OH 2.3 Snap 1224 = clear cache + tmp
Don’t know why the upgrade script didn’t do it’s job, but without manually clearing the cache + tmp dirs, I got:
broken PaperUI (same as: OH2 Snapshot #922 (Cool New Look of PaperUI))
and the following in every OH2 service startup:
==> openhab.log <==
2018-03-08 10:52:27.344 [INFO ] [org.eclipse.smarthome.ui.paper      ] - FrameworkEvent INFO - org.eclipse.smarthome.ui.paper
org.osgi.framework.BundleException: The bundle class path entry "patch/" could not be found for the bundle "osgi.identity; type="osgi.bundle"; version:Version="0.10.0.201802191927"; osgi.identity="org.eclipse.smarthome.ui.paper"; singleton:="true""
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassPathEntry(ClasspathManager.java:174) [?:?]
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.buildClasspath(ClasspathManager.java:152) [?:?]
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.<init>(ClasspathManager.java:81) [?:?]
	at org.eclipse.osgi.internal.loader.EquinoxClassLoader.<init>(EquinoxClassLoader.java:57) [?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.createClassLoaderPrivledged(BundleLoader.java:293) [?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.getModuleClassLoader(BundleLoader.java:231) [?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findEntries(BundleLoader.java:796) [?:?]
	at org.eclipse.osgi.container.ModuleWiring.findEntries(ModuleWiring.java:289) [?:?]
	at org.eclipse.osgi.storage.ManifestLocalization.findResource(ManifestLocalization.java:200) [?:?]
	at org.eclipse.osgi.storage.ManifestLocalization.lookupResourceBundle(ManifestLocalization.java:131) [?:?]
	at org.eclipse.osgi.storage.ManifestLocalization.getResourceBundle(ManifestLocalization.java:102) [?:?]
	at org.eclipse.osgi.storage.ManifestLocalization.getHeaders(ManifestLocalization.java:63) [?:?]
	at org.eclipse.osgi.storage.BundleInfo$Generation.getHeaders(BundleInfo.java:124) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.privGetHeaders(EquinoxBundle.java:462) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.getHeaders(EquinoxBundle.java:457) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.getHeaders(EquinoxBundle.java:451) [?:?]
	at org.apache.aries.spifly.BaseActivator.addConsumerWeavingData(BaseActivator.java:96) [30:org.apache.aries.spifly.dynamic.bundle:1.0.2]
	at org.apache.aries.spifly.ConsumerBundleTrackerCustomizer.addingBundle(ConsumerBundleTrackerCustomizer.java:37) [30:org.apache.aries.spifly.dynamic.bundle:1.0.2]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469) [?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415) [?:?]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
	at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183) [?:?]
	at org.osgi.util.tracker.BundleTracker.open(BundleTracker.java:156) [?:?]
	at org.apache.aries.spifly.BaseActivator.start(BaseActivator.java:81) [30:org.apache.aries.spifly.dynamic.bundle:1.0.2]
	at org.apache.aries.spifly.dynamic.DynamicWeavingActivator.start(DynamicWeavingActivator.java:37) [30:org.apache.aries.spifly.dynamic.bundle:1.0.2]
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:774) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) [?:?]
	at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:767) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:724) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:932) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309) [?:?]
	at org.eclipse.osgi.container.Module.doStart(Module.java:581) [?:?]
	at org.eclipse.osgi.container.Module.start(Module.java:449) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
clearing cache & tmp made both issues go away and system is up and running properly now
case closed :slight_smile: just for reference: Clear the Cache
Windows or other?
Linux
I usually post my config (not this time :)). Check it out here: (Check) Rule transition help
I help manage the Windows scripts so I just wanted to know if there was an issue. Thanks.
