Great thanks… should be the correct one.
Odd just trying to test on my setup.
I just reverted my setup to 2.3 and run the upgrade again.
As soon as I launch 2.4M7 I see then new channels…
The first thing that springs to mind is did you clear cache and temp files when you upgraded?
clear the cache
hmmm, no luck.
I tried following:
- uninstall binding (through paperUI)
- stop OH2
- Cleared the cache
- start OH2
- install binding (through paperUI)
In my logs, I see an error. But not sure if it’s linked with the problem/binding, or with my global installation.
2018-12-07 09:51:56.772 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-seneye': Error restarting bundles:
Exception in org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start() of bundle org.eclipse.smarthome.io.rest.sse.
But after this, everything is working as above. Except the new channels…
2018-12-07 09:51:56.737 [hingStatusInfoChangedEvent] - 'seneye:monitor:5709eb0c' changed from UNINITIALIZED to INITIALIZING
2018-12-07 09:51:56.762 [hingStatusInfoChangedEvent] - 'seneye:monitor:5709eb0c' changed from INITIALIZING to ONLINE
2018-12-07 09:52:08.989 [vent.ItemStateChangedEvent] - mySeneye_NH4 changed from NULL to 28.67
2018-12-07 09:52:08.991 [vent.ItemStateChangedEvent] - mySeneye_O2 changed from NULL to 8.4
2018-12-07 09:52:08.992 [vent.ItemStateChangedEvent] - mySeneye_par changed from NULL to 0.0
2018-12-07 09:52:08.994 [vent.ItemStateChangedEvent] - mySeneye_PH changed from 7.86 to 7.84
2018-12-07 09:52:08.995 [vent.ItemStateChangedEvent] - mySeneye_lux changed from NULL to 0.0
2018-12-07 09:52:08.997 [vent.ItemStateChangedEvent] - mySeneye_kelvin changed from NULL to 0.0
2018-12-07 09:52:08.999 [vent.ItemStateChangedEvent] - mySeneye_lastreading changed from NULL to 2018-12-07T09:37:01.000+0100
2018-12-07 09:52:09.001 [vent.ItemStateChangedEvent] - mySeneye_slideexpires changed from NULL to 2019-01-03T18:05:27.000+0100
I found this post that seams to be a similar issue, hopefully it helps a little?
As I understand it, this error comes from clearing the cache. If I know restart OH, no more error. Also a complete reboot went well.
But sadly still missing the new channels…
Very strange, are you still getting the error message about the binding failing to install?
Sorry re-read, and saw the error had gone
When you reinstalled the bindings what channels were listed in the events log?
No. I only have the error when I clear the cache.
So guess it’s an ‘issue’ with the bundle restarting without a present cache.
I see that all items are being linked with the channels.
log/events.log:2018-12-07 10:21:56.450 [.ItemChannelLinkAddedEvent] - Link 'mySeneye_kelvin-seneye:monitor:5709eb0c:kelvin' has been added.
log/events.log:2018-12-07 10:21:56.488 [.ItemChannelLinkAddedEvent] - Link 'mySeneye_Temperature-seneye:monitor:5709eb0c:temperature' has been added.
log/events.log:2018-12-07 10:21:56.525 [.ItemChannelLinkAddedEvent] - Link 'mySeneye_par-seneye:monitor:5709eb0c:par' has been added.
log/events.log:2018-12-07 10:21:56.562 [.ItemChannelLinkAddedEvent] - Link 'mySeneye_disconnected-seneye:monitor:5709eb0c:disconnected' has been added.
log/events.log:2018-12-07 10:21:56.594 [.ItemChannelLinkAddedEvent] - Link 'mySeneye_NH4-seneye:monitor:5709eb0c:nh4' has been added.
log/events.log:2018-12-07 10:21:56.607 [.ItemChannelLinkAddedEvent] - Link 'mySeneye_slideSerial-seneye:monitor:5709eb0c:slideserial' has been added.
log/events.log:2018-12-07 10:21:56.617 [.ItemChannelLinkAddedEvent] - Link 'mySeneye_slideexpires-seneye:monitor:5709eb0c:slideexpires' has been added.
log/events.log:2018-12-07 10:21:56.617 [.ItemChannelLinkAddedEvent] - Link 'mySeneye_lastreading-seneye:monitor:5709eb0c:lastreading' has been added.
log/events.log:2018-12-07 10:21:56.664 [.ItemChannelLinkAddedEvent] - Link 'mySeneye_O2-seneye:monitor:5709eb0c:O2' has been added.
log/events.log:2018-12-07 10:21:56.665 [.ItemChannelLinkAddedEvent] - Link 'mySeneye_outOfWater-seneye:monitor:5709eb0c:outofwater' has been added.
log/events.log:2018-12-07 10:21:56.668 [.ItemChannelLinkAddedEvent] - Link 'mySeneye_NH3-seneye:monitor:5709eb0c:nh3' has been added.
log/events.log:2018-12-07 10:21:56.680 [.ItemChannelLinkAddedEvent] - Link 'mySeneye_PH-seneye:monitor:5709eb0c:ph' has been added.
log/events.log:2018-12-07 10:21:56.752 [.ItemChannelLinkAddedEvent] - Link 'mySeneye_lux-seneye:monitor:5709eb0c:lux' has been added.
