Demietri
(Demietri)
February 5, 2020, 3:18pm
1
I am switching over from Domoticz to OH.
Just before the weekend crashed the software on my Raspberry Pi with Domoticz, so that was the perfect moment to make the change.
Now the system is running, i found some troubbles with the “new” Qubino Mini Dimmer ZMNHHD.
It is found by OH, but even after multiple times resetting, removing, etc, OH will not show the channels of the ZMNHHD. (the same problem in Domoticz)
I got Openhabian running on:
Raspberry Pi3b
Aeotec Z-Stick Gen 5
openjdk version “1.8.0_222”
OpenJDK Runtime Environment (Zulu8.40.0.178-CA-linux_aarch32hf) (build 1.8.0_222-b178)
OpenJDK Client VM (Zulu8.40.0.178-CA-linux_aarch32hf) (build 25.222-b178, mixed mode, Evaluation)
Made my SD card with Etcher
Put it in yhe pi and wait for about dinnertime
Than i followed the further instructions on https://www.youtube.com/watch?v=5R9Oc8xINGU (BK Hobby)
I hope someone can help me out, because the old version of the qubino dimmers are not longer available.
H102
(CM6.5 H102)
February 5, 2020, 3:25pm
2
Are you using an SD card in the Pi? If so maybe it’s corrupted so if you have a new card try using it to install OH. Also what binding are you using?
Demietri
(Demietri)
February 5, 2020, 3:44pm
3
Hi H102,
Thanks fot your reply.
I am binding with an Aeotec Z-Stick Generation 5.
It is a new sd card.
(Samsung 32G)
Domoticz crashed because my own fault by removing things from the Raspbian OS
H102
(CM6.5 H102)
February 5, 2020, 3:50pm
4
Here’s the list of supported Qubino devices:
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devices
You can reach out to @chris or @sihui for more info on adding your device.
sihui
(SiHui)
February 5, 2020, 3:59pm
5
Demietri:
ZMNHHD
Please provide the xml file from your userdata zwave folder:
sihui
(SiHui)
February 5, 2020, 4:05pm
6
Disregard. There seem to be some parts missing in the github repo, we need to ping Chris.
@chris , this device looks okay in the database but the configuration parameters (and probably more) are missing on github:
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/1100
<?xml version="1.0" encoding="UTF-8"?>
<thing:thing-descriptions bindingId="zwave"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:thing="https://openhab.org/schemas/thing-description/v1.0.0"
xsi:schemaLocation="https://openhab.org/schemas/thing-description/v1.0.0
https://openhab.org/schemas/thing-description/v1.0.0">
<thing-type id="qubino_zmnhhd_00_000" listed="false">
<label>ZMNHHD Mini Dimmer</label>
<description><![CDATA[
Mini Dimmer<br /> <h1>Overview</h1><p>Mini Dimmer is a MOSFET-switching light device that also supports control of low-voltage halogen lamps with electronic transformers, dimmable compact fluorescent lights, and dimmable LED bulbs. It measures power consumption of the connected device. It supports push-button/momentary switches (default) and toggle switches. It can work with or without the neutral line. Qubino Mini Dimmer allows the easiest and quickest installation. It is designed to be mounted inside a “flush mounting box”, hidden behind a traditional wall switch. It acts as repeater in order to improve range and stability of Z-Wave network.</p> <br /> <h2>Inclusion Information</h2><p>Inclusion</p> <p>AUTOMATICALLY ADDING THE DEVICE TO A Z-WAVE NETWORK (AUTO INCLUSION)</p> <ol><li>Enable add/remove mode on your Z-Wave gateway (hub)</li> <li>Automatic selection of secure/unsecure inclusion.</li> <li>The device can be automatically added to a Z-Wave network during the first 2 minutes</li> <li>Connect the device to the power supply</li> <li>Auto-inclusion will be initiated within 5 seconds of connection to the power supply and the device will automatically enrol in your network. </li> </ol><p>(when the device is excluded and connected to the power supply it automatically eneters the LEARN MODE state.)