Hi, is there a way to allow a thermostat setpoint below 50 deg F? I have a thermostat in the garage and I set it at 42 degrees when I’m not out there. In the Google Assistant app, it seems the lowest I can go is 50.
At least there might be a way to set this:
thermostatTemperatureRange
Object. Optional. Contains two float values that indicate the supported minimum and maximum temperature range for this device (in degrees Celsius):
minThresholdCelsius
maxThresholdCelsius
I will try to add this as a metadata config option.
But for now, you can not do anything about it. The “off” mode setting might do the trick.
I also have the problem that my thermostat worked OK for months and now I can not set the target temperature anymore, because of “unknown mode”. Tried with voice command to Nest Hub and also with the Android Home app.
I do not know if that problem started with openHAB 2.5.0 or with a server side update to myopenhab.
There is nothing in openhab.log and nothing in events.log.
BTW, it does display the current and target temperature and mode correctly in the Home app.
Group WohnzimmerHeizung "Wohnzimmer Heizung" [ "Thermostat", "Celsius" ]
"members": [
"link": "http://192.168.0.7:8090/rest/items/WohnzimmerHeizungModus",
"state": "heat",
"type": "String",
"name": "WohnzimmerHeizungModus",
"label": "Wohnzimmer Heizung Modus",
"tags": [
"HeatingCoolingMode"
"groupNames": [
"WohnzimmerHeizung",
"Persist"
"link": "http://192.168.0.7:8090/rest/items/HM_HeizungWohnzimmer_1_ActualTemperature",
"state": "23.50",
"stateDescription": {
"minimum": -3276.8,
"maximum": 3276.7,
"step": 0.1,
"pattern": "%.0f",
"readOnly": true,
"options": []
"type": "Number:Dimensionless",
"name": "HM_HeizungWohnzimmer_1_ActualTemperature",
"label": "HM_HeizungWohnzimmer_ActualTemperature",
"category": "Temperature",
"tags": [
"CurrentTemperature"
"groupNames": [
"WohnzimmerHeizung"
"link": "http://192.168.0.7:8090/rest/items/HM_HeizungWohnzimmer_1_SetPointTemperature",
"state": "24.00 °C",
"minimum": 4.5,
"maximum": 30.5,
"step": 0.1,
"pattern": "%.2f %unit%",
"readOnly": false,
"options": []
"type": "Number:Temperature",
"name": "HM_HeizungWohnzimmer_1_SetPointTemperature",
"label": "HM_HeizungWohnzimmer_SetPointTemperature",
"tags": [
"TargetTemperature"
"groupNames": [
"WohnzimmerHeizung"
"link": "http://192.168.0.7:8090/rest/items/HM_HeizungWohnzimmer_1_Humidity",
"state": "42",
"minimum": 0,
"maximum": 100,
"step": 1,
"pattern": "%.0f",
"readOnly": true,
"options": []
"name": "HM_HeizungWohnzimmer_1_Humidity",
"label": "HM_HeizungWohnzimmer_Humidity",
"category": "Humidity",
"tags": [
"CurrentHumidity"
"groupNames": [
"WohnzimmerHeizung"
"link": "http://192.168.0.7:8090/rest/items/WohnzimmerHeizung",
"state": "NULL",
"editable": false,
"type": "Group",
"name": "WohnzimmerHeizung",
"label": "Wohnzimmer Heizung",
"tags": [
"Thermostat",
"Celsius"
"groupNames": []
I dont understand…
You say you cant set target due to an “unknown mode”.
But you also say, that the Home app shows the target temperature, current temperature and mode correctly…
I have to ask then - Where do you see the “unknown mode” ?
When I SAY “set temperature to X degree”, it answers “sorry, this mode does not exist on Wohnzimmer heating”.
When I change the target temperature in the Android Home app, it jumps back to the old value after 2 seconds.
