Having a read of the URL of the other Car presence for Home Assistant on github as posted above, I can see why he uses a Wemos D1 Mini Pro (the pro has more flash, but more importantly supports an external antenna) Because to gain more accuracy, we need more RSSI signal strength samples taken over a longer period of time, and the only way to gain more (wireless air) time is to achieve a further distance, and the only way to do that is to add a larger antenna to the client.
So as the vehicle begins to arrive home, the Wemos (with antenna) associates with your Wireless AP much earlier, and therefore the baseline that the code takes should have a relatively weak signal. As the car drives up your driveway and closer to your house, the signal gets stronger and therefore associates the car with arriving home. Conversely, if the car starts up from say your garage or driveway, the signal should be relatively strong (assuming your garage is near your house / access point) and gets weaker as you gradually leave home.
The MQTT LWT (last will and testament) - eg: “MQTT broker checks to see whether it has received regular polling messages from the Wemos, if yes (1 = alive) or no (0 = dead)” - this basically overrides the signal strength as determined in OpenHAB (but only for being at home). In other words, the vehicle.rules in OpenHAB will help iron out any discrepancies by comparing both LWT and whatever the Wemos predicts as to being “home” or “away”.
LWT = alive & RSSI = getting stronger, then (arriving) = HOME
LWT = alive & RSSI = getting weaker, then (leaving, but still) = HOME
LWT = dead & (last) RSSI = getting stronger, then = HOME
LWT = dead & (last) RSSI = getting weaker, then = AWAY
So only a weaker signal and LWT dead will generate an Away, which makes sense.
I’ve done more testing, and it still seems to work ok (except that when arriving home, the Wemos D1 Mini only just connects to Wifi about 2 seconds before I go to switch my ignition off, so it may not have a chance to even tell OpenHAB it’s home) so I’ve just ordered a Wemos D1 Mini Pro with aerial from Aliexpress to test further. The 3D printed case on the Home Assistant Car presence for the Wemos Pro is pretty cool, so might steal his STL and print one myself
Will see how it goes when the Pro turns up…
