forgot to tell, but i tried to change also that into this:
actionCommand: =props.tArray[Math.min(props.tArray.join('').substring(0,props.tArray.join('').search(props.set_speed_item)).split('=').length,props.tArray.length-1)].split('=')[0]
it switch only from AUTO to SILENCE and from SILENCE to AUTO.
it won’t read other values…this issue seems to come only when i switch from
action: variable
to
action: command
could be this the issue?
JustinG
(JustinG)
August 5, 2022, 11:00pm
42
rubenfuser:
That represents only the name of the item. Not the item state. In order to get the item state, you must use items[props.set_speed_item].state
. So, that is what must go into the search method:
search(items[props.set_speed_item].state)
oh yes! from test seems to work perfectly! i will test it with real device.
thanks a lot for your support! i was near to set the right item state in code, but i missed “ ”. thanks a lot again!
Nic0205
(Nic0205)
August 8, 2022, 8:03am
44
Hey @rubenfuser ,
that looks really good.
One question:
Do you have an idea how get the footer colored?
When using the inspector of Chrome, the footer seems not to be at the bottom of the widget.
Could you have a look?
Cheers, Nic
Yes i achieved that. I will post the code:
uid: Conditioner Card v2
tags:
- MadeByEvil
props:
parameters:
- description: Small title on top of the card
label: Title
required: false
type: TEXT
- description: Icon on top of the card ( only f7 icons without "f7:" )
label: Icon
required: false
type: TEXT
- description: in rgba() or HEX or empty
label: Background Color
required: false
type: TEXT
- context: item
label: Current Temperature
required: false
type: TEXT
- context: item
label: Set Temperature
required: false
type: TEXT
- context: text
description: value=label
label: Array
required: false
type: TEXT
multiple: true
- context: item
label: Set Speed
required: false
type: TEXT
- context: item
label: Power ON/OFF
required: false
type: TEXT
- context: item
description: Modalità item
label: Modalità
required: false
type: TEXT
- context: item
description: Trendline item
label: Trendline
required: false
type: TEXT
parameterGroups:
- name: widgetAction
context: action
label: Action
description: Action to perform when the element is clicked
timestamp: Aug 6, 2022, 4:09:55 PM
component: f7-card
style:
noShadow: false
padding: 0px
box-shadow: 5px 5px 10px 1px rgba(0,0,0,0.1)
height: 200px
margin-left: 5px
margin-right: 5px
slots:
content:
- component: f7-block
style:
position: absolute
top: -10px
left: 10px
flex-direction: row
display: flex
slots:
default:
- component: f7-icon
f7: =props.icon
style:
margin-right: 10px
visible: "=props.icon ? true : false"
- component: Label
text: "=props.title ? props.title : ''"
style:
font-size: 12px
margin-top: 0px
style:
position: absolute
bottom: -20px
left: 16px
flex-direction: row
slots: {}
- component: Label
text: "=items[props.temp_item].displayState ? items[props.temp_item].displayState : items[props.temp_item].state"
style:
font-size: 20px
font-weight: 400
margin-left: 0px
margin-top: 10px
color: '=items[props.temp_item].state >= "22" ? "red" : items[props.temp_item].state <= "20" ? "blue" :"white"'
- component: oh-button
visible: '=items[props.heating_item].displayState == "Pompa di calore" ? "true" : items[props.heating_item].displayState == "Condizionatore" ? "true" : "false"'
iconColor: '=items[props.heating_item].displayState == "Deumidificatore" && items[props.power].state == "ON" ? "yellow" : items[props.heating_item].displayState == "Pompa di calore" && items[props.power].state == "ON" ? "red" : items[props.heating_item].displayState == "Condizionatore" && items[props.power].state == "ON" ? "blue" : items[props.heating_item].displayState == "Ventola" && items[props.power].state == "ON" ? "orange" : "gray"'
iconF7: arrow_up_circle
iconSize: 35
action: command
actionItem: =props.set_temp_item
actionCommand: =Number(items[props.set_temp_item].state.split(' ')[0]) + 0.5
style:
position: absolute
top: 40px
right: 0px
height: 33px
background: transparent
z-index: 98
iconF7: arrow_down_circle
iconSize: 35
action: command
actionCommand: =Number(items[props.set_temp_item].state.split(' ')[0]) - 0.5
