thisisIO
(Michael)
January 21, 2019, 2:26pm
1
i would like to postUpdate (but not send a command) on Group of items:
Group:Switch:OR(ON, OFF) gSocket_3_All "All Office Lights [(%d)]" <light> (All)
Switch Socket_3_1 "Table" <light> (GoogleHome, gLight, gSocket, gOfficeRoom, gSocket_3_All) [ "Lighting" ]
Switch Socket_3_2 "Retro" <light> (GoogleHome, gLight, gSocket, gOfficeRoom, gSocket_3_All) [ "Lighting" ]
Switch Socket_3_3 "LED" <light> (GoogleHome, gLight, gSocket, gOfficeRoom, gSocket_3_All) [ "Lighting" ]
Switch Socket_3_4 "Top" <light> (GoogleHome, gLight, gSocket, gOfficeRoom, gSocket_3_All) [ "Lighting" ]
Here a string from my rules:
gSocket_3_All.postUpdate(OFF)
This string rule do not work.
Maybe there is other syntax for update on group. But i can not find it.
Thanks a lot!
Not sure, but in my installation postUpdate on groups is not working only send.
I use group.send not group.sendCommand (don’t know why, it is working and I don’t want to change my running system), I commented sendCommand out in my rule code and have send in my config, cannot rethink why. Maybe sendCommand was not working too, only send.
vzorglub
(Vincent Regaud)
January 21, 2019, 9:21pm
3
Only sendCommand works for cascading down to group item.
It can be done is a rule:
Please see Design Pattern: What is a Design Pattern and How Do I Use Them for how to read and use DPs.
Problem Statement
Often one finds a number of Rules that are very similar and that all work on similar Items resulting in a lot of duplicated code. One way to solve this problem is through the use of Groups.
Concept
[image]
This DP is not a standard DP in that it provides a single concrete template to follow to solve a specific problem. Instead this DP is more of a grand exploration of some …
rossko57
(Rossko57)
January 21, 2019, 9:33pm
4
Because a Group state is some kind of aggregate of its members - OR, SUM, AVG - you cannot update it, even when an aggregate function isn’t given.
It’s difficult to see what the purpose would be, actually. What is it you are trying to achieve ?
