I’ll have to take a look - I look at so many logs, and there are so many threads here and from other customers that it’s hard to remember (especially in these forums where everything is unstructured).
Ok, these are still using old bindings. Please use the latest binding from 2.5.1.
Seems like Debian packages for 2.5.1 are still being built. RPMs are already there. Will test and post logs once 2.5.1 DEBs are out.
Ok, I’ve bought some of the Muller lights so I’ll have a look at them once they arrive.
I upgraded my Ubuntu 19.10 VM to OpenHab 2.5.1. Here is a log the following actions:
- Reset tint color+white light bulb (
00158D0001FDF3BD
). - Start OpenHab 2.5.1 service.
- Add BV dongle as a thing.
- Start ZigBee discovery.
- Switch on tint color+white light bulb (
00158D0001FDF3BD
). The bulb starts in pairing mode. - The bulb appears in the inbox.
- Add bulb as a thing.
- Wait a little until the thing status turns to
ONLINE
. - At this point, the bulb itself still doesn’t signal successful pairing. It stays in a dimmed mode like it is waiting for something.
- I try to modify the lamp colors via the control panel in Paper UI. The values change in Paper UI, but the lamp does not respond.
openhab_2.5.1.log (422.6 KB)
I hope this new log is of any help. Thank you.
Yesterday I updated openhab to version 2.5.1 stable.
Since the update my aqara sensors are not working any longer, but other zigbee devices are working fine.
I haven’t tried to re-discover the devices yet.
Please can somebody give some advice how to solve the problem.
Openhab is running on PI4 with Openhabian image.
CC2531 Dongle is used.
The log level is not set to debug yet, but I can see the following entries in the log file:
2020-01-14 21:35:03.373 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 00158D0004116DF3: Starting ZigBee device discovery
2020-01-14 21:35:03.384 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 00158D000388E493: Starting ZigBee device discovery
2020-01-14 21:35:03.402 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 00158D00041105F6: Starting ZigBee device discovery
2020-01-14 21:35:03.407 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 00158D000342BF4D: Starting ZigBee device discovery
2020-01-14 21:35:14.574 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-01-14 21:35:14.575 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-01-14 21:36:36.783 [ERROR] [converter.ZigBeeConverterSwitchLevel] - 00158D000388E493: Error opening device level controls
2020-01-14 21:36:36.785 [INFO ] [ng.zigbee.handler.ZigBeeThingHandler] - 00158D000388E493: Channel zigbee:device:stick1:00158d000388e493:00158D000388E493_1_dimmer failed to initialise device
2020-01-14 21:36:42.812 [ERROR] [converter.ZigBeeConverterSwitchLevel] - 00158D000342BF4D: Error opening device level controls
2020-01-14 21:36:42.814 [INFO ] [ng.zigbee.handler.ZigBeeThingHandler] - 00158D000342BF4D: Channel zigbee:device:stick1:00158d000342bf4d:00158D000342BF4D_1_dimmer failed to initialise device
2020-01-14 21:36:52.901 [ERROR] [531.network.packet.ZToolPacketStream] - Packet parsing failed due to exception.
com.zsmartsystems.zigbee.dongle.cc2531.network.packet.ZToolParseException: Packet checksum failed
at com.zsmartsystems.zigbee.dongle.cc2531.network.packet.ZToolPacketStream.parsePacket(ZToolPacketStream.java:141) [bundleFile:?]
at com.zsmartsystems.zigbee.dongle.cc2531.network.packet.ZToolPacketParser.run(ZToolPacketParser.java:107) [bundleFile:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
2020-01-14 21:36:52.910 [ERROR] [531.network.packet.ZToolPacketStream] - Packet parsing failed due to exception.
2020-01-14 21:36:52.917 [ERROR] [531.network.packet.ZToolPacketStream] - Packet parsing failed due to exception.