style:
position: absolute
top: 104px
right: 0px
height: 33px
z-index: 98
- component: Label
text: '=items[props.set_temp_item].state == "UNDEF" ? " " : items[props.set_temp_item].state'
style:
font-size: 12px
position: absolute
right: 8px
top: 80px
visible: "=props.set_speed_item ? true : false"
iconSize: 35
action: command
actionItem: =props.set_speed_item
actionCommand: =props.tArray[Math.max(props.tArray.join('').substring(0,props.tArray.join('').search(items[props.set_speed_item].state)).split('=').length-2,0)].split('=')[0]
style:
position: absolute
top: 40px
right: 40px
height: 35px
z-index: 98
iconSize: 35
action: command
actionCommand: =props.tArray[Math.min(props.tArray.join('').substring(0,props.tArray.join('').search(items[props.set_speed_item].state)).split('=').length,props.tArray.length-1)].split('=')[0]
style:
position: absolute
top: 104px
right: 40px
height: 35px
z-index: 98
- component: Label
text: "=((items[props.set_speed_item].state) ? props.tArray[props.tArray.join('').substring(0,props.tArray.join('').search(items[props.set_speed_item].state)).split('=').length-1].split('=')[1] : 'Push a button')"
style:
color: red
font-size: 12px
position: absolute
right: 58px
top: 80px
style:
position: absolute
top: 50px
left: 15px
width: "=props.set_temp_item ? 'calc(100% - 55px)' : '100%' "
height: 120px
slots:
default:
- component: oh-trend
trendItem: =props.widgettrend
trendGradient:
- "#aa2b1d"
- "#cc561e"
- "#ef8d32"
- "#beca5c"
style:
--f7-theme-color-bg-color: transparent
background: var(--f7-theme-color-bg-color)
filter: opacity(50%)
position: absolute
width: 80%
height: 100%
top: 0px
left: 15px
z-index: 98
- component: oh-toggle
item: =props.power
color: '=items[props.heating_item].displayState == "Deumidificatore" && items[props.power].state == "ON" ? "yellow" : items[props.heating_item].displayState == "Pompa di calore" && items[props.power].state == "ON" ? "red" : items[props.heating_item].displayState == "Condizionatore" && items[props.power].state == "ON" ? "blue" : items[props.heating_item].displayState == "Ventola" && items[props.power].state == "ON" ? "orange" : "black"'
style:
--f7-toggle-height: 20px
--f7-toggle-width: 40px
font-size: 100%
top: 115px
z-index: 98
iconColor: '=items[props.heating_item].displayState == "Condizionatore" && items[props.power].state == "ON" ? "blue" : "black"'
iconF7: snow
iconSize: 25
action: command
actionItem: =props.heating_item
actionCommand: COOL
style:
position: absolute
top: 165px
left: 25%
height: 35px
z-index: 98
iconColor: '=items[props.heating_item].displayState == "Pompa di calore" && items[props.power].state == "ON" ? "red" : "black"'
iconF7: flame
iconSize: 20
action: command
actionCommand: HEAT
style:
position: absolute
top: 165px
left: 45%
height: 35px
z-index: 98
iconColor: '=items[props.heating_item].displayState == "Deumidificatore" && items[props.power].state == "ON" ? "yellow" : "black"'
iconF7: drop
iconSize: 20
action: command
actionCommand: DEHUMIDIFIER
style:
position: absolute
top: 165px
left: 65%
height: 35px
z-index: 98
iconColor: '=items[props.heating_item].displayState == "Ventola" && items[props.power].state == "ON" ? "orange" : "black"'
iconF7: wind
iconSize: 20
action: command
actionCommand: FAN
style:
position: absolute
top: 165px
left: 85%
height: 35px
z-index: 98
- component: f7-card-footer
style:
top: 84px
left: -16px
width: 110%
background: '=items[props.heating_item].displayState == "Deumidificatore" && items[props.power].state == "ON" ? "#ffffb3" : items[props.heating_item].displayState == "Pompa di calore" && items[props.power].state == "ON" ? "#ffc2b3" : items[props.heating_item].displayState == "Condizionatore" && items[props.power].state == "ON" ? "#b3b3ff" : items[props.heating_item].displayState == "Ventola" && items[props.power].state == "ON" ? "#ffd9b3" : "#3F3F3F"'
border-radius: 0 0 var(--f7-card-expandable-border-radius) var(--f7-card-expandable-border-radius)
This is the widget but not completely finished,but you will find what you need for footer
Nic0205
(Nic0205)
August 11, 2022, 7:12pm
46
Thank you - I played a bit with the code and now it looks almost like Dimitris template.
