I understand this. But why would you use a Dimmer for a Rollershutter?
To change the angle of the âLamellenâ a dimmer is ways better than an up/down button.
If youâre blinded by the sun while watching tv but you donât want to darken the room the interface is much easier to useâŠ
I see. So it is basically just because of the controls available in openHAB for that item type?
yes - just for visualization purpose in the oh-app.
Is anyone using numeric values for their Thermostat modes?
If yes, where does the mapping string-mode <-> numeric-mode come from?
I am thinking of dropping the (for me not understandable) transformation in the GA integrationâŠ
I am using number as the type for the mode. As for the operating state it is also a number, but I use a transform map on the label.
Google used string mode for the thermostat here, no need numeric-mode
Could also work with the string values provided by google, e.g. with an intermediate item that transforms on your side? (on, off, heat, cool, heatcool, auto, eco, etcâŠ)
I am just wondering where this mapping
off -> 0, heat -> 1, cool -> 2, on -> 3
comes fromâŠ
That would be awesome.
It should be possible to send the hls stream and still picture to a GH device using the ipcamera binding. But as far as I recall its a casting option. (I have yet to try it myself. It has been on my todo list for months now).
Google wants to have:
cameraStreamAccessUrl: String. URL endpoint for retrieving the realtime stream.
Other options are not available yet for the Camera device and CameraStream trait.
If this can be provided, I do not see an issue here.
In my metadata PR the camera type is already integrated and requires a String item containing the URL.
@matt1 can now provide an URL for HLS Streaming that works with chromecast.
Does this mean that it will be possible to Create an Item like:
String BabyCamHlsStreamUrl "Baby Camera" [ "Camera" ] { channel="ipcamera:DAHUA:BabyCamera:hlsUrl" }
and get a Baby Camera in Google Assistent that can cast to Chromecast?
/Mike
That would be great if we can tag as a camera, currently I have to use the Switchable tag and use a rule to cast the camera with the Chromecast binding using this rule. It works well but you have to be careful what you say to Google for it to work, for example you can not ask google to âshow the BabyMonitor camera/videoâ, you have to ask to âturn on the BabyMonitorââŠ
rule "Cast babycamera to KitchenHomeHub"
Item BabyMonitor received command
if (receivedCommand == ON){
//Start generating HLS format to reduce the startup delay
sendHttpGetRequest("http://192.168.10.60:50001/ipcamera.m3u8")
BabyCamDirection.sendCommand(1) //Ensure camera is pointed at the cot
BabyCamAutoLED.sendCommand(ON) //Turn on nightvision
tCameraTimer = createTimer(now.plusSeconds(12), [ | // Use timer to delay
KitchenHomeHubPlayURI.sendCommand("http://192.168.10.60:50001/ipcamera.m3u8")
tCameraTimer = null
else{
KitchenHomeHubPlayURI.sendCommand("") //stop stream if BabyMonitor command is OFF
Basically, yes.
As mentioned, the camera type is implemented in the metadata rework that is not yet published.
It would be something like this then:
String BabyCamHlsStreamUrl "Baby Camera" { ga="Camera" [ protocols="hls" ], channel="ipcamera:DAHUA:BabyCamera:hlsUrl" }
When do you think it will be published?
/Mike
Hi All
Just to check before starting a new topic.
Has this something to do with the ânew versionâ of openhab google assistant ??
I have been running openhab 2.4 stable with google assistant since summer without problems
From yesterday google assistants was not able to âsync my devicesâ (only openhab) after many tries, i delete the openhab connection in google assistant. now im not able to make a new connection.
Everything works in myopenhab, a new âGoogle Assistant Voice Controlâ is added every time i tried to make a new connection
Thanks Mads
Hi Belgadon
I can see my items using the âItem checkerâ some of them has errors, but they have not been changed
recently
I think you have to fix these errors. I experienced the same. I added a few new items but could sync them. I, just like you, deleted the connection and couldnât create a new one. The âItem checkerâ showed me an error in one of the older items.
After fixing that error everything worked. Good luck!
HI
I fixed alot of the problems, i still have 4 thermostat with errorsâŠBUT google are now able to connect :-)
THANKS YOU !!!
Hi All
regarding the thermostat in the examples here Google Assistant | openHAB
this is used
[ âhomekit:TargetHeatingCoolingModeâ ]
and
[ âhomekit:TargetTemperatureâ ]
but the items checker wants is to be
[âhomekit:HeatingCoolingModeâ]
and
[ âTargetTemperatureâ ]
Another this i have these 2 items using âNumber:Temperatureâ
The items checker tells me that they need to be âNumberâ
item type must be a âNumberâ for StuemaxActual
item type must be a âNumberâ for StuemaxSetTemp
Number:Temperature StuemaxActual "Stue temperatur [%.1f]" (gMAX, gTemperatur, g_stue_tstat) [ "CurrentTemperature" ] {channel="max:thermostatplus:LEQ0428648:MEQ1286281:actual_temp"}
Number:Temperature StuemaxSetTemp "Termostat instilling [%.1f]" (gMAX, g_stue_tstat) [ "TargetTemperature" ] {channel="max:thermostatplus:LEQ0428648:MEQ1286281:set_temp"}
