Just to be sure,i’m not able to show lights…
Rollershutters are okay,but lights are shown as equipment.
I haven’t tried to add tags,but for rollershutters are not needed so i suppose there’s no need to add it.
maybe are not implemented?
*Bagno" = Bathroom
“Tapparella” = Rollershutter
“Luce” = Light
Nic0205
(Nic0205)
September 9, 2022, 11:24am
282
Could you try to change "Luce Bagno"´s OpenState
to Switch
still doesn’t work. i’ve tried changing almost everything…maybe non-semantic tags could help?
hmerk
(Hans-Jörg Merk)
September 9, 2022, 11:42am
284
Your room “Bagno” needs to have the non semantic tag of the floor groupItem
Your lightswitch needs to be a Switch Item.
it has…in fact rollershutter widget works perfeclty…
hmerk
(Hans-Jörg Merk)
September 9, 2022, 12:05pm
286
Can I see the item configs for the lightbulb equipment and the light switch please.
sure, here you are:
sure i’m missing something…but better to understand now, so when the widget will be finished, we can write a full guide to help everyone
JustinG
(JustinG)
September 9, 2022, 12:59pm
288
Can you be more specific about what doesn’t work for you? For me it works on Chrome on Android and the Android OH app (and there are no pieces that should cause a safari specific issue as far as I know, but not a iOS expert).
You may have to change the height of the buttons’ container. I did not bother to make the code responsive to screen size because it was just a demo. But, the button container must be a fixed height or the buttons will wrap instead of hiding and I set the height to 2em because that was convenient but not for any other reason. Play with that height value to see if you get better results on the mobile screen.
hmerk
(Hans-Jörg Merk)
September 9, 2022, 1:03pm
289
Your Light does not have a semantic property “Light”, which would be shown as “relatesTo Property_Light”
already tried before, no way to make it work.
Nic0205
(Nic0205)
September 9, 2022, 1:20pm
291
In Safari on Desktop I could choose the responsive mode and then emulate a iOS Device…
With a height of 1em the wrapping / overlapping is just 2 lines but it’s still there. With 2em height it is 3 lines:
1em:
2em:
Setting to 0.1em does not effect:
hmerk
(Hans-Jörg Merk)
September 9, 2022, 1:25pm
292
I am out of clues now, as you modell looks the same like mine and the rollershutter works for both of us.
i see there is a Rollershutter widget that manage rollershutters, and this works, but i don’t see any Light special widget called.
could be this in any way the problem?
hmerk
(Hans-Jörg Merk)
September 9, 2022, 1:55pm
294
Ah, it is definitely in the code :
- component: widget:Cell_Light_Card_2
visible: '=vars.objVar.selectThing=="Lights" ? true : false'
header: =loop.switchItem.label + " (" + loop.switchItem.name + ")"
item_schalter: =loop.switchItem.name
Oh, spoiler, I am working on the next level
got it! easier then thought…you use widget:Cell_Light_Card_2 but on the forum there is the widget:Cell_Light_Card_1
so better to use 1 or 2? some post before i’ve linked widget:Cell_Light_Card_1…
pleasse, in next demo, can you replace all black colors to red? on dark theme texts are completely hide…also icons color…
hmerk
(Hans-Jörg Merk)
September 9, 2022, 2:22pm
296
Sorry, changed this between two versions…
I will post a new version in y couple of minutes with new feature…
hmerk
(Hans-Jörg Merk)
September 9, 2022, 2:33pm
297
As already spoilered, here is the next level.
Changes :
Added a newer lower block with special options for the home menu like security. It is only visible on home menu.
While changing rooms or floors, the thing selection gets cleared
Added a config parameter for the textcolor, default should be black if not set (next version should then set this automatically be themeOptions.