2020-01-14 21:37:19.745 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-01-14 21:37:19.748 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-01-14 21:37:19.750 [WARN ] [ding.zigbee.handler.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
2020-01-14 21:37:26.186 [ERROR] [531.network.packet.ZToolPacketStream] - Packet parsing failed due to exception.
Without a debug log it’s not really possible to say what’s happening - I can say that the binding hasn’t found some information it needs so we get the “failed opening device control” error, and there is a packet checksum failure which probably indicates an error in the reception of a frame on the serial port.
I can’t really comment much more than this.
I would recommend you to open a separate thread, as this topic is about different hardware and a different problem.
Based on advice I’ve created a separate thread.
Yesterday, I did another attempt with openhabian 1.4 / Openhab 2.5.1.
It wasn’t a 100% fresh install as I started with fresh 2.5 M2 to include two spirit zigbee thermostats and then upgraded to 2.5.1. Though zigbee was the only binding installed, this ended up with new errors (“Error reading from serial port”, “Adding local node to network: NWK unknown”) after upgrading from fresh 2.5 M2 to 2.5.1.
Finally I decided to give up on this issue, at least for the next months until things are stabilized. I already spent too many hours on this
I installed 2.5 M2 again - and as expected, everything just works.
Hello Martin,
just for my curiosity: Did you delete the userdata/cache and userdata/tmp folder after the upgrade to 2.5.1? I had strange issue with knx reconnects/OutOfMemory errors and the “serial connection errors”. After doing a openHAB shutdown, deleting userdata/cache and userdata/tmp and restart of openHAB, my system is now running for two days with 2.5.1 and a Telegesis dongle without an issue. (Currently I’m happy. )
Thank you for asking. Yes, I used the built-in function “sudo openhab-cli clean-chache”, but this didn’t help.
I’ve checked out the ZBT-ExtendedColor and ZBT-ColorTemperature bulbs and they both seem to work fine.
I started with zigbee in OH 2.5 with the HUSBZB-1 stick. Have not been able tot get the smart things sensor to pair correctly. Can get a bulb to pair correctly. Here is my log from when the paring ran.
2020-01-15 06:11:34.718 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - 286D9700010C5DFC: Discovery: Starting discovery for existing device
2020-01-15 06:11:34.740 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - B0CE1814035644AF: Discovery: Starting discovery for existing device
2020-01-15 06:11:34.740 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Starting ZigBee scan for zigbee:coordinator_ember:93b31b85
2020-01-15 06:11:34.750 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 286D9700010C5DFC: Starting ZigBee device discovery
2020-01-15 06:11:34.751 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - 286D9700010C5DFC: Creating ZigBee device zigbee:device with bridge zigbee:coordinator_ember:93b31b85
2020-01-15 06:11:34.751 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - B0CE1814035644AF: Starting ZigBee device discovery
2020-01-15 06:11:34.752 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - B0CE1814035644AF: Creating ZigBee device zigbee:device with bridge zigbee:coordinator_ember:93b31b85
2020-01-15 06:11:34.754 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - B0CE1814035644AF: ZigBee node property discovery start
2020-01-15 06:11:34.755 [home.event.InboxAddedEvent] - Discovery Result with UID 'zigbee:device:93b31b85:286d9700010c5dfc' has been added.
2020-01-15 06:11:34.756 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zigbee:device:93b31b85:286d9700010c5dfc' to inbox.
