AGH
(AGH)
March 11, 2021, 8:15pm
1
Openhab running on Raspi 4 under Buster. After making an update to the new build I get this error:
021-03-11 21:11:28.070 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-tr064, openhab-persistence-mapdb, openhab-binding-avmfritz, openhab-ui-habpanel, openhab-binding-mqtt, openhab-transformation-map, openhab-binding-ipcamera, openhab-binding-telegram, openhab-transformation-xslt, openhab-binding-homematic, openhab-transformation-exec, openhab-transformation-jinja, openhab-transformation-scale, openhab-binding-icalendar, openhab-persistence-jdbc-mariadb, openhab-binding-mpd, openhab-transformation-javascript, openhab-transformation-regex, openhab-transformation-jsonpath, openhab-automation-groovyscripting, openhab-transformation-xpath, openhab-automation-jythonscripting, openhab-ui-basic, openhab-binding-ntp, openhab-binding-astro, openhab-binding-knx': Error:
Error downloading mvn:org.mariadb.jdbc/mariadb-java-client/1.4.6
Nothing runs.
ohb1138
(Justus Reich)
March 11, 2021, 8:23pm
2
You are not the only one:
I’m using the latest docker image openhab/openhab:2.5.12-debian and I can no longer start my openhab instance because the downloading of mvn:mysql/mysql-connector-java/8.0.13 fails.
I always start with a “clean install” and add my config files some seconds later, so no cache, etc. involved. Internet connectivity is working.
This is the exception:
org.apache.karaf.features.internal.util.MultiException: Error:
Error downloading mvn:mysql/mysql-connector-java/8.0.13
at org.apache.karaf.feature…
and
I am running OH 2.5.12 Release Build in a docker container on my Synology NAS. It has been running ok for weeks. I have today rebooted my container during the day as is shut it down to test an OH 3.1 container. After starting up the OH 2.5.12 container again I receive the following error:
20:08:11.387 [ERROR] [.core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-hue, openhab-binding-exec, openhab-binding-km200, openhab-binding-mail, openhab-transformation-javascript,…
AGH
(AGH)
March 11, 2021, 8:52pm
3
also a downgrading to openHAB 3.0.1 Release Build will not work.
The same error only the version changed to /1.3.5
I got maven errors for following Plugin: Ho can I disable it?
Error downloading mvn:org.openhab.addons.bundles/org.openhab.binding.tankerkoenig/3.1.0-SNAPSHOT
Thx Alf
Getting errors on installing new bindings
ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-ntp': Error:
Error downloading mvn:org.openhab.addons.bundles/org.openhab.binding.ntp/3.1.0-SNAPSHOT
cat /etc/openhab/services/addons.cfg
remote = false
apt-get install openhab-addons
systemctl restart openhab
It works, but not with repo. Still wait until repo is fixed. Then reenable maven.
nyholm
(Robert Nyholm)
May 6, 2021, 5:56pm
8
I’m running OH3.0.1 on Windows 10 and am also getting
Error downloading mvn:org.openhab.addons.bundles/org.openhab.binding.ntp/3.0.1
I appear to have the same problem as you. Have you found the remedy to yours?
From adfderheld, it appears that I need to add remote = false to the addons.cfg file even though the OH documentation states
The binding has no configuration options, all configuration is done at Thing level.
nyholm
(Robert Nyholm)
May 6, 2021, 6:00pm
9
I looked into my addons.cfg and found the following. My problem must be different than yours.
# Access Remote Add-on Repository
# Defines whether the remote openHAB add-on repository should be used for browsing and installing add-ons. (default is true)
wborn
(Wouter Born)
May 6, 2021, 6:11pm
10
You seem to have not read or acted upon this announcement @nyholm
Dear all,
We have today published the openHAB patch release 3.0.2. It brings a couple of bug fixes for our stable release. You can find the details in the release notes .
Even if you might not need these fixes for your setup, we highly recommend to install this patch, since it takes care of adapting the update and download mechanisms to no longer point to Bintray, but to Artifactory. This is necessary, since Bintray services shut down on May 1st, 2021 , which means that add-ons cannot be dynamic…
nyholm
(Robert Nyholm)
May 6, 2021, 9:03pm
11
Thank you, Thank you. I updated to OH3.0.2 and all is well.