Hmm okay I see…
Its a bit pain to see your items like that… But I´ll try “translate” it to ordinary items
Your target tag is wrong… I believe it should be: [ "homekit:TargetTemperature" ]
The same with the heatingmode. It should be: [ "homekit:TargetHeatingCoolingMode" ]
At least thats what I´m using. And its working fine.
This is one of my thermostats:
Group g_Stortbad_TSTAT "Stort Bad Termostat" [ "Thermostat" ]
Number stort_bad_Temperature "Stort Bad Temperatur [%.1f °C]" <cu_heating> (g_Stortbad_TSTAT,Temperatur,gTvaer,gSugeTemp) [ "CurrentTemperature" ] { channel="ihc:controller:elko:stortbad_temperatur_fb" }
Number stort_bad_Tempsetpunkt "Stort Bad Temperature setpunkt [%.1f °C]" <temperature> (g_Stortbad_TSTAT) [ "homekit:TargetTemperature" ] { channel="ihc:controller:elko:stortbad_temperaturSet_fb", autoupdate="false" }
Number stort_bad_fugt "Stort Bad Fugtighed [%.0f %%]" <Humidity> (g_Stortbad_TSTAT,Fugtighed,gHumidityBathRoom) [ "CurrentHumidity" ] { channel="ihc:controller:elko:stortbad_fugtighed" }
String stort_bad_Mode "Stort Bad Mode [%s]" (g_Stortbad_TSTAT) [ "homekit:TargetHeatingCoolingMode" ]
The reason I pasted the REST response is that the items are defined in PaperUI.
I can try your hint tomorrow.
I also cannot change the heating mode in the app. When I change it from “heat” to “cool” in the app, it takes a few seconds doing something and then it is still “heat”. The mode is a simple string item in my case.
I think, I had the homekit prefix at first a year ago but then it did not work, so I removed it and it then worked fine until recently.
Edit: You were right. Adding the homekit: prefix and refreshing fixed it. Strange that I had to remove that to make it work a year ago.
Thanks!
I had the same experience a you…
But Michael/Marzima changed the integration a month ago (or later). After that we had to use it and it was working.
I´m using String for setting the Mode as well.
Great you got it to work again.
I ran a test and I am pretty sure a fresh sync would have fixed your setup without any change of the config, because the tags you defined are still supported.
Really?? I had troubble as well, when I hadn´t change the tags.But I dont recall if I made a resync back then… I probably just changed the tag, and then did the resync afterwards.
Yes… the code says:
HeatingCoolingMode, homekit:HeatingCoolingMode, homekit:TargetHeatingCoolingMode, homekit:CurrentHeatingCoolingMode
for mode
TargetTemperature, homekit:TargetTemperature
for setpoint
CurrentTemperature
& CurrentHumidity
for
I managed to set my thermostat to auto changeover mode. I added all the metadata to the items, but now when I look in google app it show mode as other and only shows the ambient temperature. openHAB shows everything correctly with auto as the mode. I wonder if it has to do with the naming discrepancies between the thermostat and the google assistant. Your code has [‘off’, ‘heat’, ‘cool’, ‘on’, ‘heatcool’, ‘auto’]. Below is the device info for the modes from https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/182?layout=openhab2.
<channel-type id="honeywell_th8320zw_00_000_thermostat_mode">
<item-type>Number</item-type>
<label>Thermostat Mode</label>
<description>Sets the thermostat mode</description>
<category>Temperature</category>
<state pattern="%s">
<options>
<option value="3">Auto</option>
<option value="0">Off</option>
<option value="11">Economy Heat</option>
<option value="2">Cool</option>
<option value="12">Economy Cool</option>
<option value="1">Heat</option>
<option value="5">Resume</option>
</options>
</state>
I have tried string and number for the mode, but it doesn’t seem to make a difference. Below is the group containing everything.