2020-01-15 06:11:34.757 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery start
2020-01-15 06:11:34.757 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - B0CE1814035644AF: ZigBee node property discovery using basic cluster on endpoint 406F/1
2020-01-15 06:11:34.760 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery using basic cluster on endpoint 928D/1
2020-01-15 06:11:34.809 [DEBUG] [converter.ZigBeeConverterSwitchLevel] - B0CE1814035644AF: ZigBee attribute reports ZclAttribute [cluster=Level Control, id=0, name=Current Level, dataType=UNSIGNED_8_BIT_INTEGER, lastValue=254, lastReportTime=Tue Jan 14 06:11:34 CST 2020, implemented=true]
2020-01-15 06:11:34.912 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - B0CE1814035644AF: Date code failed
2020-01-15 06:11:34.913 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - B0CE1814035644AF: ZigBee node property discovery using OTA cluster on endpoint 406F/1
2020-01-15 06:11:34.913 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - B0CE1814035644AF: ZigBee node property discovery complete: {zigbee_logicaltype=END_DEVICE, zigbee_powerlevel=FULL, zigbee_manufacturercode=0x1160, modelId=E11-G13, zigbee_networkaddress=16495, zigbee_powersource=MAINS, zigbee_stkversion=0, zigbee_zclversion=1, vendor=sengled, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[MAINS], hardwareVersion=1, firmwareVersion=0x00000009, zigbee_applicationVersion=1}
2020-01-15 06:11:34.914 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - B0CE1814035644AF: Update ZigBee device zigbee:device with bridge zigbee:coordinator_ember:93b31b85, label 'sengled E11-G13'
2020-01-15 06:11:35.226 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - B0CE1814035644AF: ZigBee saving network state complete.
2020-01-15 06:11:51.552 [DEBUG] [converter.ZigBeeConverterSwitchLevel] - B0CE1814035644AF: ZigBee attribute reports ZclAttribute [cluster=Level Control, id=0, name=Current Level, dataType=UNSIGNED_8_BIT_INTEGER, lastValue=254, lastReportTime=Tue Jan 14 06:11:51 CST 2020, implemented=true]
2020-01-15 06:11:58.762 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: Manufacturer request failed
2020-01-15 06:12:10.763 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: Model request failed
2020-01-15 06:12:22.765 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: Hardware version failed
2020-01-15 06:12:34.767 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: Application version failed
2020-01-15 06:12:46.768 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: Stack version failed
2020-01-15 06:12:58.769 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZCL version failed
2020-01-15 06:13:10.771 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: Date code failed
2020-01-15 06:13:10.772 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery using OTA cluster on endpoint 928D/1
2020-01-15 06:13:22.773 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: Could not get OTA firmware version from device
2020-01-15 06:13:22.774 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery complete: {zigbee_logicaltype=END_DEVICE, zigbee_powerlevel=FULL, zigbee_manufacturercode=0x1241, zigbee_networkaddress=37517, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[MAINS], zigbee_powersource=MAINS}
2020-01-15 06:13:23.035 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 286D9700010C5DFC: ZigBee saving network state complete.
This is possibly due to the device sleeping.
I am rather confident that this whole issue is related to the system OpenHab is running on. What system are you using for testing? If Linux: which distribution (version), kernel (version) and hardware are you using?
I am running into that issue on fresh installs of OpenHabian 1.5 on RPi 3B and 0w and Ubuntu 19.10 x86_64 VM. I would need to check kernel versions, though (maybe not relevant, but who knows).
Anything I can do in the mean time?
Really? Why is that do you think? Personally, I think that’s really unlikely.
I use a Mac for testing but this should make no difference at all. We have just certified (ie ZigBee alliance certification) a system running on a Pi type computer - all with the same Ember chipset (well, different chipset, but the same firmware and driver etc).
This device is also used by Qivicon - I forget if I mentioned, but I wrote this for them, and they are using this regularly with the HB2 hardware which again is similar to a Pi.
OpenHAB is pretty much hardware agnostic so I’m really surprised that you think this is caused by the host - in my experience, that’s pretty unlikely.
Kept opening and closing the contact sensor until it gave it a name in discovery.
Added it as a thing and now it has the error “OFFLINE - HANDLER_INITIALIZING_ERROR”
This is the log when I added it as a thing.
2020-01-15 20:34:54.131 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Initializing ZigBee thing handler zigbee:device:93b31b85:286d9700010c5dfc
2020-01-15 20:34:54.132 [hingStatusInfoChangedEvent] - 'zigbee:device:93b31b85:286d9700010c5dfc' changed from INITIALIZING to UNKNOWN
2020-01-15 20:34:54.133 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Coordinator status changed to ONLINE.
