Override widget configuration
I have a widget (TemperatureHumidity) which is based on the oh-label-cell.
In the widget the action is hardwired to “analyze”. Is it possible to override this for a single instance of the widget in the instance’s YAML configuration? Or do I have to change the widget itself to allow users to set different actions? I tried to just add the action and actionUrl to the YAML of one widget instance, but it seems to be ignored, it still goes to analyze. Is this not possible, or am I just doing it wrong?
Regards, Robert
No.
Yes.
You could, of course, just use widget expressions with props, but that gets out of hand quickly, because many of the action options have their own specific settings and you would have to account for each one of those with a different property.and widget expression. Fortunately, there’s an intentional, built-in, fairly clever way to do this.
The shortcut is to include a parameterGoup in the widget header info with an action context. If you do that, then your widget config popup will include the default OH action configuration section which allows your user to configure the action type and all the required sub settings as usual.
To get that information into your widget, you also give that parameterGroup a name and then set that name as the actionPropsParameterGroup of the component that should perform that action. You don’t even need to directly configure any of the action properties for that component, it’s all taken care of by the actionPropsParameterGroup.
Take a look at my confirm button widget to see an example of this in action:
Thanks, that is a great solution! Is there a way to define default values for the parameters in the group?
Yes, but it’s kind of obscure (also, more hack than intentional feature, I would guess).
There’s a lot going on in the background when you use the action parameter group, but it boils down to the fact that a series of values are automatically generated that match the required action with a prefix added that is the name you gave the group. So internally, if you have an action parameter group that you’ve named 'buttonPress' then there is a value buttonPress_action that holds the action type the user has selected in the configuration window.
This is important knowledge for two reasons:
  1. it means we can configure a widget that has an action parameter group in the text editor instead of having to use the configuration wizard. For example, this could be used to configure the confirm button widget linked to above (the action parameter group is named confirmed):
component: widget:jag_confim_button
    confirmed_action: toggle
    confirmed_actionCommand: ON
    confirmed_actionCommandAlt: OFF
    confirmed_actionItem: SomeItemName
    text: Confirm item toggle
  1. it means that we can actually override these properties by defining regular props in the widget with those names, and we can add default values to defined props. So if you just create a text property of groupname_action with a default value of 'analyzer' then your action parameter group will have a value for the action even if the user hasn’t opened up the configuration wizard and set one manually yet. Wash, rinse, repeat for each of the action values that you want to have default values for.
The one extra piece here is that if you create those props they will show up in the configuration wizard which will be confusing for users because they will just be duplicates of the action inputs in that same wizard. You can easily hide all these extra props however by giving them some other group name and then not defining that group under the widget’s parameterGroups. For instance, I like to use groupName: hidden.
Altogether it looks like this. If you have this action parameter group:
  parameterGroups:
    - name: myWidgetAction
      context: action
      label: Action widget should perform
Then to add a default action value for that you would also define the property:
    - name: myWidgetAction_action
      type: TEXT
      groupName: hidden
      label: Action default
      default: analyzer
That does not seem to work for me. I have first tried to create the group customAction with context=action. If I set an action there, it works and the widget executes that action. However I tried to use the action value as header just for testing with “props.customAction_action” but that remains undefined. If I define hidden props with that name (commented out in the example below) then “props.customAction_action” does have a value, but it does not define the action. The action is still empty if not set explicitly in the configuration UI.
Did I get something wrong about how to name these generated properties?
uid: TemperatureHumidity
tags:
  - humidity
  - standalone
  - temperature
props:
  parameters:
    - description: Title of the cell.
      label: Title
      required: true
      type: TEXT
      groupName: title
    - context: item
      description: The state of this item will be displayed as temperature.
      label: Temperature item
      required: true
      type: TEXT
      groupName: items
    - context: item
      description: The state of this item will be displayed as humidity.
      label: Humidity item
      required: true
      type: TEXT
      groupName: items
    - context: item
      description: The display state of this item will be displayed as last update
        timestamp. Use an item with the timestamp as state and set the pattern
        of the "State Description" metadata to format the timestamp.