"members": [{
"link": "http://openhab:8080/rest/items/Thermostat_TemperatureSensor",
"state": "73",
"type": "Number",
"name": "Thermostat_TemperatureSensor",
"label": "Family Room Temperature",
"tags": ["CurrentTemperature"],
"groupNames": ["gTemperature", "gFamilyRoom", "gFamRmThermostat"]
"link": "http://openhab:8080/rest/items/Thermostat_Mode",
"state": "3.0",
"pattern": "%s",
"readOnly": false,
"options": [{
"value": "3",
"label": "Auto"
"value": "0",
"label": "Off"
"value": "11",
"label": "Economy Heat"
"value": "2",
"label": "Cool"
"value": "12",
"label": "Economy Cool"
"value": "1",
"label": "Heat"
"value": "5",
"label": "Resume"
"commandDescription": {
"commandOptions": [{
"command": "3",
"label": "Auto"
"command": "0",
"label": "Off"
"command": "11",
"command": "2",
"label": "Cool"
"command": "12",
"command": "1",
"label": "Heat"
"command": "5",
"label": "Resume"
"type": "Number",
"name": "Thermostat_Mode",
"label": "Family Room Mode",
"tags": ["homekit:TargetHeatingCoolingMode"],
"groupNames": ["gFamilyRoom", "gFamRmThermostat"]
"link": "http://openhab:8080/rest/items/Thermostat_SetpointCooling",
"state": "76",
"pattern": "%.0f",
"readOnly": false,
"options": []
"type": "Number",
"name": "Thermostat_SetpointCooling",
"label": "Family Room Setpoint (cooling)",
"tags": ["homekit:TargetTemperature"],
"groupNames": ["gFamRmThermostat"]
"link": "http://openhab:8080/rest/items/Thermostat_Fan_Mode",
"state": "6",
"pattern": "%s",
"readOnly": false,
"options": [{
"value": "0",
"label": "Auto (Low)"
"value": "1",
"label": "On (Low)"
"value": "6",
"label": "Circulate"
"command": "0",
"command": "1",
"label": "On (Low)"
"command": "6",
"type": "Number",
"name": "Thermostat_Fan_Mode",
"label": "Family Room Fan Mode",
"tags": [],
"link": "http://openhab:8080/rest/items/Thermostat_Fan_OperatingState",
"state": "1",
"pattern": "%s",
"readOnly": false,
"options": [{
"value": "0",
"label": "Idle"
"command": "0",
"label": "Idle"
"type": "Number",
"name": "Thermostat_Fan_OperatingState",
"label": "Family Room Thermostat Fan State",
"tags": [],
"link": "http://openhab:8080/rest/items/gFamRmThermostat",
"state": "NULL",
"editable": false,
"type": "Group",
"name": "gFamRmThermostat",
"label": "Family Room Thermostat",
"tags": ["Thermostat", "Fahrenheit"],
"groupNames": ["gHome"]
Any ideas how/if I should set these up differently?
When you use a string item, Google sends one of four commands: heat
, cool
, on
, or off
, with on
corresponding to auto
and displaying in Google Home as Other
. @michikrug has submitted a PR that will enable you to map the states in an item and ensure they’re synchronized between your device and GA, but I don’t think there’s anything you can do to change the values on the Google side.
A bit misleading
Google doesnt sends these commands… Google will accept (receive) these.
So in openhab you can send these commands to Google, and this way tell Google the heatingmode.
I have thought about this as well…
If this should make sense, it should be possible to change the heatmode from GA to openhab as well. But I dont really see this very usefull, unless you have a specific HVAC or something simular.
You can however do some changes to the heatmode. If you change the setpoint of the thermostat, and have GO monitoring your heater/boiler/actuator, it will change to heating or cooling, all depending of the setpoint. I do this using a rule in openhab. But it´s actually only the setpoint which makes it change.
This is a screenshot of one of my thermostats when setpoint is below the actual temperature. Notice the color of the thermostat (blue). It´s in cooling mode.