2020-01-15 20:34:54.134 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Coordinator is ONLINE. Starting device initialisation.
2020-01-15 20:34:54.147 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Start initialising ZigBee Thing handler
2020-01-15 20:34:54.149 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery start
2020-01-15 20:34:54.150 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery using basic cluster on endpoint 3F13/1
2020-01-15 20:34:54.173 [nt.FirmwareStatusInfoEvent] - Firmware status of thing zigbee:device:93b31b85:286d9700010c5dfc changed to UNKNOWN.
2020-01-15 20:34:54.190 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Node updated - ZigBeeNode [state=ONLINE, IEEE=286D9700010C5DFC, NWK=3F13, Type=END_DEVICE, endpoints=[1]]
2020-01-15 20:34:54.199 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 286D9700010C5DFC: Starting ZigBee device discovery
2020-01-15 20:34:54.200 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - 286D9700010C5DFC: Creating ZigBee device zigbee:device with bridge zigbee:coordinator_ember:93b31b85
2020-01-15 20:34:54.202 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery start
2020-01-15 20:34:54.202 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery using basic cluster on endpoint 3F13/1
2020-01-15 20:34:54.409 [DEBUG] [converter.ZigBeeConverterSwitchLevel] - B0CE1814035644AF: ZigBee attribute reports ZclAttribute [cluster=On/Off, id=0, name=On Off, dataType=BOOLEAN, lastValue=false, lastReportTime=Wed Jan 15 20:34:54 CST 2020, implemented=false]
2020-01-15 20:34:54.413 [DEBUG] [converter.ZigBeeBaseChannelConverter] - B0CE1814035644AF: Channel zigbee:device:93b31b85:b0ce1814035644af:B0CE1814035644AF_1_dimmer updated to OFF
2020-01-15 20:34:54.413 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B0CE1814035644AF: Updating ZigBee channel state zigbee:device:93b31b85:b0ce1814035644af:B0CE1814035644AF_1_dimmer to OFF
2020-01-15 20:34:54.413 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - Reset timeout for handler with thingUID=zigbee:device:93b31b85:b0ce1814035644af
2020-01-15 20:34:54.413 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - Canceling timeout task for thingUID=zigbee:device:93b31b85:b0ce1814035644af
2020-01-15 20:34:54.414 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - Scheduling timeout task for thingUID=zigbee:device:93b31b85:b0ce1814035644af in 150 seconds
2020-01-15 20:34:54.466 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 286D9700010C5DFC: ZigBee saving network state complete.
2020-01-15 20:34:56.305 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: Stack version failed
2020-01-15 20:34:56.578 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: Stack version failed
2020-01-15 20:34:56.855 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: Date code failed
2020-01-15 20:34:56.857 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery using OTA cluster on endpoint 3F13/1
2020-01-15 20:34:56.857 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery complete: {zigbee_logicaltype=END_DEVICE, zigbee_powerlevel=FULL, zigbee_manufacturercode=0x1241, modelId=multi, zigbee_networkaddress=16147, zigbee_powersource=MAINS, zigbee_zclversion=2, vendor=Samjin, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[MAINS], hardwareVersion=0, firmwareVersion=0xFFFFFFFF, zigbee_applicationVersion=17}
2020-01-15 20:34:56.858 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Checking endpoint 1 channels
2020-01-15 20:34:57.131 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: Date code failed
2020-01-15 20:34:57.132 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery using OTA cluster on endpoint 3F13/1
2020-01-15 20:34:57.133 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery complete: {zigbee_logicaltype=END_DEVICE, zigbee_powerlevel=FULL, zigbee_manufacturercode=0x1241, modelId=multi, zigbee_networkaddress=16147, zigbee_powersource=MAINS, zigbee_zclversion=2, vendor=Samjin, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[MAINS], hardwareVersion=0, firmwareVersion=0xFFFFFFFF, zigbee_applicationVersion=17}
2020-01-15 20:34:57.134 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - 286D9700010C5DFC: Update ZigBee device zigbee:device with bridge zigbee:coordinator_ember:93b31b85, label 'Samjin multi'
2020-01-15 20:34:57.404 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 286D9700010C5DFC: ZigBee saving network state complete.
