openHAB Google Assistant Integration v2.0
No sorry - Openhab item groups, not actual speaker groups. I am looking to voice control my amplifier and have acheived this with alexa, now looking to do it with GA
Alexa does this metatags like:
Group Stereo    "Stereo"            {alexa="Endpoint.Speaker"}
Dimmer Volume   "Volume"  (Stereo)  {alexa="Speaker.volume"}
Switch Mute     "Mute"    (Stereo)  {alexa="Speaker.muted"}
where you can then say “alexa turn up the stereo”
Was hoping for same experience no matter what voice assistant I am using as I have a mix of them
At least type “SPEAKER” should work with a Dimmer item
Look guys: Google Assistant finally supports sensors and smoke detectors, paving the way for smarter alerts and automations
I dont understand how this is usefull for us?
Well, for one thing it means that we might be able to add individual temp and humidity sensors without having to create fake thermostat groups as a workaround.
Also, if Google Assistant gains the ability to trigger routines based on Nest Protect, we could use it to trigger OH items. It would be cloud-based, but it’s better than nothing.
Ahh okay.. But since it requires rutines, I guess it´s limited to US/UK langauge only.
It’s all speculation at this point, so there’s no reason to draw any conclusions about anything.
Hi @michikrug , when we can use new sensors api with OpenHab?
I would like ask GA for air condition, air purifier status etc :slight_smile:
Thank you for your work.
I started implementing it. Will update you when I have a working version
Hi there,
I have some trouble with my Ikea Tradfri bulbs and google assistant. I want to set the color temperature of a bulb (Colour Temperature; Thing Type 0220) by google assistant. Is there a way to implement this without setting up 2 devicese?
current item for one bulb:
Dimmer	Bue_Panel_br				"Büro Panel"										<light>				(g_Bue, g_UG_Licht, g_Licht)
	channel="knx:device:bridge:generic:Bue_Panel_Switch",
	channel="knx:device:bridge:generic:Bue_Panel_Status",
		channel="tradfri:0220:gwa0cc2bfd3693:Bue_Panel:brightness",
	ga="Light" [ roomHint="Büro" ]
Dimmer	Bue_Panel_ct				"Büro Panel"										<light>				(g_Licht,  g_UG_Licht, g_Bue )
	channel="tradfri:0220:gwa0cc2bfd3693:Bue_Panel:color_temperature",
Thanks in advance
Im my understanding you would need a Color item that is exposed to Google Assistant as “Light”.
The value of this item would be required to be converted and sent to your two Dimmer items for your Tradfi light.
The brightness is easy, because it’s just the third value of the HSB Color value (Items | openHAB).
The conversion of the temperature is a bit tricky but there is info in the web available.
To the others: please correct me if I am wrong.
Hi Kim
Have you experimented with the new Google Metadata method yet?
Hi Stuart..
Yes I tested some of them when Michael and Marzima made the changes public. But it was mainly on new test items/functions like my alarm system (security with pincode) and the ack. feature..
I havnt had time to change all the old tags to use metadata. Its a huge job. And since tags still works fine, I´m in no rush :slight_smile:
Anything specific you had in mind?
Funny you should mention that…
I’m trying to get the Velbus thermostat working with Google metadata
Current Temperature is okay
But Target Temperature only works when I don’t try to get the Mode mapped.
