.
Alternatively, run Cat5 signal cable to control and consumption points to control remotely mounted units. Again choice of tech, flexible.
A combination approach is also feasible.
Yeah, I’ve thought about master/slave wall mounts, maybe that is the way I’ll go.
KNX hardwares are like super expensive to me, I’ve just checked one relay switch which is like 300euros.
I’ll need like 10-14 wall switches, not to mention the other HW that would be used. In total 5000euros won’t cover the costs.
I’ll check on wired solution too. It seems interesting as an option to be used. Especially when my house is just getting built and i will have all the options for wiring etc.
So to talk about wired solution: So I can imagine how this thing will work…
Now I have a basic idea about wifi/zigbee/wzave products, but UTP wired wall switches bulbs? I’ve only seen a post about utp power feeded wall switch, so you won’t have to play with high voltage power… or is that an another thing? Enlighten me pls
I have a wired solution in my house… It´s called IHC. I cant find any english description of it ufortunatly. In short the concept is nearly the same as KNX, beside IHC got a specific controller (computer) where all the logic is located. And its prefered centralized setup.
I also have a small test setup of Velbus… It´s very powerfull, and for people in europe, I would suggest looking at Velbus system… https://www.velbus.eu @MDAR is a great guy to advice you on this system. My experience is not that strong, yet. But I´m getting there
MDAR
28
Thanks Kim.
It’s great to know that you’re having success with the Velbus kit.
@Kardiii
This post might give you some insights into the whole debate between wired and wireless.
The Zooz switch I posted works along with a standard 3-way switch to control the lights in 2 locations. They can also handle more switch locations with 1 smart switch, depending on the specific wiring paths.
Yeah, I’ve checked that, but from picture, it seems they are for US plugs (holes).
I’ve also checked fibaro products, they are also zwave smart switches.
EU, Hungary.
Fibaro products are almost the same, meaning they also have zwave products, or MCU is also a Zwave brand in EU. The problem is 1 switch costs 100 euros… I’ll need like 10+ pieces in the whole house. That’s a lot of money only for wall switches
I don’t know your wife’s capabilities but that requires to setup the new bulb, too (in advance or when in need) so you need to have access to the Zigbee coordinator and have to mess with it. Way more work than to just put in another traditional bulb.
And usually it’s not the switch (smart or not) but the bulb or its builtin power supply (if 12V or LED) to burn so it’s a waste of ressources and money when you have to throw away and re-pay for electronics that would still work if just they hadn’t been part of the bulb.
A smart switch to fail is less probable than a smart bulb to fail (usually no power transformation in there so no heat dissipation etc).
And overall, the most probable case is no bulb or switch but OH to fail (we’ve got only one of that to affect ALL your lights, it’s running on a computer that can fail, you can accidently misconfigure things there etc).
Smart switches will continue to provide lighting while for smart bulbs you need another remote, up-to-date and able to control ALL of your lights. You may or may not have available in that critical moment.
Huh? You can get Fibaro devices everywhere, some for less than 50€ (well unless your great politicians put ridiculous import taxes on top but Fibaros are made in Poland).
Whew, sounds like real bargains. Unfortunately there’ll be taxes on top.
That is exactly what I am watching now. 10 pcs/s 21$/ piece, would be an affordable price.
The question is, does it work with OH. Probably yes, but i’ll search for this on the forum.
Stupid question again, without a dimming switch, would I be able to dim the lights from OH, even if the switch is not a dimming one? Don’t think so.
Yeah, in Hungary we have 27% taxes on every damn thing… such a ripoff.
From Ali we can evade the taxes if I order them in smaller bulks, or agree with the seller, to pay it in 2 way, so the tax authorities will only see the smaller payment
But I’d not encourage any1 to cheat taxes
I believe so. I don’t have as much experience with using Sonoff in this way so I can’t say for sure. It depends on how the Sonoff wires to the existing light switch.
I would assume that is correct.
I know in Zwave there are some two way light switches. I’ve also seen people talk about putting in two smart switches, one actually wired to the light and the other only wired to power up itself. Then the switches are configured to talk to each other (in Zwave this is called Association Groups) or they talk to each other using openHAB.
Oops, this is exactly what rossko57 describes. I should read all the posts before I start a reply.
No. Dimming requires special hardware to achieve. If you don’t have a switch or a bulb that contains that hardware, you can’t make them dim from OH.
