somewhere in this forum I got the hint to use a very simple tranformation function for one of my items:
Number:Power wallbox_current_actual "Ladeleistung [%.1f W]" (Energy, gDezony) ["Measurement", "Power"] { channel="http:url:dezonyIQ:chargingPower" [ profile="transform:RB", toItemScript="| wallbox_state.state == 'CHARGING' ? input : 0" ] }
I think this worked before but meanwhile I find in the logs:
No ProfileFactory found which supports profile 'transform:RB' for link 'wallbox_current_actual -> http:url:dezonyIQ:chargingPower'
The jruby binding is installed. Did anything change with the way how an inline transformation needs to be specified?
Currenly running OH 4.1.1
jimtng
(jimtng)
January 30, 2024, 3:02am
3
This looks weird. Are you sure the jruby binding is active?
Try going to the karaf console and type
list -s | grep ruby
260 │ Active │ 80 │ 4.1.1 │ org.openhab.automation.jrubyscri
jimtng
(jimtng)
January 30, 2024, 10:27am
6
I would suggest trying to restart openhab first. When did this issue start to happen?
There was another issue reported, related to transform:JS which is equally weird but I suspect is somewhat related.
Wondering if it was a false alarm. When grepping my (still existing) logs it apparently only happened during a restart phase. I’m wondering if the bundle was not active while the transformation already was triggered.
I will watch out if it comes back but maybe it was only a timing issue.
jimtng
(jimtng)
January 30, 2024, 2:21pm
8
Oh yes, this does happen during startup. Items were loaded first, before script engines were. Unfortunately at the moment it is how it is.
