Need help with electric valve arm
Hi trying to undersatnd how do i control this cheap valve
i have no expraince with motors , but i am working with tasmota for sonoff and other IOT stuff
ok so got myself this arm valve
and when i apply 12V+ it goes one way
and when i apply 12V- it goes the other…
how can i control this from tasmota? i need MQTT working :slight_smile:
i was thinking i need two relays ? one with 12+ the other with 12-?
UP :frowning:?
Hi
I don’t know anything about Tasmote, but I do know about DC motors.
In short, yes, you’ll need at least 2 relays.
However, they will both need to be
Single pole, double throw
And wired in a precise manner.
  • Connect each connection of the motor to the COM connection of a relay.
  • Connect the NC (Normally Closed) connection of BOTH relays to 0V
  • Connect the NO (Normally Open) connection of BOTH relays to +12V
Only 1 relay should be operated at a time, however, should both relays be triggered by mistake, nothing will happen or get damaged, simply because the potential difference across the motor will still be 0V (as in, 12V on one side and 12V on the other. 12 - 12 = 0)
Mode of operation
  • Operate Relay 1 for 10 seconds - motor will rotate in a direction for 10 seconds
  • Operate Relay 2 for 10 seconds - motor will rotate in the opposite direction for 10 seconds
  • Operate BOTH relays at the same time - nothing will happen
This method is fine for small motors, if you ever did this with a large motor, you would need to make allowances for dissipating the electrical energy created from the generation effect of the motor still rotating when power is removed (and the two connections being “shorted together, forming an electrical brake”, this can be done by applying a dummy load.)
I’m slowing venturing into MQTT with ESP-01 / ESP8266 boards.
If I were to need a solution like this, I would probably use
  • a ESP-01 with 2 relays
  • Simple Arduino project that listened to an MQTT topic for
    ** forward
    ** backward
    ** off
And trigger the two relays accordingly.
Thankfully, someone somewhere has already thought of this setup, so a quick search will return you things like this.
{FYI, these are Single Pole, Double Throw (SPDT) relays, so will work perfectly}
https://uk-m.banggood.com/5V-ESP8266-Dual-WiFi-Relay-Module-Internet-Of-Things-Smart-Home-Mobile-APP-Remote-Switch-p-1270421.html
You’ll just need a programmer to upload your Arduino sketch.
1 point to note.
There is no way to tell how the relay board has been design or how the software on the ESP01 controls it.
One might assume that each of the GPio pins on the ESP01 / ESP8266 triggers a relay.
However, it is also possible that it is a lot more clever than that and it uses the serial connection to send instructions to the relay board.
As hinted at here
Wow Madar i will need to read this a couple of times :slight_smile:
thanks i will do my testing and get back here!
Does your valve have limit switches, so that you know when it has traveled to the end?
Once you have the motor relays working, you will probably have to think about timing elements, to shut off the motor after a while.
Hi @rossko57 i am not sure what is a limit switch, but i can hear that the motor stops working after it has reached the desierd place
but i am planing to make some kind of logic that will restore it to its orginal state(OFF)
in tasmota you can setup rules , that will run in the ESP even if no wifi conncted, so i think i will start there … if not i will do it in node red
Yes, but it most likely is just pushing up against a physical end stop, still taking electrical power and converting that to heat instead of movement.
That’s all that is needed, automatically turning off after a suitable delay.
Hi @MDAR i have orderd this one from ali
hope its the same… looks the same
and maybe you have an exmpale sketch for me?
i never done arduino… yet…
do you think that a framware like tasmota can do the same as the sketch ?
or maybe i will ask it a litle diffrently, Single Pole, Double Throw (SPDT) is done in the relay board or on the sketch ?
Sure, I’m happy to share what I’ve learnt so far.
When I get back to my office, I’ll post something on here.
Hello
I’ve had a play around with an ESP01 I have here and come up with a kind of controllable 2 relay setup.
I can’t get the “STOP” command to interrupt the DoAction loop, but I’m sure it’s only something small that I’ve missed.
