Hi, I’m new here and I’ve just start my adventure with OpenHAB. I’ve stared with setting upd weather and found this widget. Unfortunately after one day spending on implementing it I only cen get this:
I’ve checked and on dummy widget I can see data from OpenWeather
Any ideas what else should I check to make it work?
That’s what I am currently after:
I am checking the temperature at 4am and 12PM and I assume these to be the minimum and maximum.
One question:
I am using the rain forecast like:
Number:Length W_OWM_Rain3 "FC Rain [%d %unit%]" (G_jdbc) {channel="openweathermap:weather-and-forecast:OWM:local:forecastHours03#rain"}
The widget displays m (of course, because of SI).
How to get it to mm intead?
My code in the widget:
<h5>{{'%.1f' | sprintf:itemValue('W_OWM_RainDay0').split(' ')[0]}}{{itemValue('W_OWM_RainDay0').split(' ')[1]}}</h5>
EDIT: I don’t know, what happend, but it suddenly mm
By the way: I don’t get the rain populated with data.
Does someone have this issue as well?
EDIT 2: Need to check for the 2nd issue (too sunny right know
I was able to see this with no i images:
when type:
<div ng-controller="ngOwmCtrl">
<div class="row owm-row-current">
<div class="col-xs-9">
<i class="wi wi-owm-{{ itemValue('Weather_OWM_ConditionId') }} pull-right" ng-style="{ 'color' : (config.icon_color_current == NULL ? primary-color : config.icon_color_current), 'font-size' : (config.icon_size_current == NULL ? '10em' : config.icon_size_current + 'em') }"></i>
<h2 class="text-left owm-to-upper">{{ itemValue('openweathermap_weather_and_forecast_d3b95f3f_local_current_condition') }}</h2>
</div>
<div class="col-xs-3 text-right">
<h2>{{ '%.1f' | sprintf:itemValue('openweathermap_weather_and_forecast_d3b95f3f_local_current_temperature').split(' ')[0] }} {{ itemValue('openweathermap_weather_and_forecast_d3b95f3f_local_current_temperature').split(' ')[1] }}</h2>
<h5><img style="height:16px;" src="/static/openweathermap/images/humidity.png"/> {{itemValue('openweathermap_weather_and_forecast_d3b95f3f_local_current_humidity') }}</h5>
<h5><img style="height:16px;" src="/static/openweathermap/images/wind.png"/> {{ '%.1f' | sprintf:itemValue('openweathermap_weather_and_forecast_d3b95f3f_local_current_wind_speed').split(' ')[0] }} {{ itemValue('openweathermap_weather_and_forecast_d3b95f3f_local_current_wind_speed').split(' ')[1] }}</h5>
<h5>{{ itemValue('openweathermap_weather_and_forecast_d3b95f3f_local_current_time_stamp') | date: 'HH:mm' }}</h5>
</div>
</div>
When tried get icons I got this:
data:image/png;base64,iVB....
My OpenHAB is on Windows. Any idea how to get it work?