uid: main_widget
tags: []
props:
parameterGroups: []
parameters:
- name: textColor
label: Text color
type: TEXT
description: Set default color for Text
default: black
required: false
timestamp: Sep 9, 2022, 4:08:33 PM
component: f7-block
style:
display: flex
flex-direction: column
height: calc(100vh - var(--f7-toolbar-height) - var(--f7-safe-area-bottom) - var(--f7-navbar-height) - var(--f7-safe-area-top))
justify-content: space-between
margin: 0
padding: 0
widht: 100vh
slots:
default:
- component: f7-block
style:
flex: 0 0 auto
overflow: scroll
slots:
default:
- component: f7-segmented
style:
flex: 1 1 auto
slots:
default:
- component: oh-repeater
for: baseMenu
fragment: true
in:
- name: Home
- name: Floors
- name: Rooms
map: loop.baseMenu.name
sourceType: array
slots:
default:
- component: oh-button
action: variable
actionVariable: objVar
actionVariableValue:
selectSection: ="SECTION" + loop.baseMenu_idx
large: true
style:
color: '=vars.objVar.selectSection=="SECTION" + loop.baseMenu_idx ? textColor : "#8C8C8C"'
font-size: 30px
font-weight: 200
text-decoration: underline
text-decoration-color: '=vars.objVar.selectSection=="SECTION" + loop.baseMenu_idx ? "#F8BB00" : "transparent"'
text-underline-offset: 4px
text: =loop.baseMenu
- component: f7-row
style:
align-items: center
display: flex
flex-direction: row
flex-wrap: nowrap
height: 2em
width: 100%
visible: =!!(vars.objVar.selectSection == "SECTION0")
slots:
default:
action: variable
actionVariable: buttonIndexHome
actionVariableValue: =(vars.buttonIndexHome || 0) - 1
iconF7: chevron_left
style:
color: "#F8BB00"
flex: 0 0 auto
- component: f7-row
style:
display: flex
justify-content: center
overflow: hidden
slots:
default:
fetchMetadata: semantics,uiSemantics
for: menuButtonHome
fragment: true
itemTags: Home
map: loop.menuButtonHome_source[(((vars.buttonIndexHome || 0) % loop.menuButtonHome_source.length) + loop.menuButtonHome_source.length + loop.menuButtonHome_idx) % loop.menuButtonHome_source.length]
sourceType: itemsWithTags
slots:
default:
action: variable
actionVariable: floor
actionVariableValue: =loop.menuButtonHome.name
style:
color: '=vars.floor ==loop.menuButtonHome.name ? textColor : "#8C8C8C"'
flex: 0 0 auto
text-decoration-color: '=vars.floor ==loop.menuButtonHome.name ? "#F8BB00" : "transparent"'
text: =loop.menuButtonHome.label
action: variable
actionVariableValue: =(vars.buttonIndexHome || 0) + 1
iconF7: chevron_right
style:
color: "#F8BB00"
flex: 0 0 auto
- component: f7-row
style:
align-items: center
display: flex
flex-direction: row
flex-wrap: nowrap
height: 2em
width: 100%
visible: =!!(vars.objVar.selectSection == "SECTION1")
slots:
default:
action: variable
actionVariable: buttonIndexFloor
actionVariableValue: =(vars.buttonIndexFloor || 0) - 1
style:
color: "#F8BB00"
flex: 0 0 auto
- component: f7-row
style:
display: flex
overflow: hidden
slots:
default:
for: menuButtonFloor
fragment: true
itemTags: Floor
map: loop.menuButtonFloor_source[(((vars.buttonIndexFloor || 0) % loop.menuButtonFloor_source.length) + loop.menuButtonFloor_source.length + loop.menuButtonFloor_idx) % loop.menuButtonFloor_source.length]
slots:
default:
action: variable
actionVariableValue: =loop.menuButtonFloor.name
style:
color: '=vars.floor ==loop.menuButtonFloor.name ? textColor : "#8C8C8C"'
flex: 0 0 auto
text-decoration-color: '=vars.floor ==loop.menuButtonFloor.name ? "#F8BB00" : "transparent"'
text: =loop.menuButtonFloor.label
action: variable
actionVariableValue: =(vars.buttonIndexFloor || 0) + 1
style:
color: "#F8BB00"
flex: 0 0 auto
- component: f7-row
style:
align-items: center
display: flex
flex-direction: row
flex-wrap: nowrap
height: 2em
width: 100%
visible: =!!(vars.objVar.selectSection == "SECTION2")
slots:
default:
action: variable
actionVariable: buttonIndexRoom
actionVariableValue: =(vars.buttonIndexRoom || 0) - 1
style:
color: "#F8BB00"
flex: 0 0 auto
- component: f7-row
style:
display: flex
overflow: hidden
slots:
default:
for: menuButtonRoom
fragment: true
itemTags: =vars.floor
map: loop.menuButtonRoom_source[(((vars.buttonIndexRoom || 0) % loop.menuButtonRoom_source.length) + loop.menuButtonRoom_source.length + loop.menuButtonRoom_idx) % loop.menuButtonRoom_source.length]