I can change the mode with the Google assistant, but the commands always get sent to the Item as the Google options, rather than the mapping I’m trying to do
This is what I am trying
// New Google Assistant Metadata tagging (I'm still experimenting with)
		Group MiddleBedroomGP2_Thermostat	"Middle Bedroom"																																				{ ga="Thermostat" [roomHint="Middle Bedroom"], alexa="Endpoint.Thermostat" }
		Number MiddleBedroomGP2_CurrentTemperature 			"Middle Bedroom Current Temperature" 			( MiddleBedroomGP2_Thermostat ,WholeHouse_CurrentTemperature		)							{ channel="velbus:vmbgp2:VelbusNetworkBridge:17:input#CH9", 								ga="thermostatTemperatureAmbient" ,		 alexa="TemperatureSensor.temperature" }
		Number MiddleBedroomGP2_CurrentTargetTemperature 	"Middle Bedroom Current Target Temperature"		( MiddleBedroomGP2_Thermostat ,WholeHouse_CurrentTargetTemperature	)							{ channel="velbus:vmbgp2:VelbusNetworkBridge:17:thermostat#CURRENTTEMPERATURESETPOINT",		ga="thermostatTemperatureSetpoint",		 alexa="ThermostatController.targetSetpoint"}
		String MiddleBedroomGP2_ThermostatMode 				"Middle Bedroom Thermostat mode"	  	 		( MiddleBedroomGP2_Thermostat	)																{ channel="velbus:vmbgp2:VelbusNetworkBridge:17:thermostat#MODE", 							ga="thermostatMode" [ modes="off=SAFE,eco=NIGHT,on=DAY,heat=COMFORT" , lang="en" , ordered=true ] ,					 alexa="ModeController.mode" [friendlyNames="@Setting.Preset", supportedModes="SAFE=Safe,NIGHT=Night,DAY=Day,COMFORT=Comfort"]}
		String MiddleBedroomGP2_ThermostatOperatingMode 	"Middle Bedroom Thermostat operating mode"		( MiddleBedroomGP2_Thermostat )																	{ channel="velbus:vmbgp2:VelbusNetworkBridge:17:thermostat#OPERATINGMODE"	,														alexa="ThermostatController.thermostatMode" [COOL="COOLING",HEAT="HEATING"]	}
And this is what I’m seeing in the Events.log when I try to set a mode in Google
2020-03-26 14:41:23.265 [nt.ItemStatePredictedEvent] - MiddleBedroomGP2_ThermostatMode predicted to become heat // This should have been mapped to COMFORT
2020-03-26 14:41:23.273 [vent.ItemStateChangedEvent] - MiddleBedroomGP2_ThermostatMode changed from SAFE to heat
2020-03-26 14:41:24.344 [vent.ItemStateChangedEvent] - MiddleBedroomGP2_ThermostatMode changed from heat to SAFE // This is the Velbus binding rejecting the "heat" command and defaulting to SAFE
2020-03-26 14:42:03.334 [ome.event.ItemCommandEvent] - Item 'MiddleBedroomGP2_ThermostatMode' received command heat // This should have been mapped to COMFORT
2020-03-26 14:42:03.360 [nt.ItemStatePredictedEvent] - MiddleBedroomGP2_ThermostatMode predicted to become heat
2020-03-26 14:42:03.373 [vent.ItemStateChangedEvent] - MiddleBedroomGP2_ThermostatMode changed from SAFE to heat
2020-03-26 14:42:05.402 [vent.ItemStateChangedEvent] - MiddleBedroomGP2_ThermostatMode changed from heat to SAFE// This is the Velbus binding rejecting the "heat" command and defaulting to SAFE
2020-03-26 14:42:39.097 [ome.event.ItemCommandEvent] - Item 'MiddleBedroomGP2_ThermostatMode' received command off
2020-03-26 14:42:39.114 [nt.ItemStatePredictedEvent] - MiddleBedroomGP2_ThermostatMode predicted to become off // This should have been mapped to SAFE
2020-03-26 14:42:39.121 [vent.ItemStateChangedEvent] - MiddleBedroomGP2_ThermostatMode changed from SAFE to off
2020-03-26 14:42:40.420 [vent.ItemStateChangedEvent] - MiddleBedroomGP2_ThermostatMode changed from off to SAFE // This is the Velbus binding rejecting the "off" command and defaulting to SAFE
@michikrug @MARZIMA
Can either of your gentlemen provide any clarification on if this is even possible or what the correct syntax should be?
I’ve tried to follow these instruction to the letter
Should the mode mapping be places in the Themostat group Item as suggested?
Or with the Thermostat Mode String item?
(I’ve tried both, with the mapping in various forms)
We / I am so close to having a complete solution that it’s getting really frustrating..