But it doesn’t work for
<div class="row owm-row-forecast">
<div class="col-xs-3 col-md-border">
<h4 class="owm-to-upper">{{ date_time0 | date:(config.config.day_format == NULL ? 'EEEE' : config.day_format) }}</h4>
<i class="wi wi-owm-{{ condition_id0 }}" ng-style="{ 'color' : (config.icon_color_forecast == NULL) ? primary-color : config.icon_color_forecast, 'font-size' : (config.icon_size_forecast == NULL) ? '3em' : config.icon_size_forecast + 'em' }"></i>
<h5 class="owm-condition owm-to-upper">{{ condition0 }}</h5>
<h4><b>{{ temp0 == NULL ? '' : '%.1f' | sprintf:temp0.split(' ')[0]}} {{temp0.split(' ')[1] }}</b></h4>
</div>
<h4 class="owm-to-upper">{{ date_time1 | date:(config.config.day_format == NULL ? 'EEEE' : config.day_format) }}</h4>
<i class="wi wi-owm-{{ condition_id1 }}" ng-style="{ 'color' : (config.icon_color_forecast == NULL) ? primary-color : config.icon_color_forecast, 'font-size' : (config.icon_size_forecast == NULL) ? '3em' : config.icon_size_forecast + 'em' }"></i>
<h5 class="owm-condition owm-to-upper">{{ condition1 }}</h5>
<h4><b>{{ temp1 == NULL ? '' : '%.1f' | sprintf:temp1.split(' ')[0]}} {{temp1.split(' ')[1] }}</b></h4>
</div>
<h4 class="owm-to-upper">{{ date_time2 | date:(config.config.day_format == NULL ? 'EEEE' : config.day_format) }}</h4>
<i class="wi wi-owm-{{ condition_id2 }}" ng-style="{ 'color' : (config.icon_color_forecast == NULL) ? primary-color : config.icon_color_forecast, 'font-size' : (config.icon_size_forecast == NULL) ? '3em' : config.icon_size_forecast + 'em' }"></i>
<h5 class="owm-condition owm-to-upper">{{ condition2 }}</h5>
<h4><b>{{ temp2 == NULL ? '' : '%.1f' | sprintf:temp2.split(' ')[0]}} {{temp2.split(' ')[1] }}</b></h4>
</div>
<h4 class="owm-to-upper">{{ date_time3 | date:(config.config.day_format == NULL ? 'EEEE' : config.day_format) }}</h4>
<i class="wi wi-owm-{{ condition_id3 }}" ng-style="{ 'color' : (config.icon_color_forecast == NULL) ? primary-color : config.icon_color_forecast, 'font-size' : (config.icon_size_forecast == NULL) ? '3em' : config.icon_size_forecast + 'em' }"></i>
<h5 class="owm-condition owm-to-upper">{{ condition3 }}</h5>
<h4><b>{{ temp3 == NULL ? '' : '%.1f' | sprintf:temp3.split(' ')[0]}} {{temp3.split(' ')[1] }}</b></h4>
</div>
Couple of thoughts. First, go to the Paper UI and look at the Control tab. Is OpenWeatherMap shown in Local Weather? Are you getting data?
Next, if that’s good, you may be missing the Items from the setup. Copy the text and paste it into a plain text file with the .items extension and save it to /srv/openhab2-conf/items Once you do that, check the log viewer and you should see OpenHAB refresh the items list.
If you’ve tried setting up other weather widgets and already have a .items file, consider removing those other things first. I had some in there that were incorrectly formed and OpenHAB wouldn’t refresh the items till I removed them. If you’re not using items for anything else, consider just deleting that file and starting over.
Let us know how it turns out!
Okay so you’re getting some data, that’s good. Looks like it is only the current stuff. When you set up the OpenWeatherMaps binding, did you add the forecast data? You don’t need them all. You have the current weather so that’s good. Make sure you added things for Forecast Time, Condition, and Icon for 3, 24, 48, and 72 hours.
Once we get the data working we can take a look at the icon problem.
Looks familiar. Probably your Items have a different name than the Item names the default OWM widget is expecting to see. As a result, the widget is not populated.
In HABPanel, go to the HABPanel settings (cogwheel at the bottom of the left column), and click “Manage custom widgets”. Click the OWM widget so you can see and edit the source code. Mine looks like this:
<div id="container">
<div class="col-md-9">
<i class="wi wi-owm-{{itemValue('Weather_OWM_Current_ConditionId')}} pull-right" ng-style="{ 'color' : (config.icon_color_current == NULL) ? primary-color : config.icon_color_current, 'font-size' : (config.icon_size_current == NULL) ? '10em' : config.icon_size_current + 'em' }"></i>
<h2 class="text-left owm-to-upper">{{itemValue('Weather_OWM_Current_Condition')}}</h2>
</div>
Look for the {{itemValue('Weather_OWM_Current_ConditionId')}}
entries in your OWM widget code, and adapt the names in the widget so they match the names you defined in your openweathermaps.items
file.