2020-01-15 20:34:57.925 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 286D9700010C5DFC: IAS zone type CONTACT_SWITCH
2020-01-15 20:34:57.929 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 286D9700010C5DFC: IAS zone type CONTACT_SWITCH
2020-01-15 20:34:57.930 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 286D9700010C5DFC: IAS zone type CONTACT_SWITCH
2020-01-15 20:34:58.193 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 286D9700010C5DFC: IAS zone type CONTACT_SWITCH
2020-01-15 20:34:58.196 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 286D9700010C5DFC: IAS zone type CONTACT_SWITCH
2020-01-15 20:34:58.197 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 286D9700010C5DFC: IAS zone type CONTACT_SWITCH
2020-01-15 20:34:58.198 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 286D9700010C5DFC: IAS zone type CONTACT_SWITCH
2020-01-15 20:34:58.199 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 286D9700010C5DFC: IAS zone type CONTACT_SWITCH
2020-01-15 20:34:58.200 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Dynamically created 7 channels
2020-01-15 20:34:58.202 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Updating thing definition as channels have changed from [] to [zigbee:device:93b31b85:286d9700010c5dfc:286D9700010C5DFC_1_batterylevel, zigbee:device:93b31b85:286d9700010c5dfc:286D9700010C5DFC_1_temperature, zigbee:device:93b31b85:286d9700010c5dfc:286D9700010C5DFC_1_tamper, zigbee:device:93b31b85:286d9700010c5dfc:286D9700010C5DFC_1_batteryalarm, zigbee:device:93b31b85:286d9700010c5dfc:286D9700010C5DFC_1_contact1, zigbee:device:93b31b85:286d9700010c5dfc:286D9700010C5DFC_1_iaslowbattery, zigbee:device:93b31b85:286d9700010c5dfc:286D9700010C5DFC_1_batteryvoltage]
2020-01-15 20:34:58.204 [me.event.ThingUpdatedEvent] - Thing 'zigbee:device:93b31b85:286d9700010c5dfc' has been updated.
2020-01-15 20:34:58.205 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Initializing device
2020-01-15 20:34:58.206 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Initializing channel zigbee:device:93b31b85:286d9700010c5dfc:286D9700010C5DFC_1_batterylevel with org.openhab.binding.zigbee.internal.converter.ZigBeeConverterBatteryPercent@6628e230
2020-01-15 20:34:58.207 [DEBUG] [verter.ZigBeeConverterBatteryPercent] - 286D9700010C5DFC: Initialising device battery percent converter
2020-01-15 20:34:58.738 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Initializing channel zigbee:device:93b31b85:286d9700010c5dfc:286D9700010C5DFC_1_temperature with org.openhab.binding.zigbee.internal.converter.ZigBeeConverterTemperature@3b9ef5df
2020-01-15 20:34:59.062 [ERROR] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Exception creating channels
at org.openhab.binding.zigbee.internal.converter.ZigBeeConverterTemperature.initializeDevice(ZigBeeConverterTemperature.java:79) ~[bundleFile:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.initializeDevice(ZigBeeThingHandler.java:492) ~[bundleFile:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.doNodeInitialisation(ZigBeeThingHandler.java:381) [bundleFile:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.access$0(ZigBeeThingHandler.java:238) [bundleFile:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler$1.call(ZigBeeThingHandler.java:232) [bundleFile:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler$1.call(ZigBeeThingHandler.java:1) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_232]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_232]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_232]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_232]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
2020-01-15 20:34:59.078 [hingStatusInfoChangedEvent] - 'zigbee:device:93b31b85:286d9700010c5dfc' changed from UNKNOWN to OFFLINE (HANDLER_INITIALIZING_ERROR)
2020-01-15 20:34:59.085 [me.event.ThingUpdatedEvent] - Thing 'zigbee:device:93b31b85:286d9700010c5dfc' has been updated.
