Agree. I could need a list of available tags, both those which are suppose to work, and those which needs testing. And a small example as well.
This list should be updated when new tags is supported.
Reading the last few entries in this thread surely confuses me. I have seen “Termostat”, TargetTemperature" and “CurrentTemperature”.
As for my own tets, it seems like Google understand “CurrentTemperature”, but not “TargetTemperature”.
2018-05-08 08:07:17.349 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:Weather_Rain in ManagedMetadataProviderImpl, because it does not exists.
2018-05-08 08:07:17.364 [ome.event.ItemUpdatedEvent] - Item 'Weather_Rain' has been updated.
2018-05-08 08:07:17.368 [vent.ItemStateChangedEvent] - unifi_client_84655265_uptime changed from 42125 to 42136
2018-05-08 08:07:17.369 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key _tags:Weather_Wind_Speed in ManagedMetadataProviderImpl, because it does not exists.
I cant see how this is related to the Google Home stuff, as that is all in the cloud and this error is occuring locally.
All i did to cause this was to add CurrentTemperature tag to an item. I think there is now something broken in the items registry…
Do you have the Imperihome binding installed too? I ask because it also breaks my Imperihome.
2018-05-08 08:19:50.799 [WARN ] [eclipse.jetty.servlet.ServletHandler] - /imperihome/iss/rooms
at java.util.HashSet.<init>(HashSet.java:119) [?:?]
at org.openhab.io.imperihome.internal.processor.DeviceRegistry.getRooms(DeviceRegistry.java:49) [229:org.openhab.io.imperihome:2.3.0.201804092039]
at org.openhab.io.imperihome.internal.handler.RoomListHandler.handle(RoomListHandler.java:31) [229:org.openhab.io.imperihome:2.3.0.201804092039]
at org.openhab.io.imperihome.internal.ImperiHomeApiServlet.service(ImperiHomeApiServlet.java:202) [229:org.openhab.io.imperihome:2.3.0.201804092039]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) [31:javax.servlet-api:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [85:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [183:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [84:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [77:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [77:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [77:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [88:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [88:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [88:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [88:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [88:org.eclipse.jetty.util:9.3.21.v20170918]
I can confirm that the tag CurrentTemperature is sufficient to get the temperature through Google Home.
Unfortunately I can confirm that the temperatures are rounded by Google to 0,5 °C.
Sometimes I get a response about the thermostat mode in the room rather than the temperature in the room.
MDAR
308
Hi
There must be another location that the JSON data is stored and being referenced because…
I just deleted the entire contents of the jsondb folder and restarted OpenHab2.
Within seconds all the files were back in the jsondb folder, exactly as they were before I deleted them.
Still without the extra wall light dimmer, which is working perfectly in HabPanel.
Okay, not sure what happened here…
I’ve repeated the process and now I have new JSON files…
Which means I’ve effectively purged my system.
I’m going to try and drop the text for the new dimmer (from the new JSON file) into the backed up JSON file and restart with the edited old file/s in place.
Yes of course.
I think google is trying to set a mode on a tag that not exist. I dont have a mode on my thermostat.
I wil try to add a item for the mode function.
Google is QUITE specific about temperature, you need at least items for:
Mode
Setpoint / Target Temperature
Current Temperature / Ambient Temperature
(See the HomeKit addon page for further info on item setup, grouping, and tag usage).
I made my own “thermostat” with a temperature sensor and a dry contact so I had to have a Mode item for Google to properly provide temperature details.
There are also variables for high and low range, but there does not exist the HomeKit tag convention yet to support.
I’m having the same problem with items set up like that. Seems right, from what I’ve read, but I’m not very experienced with this. Just problems with the mode. It doesn’t seem like Google Home is using the item tagged with [“homekit:HeatingCoolingMode”]. Can’t reach openHAB when I try to set the thermostat mode, and Google always tells me it’s off, even when it’s set to HEAT or AUTO.
I can read the current temperature, and set the target temperature. Just not the mode.
Can someone please post a working example of items for a thermostat?
Hi is there a fix being worked on for the multiple tag issue i use imperihome addon, the workaround i use now is just sync the devices with google then add the additional tags, but if i resync i lose google assistant control after.
For anyone that had the “Sorry I am unable to process your request” issue due to previous IFTTT linkages, it looks like it might finally be fixed. Mine started responding to “turn on/off” commands a few days ago, and just had a reply on my support case confirming that they’ve fixed a number of ‘minor glitches’ including the IFTTT one that I had. So if you were affected too - give it a shot now. ;p