For instance, I named all my OWM weather items as follows:
- Current values:
Weather_OWM_Current_XXX
(replace XXX with: Wind, Snow, Temperature, …) - Forecast values:
Weather_OWM_Forecast_XXX_YYh
(replace XXX as above, and YY with 03, 06, 09… until 96 for the 3-hour forecast values)
This way they differ from what the default OWM HABPanel widget is expecting.
Ok, thanks for all feedbaks I will check all. For now I can see this:
So I believe I have forecast. I can seen that it is populatet in events.log
That’s my errors in openhab.log
2019-02-22 11:24:53.027 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'home_items.items' has errors, therefore ignoring it: [1,1]: missing EOF at 'ď'
2019-02-22 11:25:03.542 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.eclipse.smarthome.binding.openweathermap.internal.handler.OpenWeatherMapWeatherAndForecastHandler@6d2a78': Duplicate channels openweathermap:weather-and-forecast:d3b95f3f:local:forecastHours27#time-stamp
java.lang.IllegalArgumentException: Duplicate channels openweathermap:weather-and-forecast:d3b95f3f:local:forecastHours27#time-stamp
2019-02-22 11:25:03.558 [ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'openweathermap:weather-and-forecast:d3b95f3f:local': Duplicate channels openweathermap:weather-and-forecast:d3b95f3f:local:forecastHours27#time-stamp
2019-02-22 11:25:15.496 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule 'Set random image URLs': The name 'ImageURL' cannot be resolved to an item or type; line 138, column 16, length 8
2019-02-22 11:25:20.121 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule 'Set random image URLs': The name 'ImageURL' cannot be resolved to an item or type; line 138, column 16, length 8
2019-02-22 11:25:20.246 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule 'Set random wifi variations': The name 'Wifi_Level' cannot be resolved to an item or type; line 128, column 16, length 10
So it seems that .items file is ignored, hmm?
I have copied files 1:1 from github so I have same same names in .items and in widget
HA I’ve recreate .items file from scrach and paste config lines again and it start to work finaly. No EOF error anymore.
Still have problems with images
I have a feeling that sth is nof fully correct here
Two times Staturday… and for second one -4.5 is here all day since it get start to work.
Strange isn’t it?
I followed your installation guide. Under control in PaperUI I see all values, so settings should be fine.
I added the widget in habpanel but it stayes without showing something.
Strange thing, no entry in openhab.log …
Any ideas what could be wrong or where to look for solution?
That is strange. Did you set up the items file?
Yes I did:
// Open Weather Map
Number:Temperature Weather_OWM_Temperature "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:current#temperature"}
Number:Dimensionless Weather_OWM_Humidity "Humidity [%d %unit%]" {channel="openweathermap:weather-and-forecast:893c3708:current#humidity"}
Number:Speed Weather_OWM_Wind_Speed "Windspeed [%.1f km/h]" {channel="openweathermap:weather-and-forecast:893c3708:current#wind-speed"}
String Weather_OWM_Station_Name "Station Name [%s]" {channel="openweathermap:weather-and-forecast:893c3708:station#name"}
DateTime Weather_OWM_ObservationTime "Observation time [%1$tY-%1$tm-%1$td]" {channel="openweathermap:weather-and-forecast:893c3708:current#time-stamp"}
String Weather_OWM_Condition "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:current#condition"}
String Weather_OWM_ConditionId "ConditionId [%s]" {channel="openweathermap:weather-and-forecast:893c3708:current#condition-id"}
Image Weather_OWM_ConditionIcon "Icon [%s]" {channel="openweathermap:weather-and-forecast:893c3708:current#icon"}
String Weather_OWM_ConditionIconId "IconId [%s]" {channel="openweathermap:weather-and-forecast:893c3708:current#icon-id"}
Number:Temperature Weather_OWM_Temp0 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours03#temperature"}
Number:Temperature Weather_OWM_Temp1 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours24#temperature"}
Number:Temperature Weather_OWM_Temp2 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours48#temperature"}
Number:Temperature Weather_OWM_Temp3 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours72#temperature"}
DateTime Weather_OWM_Forecast_Time0 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours03#time-stamp"}
DateTime Weather_OWM_Forecast_Time1 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours24#time-stamp"}
DateTime Weather_OWM_Forecast_Time2 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours48#time-stamp"}
DateTime Weather_OWM_Forecast_Time3 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours72#time-stamp"}
String Weather_OWM_Condition0 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours03#condition"}
String Weather_OWM_Condition1 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours24#condition"}
String Weather_OWM_Condition2 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours48#condition"}
String Weather_OWM_Condition3 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours72#condition"}
String Weather_OWM_ConditionId0 "Icon [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours03#condition-id"}