And this is the same thermostat, where I changed the setpoint above the actual temerature. Now the color is red, at the thermostat is in heating mode.
This is controled by a simple rule, where I monitor the actuator, and send heat
if the actuator is ON, or cool
if the actuator is OFF.
Very simple, but it makes good sense to me.
Since this is a very simple thermostat, it makes no sense using auto
mode. A simple thermostat is already in auto mode. I could have used on/off insted, but it makes better sense using heat/cool
That would be awesome if you could. I’d imagine there are others that would find this useful.
Well, it’s actually both. When you select a mode in the Google Home app, you can see in the log that it very clearly sends one of these commands if your item is a string. And as a result, these are the strings it can accept. So you could say it either way, but there’s nothing misleading about what I wrote.
Sorry, You´re right… I Just tried, and it did change…
Didnt know that GH could do such a thing. Thats rather interesting.
Let me start by saying I think the integration between Google Assistant and openHAB is awesome already, and I hugely appreciate all the work that’s gone into it …
With that said, is there any plan/possibility to add capability for GA to report more values out of openHAB than just thermostat temperature? For example, “OK Google, what is my total power usage so far today” (assuming I have a Number item with label=‘total power usage so far today’).
Right now, the openHAB-GA integration seems pretty focused on ‘one-way control actions’ and less so as an interactive interface to openHAB.
Am I way off in left field, or are others interested in this sort of capability?
I think the thing is that Google Assistant would have to be able to recognize the device type, and they have a relatively short list that understandably focuses on controllable devices. For thermostats, we’re working within the pre-existing abilities of GA. The same can be said for other devices: GA can control them or tell you their current state for any assigned traits.
In my opinion, it’s really not meant for more than this when it comes to home automation. I would guess that Google is more concerned about making GA accessible to any random person who wants to plug in a device, control it by voice, and then tell their friends.
What I would like to see is for devices to trigger announcements via GA (e.g. when a device’s timer/alarm goes off, when the dishwasher finishes, when the washing machine stops in mid-cycle, etc.). But I’m not holding my breath, because they haven’t even made this happen with the Nest Protect. It would make a ton of sense for your Google Home/Nest Hub devices to speak up when the Nest Protect is about to go off, and allow you to cancel the alarm with two-factor acknowledgement.
I tried to get my zwave curtains to open as a group. I made a Rollershutter group
but I always get a message:
“[WARN ] [rest.core.internal.item.ItemResource] - Received HTTP POST request at ‘items/ZW_GROUP_GORDIJNEN_WOONKAMER’ with an invalid status value ‘ON’.”
I also tried with adding AVG and MIN to the group but that doesn’t seem to work either.
Also changing the tag to eg. Blinds doesn’t seem to work.
And I use the command “google sync devices” after each change.
If I add the ga=“blinds” tag to a individual rollershutter item it works:
“Item ‘ZW_022_SHUTTLE_WOONKAMER_ACHTERRAAM_DRAPERYOPENER_SHUTTER’ received command UP” .
This is my code:
//Forest Shuttle
Group:Rollershutter ZW_GROUP_GORDIJNEN_WOONKAMER "Gordijnen woonkamer" { ga="Blinds" }
Rollershutter ZW_022_SHUTTLE_WOONKAMER_ACHTERRAAM_DRAPERYOPENER_SHUTTER "Gordijn raam [%s]" (ZW_GROUP_GORDIJNEN_WOONKAMER) {channel="zwave:device:bf9f9b39:node22:blinds_control",autoupdate="false"}
Rollershutter ZW_026_SHUTTLE_WOONKAMER_TUINDEUR_DRAPERYOPENER_SHUTTER "Gordijn deur [%s]" (ZW_GROUP_GORDIJNEN_WOONKAMER) {channel="zwave:device:bf9f9b39:node26:blinds_control",autoupdate="false"}