Maybe it was a timing issue when clearing the cache and restarting?
Do the new channels show in paper now? they are in the logs so hopefully they will!
Found it!
Seems that an update of the binding was not enough.
I had to remove the thing from the paperUI, add it again.
Then, the new channels were present.
Thanks for you patience!
Glad its working, I have learned something new!
Hopefully others will see this post if they have similar problems and it will help them!
I’ve created an issue for this:
I’m still can’t get this binding to work. I upgraded to stable 2.4 yesterday. uninstalled seneye binding, reinstalled, removed seneye thing in PaperUI and added it again. It shows online. My temperature gets pulled once, but then nothing is updated. I see all the channels in PaperUI but in Control screen all are empty (except temperature which is pulled once, but also seems old value). Then I get this error every time I change something in the config:
09:58:07.407 [WARN ] [e.core.thing.binding.BaseThingHandler] - BaseThingHandler.initialize() will be removed soon, ThingStatus can be set manually via updateStatus(ThingStatus.ONLINE)
09:58:08.177 [WARN ] [ommon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.seneye.internal.handler.SeneyeHandler.newState(SeneyeHandler.java:70) ~[?:?]
at org.openhab.binding.seneye.internal.SeneyeService.lambda$0(SeneyeService.java:77) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:?]
I’m curious on how the rest is able to get this working Do you guys create the thing via PaperUI or a seperate Things file? I used PaperUI at least.
Are you using username or email address to login?
I think email address is more reliable!
I use both Paperui definitions and some in items at present… I will be updating this to all in items as soon as I get chance
I’ve only used email address + password for login, I must be doing something wrong since everybody succeeds but I don’t . The only thing that’s different now then before, my slide has expired last week, and haven’t replaced it yet. But now in the winter months I was planning on waiting for a bit. However, I don’t see why this shouldn’t work without an active slide. I get temperature updates via de login/app
Double check you have no old text file configs for this (.items, .things etc), or references in other config files.
The current binding should definitely work with expired slide, as I am using it like that at the moment.
Have you got a persistence service running that could have the old reading?
Do you mention/use the binding in any rules?
One other thing that is worth checking, is in a previous post; you hadn’t populated the location field in paperUI. It might be worth adding the location details, just to rule that out?
Ok, just FYI, I thought I try again. First uninstalled the binding, then made sure no files (things,items) remain for seneye. Then removed seneye monitor Thing via PaperUI. re-installed the binding and configured a new Thing via PaperUI with all the details. It pulls the correct data (once). But then doesn’t seem to react anymore. I get this warning in karaf. Seems the same as I had in older version of binding. help
ps I used the api.seneye.com URL and response to make sure I used the correct name for ‘aquarium’ etc.
09:44:21.479 [WARN ] [e.core.thing.binding.BaseThingHandler] - BaseThingHandler.initialize() will be removed soon, ThingStatus can be set manually via updateStatus(ThingStatus.ONLINE)
09:44:21.489 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'seneye:monitor:c7a38169' changed from INITIALIZING to ONLINE
09:44:22.187 [WARN ] [ommon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
09:44:22.190 [INFO ] [smarthome.event.ItemStateChangedEvent] - seneye_monitor_c7a38169_temperature changed from NULL to 6.5
09:44:22.196 [INFO ] [smarthome.event.ItemStateChangedEvent] - seneye_monitor_c7a38169_nh3 changed from NULL to 0.001
Ok, slightly different approach…
in PaperUI go to configuration, things, Seneye then unselect all channels except temperature.
It looks like one of the channels is playing up, if that works try adding them back one at a time until it stops working.
I think NH3 channel also looks ok but best to go one at a time!
Can you also heck what version of the binding is reported when you run bundle:list from the openHab console
Actually tried this right after I wrote my last message as well, tried it again now with uninstalling binding while only temperature was marked. But seem to keep getting that same error message “Scheduled runable ended with an exception”. Checked the binding version which is 2.4.0.
Ok lets go back to square one…
Delete all Seneye configuration in PaperUI except the binding.
Check the logs to see if it is still trying to pull data, if it is there could be an old setting left behind somewhere.
Create new file seneye.things in your things folder with this as the content
Thing seneye:monitor:c7a38169 "Seneye" @ "Test" [aquarium_name="Koningshoflei", username="mail@example.com", password="xxx", poll_time=5]
Just use your own email address and password
Also create a new file seneye.items in your items folder with the following
String mySeneye_Temperature "Temp [%s] C" { channel="seneye:monitor:c7a38169:temperature" }
Lets see if the improves things in the logs
