for whatever reason this seems to happen to me always on those chinese branded sensors like coolcam, heiman etc. … they actually look ok in habmin however if you wake them up couple times you can see that suddenly the initalization is actually done finally and the device works afterwards
never have those issues with eg fibaro … still for sure manufactured in china
I have a couple of the window sensors, they are working to my satisfaction except one.
It only detects motion, when the magnet is in the immidiate vicinity (The cover of the sensor has to be off). It is included and working find otherwise.
Maybe @alefz3r0 or @helmar74 have an idea - from my understanding it must be some kind of hardware failure. Could the reed sensor be broken? Where would I find replacement to solder it in.
Thank you guys! Just slinging the device seems like a waste…
The Coolcam power plugs are nicely included in my network. Openhab then logs this;
[wave.discovery.ZWaveDiscoveryService] - NODE 18: Device discovery could not resolve to a thingType! 0258:0200:1027::2.32
[wave.discovery.ZWaveDiscoveryService] - NODE 19: Device discovery could not resolve to a thingType! 0258:0200:1027::2.32
I am on the latest stable zwave binding;
openhab> bundle:list | grep -i zw
242 | Active | 80 | 2.4.0 | ZWave Binding
openhab>
I’ve read through this topic, seen all the tips and tricks like waking up the device, be very patient and wait for the device to complete initialization etc. After excluding, including, heal commands, waking the devices and waiting for more than 24 hours still the devices will not be ‘recognized’ by Openhab. The error message I get about not being able to resolve a thing type seems to be very consistent. I haven’t had any other messages whatever I tried.
I don’t think I’m doing something wrong and I do not think I have a problem with my installation. All other devices were added without any problems or delays. Mesh network and Openhab software, all is working fine.
I’ve seen a sort of explanation from Chris how you can manually add a device to Openhab using his database and exported xml’s but I can only follow his explanation up to where he tells to search for the application version in the XML file.
How can I force Openhab to actually use the predefined device from the zwave binding? After all the coolcam power plugs report themselves exactly as they should (0258:0200:1027) and to my understanding the zwave binding should not have any difficulties resolving / installing / using the power plugs.
Just added a Neo Coolcam Powerplug, Manufacturer 0258, Type/ID 0200:1027.
It is joined in the openhab2 / z-wave network and states the data as above.
Only it’s not fully discovered ?! It says: “unknown device”.
But if I check the database online, the powerplug is in there !
I’ve got:
Openhab2 v 2.3
Z-wave binding v2.3.0
What to do to fully discover the item?
Would it be possible to only upgrade the version of the z-wave binding to the abovementioned latest 2.5 snapshot ?
But … O Boy,
I already did execute the karaf command to load the z-wave 2.5 version you had in a discussion mhilbush.
It was executed but Openhab2 seems to ignore it as in PaperUI it still states z-wave binding v2.3.0…
I had to restored a backup as after the command z-wave was no longer working and I tried updating to OpenHAB 2.4. So now I’m up and running on OpenHab v 2.3 again.
Only my new thing, the Neo Coolcam powerplug is still in status “unknown device”.
I don’t understand it though, it’s not my first NEO Coolcam device and also not the first powerplug. I’ve got quite a few (powerplug, wall switch and motion sensor) running for months now without any problem…
Updating to v2.4 seems to be quite a problem.
I think I was told the database was queried online, so updating the binding was not necessary for new things? Is that no longer the case or did I misunderstand ?
Anyway, any other ways or suggestions on how to get the NEO Coolcam Powerplug (Manufacturer 0258, Type/ID 0200:1027) working?
Nb.1. I’m running an OpenHabian (RPi) version of OpenHab.
Nb.2. This is the error message:
NODE 23: Device discovery could not resolve to a thingType! 0258:0200:1027::2.32
The database is part of the binding. They are inseparable. To the best of my knowledge, it has always been this way in OH2.
Based on my reading of posts on this forum, many people running openHABian have upgraded from 2.3 to 2.4. You might want to seek some help here on the forum. Unfortunately, I’m not of much help because I don’t run release builds.
Hey @sihui, Can a recent snapshot version of the zwave binding run on the OH 2.3 stable release?
One way or another, in order to use this device, you need to get on a very recent version of the zwave binding. That type:id was added to the binding on January 19, so you need to be running the latest snapshot zwave binding.
I also aquired some of the new Neo Coolcam wall plugs with the new device ID. (type/ID 0200:1027). With the latest z-wave binding all the basic functionality works okay. I have however 2 issues:
KWH usage sometimes reports a large negative number and some hours later it switches back: PWR_SW_TVLR_KWH changed from -21474834.58 to -21474834.57
Did anyone experience this, and have any clue on how to fix it?
The other issue I encountered that the switches do not seem to react to any configuration parameter I send. Tried to switch of the lights, tried to disable the on/off button. All is ignored.
Make sure you are using HABmin to change any configuration parameters.
Also there seem to be no problem with the kwh:
2019-02-12 13:12:36.176 [vent.ItemStateChangedEvent] - Neo_PowPlug_2_kwh changed from 0.67 to 0.68
2019-02-12 22:49:00.414 [vent.ItemStateChangedEvent] - Neo_PowPlug_2_kwh changed from 0.68 to 0.69
2019-02-13 07:39:41.870 [vent.ItemStateChangedEvent] - Neo_PowPlug_2_kwh changed from 0.69 to 0.7
2019-02-13 16:20:55.350 [vent.ItemStateChangedEvent] - Neo_PowPlug_2_kwh changed from 0.7 to 0.71
Are you sure your devices have the same device/type id? 0200:1027? I’ve tried changing the config with paperUI and habmin. Both to no success. All my other devices (Qubino and aeotec) do respond correctly to config changes.
