hmn did you fill it in as Username or as Token?
the wierd part is the events etc work super
actually I just looked at my setup and I did both…
Same here.. Node-red can’t select itemName · Issue #27 · jeroenhendricksen/node-red-contrib-openhab3 (github.com)
and here
Node-red can’t select itemName - Off-Topic - openHAB Community
I have to add that i have NodeRed 2.1.3 in a docker container, and 1.3.4 not in a docker…
Pcap traces showing that the Docker container is doing the request to items, OH answers with the json file, but the openhab node does not handling the answer corect …
still trubelshooting, maybe i finde the differentce betwenn 1.3.4 and 2.1.3 Nodred ..
regards
Hi All,
Found the reason for the problem…
has nothing todo with the Node or NodeRed !
i am using a Docker Nodered instance in combination with Hassio .. in that case all the NodeRed Entpoints get prefixed with /endpoint/ … so i had to change
line 545 in 77-openhab2.html from
$.getJSON("/openhab3/items", config)
to
$.getJSON("/endpoint/openhab3/items", config)
Hope this helps someone else doing the same thing and facing the same problem !
Regards
I’ve just created this post:
But it seems it’s the wrong place.
Can you please tell me where is located: ** 77-openhab2.html ** ?
Thanks, BR
[ SOLVED ]