String Weather_OWM_ConditionId1 "Icon [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours24#condition-id"}
String Weather_OWM_ConditionId2 "Icon [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours48#condition-id"}
String Weather_OWM_ConditionId3 "Icon [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours72#condition-id"}
Number:Temperature Weather_OWM_Temp_h3 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours03#temperature"}
Number:Temperature Weather_OWM_Temp_h6 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours06#temperature"}
Number:Temperature Weather_OWM_Temp_h9 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours09#temperature"}
Number:Temperature Weather_OWM_Temp_h12 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours12#temperature"}
Number:Temperature Weather_OWM_Temp_h15 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours15#temperature"}
Number:Temperature Weather_OWM_Temp_h18 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours18#temperature"}
Number:Temperature Weather_OWM_Temp_h21 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours21#temperature"}
Number:Temperature Weather_OWM_Temp_h24 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours24#temperature"}
Number:Temperature Weather_OWM_Temp_h27 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours27#temperature"}
Number:Temperature Weather_OWM_Temp_h30 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours30#temperature"}
Number:Temperature Weather_OWM_Temp_h33 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours33#temperature"}
Number:Temperature Weather_OWM_Temp_h36 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours36#temperature"}
Number:Temperature Weather_OWM_Temp_h39 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours39#temperature"}
Number:Temperature Weather_OWM_Temp_h42 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours42#temperature"}
Number:Temperature Weather_OWM_Temp_h45 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours45#temperature"}
Number:Temperature Weather_OWM_Temp_h48 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours48#temperature"}
Number:Temperature Weather_OWM_Temp_h51 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours51#temperature"}
Number:Temperature Weather_OWM_Temp_h54 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours54#temperature"}
Number:Temperature Weather_OWM_Temp_h57 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours57#temperature"}
Number:Temperature Weather_OWM_Temp_h60 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours60#temperature"}
Number:Temperature Weather_OWM_Temp_h63 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours63#temperature"}
Number:Temperature Weather_OWM_Temp_h66 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours66#temperature"}
Number:Temperature Weather_OWM_Temp_h69 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours69#temperature"}
Number:Temperature Weather_OWM_Temp_h72 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours72#temperature"}
Number:Temperature Weather_OWM_Temp_h75 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours75#temperature"}
Number:Temperature Weather_OWM_Temp_h78 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours78#temperature"}
Number:Temperature Weather_OWM_Temp_h81 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours81#temperature"}
Number:Temperature Weather_OWM_Temp_h84 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours84#temperature"}
Number:Temperature Weather_OWM_Temp_h87 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours87#temperature"}
Number:Temperature Weather_OWM_Temp_h90 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours90#temperature"}
Number:Temperature Weather_OWM_Temp_h93 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours93#temperature"}
Number:Temperature Weather_OWM_Temp_h96 "Temperature [%.1f %unit%]" <temperature> {channel="openweathermap:weather-and-forecast:893c3708:forecastHours96#temperature"}
String Weather_OWM_Condition_h3 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours03#condition"}
String Weather_OWM_Condition_h6 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours06#condition"}
String Weather_OWM_Condition_h9 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours09#condition"}
String Weather_OWM_Condition_h12 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours12#condition"}
String Weather_OWM_Condition_h15 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours15#condition"}
String Weather_OWM_Condition_h18 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours18#condition"}
String Weather_OWM_Condition_h21 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours21#condition"}
String Weather_OWM_Condition_h24 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours24#condition"}
String Weather_OWM_Condition_h27 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours27#condition"}
String Weather_OWM_Condition_h30 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours30#condition"}
String Weather_OWM_Condition_h33 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours33#condition"}
String Weather_OWM_Condition_h36 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours36#condition"}
String Weather_OWM_Condition_h39 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours39#condition"}
