I didnāt go through the whole log, but the binding seems to have information about a wide range of devices, and immediately after these log messages it updates the discovery service -:
Thanks - looks fine as well (standard HA link key is still in use) so devices should be able to join ok with that. It looks like the same policies as standard, and I certainly have no problems getting an Osram bulb to join.
Is it just one device that youāve having problems with (letās ignore Xiaomi devices for a second at least)?
To be sure, I just tried three to pair three other devices:
First one is a KSentry On Off Controller (01124B001C2E7B92). Though discovered as āUnknown Zigbee Deviceā, I added this one as a thing after discovery, but information but did not get completed.
Second one is the Osram Smart Plug (7cb03eaa00b286f8) which earlier today was the first and only device I could successfully pair (I removed it again for testing).
Third one is an Ikea Tradfri Signal Repeater (000D6FFFFE9A0D40)
Here is the log trying to discover these three devices (again itās a .zip-file): openhab_2.txt (100.9 KB)
None of them did complete discovery, all stayed āUnknown Zigbee Devicesā (and all used to work with earlier versions).
I donāt know anything about these devices, but looking in the log, they do not respond - at least the Tradfri doesnāt respond and the NCP canāt communicate with it (ie it does not respond).
Iāve no idea why without a network log (and even then it may not tell whatās going on). Clearly the device joined the network - maybe it left again due to key exchange issues - I really canāt tell from this.
Thereās one setting I could look at changing, it may help, or it may cause a load of problems (it was changed as it caused problems with some devices). However thereās no easy way to change that right now but Iāll have a look at coming up with a CLI command to do this.
A couple of days ago, I received an Ikea Tradfri light bulb (model: TRADFRI bulb E27 WS opal 1000lm). In contrast to the light bulbs I was talking about above (tint color+white), pairing works instantly on OpenHab 2.5 and I am also able to control the brightness and color temperature.
Just to be clear: The tint bulbs worked well in OpenHab 2.4 and even in OpenHab 2.5 after upgrading. Itās just the pairing that seems to be broken in 2.5.
I am using the regular 2.5 zigbee binding, not the 2.5.1 that was talked about above. I can update manually and do some further tests if needed, but unfortunately, I wonāt have much time during the coming days. I might be able to do some testing on the next weekend, if this is still of any help. Just let me know.
@chris seems to have the same Ikea Tradfri bulbs working that I have now working as well, but @mrfrh and @chris both have an Osram smart plug and @mrfrhās isnāt working while @chrisās is. Maybe differences in the pairing of that Osram smart plug can give some insight. But I am just guessing
I just tested Openhab 2.5 stable and the Ember dongle on my laptop running opensuse linux. And, surprise, I could immediately pair all the things (including the xiaomi sensors) that didnāt work yesterday. I also paired one of the tradfri bulbs mentioned in the first post (i even tried two times because I couldnāt believe it :-D).
So, my conclusions:
Dongle and Zigbee hardware is ok.
Combination of Openhab 2.5 stable / Zigbee binding / Ember dongle / Firmware 5.8 is ok, too.
Combination of 1. & 2. with my raspberry pi / openhabian 1.5 is problematic for me:
3.1 fresh install of openhabian 1.5 / openhab 2.5 stable ā pairing (especially tradfri bulbs) didnāt work
3.2 downgrade to openhab 2.5 M2 ā pairing worked
3.3 upgrade to openhab 2.5 stable again ā paring didnāt work, even with things that initially worked in step 3.1 (Osram plugs)
So, to conclude: I think I should format my Raspberry PI SSD and start to install 2.5 from scratch, maybe with a different OS. This will take some time, but Iāll let you know if it worked!
@chris Many many thanks for your support! And sorry for āblamingā the zigbee binding while this actually seems to be caused by something elseā¦
@porst17 Do you also have the possibility to try your zigbee hardware with a different system?
Hello Martin,
I was following the discussion, because I have the same issue as you. I was also running 2.5 official OpenHAB and upgraded the zigbee binding to the version which you linked above.
Iām using a Telegesis (Qivicon) dongle connected to a raspberry pi (version 3). The linux is a custom build yocto system. So I think your reinstallation might not solve the issue.
Maybe the issue is related to the performance of the RPI. Maybe some changes which effect timing and the RPI is too slow to handle some requests?
This is a totally different device than we are talking about here, so the joining issue is almost certainly not the same. The Telegesis dongle is getting a bit old and doesnāt support ZB3.0 so it may depend on your devices if it will work or not.
I think thatās not very likely in this case - there was no sign of lost frames etc in the logs I looked at either. Really, ZigBee communications isnāt especially fast in the grand scheme of things.
Thanks for the quick reply.
But it doesnāt explain to me why I was able to pair the same Lupus Temp Sensor with one of the Milestone releases. (Same dongle, Same RPI)
Now it does find the Lupus, but only as unknown device. Iām able to add it as Thing, but then in the Thing overview it just says: āStatus: OFFLINE Node has not completed discoveryā
Ok, but you didnāt mention anything about this in your previous message! Itās hard for me to comment on things that you donāt say.
Ok. Is there any more information you can provide? Do you have a sniffer log, or at least a binding log? Itās really difficult for me to really comment when the only information I have is āit doesnāt workā - sorry.
I was able to quickly test OpenHab 2.5 in an Ubuntu 19.10 virtual machine running in VirtualBox on my MacBook Pro. I donāt have another physical machine at hand.
I mounted the BV dongle into the VM. Discovery of the dongle was without problems.
Trying to pair my tint lamps resulted in the same issue: āUnknown device ā¦ā
Pairing the Ikea Tradfri lamps just works
Openhabian (tested on Rpi 0w and 3B) and Ubuntu 19.10 (amd64, Linux VM) are both based on the same Debian release (buster) and share the same symptoms with OpenHab 2.5 and the BV dongle.
The only logs I can provide are the regular OpenHab ZigBee logs I already provided above for these devices, no sniffer log AFAICS.
Maybe that Osram smart plug is a more promising candidate for debugging, because you seem to own one as well as @mrfrh. And @mrfrh has a working and non-working OpenHab 2.5 configuration.