</p> <p><strong>NOTE: LEARN MODE state allows the device to receive network infromation from the controller</strong></p> <p><strong>NOTE: Please wait at least 30 seconds between each inclusion and exclusion.</strong></p> <p>MANUALLY ADDING THE DEVICE TO A Z-WAVE NETWORK (MANUAL INCLUSION)</p> <ol><li>Connect the device to the power supply</li> <li>Enable add/remove mode on your Z-Wave gateway (hub)</li> <li>Toggle the switch connected to the I1 terminal 3 times within 3 seconds (this procedure put the device in LEARN MODE)</li> </ol><p>OR</p> <p>Press and hold the S (Service) button between 2 and 6 seconds if connected to 24-30VDC (this procedure put the device in LEARN MODE)</p> <p>4. A new device will appear on your dashboard</p> <p><strong>NOTE: LEARN MODE state allows the device to receive network infromation from the conttoller </strong></p> <p><strong>NOTE: Please wait at least 30 seconds between each inclusion and exclusion.</strong></p> <p>Mini Dimmer supports the latest Security 2 feature. When adding the Mini Dimmer to a Z-Wave network with a controller supporting Security 2 (S2), the PIN code of the Z-Wave Device Specific Key (DSK) is required. The unique DSK code is printed on the product label and a copy is inserted in the packaging, which must not be lost. Do not remove the DSK from the product. As a backup measure, use the label in the packaging. The first five digits of the key are highlighted or underlined to help the user identify the PIN code portion of the DSK text.</p> <br /> <h2>Exclusion Information</h2><p>Exclusion</p> <p>REMOVAL FROM A Z-WAVE NETWORK (Z-WAVE EXCLUSION)</p> <ol><li>Connect the device to the power supply</li> <li>Make sure the device is within direct range of your Z-Wave gateway (hub) or use a hand-held Z-Wave remote to perform exclusion</li> <li>Enable add/remove mode on your Z-Wave gateway (hub)</li> <li>Toggle the switch connected to the I1 terminal 3 times within 3 seconds (this procedure put the device in LEARN MODE)</li> </ol><p>OR</p> <p>Press and hold the S (Service) button between 2 and 6 seconds if connected to 24-30VDC (this procedure put the device in LEARN MODE)</p> <ol><li>The device will be removed from your network, but any custom configuration parameters will not be erased</li> </ol><p><strong>NOTE: LEARN MODE state allows the device to receive network infromation from the conttoller </strong></p> <p><strong>NOTE: Please wait at least 30 seconds between each inclusion and exclusion.</strong></p>
]]></description>
<category>WallSwitch</category>
<!-- CHANNEL DEFINITIONS -->
<channels>
<channel id="switch_dimmer" typeId="switch_dimmer">
<label>Dimmer</label>
<properties>
<property name="binding:*:PercentType">COMMAND_CLASS_SWITCH_MULTILEVEL,COMMAND_CLASS_BASIC</property>
This file has been truncated. show original
Demietri
(Demietri)
February 5, 2020, 4:23pm
8
Thanks.
But i can’t imagine that i am the only one to have this problem.
sihui
(SiHui)
February 5, 2020, 4:30pm
9
It is quite possible that in the stable release you are using the database export did not work.
Other users may use an older or newer zwave binding version where the database export went well.
True me too . Glad @sihui found it this time
Demietri
(Demietri)
February 5, 2020, 4:41pm
11
I read something about three different Java platforms.
Zulu would be the recommended one.
Do you know why OpenJDK is installed on my system? I thought Openhabian was especialy for Openhab -noobs like me…
(btw, i realy would like to get it work with my Google home devices. so maybe using an other java platform would be better)
sihui
(SiHui)
February 5, 2020, 4:49pm
12
What does java -version
give you?