String Weather_OWM_Condition_h42 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours42#condition"}
String Weather_OWM_Condition_h45 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours45#condition"}
String Weather_OWM_Condition_h48 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours48#condition"}
String Weather_OWM_Condition_h51 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours51#condition"}
String Weather_OWM_Condition_h54 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours54#condition"}
String Weather_OWM_Condition_h57 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours57#condition"}
String Weather_OWM_Condition_h60 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours60#condition"}
String Weather_OWM_Condition_h63 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours63#condition"}
String Weather_OWM_Condition_h66 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours66#condition"}
String Weather_OWM_Condition_h69 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours69#condition"}
String Weather_OWM_Condition_h72 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours72#condition"}
String Weather_OWM_Condition_h75 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours75#condition"}
String Weather_OWM_Condition_h78 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours78#condition"}
String Weather_OWM_Condition_h81 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours81#condition"}
String Weather_OWM_Condition_h84 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours84#condition"}
String Weather_OWM_Condition_h87 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours87#condition"}
String Weather_OWM_Condition_h90 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours90#condition"}
String Weather_OWM_Condition_h93 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours93#condition"}
String Weather_OWM_Condition_h96 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours96#condition"}
String Weather_OWM_ConditionId_h3 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours03#condition-id"}
String Weather_OWM_ConditionId_h6 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours06#condition-id"}
String Weather_OWM_ConditionId_h9 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours09#condition-id"}
String Weather_OWM_ConditionId_h12 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours12#condition-id"}
String Weather_OWM_ConditionId_h15 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours15#condition-id"}
String Weather_OWM_ConditionId_h18 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours18#condition-id"}
String Weather_OWM_ConditionId_h21 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours21#condition-id"}
String Weather_OWM_ConditionId_h24 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours24#condition-id"}
String Weather_OWM_ConditionId_h27 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours27#condition-id"}
String Weather_OWM_ConditionId_h30 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours30#condition-id"}
String Weather_OWM_ConditionId_h33 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours33#condition-id"}
String Weather_OWM_ConditionId_h36 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours36#condition-id"}
String Weather_OWM_ConditionId_h39 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours39#condition-id"}
String Weather_OWM_ConditionId_h42 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours42#condition-id"}
String Weather_OWM_ConditionId_h45 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours45#condition-id"}
String Weather_OWM_ConditionId_h48 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours48#condition-id"}
String Weather_OWM_ConditionId_h51 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours51#condition-id"}
String Weather_OWM_ConditionId_h54 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours54#condition-id"}
String Weather_OWM_ConditionId_h57 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours57#condition-id"}
String Weather_OWM_ConditionId_h60 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours60#condition-id"}
String Weather_OWM_ConditionId_h63 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours63#condition-id"}
String Weather_OWM_ConditionId_h66 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours66#condition-id"}
String Weather_OWM_ConditionId_h69 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours69#condition-id"}
String Weather_OWM_ConditionId_h72 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours72#condition-id"}
String Weather_OWM_ConditionId_h75 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours75#condition-id"}
String Weather_OWM_ConditionId_h78 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours78#condition-id"}
String Weather_OWM_ConditionId_h81 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours81#condition-id"}
String Weather_OWM_ConditionId_h84 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours84#condition-id"}
String Weather_OWM_ConditionId_h87 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours87#condition-id"}
String Weather_OWM_ConditionId_h90 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours90#condition-id"}
