[OH3] New Binding - Speedtest
The binding uploaded to market place received some additional improvements and incompatible changes:
  • rebased to openHAB 3.4.0 Snaphot
  • channel names in lowerCamelCase
  • introduced UOM
  • improved Docu
When I try to install speedtest, as per Ookla’s instructions for Debian (rpi 4), I get errors:
openhabian@openhabian:~ $ sudo apt-get install speedtest
Reading package lists... Done
Building dependency tree... Done
E: Unable to locate package speedtest
The previous steps were all successful.
Please advise. Thx!
Solved!
I downloaded the Linux armhf binary from the bottom of the Ookla instructions page, ran speedtest once to accept the T&Cs, stop/started the speedtest binding and it’s now Online!
I am getting the same result
The repository is setup! You can now install packages.
Speedtest Binding is not working for me. The Thing stays UNKNOWN.
Please help
did you run sudo apt update before running sudo apt-get install speedtest
according to the error message the package was not found. Reason for this might be that the package indexes were not updated locally.
openhabian@openhabian:~ $ sudo apt update
Get:1 http://davesteele.github.io/comitup/repo comitup InRelease [4,659 B]
Get:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
Get:3 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
Hit:5 https://repos.influxdata.com/debian bullseye InRelease
Ign:6 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye InRelease
Hit:7 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
Err:8 https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release
  404  Not Found [IP: 2600:1f1c:2e5:6900:b931:927:7098:932c 443]
Get:9 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [308 kB]
E: The repository 'https://packagecloud.io/ookla/speedtest-cli/raspbian bullseye Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
openhabian@openhabian:~ $ curl -s https://packagecloud.io/install/repositories/ookla/speedtest-cli/script.deb.sh | sudo bash
Detected operating system as raspbian/bullseye.
Checking for curl...
Detected curl...
Checking for gpg...
Detected gpg...
Detected apt version as 2.2.4
Running apt-get update... done.
Installing apt-transport-https... done.
Installing /etc/apt/sources.list.d/ookla_speedtest-cli.list...done.
Importing packagecloud gpg key... Packagecloud gpg key imported to /etc/apt/keyrings/ookla_speedtest-cli-archive-keyring.gpg
done.
I am having this problem as well
Just did a test on a Debian Bullseye VM - not a Pi and it worked.
Folder /var/lib/apt/lists/ should contain two files. Their names start with packagecloud.io_ookla_speedtest-cli_debian_dists_bullseye_* .
One of the files is called packagecloud.io_ookla_speedtest-cli_debian_dists_bullseye_main_binary-amd64_Packages on the VM - the Pi version has a different name.
That file contains the information about where to find the speedtest package on the remote server:
pool/bullseye/main/s/speedtest/speedtest_1.2.0.84-1.ea6b6773cf_amd64.deb
Is this information available in your case, too ( will look slightly different for a Pi ) ?
I have nearly the same setup. DS918+, docker. But openHAB 3.3 and it is unable to find the speedtest executable.
I am running the binding installed through the market place.
Trying this I end up in an error command not found
I was able to run the speedtest using a SSH session.
  • Speedtest is placed in /usr/bin/speedtest - or do I need a folder /usr/bin/speedtest where I place the speedtest file into?
  • access rights are pretty “forgiving”
  • execPath from the binding is empty execPath: ""
How can docker access those folders? Do I need to mount something?
Also I am not 100% sure which user is used to startup my OH container. I accepted the licence aggreement now with user admin, openhab and docker.
since speedtest version 3.4 I install under openhab 3.3 as follows:
Copy org.openhab.binding.speedtest-3.4.0-SNAPSHOT.jar to openhab/addons
Copy the Speedtest program to /usr/bin
Adding to Docker Compose:
version: '2.2'
services:
  openhab3:
    image: "openhab/openhab:3.3.0"
    container_name: openhab3
    restart: always
    network_mode: host
    volumes:
      - "/volume1/docker/localtime:/etc/localtime:ro"
      - "/etc/TZ:/etc/timezone:ro"
      - "/volume1/docker/openhab/addons:/openhab/addons"
      - "/volume1/docker/openhab/conf:/openhab/conf"
      - "/volume1/docker/openhab/userdata:/openhab/userdata"
      - "/volume1/docker/openhab/speedtest:/usr/bin/speedtest" // <- <- <- <- <- <- Add this entry to the file
    environment:
      OPENHAB_HTTP_PORT: "xxxxx"
      OPENHAB_HTTPS_PORT: "yyyyy"
      CRYPTO_POLICY: "unlimited"
      EXTRA_JAVA_OPTS: "-Xms1024m -Xmx2048m -Duser.timezone=${TZ}"
      USER_ID: "9001"
      GROUP_ID: "9001"
      LC_ALL: "de_DE.UTF-8"
      LANG: "de_DE.UTF-8"
      LANGUAGE: "de_DE.UTF-8"
  frontail-openhab:
    container_name: "frontail-openhab"
    restart: unless-stopped
    image: "welteki/frontail-openhab"
    ports:
      - "9001:9001"
    volumes:
      - "/volume1/docker/openhab/userdata/logs:/openhab/userdata/logs:ro"
After that everything should work again.
root@DS918:/usr/bin# ll -s speedtest
2560 -rwx------ 1 root root 2613400 Nov  6 04:24 speedtest
Works like a charm. I was unable to see any effect placing the speedtest jar in openhab/addons. The thing was missing it’s handler.
So I reinstalled the Ookla speedtest binding through Marketplace again and added the mounting of the speedtest file as described by you using the standard Docker GUI.
This solved my issue:
In case a message appears the next time you restart the container, I recommend moving the “speedtest” file to /volume1/docker/openhab/.
Sorry, I have same issue of @DivineJimmi and there not two files indicated by @Wolfgang_S , how I can to install speedtest on RPI Raspbian GNU/Linux 11 (bullseye)?
Download application from its site:
https://install.speedtest.net/app/cli/ookla-speedtest-1.2.0-linux-armhf.tgz
and copy extracted binary executable file in: /usr/bin/speedtest