slots:
default:
action: variable
actionVariable: room
actionVariableValue: =loop.menuButtonRoom.name
style:
color: '=vars.room ==loop.menuButtonRoom.name ? textColor : "#8C8C8C"'
flex: 0 0 auto
text-decoration-color: '=vars.room ==loop.menuButtonRoom.name ? "#F8BB00" : "transparent"'
text: =loop.menuButtonRoom.label
action: variable
actionVariableValue: =(vars.buttonIndexRoom || 0) + 1
style:
color: "#F8BB00"
flex: 0 0 auto
style:
flex: 1 1 auto
overflow: scroll
slots:
default:
fetchMetadata: semantics,metadata,listWidget
filter: loop.equipmentItem.metadata.semantics.config.hasLocation == vars.room
for: equipmentItem
itemTags: Blinds
slots:
default:
for: shutterItem
groupItem: =loop.equipmentItem.name
sourceType: itemsInGroup
filter: '(loop.shutterItem.type=="Rollershutter") ? true : false'
slots:
default:
- component: widget:Cell_Shutter_Card_1
visible: '=vars.objVar.selectThing=="Rollers" ? true : false'
header: =loop.shutterItem.label + " (" + loop.shutterItem.name + ")"
item: =loop.shutterItem.name
for: equipmentItem
itemTags: Lightbulb
slots:
default:
for: switchItem
filter: '(loop.switchItem.type=="Switch") ? true : false'
slots:
default:
- component: oh-label-card
title: I am Just a test for the upcoming security Menu
label: =vars.objVar.selectSection
footer: = vars.objVar.selectThing
visible: =!!(vars.objVar.selectSection + vars.objVar.selectThing == "SECTION0Security")
- component: widget:Temp_Control
style:
flex: 1 1 auto
overflow-y: auto
position: relative
visible: =!!(vars.objVar.selectSection + vars.selectDivision + vars.selectThing == "SECTION1DIV2Climate")
widgettrend: HeizungWohnzimmer_Temperature
style:
flex: 1 1 auto
overflow-y: auto
position: relative
visible: =!!(vars.objVar.selectSection + vars.selectDivision + vars.selectThing == "SECTION2DIV2Climate")
style:
flex: 1 1 auto
overflow-y: auto
position: relative
style:
flex: 1 1 auto
overflow-y: auto
position: relative
style:
flex: 1 1 auto
overflow-y: auto
position: relative
- component: oh-cell
icon: f7:lightbulb
style:
flex: 1 1 auto
overflow-y: auto
position: relative
subtitle: only for testing
title: I am a light card in the Bedroom
visible: =!!(vars.objVar.selectSection + vars.selectDivision + vars.selectThing == "SECTION2DIV2Lights")
icon: f7:lightbulb
style:
flex: 1 1 auto
overflow-y: auto
position: relative
title: I am a light card in the Home
- component: Label
style:
flex: 1 1 auto
overflow-y: auto
position: relative
text: =vars.objVar.selectSection + vars.floor
visible: =(vars.objVar.selectSection == "SECTION0")
style:
flex: 0 0 auto
overflow: scroll
slots:
default:
class:
- segmented-strong
style:
--f7-segmented-strong-between-buttons: 0px
--f7-segmented-strong-bg-color: transparent
--f7-segmented-strong-button-font-weight: 300
--f7-segmented-strong-button-hover-bg-color: rgba(255, 255, 255, 0.15)
--f7-segmented-strong-padding: 0px
slots:
default:
action: variable
selectSection: =vars.objVar.selectSection
selectThing: Security
class:
- padding-top-half
- display-flex
- flex-direction-column
fill: '=vars.objVar.selectThing=="Security" ? true : false'
icon-f7: shield_fill
iconColor: green
iconSize: 20
style:
--f7-button-bg-color: '=vars.objVar.selectThing=="Security" ? "#F8BB00" : "transparent"'
--f7-button-border-radius: 15px
--f7-button-hover-bg-color: '=vars.objVar.selectThing=="Security" ? "F8BB00" : "transparent"'
--f7-button-padding-horizontal: 0px
--f7-button-padding-vertical: 0px
--f7-button-text-color: '=vars.objVar.selectThing=="Security" ? "#6A6A6A" : "#8C8C8C"'
font-size: 12px
height: auto
text: Security
action: variable
selectThing: Scenes
class:
- padding-top-half
- display-flex
fill: '=vars.objVar.selectThing=="Scenes" ? true : false'
icon-f7: lightbulb
iconColor: textColor
iconSize: 20
style:
--f7-button-bg-color: '=vars.objVar.selectThing=="Scenes" ? "#F8BB00" : "transparent"'
--f7-button-hover-bg-color: '=vars.objVar.selectThing=="Scenes" ? "F8BB00" : "transparent"'
--f7-button-text-color: '=vars.objVar.selectThing=="Scenes" ? "#6A6A6A" : "#8C8C8C"'
