Hello, i have a problem with mi openhab, it always reloading all items, rules… webpage only shows openhabian help.
i installed latest oracle java 32bit.
please help me ![]()
here some logs:
journalctl -u openhab2.service -b
Jul 15 19:58:13 smarthome karaf[19994]: #
Jul 15 19:58:13 smarthome karaf[19994]: # A fatal error has been detected by the Java Runtime Environment:
Jul 15 19:58:13 smarthome karaf[19994]: # SIGBUS (0x7) at pc=0xf7392df8, pid=19994, tid=0xe31d2470
Jul 15 19:58:13 smarthome karaf[19994]: # JRE version: Java(TM) SE Runtime Environment (8.0_171-b11) (build 1.8.0_171
Jul 15 19:58:13 smarthome karaf[19994]: # Java VM: Java HotSpot(TM) Client VM (25.171-b11 mixed mode linux-arm )
Jul 15 19:58:13 smarthome karaf[19994]: # Problematic frame:
Jul 15 19:58:13 smarthome karaf[19994]: # V [libjvm.so+0x380df8]
Jul 15 19:58:14 smarthome systemd[1]: openhab2.service: Main process exited, code=killed, status=11/SEGV
Jul 15 19:58:16 smarthome karaf[20621]: Can't connect to the container. The container is not running.
Jul 15 19:58:16 smarthome systemd[1]: openhab2.service: Control process exited, code=exited status=1
Jul 15 19:58:16 smarthome systemd[1]: openhab2.service: Unit entered failed state.
Jul 15 19:58:16 smarthome systemd[1]: openhab2.service: Failed with result 'exit-code'.
Jul 15 19:58:21 smarthome systemd[1]: openhab2.service: Service hold-off time over, scheduling restart.
Jul 15 19:58:21 smarthome systemd[1]: Stopped openHAB 2 - empowering the smart home.
# service openhab2 status
openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2018-07-15 19:58:21 CEST; 9min ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 20621 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=1/FAILURE)
Main PID: 20752 (java)
CGroup: /system.slice/openhab2.service
└─20752 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/u
Jul 15 19:58:21 smarthome systemd[1]: Started openHAB 2 - empowering the smart home.
# java -version
java version "1.8.0_171"
Java(TM) SE Runtime Environment (build 1.8.0_171-b11)
Java HotSpot(TM) Client VM (build 25.171-b11, mixed mode)
