This is, to my understanding, how it is.
And yes, you´ll then need to map Velbus Modes to Google modes, (just like you did). But I think you mapped them wrong.
This is just a wild guess, but based on your previous log, where I see openhab trying to send “heat” to your ThermostatMode, maybe you need to swap the commands? Like this:
I´m a bit “handicaped” here, cause my Velbus setup is running on the Odroid, and my GA connection is running on my Rpi. And on my Rpi, I havn´t got true Thermostats with modes. So I cant test it directly, only through sitemaps, which is only half the test worthy
(And I need a 20meter USB cable to get the Velbus setup to my Rpi ).
Second, I have some issues understanding how come the Modes has been splitted into two items? (I think thats the Velbus binding doing this). I know Velbus panels can handle it. But I dont see how Google would be able to. And I fail to understand how Alexa can.
MDAR
348
Indeed, I’ve tried all kinds of variations on that theme.
(I’ve just tried this {again} and it doesn’t make any difference )
I’m not sure if it is openHAB2 that does that mapping (so I would expect it to be operational as soon as the Item file is updated and accepted.)
Or if that information has to be synchronised with Google during a refresh.
You could…
Add the Velbus binding to your RPi and use the Network Bridge to connect it to your Odroid.
(But why you haven’t simply restored your RPi configuration onto the Odroid I don’t know… it would be easy enough to add VelServ to your RPi is you wanted to isolate the Velbus kit)
Or you could poll the Odroid for Velbus Item values…
Openhab should do the mapping. Otherweise it makes no sense to me.
I always do syncronise whenever I have made any changes regarding GA.
Ahmm.. Sorry I havn´t thought about this before
It´s not that I wanted to isolated Velbus.. Quite opposite infact.. But I simply had this idea, I had to connect the Velbus USB module to the Rpi to get it to work
MDAR
350
I’ll PM you so we can get you up and running.
It’ll be a very quick process
Furthermore. I am still not sure if marziman has already published the version that included the modes features or if it just was merged into the master branch and stopped there…
MDAR
354
I see.. Lets see if this will do any changes then..
In the mean time.. I noticed you answered Stuart (MDAR), that the mode mapping should be applied to the Thermostat group.. Is this correct? According to the doc, it should be added to the ga="thermostatMode"
(Mandatory) Mode: Number (Zwave THERMOSTAT_MODE Format) or String (off, heat, cool, on, ...). { ga="thermostatMode" }
@MARZIMA
If you have deployed the new Mode mapping for thermostat, then it doesnt work.
If you havnt deployed it yet, could you please do so, or at least remove it from the doc.
MDAR
359
If you read this very slowly, it is very clear
to custom ones for your specific setup, you can use the modes config option on the thermostat group
Since at least two of you found the docs confusing on this point, I’m sure any ideas you have to make them more clear would be greatly appreciated. I doubt you are the only ones.
P.S.
I don’t think the roomHint is working either.
I’m quite happy to take a look at the docs and add a few full examples, once it’s all up and running (so I can test that what I’m suggesting actually works)
That looks like the way it is meant to be. I guess @michikrug can confirm.
When @MARZIMA can confirm the feature has been deployed, its time to change (optimize) the docs, or bug fixing
I changed to new metadata version last year. Also I could configure my aircon as a thermostat and now I can control. But it would be good if I can change modes and configure other things as well. Plus can we use this connection with Google locally somehow? I do not need full description, but if it is possible and I can get some hints I would be very grateful. Than I can do it by myself.
Just wanted to ask if there ever will be a generic string or numeric item controllable via google assistant. like i expose a string item to openhab and be able to set it to anything via google assistant .
This is similar to what ifttt does…trigger based of google assistant telling cum
