I am runing OH 2.3 snapshot in a docker under ubuntu 16.04. Not sure if that makes a difference from running under Win 10
Will go back and print out the whatever it shows in the paper UI
Neo coolcam z-wave devices
Its worse now. I cannot even get openhab to see it during inclusion mode. pressed 3 times in quick succesion, saw the red light blink 5 times, but no response in the Paper UI of openhab
maybe try a factory reset of the door sensor device with press and holding the button for 10-15s. after it, wait 20s and try again an inclusion.
Thanks!. The factory reset allows inclusion. Now its back to the sensor being online but “not in database” and “initialisation is not complete”
Where do I find the product id? These below are the properties
zwave_class_basic | ROUTING_SLAVE |
zwave_class_generic | SENSOR_NOTIFICATION |
zwave_neighbours | |
zwave_frequent | false |
zwave_nodeid | 2 |
zwave_version | 0.0 |
zwave_listening | false |
zwave_routing | true |
zwave_plus_devicetype | UNKNOWN_TYPE |
zwave_beaming | true |
zwave_class_specific | NOTIFICATION_SENSOR |
It will show in this list once it is known. I guess that this is a battery device? You probably need to wake the device up a couple of times so that the binding can discover the device. If that doesn’t help, then you’ll need to provide a debug logfile.
I did try waking it up but it does not seem to make a difference . My battery sensor is exactly this item here:
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/400
How do I get a debug logfile?
I cannot seem to upload the openhab.log and events.log files to this forum. Must I convert them to something else?
You need to find somewhere to load them to - eg Dropbox, or something similar.
https://drive.google.com/file/d/1StZniafbn3NRcqgZ1Qi4_JDxODWvpXM9/view?usp=sharing
https://drive.google.com/file/d/1e7PEyfRNTEOKTN0MnJKfrp1AVgf1wF-y/view?usp=sharing
thanks Chris
Unfortunately that is not a debug log.
Did you see the link to the docs from my post above?
Go to karaf console and type
log:set DEBUG org.openhab.binding.zwave
You should also log zwave to a separate file to make it better readable:
https://docs.openhab.org/administration/logging.html#logging-into-separate-file
You have a lot of errors in your logs:
Your Zigbee is not connected to the correct port. Are you using two USB devices at the same time? That can cause trouble when rebooting because the ports can change, you may need to use symlinks:
Also your network bindings needs arping installed:
https://docs.openhab.org/addons/bindings/network/readme.html#arping
I would highly recommend to first troubleshoot all your errors and then advance to zwave device inclusion.
Thanks!
How do I get the log file out after the
Same procedure you did already:
post your openhab.log.
But after a debug command it will be several megabytes
Did you create a separate zwave log as I recommended above?
Then you need to use that file …
Here you can see an example for a zwave debug log file:
Note the debug in
07-Nov-2017 16:35:02.207 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - NODE 10: TID 13471: Timeout at state ABORTED. 3 retries remaining.
Yes I did.
Here it is:
https://drive.google.com/file/d/1D4kOJoFvJILaQwoaJYw2wFlQnIKI-VEw/view?usp=sharing
oops … just saw your msg. Wrong log file then
Feeding that through the log viewer it does not look too bad for the controller and node 3:
But nothing at all for node 2.
So you need to catch a log when you either include the node in question (or reinitialize it, or wake it up)
I am not sure which is node 2 or node 3. I only have 2 z wave devices now connected, the Aeotec Z stick and the Neo door sensor.