(It’ll give you something to fix) Update, it was bugging me so I changed my approach, see 2nd script below
This is the Node-RED flow I use to control it with MQTT
Command structure I’ve used is -
Command:Duration in Milliseconds
IE
UP:5000 = UP for 5000ms
DOWN:1500 = Down for 1500ms
STOP = ALL STOP, regardless of current state
UP = UP with a default duration of 500ms
DOWN = DOWN with a default duration of 500ms
        "id": "209ddf60.f3782",
        "type": "mqtt out",
        "z": "bf2ab0d4.458a7",
        "name": "",
        "topic": "",
        "qos": "",
        "retain": "",
        "broker": "",
        "x": 3330,
        "y": 400,
        "wires": []
        "id": "8c7b3762.f07ec8",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Blind01",
        "payload": "UP:300000",
        "payloadType": "str",
        "x": 3070,
        "y": 200,
        "wires": [
                "209ddf60.f3782"
        "id": "b77fba37.7a8908",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Blind01",
        "payload": "DOWN:20000",
        "x": 3040,
        "y": 400,
        "wires": [
                "209ddf60.f3782"
        "id": "e72e06b.de6e3f8",
        "type": "mqtt in",
        "name": "",
        "topic": "Blind01_FB",
        "qos": "2",
        "datatype": "auto",
        "broker": "",
        "x": 3530,
        "y": 480,
        "wires": [
                "b1739811.4bc9f8"
        "id": "b1739811.4bc9f8",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": false,
        "console": false,
        "tostatus": true,
        "complete": "payload",
        "targetType": "msg",
        "x": 3760,
        "y": 480,
        "wires": []
        "id": "22bf4f3c.5a128",
        "type": "mqtt in",
        "name": "",
        "topic": "Blind01",
        "qos": "2",
        "datatype": "auto",
        "broker": "",
        "x": 3500,
        "y": 400,
        "wires": [
                "bc2f7060.0badc"
        "id": "bc2f7060.0badc",
        "type": "debug",
        "name": "",
        "active": true,
        "tosidebar": false,
        "console": false,
        "tostatus": true,
        "x": 3750,
        "y": 400,
        "wires": []
        "id": "7a7a5e84.96c37",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Blind01",
        "payload": "STOP",
        "x": 3070,
        "y": 620,
        "wires": [
                "209ddf60.f3782"
        "id": "bd5f8031.91001",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Blind01",
        "payload": "UP:2000",
        "x": 3060,
        "y": 280,
        "wires": [
                "209ddf60.f3782"
        "id": "2d88268b.a6910a",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Blind01",
        "payload": "DOWN:1500",
        "x": 3050,
        "y": 480,
        "wires": [
                "209ddf60.f3782"
        "id": "c23071b9.b6248",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Blind01",
        "payload": "DOWN:6000",
        "x": 3050,
        "y": 440,
        "wires": [
                "209ddf60.f3782"
        "id": "6db34c1a.f27f24",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Blind01",
        "payload": "UP:6000",
        "x": 3060,
        "y": 240,
        "wires": [
                "209ddf60.f3782"
        "id": "e7022e4a.2119c",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Blind01",
        "payload": "UP:3000000",
        "x": 3070,
        "y": 160,
        "wires": [
                "209ddf60.f3782"
        "id": "3da71972.8feda6",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Blind01",
        "payload": "UP",
        "x": 3020,
        "y": 120,
        "wires": [
                "209ddf60.f3782"
        "id": "f6d6d67f.9f3e78",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Blind01",
        "payload": "DOWN",
        "x": 3040,
        "y": 520,
        "wires": [
                "209ddf60.f3782"
        "id": "acb41424.6c9418",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Blind01",
        "payload": "stop",
        "x": 3050,
        "y": 680,
        "wires": [
                "209ddf60.f3782"
