I have problem with configuration of Qubino ZMNHXD1 power meter. Settings on GUI are not ok and can’t be changed:
In “code” I see this:
UID: zwave:device:0b64393fce:node32
label: ZWave_Floor2_Kitchen_PowerMeter_1
thingTypeUID: zwave:qubino_zmnhxd_00_000
configuration:
config_43_2: 600
config_42_2: 600
config_101_1: 0
config_40_1: 50
config_100_1: 0
config_7_1: 0
config_112_2: 0
group_1:
- controller
binding_pollperiod: 60
node_id: 32
config_106_2: 0
bridgeUID: zwave:serial_zstick:0b64393fce
If I try change it to this manualy in code and save:
configuration:
config_43_2: 60
config_42_2: 3600
config_101_1: 0
config_40_1: 1
config_100_1: 0
config_7_1: 0
config_112_2: 0
group_1:
- controller
node_id: 32
config_106_2: 0
It do not save data and in log repeat this lines many times for arround 2-3 minutes:
2020-11-22 12:46:38.930 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising Thing Node…
2020-11-22 12:46:38.930 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_powerfactor for DecimalType
2020-11-22 12:46:38.930 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_powerfactor for DecimalType
2020-11-22 12:46:38.931 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_watts for DecimalType
2020-11-22 12:46:38.931 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_watts for DecimalType
2020-11-22 12:46:38.931 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_kwh for DecimalType
2020-11-22 12:46:38.931 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_kwh for DecimalType
2020-11-22 12:46:38.931 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_kvah for DecimalType
2020-11-22 12:46:38.931 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_kvah for DecimalType
2020-11-22 12:46:38.931 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_powerfactor1 for DecimalType
2020-11-22 12:46:38.931 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_powerfactor1 for DecimalType
2020-11-22 12:46:38.932 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_powerfactor1 for DecimalType
2020-11-22 12:46:38.932 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_watts1 for DecimalType
2020-11-22 12:46:38.932 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_watts1 for DecimalType
2020-11-22 12:46:38.932 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_kwh1 for DecimalType
2020-11-22 12:46:38.932 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_kwh1 for DecimalType
2020-11-22 12:46:38.932 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_kvah1 for DecimalType
2020-11-22 12:46:38.932 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_kvah1 for DecimalType
2020-11-22 12:46:38.933 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_powerfactor2 for DecimalType
2020-11-22 12:46:38.933 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_powerfactor2 for DecimalType
2020-11-22 12:46:38.933 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_current2 for DecimalType
2020-11-22 12:46:38.933 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_current2 for DecimalType
2020-11-22 12:46:38.933 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_watts2 for DecimalType
2020-11-22 12:46:38.933 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_watts2 for DecimalType
2020-11-22 12:46:38.933 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_voltage2 for DecimalType
2020-11-22 12:46:38.933 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_voltage2 for DecimalType
2020-11-22 12:46:38.933 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_powerfactor3 for DecimalType
2020-11-22 12:46:38.933 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_powerfactor3 for DecimalType
2020-11-22 12:46:38.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_powerfactor3 for DecimalType
2020-11-22 12:46:38.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_current3 for DecimalType
2020-11-22 12:46:38.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_current3 for DecimalType
2020-11-22 12:46:38.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_watts3 for DecimalType
2020-11-22 12:46:38.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_watts3 for DecimalType
2020-11-22 12:46:38.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_voltage3 for DecimalType
2020-11-22 12:46:38.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_voltage3 for DecimalType
2020-11-22 12:46:38.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_powerfactor4 for DecimalType
2020-11-22 12:46:38.934 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_powerfactor4 for DecimalType
2020-11-22 12:46:38.935 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_current4 for DecimalType
2020-11-22 12:46:38.935 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_current4 for DecimalType
2020-11-22 12:46:38.935 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_watts4 for DecimalType
2020-11-22 12:46:38.935 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_watts4 for DecimalType
2020-11-22 12:46:38.935 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising cmd channel zwave:device:0b64393fce:node32:meter_voltage4 for DecimalType
2020-11-22 12:46:38.935 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Initialising state channel zwave:device:0b64393fce:node32:meter_voltage4 for DecimalType
2020-11-22 12:46:38.936 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Polling initialised at 60 seconds - start in 35880 milliseconds.
2020-11-22 12:46:38.936 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Device initialisation complete.
2020-11-22 12:46:39.013 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Handler disposed. Unregistering listener.
2020-11-22 12:46:39.017 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 32: Serializing to file /var/lib/openhab/zwave/network_f804f9b3__node_32.xml
2020-11-22 12:46:39.020 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:0b64393fce:node32.
2020-11-22 12:46:39.020 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Controller status changed to ONLINE.
2020-11-22 12:46:39.021 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Controller is ONLINE. Starting device initialisation.
2020-11-22 12:46:39.022 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Updating node properties.
2020-11-22 12:46:39.023 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Updating node properties. MAN=345
2020-11-22 12:46:39.023 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Updating node properties. MAN=345. SET. Was 345
2020-11-22 12:46:39.023 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Properties synchronised
2020-11-22 12:46:39.023 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Update ASSOCIATION group_ZWaveAssociationGroup [index=1, name=null, profile1=null, profile2=null, associations=[node_1_1]]: Adding Controller (node_1_1)
2020-11-22 12:46:39.023 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 32: Configuration synchronised
2020-11-22 12:46:39.025 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
Node XML file:
network_f804f9b3__node_32.xml (22.5 KB)
Issue is also that device sometime stuck/freeze and stop updating power usage so I need restart it…
Thanks for any help.