font-size: 12px
height: auto
text: Scenes
action: variable
selectThing: Weather
class:
- padding-top-half
- display-flex
fill: '=vars.objVar.selectThing=="Weather" ? true : false'
icon-f7: cloud
iconSize: 20
style:
--f7-button-bg-color: '=vars.objVar.selectThing=="Weather" ? "#F8BB00" : "transparent"'
--f7-button-hover-bg-color: '=vars.objVar.selectThing=="Weather" ? "F8BB00" : "transparent"'
--f7-button-text-color: '=vars.objVar.selectThing=="Weather" ? "#6A6A6A" : "#8C8C8C"'
font-size: 12px
height: auto
text: Weather
action: variable
selectThing: HVAC
class:
- padding-top-half
- display-flex
fill: '=vars.objVar.selectThing=="HVAC" ? true : false'
icon-f7: flame
iconSize: 20
style:
--f7-button-bg-color: '=vars.objVar.selectThing=="HVAC" ? "#F8BB00" : "transparent"'
--f7-button-hover-bg-color: '=vars.objVar.selectThing=="HVAC" ? "F8BB00" : "transparent"'
--f7-button-text-color: '=vars.objVar.selectThing=="HVAC" ? "#6A6A6A" : "#8C8C8C"'
font-size: 12px
height: auto
text: HVAC
visible: =(vars.objVar.selectSection == "SECTION1" || vars.objVar.selectSection == "SECTION2")
style:
flex: 0 0 auto
overflow: scroll
slots:
default:
class:
- segmented-strong
style:
slots:
default:
action: variable
selectThing: Lights
class:
- padding-top-half
- display-flex
fill: '=vars.objVar.selectThing=="Lights" ? true : false'
icon-f7: lightbulb
iconSize: 20
style:
--f7-button-bg-color: '=vars.objVar.selectThing=="Lights" ? "#F8BB00" : "transparent"'
--f7-button-hover-bg-color: '=vars.objVar.selectThing=="Lights" ? "F8BB00" : "transparent"'
--f7-button-text-color: '=vars.objVar.selectThing=="Lights" ? "#6A6A6A" : "#8C8C8C"'
font-size: 12px
height: auto
text: Lights
action: variable
selectThing: Climate
class:
- padding-top-half
- display-flex
fill: '=vars.objVar.selectThing=="Climate" ? true : false'
icon-f7: snow
iconSize: 20
style:
--f7-button-bg-color: '=vars.objVar.selectThing=="Climate" ? "#F8BB00" : "transparent"'
--f7-button-hover-bg-color: '=vars.objVar.selectThing=="Climate" ? "F8BB00" : "transparent"'
--f7-button-text-color: '=vars.objVar.selectThing=="Climate" ? "#6A6A6A" : "#8C8C8C"'
font-size: 12px
height: auto
text: Climate
action: variable
selectThing: Rollers
class:
- padding-top-half
- display-flex
fill: '=vars.objVar.selectThing=="Rollers" ? true : false'
icon-f7: archivebox
iconSize: 20
style:
--f7-button-bg-color: '=vars.objVar.selectThing=="Rollers" ? "#F8BB00" : "transparent"'
--f7-button-hover-bg-color: '=vars.objVar.selectThing=="Rollers" ? "F8BB00" : "transparent"'
--f7-button-text-color: '=vars.objVar.selectThing=="Rollers" ? "#6A6A6A" : "#8C8C8C"'
font-size: 12px
height: auto
text: Rollers
JustinG
(JustinG)
September 9, 2022, 2:46pm
298
If you want this to be fully responsive, then you have to make sure that you are controlling the height of all of the elements involved. Here’s an outline of the structure:
- component: f7-row
- component: f7-row
Right now, only the outside f7-row container height is set… Try also setting the iconSize
on the two chevron buttons to 2em, also set the height on the inner f7-row to 2em. Probably couldn’t hurt to also set the repeater’s buttons’ height to 2em. The check to see if it is responsive.
In the end it may turn out that em is the wrong unit to use to maintain the full responsiveness you want in the final product. Play with other options; maybe you want vh or just plain old %.
W3Schools offers free online tutorials, references and exercises in all the major languages of the web. Covering popular subjects like HTML, CSS, JavaScript, Python, SQL, Java, and many, many more.
Just make sure you understand what the size of each piece of the structure is, because for the buttons that don’t fit to disappear they have to wrap above and below the edge of the f7-row that has the overflow: hidden
property.
maybe you will hate me…when the room name is selected, all other rooms disappear…
personally suggest to move HVAC to rooms next to climate, instead in Home tab…
hmerk
(Hans-Jörg Merk)
September 9, 2022, 2:59pm
300
Why should I hate you?
Your early feedback is highly appreciated to eliminate bugs. I will check this ….