What’s really curious is that openHAB2 is obviously sharing the current mode with Google, because shortly after sending the mode command to openHAB2, Google rolls back to “Other” mode
Screenshot_20200326-150254_Home
Can you change the Thermostat Mode from a sitemap? (I havn´t tried myself).
I have not the first clue about sitemaps…
From HabPanel, NodeRed, PaperUI — YES :smile:
So I assume that it’s possible from a sitemap
Just sitting here looking at the Velbus binding docs.. It really lacks info :frowning:
I have no clue about Habpanel or NodeRed, so I´ll need to have the modes for making at sitemap mapping..
But. If you can set the mode from habpanel, I really dont understand why it shouldnt work with GA. According to your log, it does work, but for some reason the Velbus panel don´t accept the command. Normally I would say, it shouldnt work from habpanel/sitemap/NodeRed either, as it´s the exact same.
Will give it a few shots from here (using sitemap). Just need to know the modes the glaspanels accept.
Okay..
Well..
The Velbus Thermostat Mode accepts - SAFE,NIGHT,DAY,COMFORT
The Velbus Thermostat Operating Mode accepts - HEATING,COOLING
Google seems to be sending, heat,off,cool (But no sign of eco or auto)
It’s the mapping between what Google sends and Velbus thermostats accept.
There is a [ modes="off=SAFE etc option mentioned in the Google assistant page, but no matter what I try it doesn’t seem to change what is sent to the Velbus panel.
With habjes’ assistance, we’ve got Alexa mapping correctly, for both the Operating Mode and the Thermostat modes (or as Alexa prefers to call then “Presets”
Where are you seeing that ?
I see the new mode coming in from Google and being sent to the Velbus Item, then being rejected (because it hasn’t been mapped) and the thermostat defaulting back to SAFE
As an example, I have just used Alexa to “Set the middle bedroom preset to xxx” and this is what I see in the logs
2020-03-26 16:18:31.735 [vent.ItemStateChangedEvent] - BackBedroomGP2_CurrentTemperature changed from 21.3125 to 21.75
2020-03-26 16:18:31.736 [GroupItemStateChangedEvent] - WholeHouse_CurrentTemperature changed from 20.0313 to 20.25 through BackBedroomGP2_CurrentTemperature
2020-03-26 16:18:53.813 [ome.event.ItemCommandEvent] - Item 'MiddleBedroomGP2_ThermostatMode' received command DAY
2020-03-26 16:18:53.839 [nt.ItemStatePredictedEvent] - MiddleBedroomGP2_ThermostatMode predicted to become DAY
2020-03-26 16:18:53.848 [vent.ItemStateChangedEvent] - MiddleBedroomGP2_ThermostatMode changed from COMFORT to DAY
2020-03-26 16:18:53.871 [vent.ChannelTriggeredEvent] - velbus:vmbgp2:VelbusNetworkBridge:17:thermostat#HEATER triggered RELEASED
2020-03-26 16:18:53.894 [vent.ItemStateChangedEvent] - MiddleBedroomGP2_HeatingRelay changed from ON to OFF
2020-03-26 16:18:56.210 [vent.ItemStateChangedEvent] - MiddleBedroomGP2_CurrentTargetTemperature changed from 20.0 to 18.0
2020-03-26 16:18:56.211 [GroupItemStateChangedEvent] - WholeHouse_CurrentTargetTemperature changed from 16.0 to 15.0 through MiddleBedroomGP2_CurrentTargetTemperature
2020-03-26 16:19:06.101 [ome.event.ItemCommandEvent] - Item 'MiddleBedroomGP2_ThermostatMode' received command NIGHT
2020-03-26 16:19:06.119 [nt.ItemStatePredictedEvent] - MiddleBedroomGP2_ThermostatMode predicted to become NIGHT
2020-03-26 16:19:06.125 [vent.ItemStateChangedEvent] - MiddleBedroomGP2_ThermostatMode changed from DAY to NIGHT
2020-03-26 16:19:06.167 [vent.ChannelTriggeredEvent] - velbus:vmbgp2:VelbusNetworkBridge:17:thermostat#ALARM3 triggered RELEASED
2020-03-26 16:19:06.169 [vent.ChannelTriggeredEvent] - velbus:vmbgp2:VelbusNetworkBridge:17:thermostat#ALARM4 triggered RELEASED