2020-01-15 20:34:59.090 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Start initialising ZigBee Thing handler
2020-01-15 20:34:59.090 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery start
2020-01-15 20:34:59.091 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery using basic cluster on endpoint 3F13/1
2020-01-15 20:34:59.525 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: Stack version failed
2020-01-15 20:34:59.773 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: Date code failed
2020-01-15 20:34:59.774 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery using OTA cluster on endpoint 3F13/1
2020-01-15 20:34:59.775 [DEBUG] [scovery.ZigBeeNodePropertyDiscoverer] - 286D9700010C5DFC: ZigBee node property discovery complete: {zigbee_logicaltype=END_DEVICE, zigbee_powerlevel=FULL, zigbee_manufacturercode=0x1241, modelId=multi, zigbee_networkaddress=16147, zigbee_powersource=MAINS, zigbee_zclversion=2, zigbee_routes=[], zigbee_lastupdate=, zigbee_stkcompliance=22, vendor=Samjin, zigbee_powermode=RECEIVER_ON_IDLE, zigbee_powersources=[MAINS], hardwareVersion=0, firmwareVersion=0xFFFFFFFF, zigbee_neighbors=[], zigbee_applicationVersion=17, zigbee_device_initialised=false, zigbee_devices=[]}
2020-01-15 20:34:59.776 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Checking endpoint 1 channels
2020-01-15 20:34:59.780 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 286D9700010C5DFC: IAS zone type CONTACT_SWITCH
2020-01-15 20:34:59.785 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 286D9700010C5DFC: IAS zone type CONTACT_SWITCH
2020-01-15 20:34:59.786 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 286D9700010C5DFC: IAS zone type CONTACT_SWITCH
2020-01-15 20:34:59.788 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 286D9700010C5DFC: IAS zone type CONTACT_SWITCH
2020-01-15 20:34:59.789 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 286D9700010C5DFC: IAS zone type CONTACT_SWITCH
2020-01-15 20:34:59.793 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 286D9700010C5DFC: IAS zone type CONTACT_SWITCH
2020-01-15 20:34:59.794 [DEBUG] [nternal.converter.ZigBeeConverterIas] - 286D9700010C5DFC: IAS zone type CONTACT_SWITCH
2020-01-15 20:34:59.795 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Dynamically created 7 channels
2020-01-15 20:34:59.796 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Initializing device
2020-01-15 20:34:59.797 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Initializing channel zigbee:device:93b31b85:286d9700010c5dfc:286D9700010C5DFC_1_batterylevel with org.openhab.binding.zigbee.internal.converter.ZigBeeConverterBatteryPercent@11cbaacc
2020-01-15 20:34:59.797 [DEBUG] [verter.ZigBeeConverterBatteryPercent] - 286D9700010C5DFC: Initialising device battery percent converter
2020-01-15 20:35:00.280 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Initializing channel zigbee:device:93b31b85:286d9700010c5dfc:286D9700010C5DFC_1_temperature with org.openhab.binding.zigbee.internal.converter.ZigBeeConverterTemperature@713f3717
2020-01-15 20:35:00.561 [ERROR] [ng.zigbee.handler.ZigBeeThingHandler] - 286D9700010C5DFC: Exception creating channels
2020-01-15 20:35:25.486 [WARN ] [nternal.profiles.SystemOffsetProfile] - Received a QuantityType state '18 °C' with unit, but the offset is defined as a plain number without unit (2), please consider adding a unit to the profile offset.
