How do I refer to an Item by a var or val defition? Here’s how I would like it to work, but it’s not working at the moment:
sample.rules:
...imports omitted...
var physical_relay1 = "HardWire_20AMP_Relay" // An actual Item name, as defined in .items file.
var physical_relay2 = "Safety_20AMP_Relay" // An actual Item name, as defined in .items file.
// All the Item references below are to *variables* defined above, not "real" Items in .items file.
// How do I get OH to interpret the variables as Items?
rule "Zone Heat Power - Status Indicator"
Item physical_relay changed
if ((physical_relay1.toString() + ".state") == OFF ) {
Kitchen_Heat_Power_STATUS.postUpdate("OFF") }
} else if {
physical_relay2.sendCommand(OFF)
NOTE: do you really mean to check if physical_relay1’s state is ON in the else if? If not then that clause will never be executed. If you really do mean OFF then:
Thanks for your detailed reply and for outlining the “hack” solution even though it’s a hack. It works.
The code I pasted was just a hypothetical, not actually real-world, please ignore the ON/OFF consequences.
Looks like I need to invest some time learning how to program properly for using Groups and lambdas.
In the meantime tho, just to hack it together & make it work I will be using “val” definitions & copy/pasting .rules definitions for each zone.
There’s a learning curve for all this stuff and I can’t integrate everything, mentally, at once, but I do need it to work in the interrim until I can restructure it all properly.
I wanted to just do a single val definition at the top of the .rules file:
val physical_relay1 = HardWire_20AMP_Relay
val physical_relay2 = Safety_20AMP_Relay
And then refer to “physical_relay1” etc. in any rule within that file. But for whatever reason the rules engine refuses to use the global val definitions. The val definitions above will work if declared within a single rule, but not when declared at the top of a .rules file.
I tried restarting OH completely (not just reloading Rules files) to ensure the val’s get initialized, still doesn’t work.
I currently face the same problem. When trying to initalize a new variable with the value of an Item called Temp_Value_Day, I get “The method or field Temp_Value_Day is undefined”.