2020-03-26 16:19:08.512 [GroupItemStateChangedEvent] - WholeHouse_CurrentTargetTemperature changed from 15.0 to 13.5 through MiddleBedroomGP2_CurrentTargetTemperature
2020-03-26 16:19:08.513 [vent.ItemStateChangedEvent] - MiddleBedroomGP2_CurrentTargetTemperature changed from 18.0 to 15.0
2020-03-26 16:19:17.287 [ome.event.ItemCommandEvent] - Item 'MiddleBedroomGP2_ThermostatMode' received command SAFE
2020-03-26 16:19:17.306 [nt.ItemStatePredictedEvent] - MiddleBedroomGP2_ThermostatMode predicted to become SAFE
2020-03-26 16:19:17.320 [vent.ItemStateChangedEvent] - MiddleBedroomGP2_ThermostatMode changed from NIGHT to SAFE
2020-03-26 16:19:19.499 [vent.ItemStateChangedEvent] - MiddleBedroomGP2_CurrentTargetTemperature changed from 15.0 to 12.0
2020-03-26 16:19:19.502 [GroupItemStateChangedEvent] - WholeHouse_CurrentTargetTemperature changed from 13.5 to 12.0 through MiddleBedroomGP2_CurrentTargetTemperature
Just a quick try using sitemap (with this mapping) on the Thermostatmode item.. It works like a dream:
		Selection item=VmbeloMode mappings=[SAFE="SAFE", NIGHT="NIGHT", DAY="DAY", COMFORT="COMFORT"]
But I guess what you´re trying to do is to control the acutal heater, right? Thats the OpMode item and not the ThermostatMode item.
This tells that your item changed from SAFE to heat..
BUT! thats the ThermostatMode item.. And it does not accept the “heat” command as far as I understand.. So it reject the command ofcouse.
You problem is, you´re trying to control the thermostat with commands belonging to another item..
Thats why I asked for the possible modes for the glasspanels :smiley:
But are these two modes read/writeable or only readable?
It takes only a few seconds to test using sitemaps :smiley:
EDIT.
Tested the OpMode in sitemap using this mapping:
		Selection item=VmbeloOpMode  mappings=[HEATING="HEATING", COOLING="COOLING", OFF="OFF"]
This is the outcome.
2020-03-26 17:33:58.780 [ome.event.ItemCommandEvent] - Item 'VmbeloOpMode' received command COOLING
2020-03-26 17:33:58.797 [nt.ItemStatePredictedEvent] - VmbeloOpMode predicted to become COOLING
2020-03-26 17:33:58.832 [vent.ItemStateChangedEvent] - VmbeloOpMode changed from HEATING to COOLING
2020-03-26 17:33:59.005 [vent.ItemStateChangedEvent] - Vmbelo1TempSet changed from 22.0 °C to 21.0 °C
2020-03-26 17:33:59.355 [vent.ChannelTriggeredEvent] - velbus:vmbelo:1e8ce9e5:02:input#CH12 triggered PRESSED
2020-03-26 17:33:59.359 [vent.ChannelTriggeredEvent] - velbus:vmbelo:1e8ce9e5:02:thermostat#COOLER triggered PRESSED
2020-03-26 17:34:30.565 [ome.event.ItemCommandEvent] - Item 'VmbeloOpMode' received command OFF
2020-03-26 17:34:30.574 [nt.ItemStatePredictedEvent] - VmbeloOpMode predicted to become OFF
2020-03-26 17:34:30.599 [vent.ItemStateChangedEvent] - VmbeloOpMode changed from COOLING to OFF
2020-03-26 17:34:30.614 [vent.ItemStateChangedEvent] - VmbeloOpMode changed from OFF to COOLING
2020-03-26 17:34:30.877 [vent.ItemStateChangedEvent] - Vmbelo1Temp changed from 24.4375 °C to 24.5 °C
2020-03-26 17:34:54.052 [ome.event.ItemCommandEvent] - Item 'VmbeloOpMode' received command HEATING
2020-03-26 17:34:54.060 [nt.ItemStatePredictedEvent] - VmbeloOpMode predicted to become HEATING
2020-03-26 17:34:54.075 [vent.ItemStateChangedEvent] - VmbeloOpMode changed from COOLING to HEATING
2020-03-26 17:34:54.415 [vent.ItemStateChangedEvent] - Vmbelo1TempSet changed from 21.0 °C to 22.0 °C
2020-03-26 17:34:54.853 [vent.ChannelTriggeredEvent] - velbus:vmbelo:1e8ce9e5:02:input#CH12 triggered RELEASED
2020-03-26 17:34:54.857 [vent.ChannelTriggeredEvent] - velbus:vmbelo:1e8ce9e5:02:thermostat#COOLER triggered RELEASED
Notice.. OFF did not work. HEATING and COOLING worked fine, and it triggered a input channel.