I tried to get it as responsive as it I could…
@Dimitris : Would you please give it another try?
uid: Temp_Control
tags: []
props:
parameters:
label: Title
required: false
type: TEXT
- context: item
label: Actual Temperature for Trendline
required: false
type: TEXT
- context: item
label: Set Temperature - right arrows
required: false
type: TEXT
- context: text
label: List for left array
required: false
type: TEXT
multiple: true
- context: item
label: Set Speedc-cleft arrows
required: false
type: TEXT
- context: item
label: Power ON/OFF
required: false
type: TEXT
- context: item
description: Item for selecting the mode
label: Mode item
required: false
type: TEXT
- context: item
label: Trendline
required: false
type: TEXT
timestamp: Aug 10, 2022, 9:56:59 PM
component: f7-card
noShadow: false
padding: false
style:
padding: 0px
box-shadow: 5px 5px 15px 1px rgba(0,0,0,0.05)
--f7-card-header-border-color: transparent
min-width: 90%
stylesheet: >
.card-header:after {
display: none;
slots:
default:
- component: f7-card-header
style:
--f7-card-header-border-color: none
slots:
default:
- component: Label
text: =props.title
style:
font-size: 15px
font-weight: 250
- component: f7-card-content
config: {}
slots:
default:
- component: Label
style:
font-size: 20px
font-weight: 400
- component: Label
text: space
style:
font-size: 20px
font-weight: 400
color: transparent
iconSize: 35
action: command
style:
position: absolute
bottom: 0%
right: 10%
padding-right: 2%
padding-left: 4%
margin-right: 6%
margin-bottom: 1%
height: 35px
z-index: 98
color: grey
iconSize: 35
action: command
style:
position: absolute
top: 0%
right: 10%
height: 35px
padding-right: 2%
padding-left: 4%
margin-right: 6%
margin-bottom: 1%
z-index: 98
color: "=vars.footercolor === 'lightblue' ? 'lightblue' : =vars.footercolor === 'red' ? 'red' : 'gray'"
- component: Label
text: =vars.footercolor
style:
font-size: 12px
position: absolute
right: 14%
top: 40%
iconSize: 35
action: command
style:
position: absolute
top: 0%
right: 0%
height: 35px
z-index: 98
padding-right: 0%
padding-left: 4%
margin-right: 3%
margin-bottom: 1%
iconSize: 35
action: command
style:
position: absolute
bottom: 0%
right: 0%
height: 35px
padding-right: 2%
padding-left: 4%
margin: 1%
z-index: 98
- component: Label
text: eee
style:
color: red
font-size: 12px
position: absolute
right: 3.5%
top: 40%
style:
position: absolute
top: 50px
left: 15px
height: 120px
slots:
default:
trendGradient:
- teal
style:
position: absolute
width: 80%
height: 100%
bottom: 40%
z-index: 98
style:
background: "=(vars.footercolor) ? 'rgba(var(--f7-color-' + vars.footercolor + '-rgb), 0.1)' : 'var(--f7-bars-bg-color)'"
slots:
default:
color: =vars.footercolor || 'gray'
style:
--f7-toggle-height: 25px
--f7-toggle-width: 50px
style:
width: 130px
padding: 0
display: flex
justify-content: space-between
slots:
default:
- component: oh-link
iconF7: snow
iconSize: 30
height: 30px
width: 30px
color: "=vars.footercolor === 'lightblue' ? 'lightblue' : 'gray'"
action: variable
actionVariable: footercolor
actionVariableValue: lightblue
iconF7: flame
iconSize: 30
height: 30px
width: 30px
color: "=vars.footercolor === 'red' ? 'red' : 'gray'"
action: variable
actionVariableValue: red
iconF7: wind
iconSize: 30
height: 30px
width: 30px
color: "=vars.footercolor === 'yellow' ? 'yellow' : 'gray'"
action: variable
actionVariableValue: yellow
Nic0205
(Nic0205)
August 11, 2022, 7:21pm
47
Hey @Aaron2 ,
Did you made any efforts? I postet the last version of the climate widget just a few minutes ago.
Dimitris
(Dimitris Baltas)
August 12, 2022, 1:48pm
48
Im still in vacations
I’m sending you JUST a draft. Still, long road. Hope you liked.
Cheers
PS. Yes, I’m working on it!!
HOMEUI.pdf (592.7 KB)
Widgets.pdf (417.5 KB)
Nic0205
(Nic0205)
August 12, 2022, 4:31pm
49
Hey there and hey @ysc ,
@Dimitris draft for an UI looks - at least for me - really nice.
Is there a chance to implement such an UI? In my opinion this UI contains of 3 nested TAB-Pages.
I tried to create such a page - but it seems, that nested tab pages are not possible.
Do you have a hint for me?