And this is the Arduino script I use on the ESP8266 / ESP01 board
#include "EspMQTTClient.h"
 #define Identifier "Blind01" // Delimiter is "_"
/* Which software GPio Pin to use (not the same as marked on board)
ESP01 = Pin 2 or 0
NodeMCU = Pin 5
int UP = 2;
int DOWN = 0;
// MQTT client setup example
EspMQTTClient client(
  "WifiSSID",
  "WifiPassword",
  "192.168.1.100",  // MQTT Broker server ip
//  "MQTTUsername",   // Can be omitted if not needed
//  "MQTTPassword",   // Can be omitted if not needed
  Identifier,     // Client name that uniquely identify your device, as set above
//  1883              // The MQTT port, default to 1883. this line can be omitted
int ind1;
int ind2;
String Command = "OFF" ;
String Duration = "500" ;
int Event;
volatile int state = false;
volatile int flag = false;
String input_state = "OFF";
String LEDState = "System Boot";
void ICACHE_RAM_ATTR changeStatus ();
unsigned long previousMillis = 0;
const long interval = 150;
void setup() {
      Serial.begin(9600);
    delay(2000);
      Serial.println("LED Setup....");
     pinMode(UP,OUTPUT);
     pinMode(DOWN,OUTPUT);
    digitalWrite(UP, LOW);
    digitalWrite(DOWN, LOW);
        delay(350);
    digitalWrite(UP, HIGH);
        delay(350);
    delay(2000);
          Serial.println("2nd Blink ....");
        delay(350);
        delay(350);
    Serial.println("Preparing MQTT Relay control project...");
    Serial.println();
    Serial.println();
    Serial.print("Connecting to MQTT broker ");
      WiFi.mode(WIFI_OFF);        //Prevents reconnection issue (taking too long to connect)
       delay(1000);
      WiFi.mode(WIFI_STA);        //This line hides the viewing of ESP as wifi hotspot
                                   //WIFI_STA It's very important !!!!
    Serial.println("");
    Serial.println("No 5 is alive");
void onConnectionEstablished() {
  client.subscribe(Identifier, [] (const String &payload)  {
    Serial.println(payload);
      ind1 = payload.indexOf(':');  //finds location of first ,
 Command = payload.substring(0, ind1);   //captures first data String
      ind2 = payload.indexOf(':', ind1+1 );   //finds location of second ,
 Duration = payload.substring(ind1+1, ind2);   //captures second data String
 if ( Command != "UP" || Command != "up" || Command != "DOWN" || Command != "down"|| Command == "STOP"|| Command == "stop"|| payload == "STOP"|| payload == "stop"){
        digitalWrite(UP, LOW); // Change these to HIGH if your relays work that way
        client.publish(String(Identifier)+ "_FB", String(Identifier)+ " state = STOPPED");
        Event = 0; // Reset event so that a new message can overide this
 if ( Command == "UP" || Command == "up" || Command == "DOWN" || Command == "down"){
        Event = 1; // Triggers DoAction timer loop
); // End of Subscribe loop
  client.publish(String(Identifier)+ "_FB", String(Identifier)+ " state = " + Command);
//  client.publish(String(Identifier), String(Identifier)+ " is Alive");
void loop() {
  client.loop();
  DoAction();
void DoAction(){
if (Event >0){
 if ( Command == "UP" || Command == "up"){
        digitalWrite(UP, HIGH); // Change these to HIGH or LOW according to how your relays work
 if ( Command == "DOWN" || Command == "down"){
        digitalWrite(UP, LOW); // Change these to HIGH or LOW according to how your relays work
        digitalWrite(DOWN, HIGH);
   client.publish(String(Identifier)+ "_FB", String(Identifier)+ " state = " + Command + ": Time = "+ Duration.toInt());
 if (!Duration){
  Duration = "5000"; // Sets a default duration if none is in the message
delay(Duration.toInt()); // Durations of delay set by message
        client.publish(String(Identifier)+ "_FB", String(Identifier)+ " state = STOP");
Good luck, if you fix the STOP command, please do share how you manage it
This might help
Update
Well that didn’t take very long, I must be slowly learning things.
This version of the script (which uses a Time Check routine rather than a Delay command (Which seems to mean “Stop doing everything”) enables the STOP command.
