Hi there, anyone still experiencing problems with the “small” icons .png in /images.
I’m running Openhab on Raspbian (RPi 3B+) and I couldn’t even open the .png files in file explorer on my pi!
It showed me a message saying file format was corrupt.
What I did is this:
Open png files on Windows with Irfanview (maybe other program works too)
Hello everyone,
I picked the free API und installed the habpanel widget.
But I only get 24 h forecast?
I am runnig OH 3 an raspberry und I can´t add more hours:
I’ve have a different trouble: the widget OWM is empty.
I’m using OH3.
I followed the instruction.
The “local weather and forcast” thing is running and I think that all items are correctly linked to the channels because they have an updated value instead of NULL.
I’ve copied images folder, the owm.controller.js file and weather-icons-master folder in /etc/openhab/html/openweathermap. I changed the ownner of the file in the user openhab .
I imported the widget OWM in HABPanel, I tryed to edit and save it, but the widget appears always empty.
Same for me… Oh3, all placed in right directories, things working… If I add a dummy tile with direct link(ex temp) it works, but widget is always empty
I am new here and new to openHAB. I like the OpenWeatherMap widget solution and want to import and configure that on my openHAB. I followed the installiation guide and can see all item in my Paper UI:
My folder structure on my openHAB looks as expected But as I put the corresponding widget to my HABPanel I see nothing. What could be the issue? Thanks for your help!
I’m new here too, but I think I worked out that a possible solution to post #289 might come from the comment in post #287. I believe this is saying to make a directory called “openweathermap” in a different location than the OP has listed on their github page. I’m running OH3 with OWM 3 (on a Raspberry Pi 3 running Raspian stretch) and in order to solve the blank widget issue, I did the following utilizing the command line and the information in this thread:
Follow all instructions from the OP’s git hub page for the installation of the widget, but change the location of where you copy the files according to the next points.
Create a new directory “openweathermap” inside openhab/html/ instead of inside openhab/conf/html.
copy the owm.controller.js file and the weather-icons-master and images directories indicated by the OP into the openhab/html/openweathermap directory.
refresh the panel and see if it worked
I hope this might fix the partial and/or blank widget issue since it seemed to work for me.
Many thanks to Bastiaan for making this wonderful resource!
Cheers!
I put the files into the “openhab-conf” samba folder. That meens, that I copied the needed files into your proposed directory: “/etc/openhab/html/openweathermap”, but it does not work as in many posts described.
Thank you very much for the widget. It’s working out of the box and looks great!
Is there a possibility that nighttime icons will also be used in the future? Or did I miss something within the configuration?
Best regards
EDIT: Have you thought about using the onecall api data for the 4-day forecast? The api delivers the daily minimum and maximum values, so you don´t need a calculation (and it is a bit more precise ). You only need a second thing.