String Weather_OWM_ConditionId_h93 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours93#condition-id"}
String Weather_OWM_ConditionId_h96 "Condition [%s]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours96#condition-id"}
DateTime Weather_OWM_ DateTime_h3 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours03#time-stamp"}
DateTime Weather_OWM_ DateTime_h6 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours06#time-stamp"}
DateTime Weather_OWM_ DateTime_h9 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours09#time-stamp"}
DateTime Weather_OWM_ DateTime_h12 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours12#time-stamp"}
DateTime Weather_OWM_ DateTime_h15 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours15#time-stamp"}
DateTime Weather_OWM_ DateTime_h18 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours18#time-stamp"}
DateTime Weather_OWM_ DateTime_h21 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours21#time-stamp"}
DateTime Weather_OWM_ DateTime_h24 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours24#time-stamp"}
DateTime Weather_OWM_ DateTime_h27 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours27#time-stamp"}
DateTime Weather_OWM_ DateTime_h30 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours30#time-stamp"}
DateTime Weather_OWM_ DateTime_h33 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours33#time-stamp"}
DateTime Weather_OWM_ DateTime_h36 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours36#time-stamp"}
DateTime Weather_OWM_ DateTime_h39 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours39#time-stamp"}
DateTime Weather_OWM_ DateTime_h42 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours42#time-stamp"}
DateTime Weather_OWM_ DateTime_h45 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours45#time-stamp"}
DateTime Weather_OWM_ DateTime_h48 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours48#time-stamp"}
DateTime Weather_OWM_ DateTime_h51 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours51#time-stamp"}
DateTime Weather_OWM_ DateTime_h54 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours54#time-stamp"}
DateTime Weather_OWM_ DateTime_h57 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours57#time-stamp"}
DateTime Weather_OWM_ DateTime_h60 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours60#time-stamp"}
DateTime Weather_OWM_ DateTime_h63 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours63#time-stamp"}
DateTime Weather_OWM_ DateTime_h66 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours66#time-stamp"}
DateTime Weather_OWM_ DateTime_h69 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours69#time-stamp"}
DateTime Weather_OWM_ DateTime_h72 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours72#time-stamp"}
DateTime Weather_OWM_ DateTime_h75 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours75#time-stamp"}
DateTime Weather_OWM_ DateTime_h78 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours78#time-stamp"}
DateTime Weather_OWM_ DateTime_h81 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours81#time-stamp"}
DateTime Weather_OWM_ DateTime_h84 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours84#time-stamp"}
DateTime Weather_OWM_ DateTime_h87 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours87#time-stamp"}
DateTime Weather_OWM_ DateTime_h90 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours90#time-stamp"}
DateTime Weather_OWM_ DateTime_h93 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours93#time-stamp"}
DateTime Weather_OWM_ DateTime_h96 "Forecast time [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" {channel="openweathermap:weather-and-forecast:893c3708:forecastHours96#time-stamp"}
Wow, yes you did!
If you were to edit it and save it, does it show in the OpenHAB Log Viewer that it is refreshing the items? Something like:
2019-02-24 07:44:02.490 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2019-02-24 17:45:03.240 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'openweathermap.items'
again a clear: yes
Is there more to do as to add the widget?
I am with Homer-Sim.
I followed through things exactly. I can see all items, in the correct units, on PaperUI and can create a Dummy widget to display particular items.
BUT, the created widget is blank. Tried all items on this thread with no luck.
Also, when I import the widget manually (from downloaded file, not from “get more”), I get an error which states:
Error
Widget import error: SyntaxError: Unexpected token < in JSON at position 6
Any ideas?
Thanks, I did the same stupid mistake, this saved me
Okay, that’s weird. I had a problems like this with the WeatherUnderground widget and never figured it out so I switched to the OpenWeatherMap one. Still had some problems but was able to work through them.
I think the best way to troubleshoot this is to pick one weather item and see if we can get it working. If we can, that should tell us what is wrong with all of them.
Try this, go to Paper UI > Configuration > Things > Local weather and forecast and take a look at Weather Condition
Expand the thing by click on the arrows to the right of it and see what it says for Linked Items. Here’s what I have, what are you seeing?
I don’t and it is working. What is that?