2020-01-15 20:35:25.489 [vent.ItemStateChangedEvent] - ThermostatCurrentTempUp changed from 66.4 to 18
2020-01-15 20:35:28.455 [DEBUG] [converter.ZigBeeConverterSwitchLevel] - B0CE1814035644AF: ZigBee attribute reports ZclAttribute [cluster=Level Control, id=0, name=Current Level, dataType=UNSIGNED_8_BIT_INTEGER, lastValue=254, lastReportTime=Wed Jan 15 20:35:28 CST 2020, implemented=true]
2020-01-15 20:35:49.022 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B0CE1814035644AF: Polling...
2020-01-15 20:35:49.023 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B0CE1814035644AF: Polling zigbee:device:93b31b85:b0ce1814035644af:B0CE1814035644AF_1_dimmer
2020-01-15 20:35:49.064 [DEBUG] [converter.ZigBeeConverterSwitchLevel] - B0CE1814035644AF: ZigBee attribute reports ZclAttribute [cluster=On/Off, id=0, name=On Off, dataType=BOOLEAN, lastValue=false, lastReportTime=Wed Jan 15 20:35:49 CST 2020, implemented=false]
2020-01-15 20:35:49.064 [DEBUG] [converter.ZigBeeBaseChannelConverter] - B0CE1814035644AF: Channel zigbee:device:93b31b85:b0ce1814035644af:B0CE1814035644AF_1_dimmer updated to OFF
2020-01-15 20:35:49.069 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B0CE1814035644AF: Updating ZigBee channel state zigbee:device:93b31b85:b0ce1814035644af:B0CE1814035644AF_1_dimmer to OFF
2020-01-15 20:35:49.069 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - Reset timeout for handler with thingUID=zigbee:device:93b31b85:b0ce1814035644af
2020-01-15 20:35:49.070 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - Canceling timeout task for thingUID=zigbee:device:93b31b85:b0ce1814035644af
2020-01-15 20:35:49.070 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - Scheduling timeout task for thingUID=zigbee:device:93b31b85:b0ce1814035644af in 150 seconds
2020-01-15 20:35:49.114 [DEBUG] [converter.ZigBeeConverterSwitchLevel] - B0CE1814035644AF: ZigBee attribute reports ZclAttribute [cluster=Level Control, id=0, name=Current Level, dataType=UNSIGNED_8_BIT_INTEGER, lastValue=254, lastReportTime=Wed Jan 15 20:35:49 CST 2020, implemented=true]
2020-01-15 20:35:54.201 [DEBUG] [converter.ZigBeeConverterSwitchLevel] - B0CE1814035644AF: ZigBee attribute reports ZclAttribute [cluster=On/Off, id=0, name=On Off, dataType=BOOLEAN, lastValue=false, lastReportTime=Wed Jan 15 20:35:54 CST 2020, implemented=false]
2020-01-15 20:35:54.201 [DEBUG] [converter.ZigBeeBaseChannelConverter] - B0CE1814035644AF: Channel zigbee:device:93b31b85:b0ce1814035644af:B0CE1814035644AF_1_dimmer updated to OFF
2020-01-15 20:35:54.202 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - B0CE1814035644AF: Updating ZigBee channel state zigbee:device:93b31b85:b0ce1814035644af:B0CE1814035644AF_1_dimmer to OFF
2020-01-15 20:35:54.203 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - Reset timeout for handler with thingUID=zigbee:device:93b31b85:b0ce1814035644af
2020-01-15 20:35:54.204 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - Canceling timeout task for thingUID=zigbee:device:93b31b85:b0ce1814035644af
2020-01-15 20:35:54.205 [DEBUG] [.zigbee.handler.ZigBeeIsAliveTracker] - Scheduling timeout task for thingUID=zigbee:device:93b31b85:b0ce1814035644af in 150 seconds
I personally do not use Zigbee but perhaps the log viewer can help.
https://www.cd-jackson.com/index.php/openhab/zigbee-log-viewer