ESP01 = Pin 2 or 0
NodeMCU = Pin 5
int UP = 2; // UP Relay connected to GPio No. (Which is not always the same as marked on the board)
int DOWN = 0; // DOWN Relay connected to GPio No. (Which is not always the same as marked on the board)
// If your relay board is inverted, just go through this Script and swap HIGH for LOW etc
  "WifiSSID", // Your 2.4Ghz WiFi SSid
  "WifiPassword",  // Your WiFi password
  Identifier,     // Client name that uniquely identify your device, as defined above
int ind1;
int ind2;
bool Event;
bool Timer;
unsigned long currentMillis = 0;    // stores the value of millis() in each iteration of loop()
unsigned long previousMillis = 0;   // will store last time an action happened
void setup() {
      Serial.begin(9600);
    delay(2000);
     pinMode(UP,OUTPUT);
        delay(350);
        delay(350);
    delay(2000);
        delay(350);
        delay(350);
    Serial.println();
    Serial.println();
       delay(1000);
    Serial.println("");
 if ( Command == "STOP"|| Command == "stop"|| payload == "STOP"|| payload == "stop"){
        Serial.println("Stopped by MQTT command at " + String(currentMillis));
        Event = false; // Reset event so that a new message can overide this
        Timer = false; // Cancel timer
 //       Serial.println("MQTT command " state = " + Command + ": Time = "+ Duration.toInt());
        Event = true; // Triggers DoAction timer loop
void loop() {
   currentMillis = millis();   // capture the latest value of millis()
                             //   this is equivalent to noting the time from a clock
  client.loop();
  DoAction();
  TimerAction();
void DoAction(){
if (Event){
 if (Duration.toInt() == 0){
  Duration = "500"; // Sets a default duration if none is in the message
         Serial.println("MQTT command = " + Command + ": Time = "+ Duration.toInt());
 if (!Duration){
        previousMillis = currentMillis; // Store point in time when action occured
        Event = false;
        Timer = true; // Start timer
            Serial.println("Timer started at " + String(currentMillis));
void TimerAction(){
  if (Timer) {
  if (currentMillis - previousMillis >= Duration.toInt()) {
    Serial.println("Timer stopped at " + String(currentMillis));
        Timer = false;
Hi
That’s a phrase used to describe the physical characteristics of a relay.
For example.
A relay that only closes a single circuit would be called a “Single Pole, Single Throw”
Whereas a relay that offers TWO states, because the COM connection in it’s relaxed state connects to “Normal Closed” and in it’s energises state connects to “Normally Open”, would be called a “Single Pole, Double Throw”
For a DC inverter circuit, where both relaxed relays provide a kind of Electrical Brake (by effectively shorting out the motor) would be connected like this :-
(this diagram uses “Double Pole, Double Throw” relays, because that’s what I have in the image library)
I have no idea… I’ve never used the Tasmota firmware.
All I can tell you is that the script I’ve written prevents both relays being ON at the same time.
(not a major issue with this diagram and style of DC polarity control, but it would be fatal for a MAINS blind motor, should 2 x LIVE be applied at the same time, I know because I’ve done it… ONCE)
IE
The UP command
Switches ON the UP relay and ensures the DOWN relay is OFF
The DOWN command
Switches ON the DOWN relay and ensures the UP relay is OFF
The STOP command simply switches OFF both relays
BE AWARE
The relay board you have purchased uses a serial connection to the ESP01, NOT the GPIO pins.
As hinted at here
You will have to modify the sketch I have created so that the ESP01 / ESP8266 sends out a Serial instruction, rather than a PIN state.
It’s fairly straightforward to add this.
(Although I haven’t had the need to yet)
It should just be a matter of commenting out all the
Serial.println
Serial.print
lines in the script and replace the digitalWrite lines with Serial.println commands to get the relay to do what you want.
for example
replace digitalWrite(UP,LOW); with Serial.println("A0 01 01 A2");
digitalWrite(UP,HIGH); with Serial.println("A0 01 00 A1");
digitalWrite(DOWN,LOW); with Serial.println("A0 02 01 A3");
digitalWrite(UP,LOW); with Serial.println("A0 02 00 A2");
Looking at the reviews of the item, it seems that these are standard commands for Tasmota, but like i say, I don’t know anything about that.
@MDAR thank you i think i will first try to make it work with somthing like espeasy, tasmota
if not i will dive right into the IDE
I look forward to reading about your journey.
Good luck