java -version
openjdk version "1.8.0_242"
OpenJDK Runtime Environment (Zulu 8.44.0.11-CA-linux64) (build 1.8.0_242-b20)
OpenJDK 64-Bit Server VM (Zulu 8.44.0.11-CA-linux64) (build 25.242-b20, mixed mode)
Demietri:
Google home devices
Works great, follow the docs:
chris
(Chris Jackson)
February 6, 2020, 8:24am
15
It looks ok to me. Based on the thing ID, the link you’ve provided is not the same for the database and github. The database has a name of minidimmer
which means this is the correct thin definition -:
<thing-type id="qubino_minidimmer_00_000" listed="false">
Mini Dimmer<br /><h1>Overview</h1><p>Mini Dimmer is a MOSFET-switching light device that also supports control of low-voltage halogen lamps with electronic transformers, dimmable compact fluorescent lights, and dimmable LED bulbs. It measures power consumption of the connected device. It supports push-button/momentary switches (default) and toggle switches. It can work with or without the neutral line. Qubino Mini Dimmer allows the easiest and quickest installation. It is designed to be mounted inside a “flush mounting box”, hidden behind a traditional wall switch. It acts as repeater in order to improve range and stability of Z-Wave network.</p> <br /><h2>Inclusion Information</h2><p>Inclusion</p> <p>AUTOMATICALLY ADDING THE DEVICE TO A Z-WAVE NETWORK (AUTO INCLUSION)</p> <ol><li>Enable add/remove mode on your Z-Wave gateway (hub)</li> <li>Automatic selection of secure/unsecure inclusion.</li> <li>The device can be automatically added to a Z-Wave network during the first 2 minutes</li> <li>Connect the device to the power supply</li> <li>Auto-inclusion will be initiated within 5 seconds of connection to the power supply and the device will automatically enrol in your network. </li> </ol><p>(when the device is excluded and connected to the power supply it automatically eneters the LEARN MODE state.)</p> <p><strong>NOTE: LEARN MODE state allows the device to receive network infromation from the controller</strong></p> <p><strong>NOTE: Please wait at least 30 seconds between each inclusion and exclusion.</strong></p> <p>MANUALLY ADDING THE DEVICE TO A Z-WAVE NETWORK (MANUAL INCLUSION)</p> <ol><li>Connect the device to the power supply</li> <li>Enable add/remove mode on your Z-Wave gateway (hub)</li> <li>Toggle the switch connected to the I1 terminal 3 times within 3 seconds (this procedure put the device in LEARN MODE)</li> </ol><p>OR</p> <p>Press and hold the S (Service) button between 2 and 6 seconds if connected to 24-30VDC (this procedure put the device in LEARN MODE)</p> <p>4. A new device will appear on your dashboard</p> <p><strong>NOTE: LEARN MODE state allows the device to receive network infromation from the conttoller </strong></p> <p><strong>NOTE: Please wait at least 30 seconds between each inclusion and exclusion.</strong></p> <p>Mini Dimmer supports the latest Security 2 feature. When adding the Mini Dimmer to a Z-Wave network with a controller supporting Security 2 (S2), the PIN code of the Z-Wave Device Specific Key (DSK) is required. The unique DSK code is printed on the product label and a copy is inserted in the packaging, which must not be lost. Do not remove the DSK from the product. As a backup measure, use the label in the packaging. The first five digits of the key are highlighted or underlined to help the user identify the PIN code portion of the DSK text.</p> <br /><h2>Exclusion Information</h2><p>Exclusion</p> <p>REMOVAL FROM A Z-WAVE NETWORK (Z-WAVE EXCLUSION)</p> <ol><li>Connect the device to the power supply</li> <li>Make sure the device is within direct range of your Z-Wave gateway (hub) or use a hand-held Z-Wave remote to perform exclusion</li> <li>Enable add/remove mode on your Z-Wave gateway (hub)</li> <li>Toggle the switch connected to the I1 terminal 3 times within 3 seconds (this procedure put the device in LEARN MODE)</li> </ol><p>OR</p> <p>Press and hold the S (Service) button between 2 and 6 seconds if connected to 24-30VDC (this procedure put the device in LEARN MODE)</p> <ol><li>The device will be removed from your network, but any custom configuration parameters will not be erased</li> </ol><p><strong>NOTE: LEARN MODE state allows the device to receive network infromation from the conttoller </strong></p> <p><strong>NOTE: Please wait at least 30 seconds between each inclusion and exclusion.</strong></p>
]]></description>
<channels>
<properties>
Hmm to bad so it stays unresolved why this device isn’t showing options voor config params and association groups in openhab (ZMNHHD Qubino Mini Dimmer missing association groups,channels , configuration options but works ).
I tried to add/remove (also on controller itself ) a few times but the result is always the same.
Device is recognized but no options available to configure it (in habmin of paperui) .
chris
(Chris Jackson)
February 6, 2020, 10:05am
18
Sorry if I’ve missed it, but have you provided information on your device? Either the XML file, or at least the parameters showing the device type, id and version?
chris
(Chris Jackson)
February 6, 2020, 10:25am
20
Thanks.
So the issue is caused by there being two devices in the database with the same IDs -:
This can happen when the database gets updated, and is fixed when I do a complete database export (which I only do a few times a year - normally a month or two before a major release). In this case, a new device was added (1188) which was then deleted, but it still exists in GH.
I’ve now deleted this in GH and it should resolve this issue in the next update.
openhab:2.5.x
← openhab:delete-1188
opened 10:25AM - 06 Feb 20 UTC
