something is weird with your openHABian configuration menu. It is not able to update itself out of a to me unknown reason. Good news: It appears you are on the latest openHAB version!!
To repair openHABian, please execute line by line:
made a fresh install of the new openHABian 1.4.
Now I want to install homegear via config-tool, but runs into error:
$ apt -y install homegear homegear-homematicbidcos homegear-homematicwired
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
homegear : Depends: libgnutls-deb0-28 (>= 3.3.0) but it is not installable
Depends: libmysqlclient18 (>= 5.5.24+dfsg-1) but it is not installable
Depends: libssl1.0.0 (>= 1.0.1) but it is not installable
E: Unable to correct problems, you have held broken packages.
FAILED
I made a fresh install of the new openHABian 1.4 on sunday. I think openhab was still version 2.1 but I don’t realy know. After restoring/copying /etc/openhab2/ and /var/lib/openhab2/ all works fine.
But then I update openhab over openhab-config (think from 2.1 to 2.2) I get this error:
2017-12-19 20:12:29.013 [SEVERE] [org.apache.karaf.main.Main] - Could not launch framework
java.lang.RuntimeException: Could not resolve mvn:org.eclipse.tycho/org.eclipse.osgi/3.10.101.v20150820-1432
at org.apache.karaf.main.util.SimpleMavenResolver.resolve(SimpleMavenResolver.java:59)
at org.apache.karaf.main.Main.createClassLoader(Main.java:457)
at org.apache.karaf.main.Main.launch(Main.java:254)
at org.apache.karaf.main.Main.main(Main.java:179)
I decided to try this again…download openhabian 1.4, install (now it oh is 2.2) and restoring my files again and I get this error immediatly.
Yes, the system password.
However I suspect the problem to sit in front of the screen. I was able to change that password in the previous edition, but I failed to get the one for the Karaf console changed. This time it was the system password, I didn’t even try the one for the console.
I’m starting the config tool with sudo, IMHO I can’t do anything wrong in the procedure to change a password.???
Is your system installed onto a RPi / Pine64 or have you used the tool on a generic ubuntu dist?
When you run the script for the first time it ask for the system user so it can handle all changes correctly.
If that one somehow is incorrect these function will not work.
I’m on a Raspi3.
Do I understand correctly, when using “openhabian-config” initially (without sudo) I’m getting the message that sudo is needed, input with sudo, confirming with password and then it should NOT work?
I just made the upgrade to Openhabian 1.4
It looks like everything went fine, only the start of the service openhabian did not work.
So I made a sudo shutdown -r, and openhabian came up as expected, also all functionality seems to be ok.
BUT, if I look to the logs, the last entries were the removing of things from the shutdown.
After that, no new entries!!! Nothing! What is going on here? And how can I find out why no logs are written?
I also commend you @ThomDietrich for the work you have done… much appreciated.
Maybe there is a place to report anomalies?
When running the menu item: install node-red, this happens:
--2017-12-23 16:14:50-- https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/update-nodejs-and-nodered
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.96.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.96.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 19513 (19K) [text/plain]
Saving to: ‘/tmp/update-nodejs-and-nodered.sh’
/tmp/update-nodejs-and-nodered.sh 100%[============================================================>] 19.06K --.-KB/s in 0.05s
2017-12-23 16:14:50 (356 KB/s) - ‘/tmp/update-nodejs-and-nodered.sh’ saved [19513/19513]
$ bash /tmp/update-nodejs-and-nodered.sh
Root user detected. Typically install as a normal user. No need for sudo.
**Are you really sure you want to install as root ? (y/N) ?**
I wonder what’s the correct procedure to switch from a older unstable 2.2 with openhab 1.3 to stable 2.2 and openhab 1.4? Also what to backup expect of /etc/openhab2, where does paperui store it’s configuration if I knew something up so I can restore it?