@jeshab described it perfectly..
The combination of the ThermostatMode and the ThermostatOperatingMode creates a matrix of options.
You can assign 4 different values to the ThermostatMode - SAFE,NIGHT,DAY & COMFORT
and change the ThermostatOperatingMode between HEATING & COOLING
Creating in effect 8 different modes of operation.
Jeshab described it as 2 thermostat modes, each with 4 presets.
Which in Alexa terms was perfect.
So..
I have all the Velbus side of things working perfectly and with Jeshab’s assistance, Alexa seems to be happy too.
What I can’t do yet is get Google Assistant’s incoming commands to be mapped to something that the Velbus (binding) is happy with, (IE, Values that are valid for the thermostats)
So to go through your comments…
Unlike the Alexa metadata that can be mapped and Alexa informed as to the Presets and Modes that are available, we must accept whatever Google understands and map it to whatever our brand of thermostats accept.
(I could be very wrong here)
Either of the following is right
  • Google only knows it’s own options for modes and those have to be mapped to our thermostats
  • I haven’t worked out how to inform Google of the Modes that are available
That is the Google mode (heat) being sent to the Velbus thermostat.
The following line in the log is the Thermostat rejecting that command and resetting to SAFE
(Everything is READ/WRITE)
This is where the confusion is
The ThermostatOperatingMode can be either HEATING or COOLING
Whereas the ThermostatMode can be any of the 4 options, SAFE,NIGHT,DAY or COMFORT
		String MiddleBedroomGP2_ThermostatMode 				"Middle Bedroom Thermostat mode"	  	 		( MiddleBedroomGP2_Thermostat	)																{ channel="velbus:vmbgp2:VelbusNetworkBridge:17:thermostat#MODE", 							ga="thermostatMode" [ modes="off=SAFE,eco=NIGHT,on=DAY,heat=COMFORT" , lang="en" , ordered=true ] ,					 alexa="ModeController.mode" [friendlyNames="@Setting.Preset", supportedModes="SAFE=Safe,NIGHT=Night,DAY=Day,COMFORT=Comfort"]} // Accepts SAFE,NIGHT,DAY,COMFORT
		String MiddleBedroomGP2_ThermostatOperatingMode 	"Middle Bedroom Thermostat operating mode"		( MiddleBedroomGP2_Thermostat )																	{ channel="velbus:vmbgp2:VelbusNetworkBridge:17:thermostat#OPERATINGMODE"	,														alexa="ThermostatController.thermostatMode" [COOL="COOLING",HEAT="HEATING"]	} // Accepts HEATING & COOLING
The behaviour that you’ll see in the Velbus panel is that when in HEATING mode, the HEATER channel is “PRESSED” when the target temperature is ABOVE the current temperature
Whereas in COOLING mode the COOLER channel is PRESSED when the Target temperature is BELOW the Current temperature.
(It’s possible to create a kind of AUTO mode by assigning actions to the Thermostat Alarm channels and the OperatingMode, where if the Current temperature is +10° above the target, the unit changes to COOLING and another where if the Current Temperature is -10°c below the target temperature the unit changes to HEATING mode)
