POPP 10 year Smoke Detector has possibly the wrong id
Hello All,
@chris told me to ask here. I have the POPP Outdoorsiren with id 0004:0002 and Firmware-Version 1.1. Sadly it is detectet as the 10year Smoke Detector. Because this one have the same id in the database.
Now i search for people, who have the Smoke Detector. To identify the right Id in OpenHAB. So that we can correct the database.
Herbert
It’s probably worth also looking here -:
https://github.com/openhab/org.openhab.binding.zwave/issues/311
Hello @chris,
yes i am aware of this, but i wrote in the Issue, that my Siren has the Firmware Version 1.1 and therefore it is detected wrong by the binding.
So if anyone have the popp smoke detector with id 0004:0002, please write here, that we can identify a solution for the problem.
Herbert
Hello @chris,
meanwhile i have answer from POPP. Thay say, that die Siren have the ID 0004:0002 and the Smoke Detector the ID 0004:0004.
See here its in german, but i think you see it:
Die ManufakturID für alle Popp Geräte is 0x0154
Die Solar Außensirene hat die ID’s Produkttyp ID 0004 und die Produkt ID 0002
Der 10 Jahres Rauchmelder hat die ID’s Produkttyp ID 0004 und die Produkt ID 0004
Should i change this in the Database?
Herbert
Yes - let’s go with that. Please make a comment in the database - either pasting this text from Popp, and/or referencing this post.
Thanks.
Hi!
Sorry for late response.
After I have managed to integrate my 004:004 v1.14 smoke detector to oh2
I have decided to buy three further devices from the same vendor.
Unfortunatelly this 3 devices are running on firmware 1.1 and with ids 004:002
Seems that Popp had a problem within firmware 1.1 of this device. So maybe firmwareupdate will help to get correct IDs. Unfortunatelly I haven’t found a solution to do an upgrade of my device.
@chris: do you see any chance to handle this duplicates?
Otherwise this would mean all smoke detectors with version 1.1 will not work in future.
BR
Martin
There’s no nice way to do this I think. All I can currently suggest is to include the device into the network, let it create the XML, and then edit the XML to set it to 0004:0004. This should work so long as the XML doesn’t get deleted (which can happen if there are changes to the binding that impact the format).
The other option (maybe!) is to send the incorrect ones back to Popp and ask them to replace them with ones that are correctly defined, as per their own statement above ;).
Hello Martin,
i would suggest, that you take contact with Popp, if they can update the firmware for you. I’ve contacted Popp in the past and they say, that this problem is fixed in newer firmware, so this would be the easiest way to solve the problem.
Herbert
I have 6 smoke detectors with firmware 1.1 and they worked properly for several months. In spring I updated to a newer version of OH2. Yesterday i had to swap one battery of the z-wave module of a smoke detector because it had no power. After swapping the battery the smoke detector was recognised as a new node and also recognised as “5107 Solar Powered Outdoor Siren”. The other smoke detectors are still working properly. The workaround from Chris doesn’t work (edit the node.xml to set it to 0004:0004) in my environment.
Did you find any solution or is there any other workaround?
I don’t think that POPP will replace the z-wave modules.
Thanks & Regards,
Martin
Hi!
I have contacted POPP and they have managed a free software update via one of their partners.
Br
Martin