Aaron2
(Aaron2)
August 13, 2022, 9:49am
50
Hi @Nic0205 ,
Unfortunately not, I was limited on the time to spend last weeks. Apologies!
I will start a new topic later this tonight when I’m back home
I really like the designs and work created, is there any idea on the visibility of the tabs? Maybe we should follow an approach with a Minimal Viable Product, that is relatively simple to create based on the current possibilites. After we have that in production add some more complexity?
Looking forward to hear you idea’s
I will follow this project,and i will test it on iphone device and ipad to report if everything is shown properly!
Nic0205
(Nic0205)
August 14, 2022, 6:38pm
52
Hi @Aaron2 ,
I would prefer this more or less agile approach (MVP), too.
I tried several things, but nested tabs seem not to be possible.
Did you (or anybody here with more coding experience than me) made any progress on this?
JustinG
(JustinG)
August 14, 2022, 6:57pm
53
Nested tabs are possible with the widget system, but it is very cumbersome and awkward and I’m not sure I’d really recommend it. It looks something like this:
uid: demo:nested_tabs
props:
parameters: []
parameterGroups: []
component: f7-page
style:
padding: 0
tabs: true
slots:
fixed:
- component: f7-tabs
slots:
default:
- component: f7-page-content
style:
padding-top: 38px
tab: true
tabActive: true
slots:
default:
- component: f7-toolbar
position: bottom
tabbar: true
slots:
default:
- component: f7-link
tabLink: "#tab3"
text: "Tab A(1)"
tabLink: "#tab4"
text: "Tab B(1)"
style:
padding-top: 0
slots:
default:
- component: f7-tab
slots:
default:
- component: oh-label-card
title: Content for Tab 1-A
- component: f7-tab
slots:
default:
title: Content for Tab 1-B
style:
padding-top: 38px
tab: true
slots:
default:
position: bottom
tabbar: true
slots:
default:
tabLink: "#tab5"
text: "Tab A(2)"
tabLink: "#tab6"
text: "Tab B(2)"
style:
padding-top: 0
slots:
default:
- component: f7-tab
slots:
default:
title: Content for Tab 2-A
- component: f7-tab
slots:
default:
title: Content for Tab 2-B
bottom: true
style:
top: 0
tabbar: true
slots:
default:
tabLink: "#tab1"
tabLinkActive: true
text: "Tab #1"
tabLink: "#tab2"
text: "Tab #2"
In this case you might find that something more along the lines several different segmental buttons setting variables which determine the visibility of different content blocks would be more effective. This is essentially the same thing as tabs but will give you a little more control over both appearance and function.
Nic0205
(Nic0205)
August 14, 2022, 8:04pm
54
Hey @JustinG ,
looks really weird - but perhaps we could give it a try.
One probably stupid question:
Could I somehow use custom components instead of the f7-components?
For example:
slots:
default:
- component: Temp_control
Dimitris
(Dimitris Baltas)
August 14, 2022, 8:15pm
55
Some small progress -I’m just sharing
HOMEUIv2.pdf (201.9 KB)
Cheers
JustinG
(JustinG)
August 14, 2022, 9:16pm
56
Yeah, it does. And it is just somewhat difficult to keep track of. There’s almost certainly a better solution for your use case, I just wanted to make sure you knew this option is technically feasible.
Yep. Within each f7-tab
component (where I put the label cards) you can build whatever you like.
Nic0205
(Nic0205)
August 15, 2022, 4:55am
57
Yeah - but is it possible to call a custom-widget in a custom-widget?
For example I created a custom-widget with the uid “Temp_control”.
If I understand it right, I have to put the whole code in the f7-Tab-component. That would end up in a really long code…
What I would to achieve is to call the custom-widget temp_control like any other oh- or f7-component.
Is it possible to call a custom-widget in an other custom-widget?
Dimitris
(Dimitris Baltas)
August 15, 2022, 1:27pm
58
…progress for widgets:
Widgetsv2.pdf (493.0 KB).
@Nic0205 @ysc @JustinG Now guys -in this very early design stage- i need your feedback: feasibility, directions, rethinking?
JustinG
(JustinG)
August 15, 2022, 2:35pm
59
Ah, sorry for misunderstanding. Yes, it’s possible. In the component
line just add widget:
followed by the uid of your widget. For example, I have a widget that displays different other custom widgets depending on the time of day. To show the dinner time custom widget (uid - tod:dinner_page
), I put:
- component: widget:tod:dinner_page
Nic0205
(Nic0205)
August 15, 2022, 3:00pm
60
Cool - it works!
Is there also a chance to define the props of the “nested” custom-widget somewhere?
Once again: Thank you for helping us newbies ;.)