      label: Last update item
      required: false
      type: TEXT
      groupName: items
    - description: Label to be displayed in front of the temperature.
      label: Temperature Label
      required: false
      type: TEXT
      groupName: labels
    - description: Suffix to be displayed after the temperature.
      label: Temperature Suffix
      required: false
      type: TEXT
      groupName: labels
    - description: Label to be displayed in front of the humidity.
      label: Humidity Label
      required: false
      type: TEXT
      groupName: labels
    - description: Suffix to be displayed after the humidity.
      label: Humidity Suffix
      required: false
      type: TEXT
      groupName: labels
    - description: Label to be displayed in front of the last update timestamp.
      label: Last Update Label
      required: false
      type: TEXT
      groupName: labels
#    - default: analyzer
#      label: Action default
#      name: customAction_action
#      required: false
#      type: TEXT
#      groupName: hidden
#    - default: =[props.hum_item, props.tmp_item]
#      name: customAction_actionAnalyzerItems
#      required: false
#      type: TEXT
#      groupName: hidden
  parameterGroups:
    - name: title
      label: Title
    - name: items
      label: Items
    - name: labels
      label: Labels
    - name: customAction
      context: action
      label: Action
timestamp: Feb 9, 2025, 10:41:01 AM
component: oh-label-cell
  actionPropsParameterGroup: customAction
#  action: analyzer
#  actionAnalyzerItems: =[props.hum_item, props.tmp_item]
  expandable: false
  footer: '= (props.update_item ? (props.update_label ? props.update_label :
    "")  + " " + items[props.update_item].displayState : "")'
#  header: = props.title
  header: = props.customAction_action
  icon: oh:temperature
  label: '= (props.tmp_label ? props.tmp_label + " " : "") +
    items[props.tmp_item].state + (props.tmp_suffix ? " " + props.tmp_suffix :
  subtitle: '= (props.hum_label ? props.hum_label + " " : "") +
    items[props.hum_item].state + (props.hum_suffix ? " " + props.hum_suffix :
  trendItem: = props.tmp_item
There are two things going on here (one I didn’t know until testing your code).
Yes, I was careless when typing up this example and used myWidgetAction as a demonstration. Actually, this trick doesn’t work if your action name base includes the word ‘action’ in it. If you just change everything from customAction to something like customAct (or even ‘asdf’ for that matter), you will fix that issue. Sorry, my bad.
The second issue is a weird one and took me a little time to track down. This doesn’t work if you are trying to do it on the root element of the widget…for…reasons…(I actually have zero explanation for this at this time). If you make the root element of the widget some basic container, such as a simple div and put your label cell inside that, everything works (at least it did in my tests):
component: div
slots:
  default:
    - component: oh-label-cell
        ...rest of widget...
Thanks a lot, I’d never have figured that one out!
I went for a slightly different approach for the default values now. Based on an idea from @djal, I used the customAct_action to decide if actionPropsParameterGroup is set. If the action in the properties is undefined, then actionPropsParameterGroup will not be set and therefore it will fall back to the action/actionAnalyzerItems values set before. This requires less code and also seems to work without that basic container.
Here is the code:
tags:
  - humidity
  - standalone
  - temperature
props:
  parameters:
      label: Title
      required: true
      type: TEXT
      groupName: title
    - context: item
      required: true
      type: TEXT
      groupName: items
    - context: item
      required: true
      type: TEXT
      groupName: items
    - context: item
      required: false
      type: TEXT
      groupName: items
      required: false
      type: TEXT
      groupName: labels
      required: false
      type: TEXT
      groupName: labels
      required: false
      type: TEXT
      groupName: labels
      required: false
      type: TEXT
      groupName: labels
      required: false
      type: TEXT
      groupName: labels
  parameterGroups:
    - name: title
      label: Title
    - name: items
      label: Items
    - name: labels
      label: Labels
    - name: customAct
      context: action
      label: Action
timestamp: Feb 9, 2025, 7:10:06 PM
  actionPropsParameterGroup: '= props.customAct_action ? "customAct" : ""'
  action: analyzer
  expandable: false
