Serious issue - Bindings wont start after clearing cache and tmp
Using Rpi 3B+ with openhab (hassle free) 2.5M1 build 1575.
I have no idea what have happened, but after installing the latest ipcamera binding, I had to clear the cache and tmp. When openhab restarts, this happen:
2019-06-12 01:02:30.919 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-hue, openhab-binding-modbus, openhab-voice-googletts, openhab-misc-openhabcloud, openhab-binding-smaenergymeter, openhab-binding-tplinksmarthome, openhab-transformation-javascript, openhab-binding-network, openhab-persistence-influxdb, openhab-ui-habpanel, openhab-action-pushover, openhab-binding-zwave, openhab-binding-mihome, openhab-binding-chromecast, openhab-ui-restdocs, openhab-binding-netatmo, openhab-ui-basic, openhab-transformation-map, openhab-binding-openweathermap, openhab-ui-habmin, openhab-binding-expire1, openhab-ui-paper, openhab-transformation-scale': Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-binding-network; type=karaf.feature; version="[2.5.0.SNAPSHOT,2.5.0.SNAPSHOT]"; filter:="(&(osgi.identity=openhab-binding-network)(type=karaf.feature)(version>=2.5.0.SNAPSHOT)(version<=2.5.0.SNAPSHOT))" [caused by: Unable to resolve openhab-binding-network/2.5.0.SNAPSHOT: missing requirement [openhab-binding-network/2.5.0.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.binding.network; type=osgi.bundle; version="[2.5.0.201906102020,2.5.0.201906102020]"; resolution:=mandatory [caused by: Unable to resolve org.openhab.binding.network/2.5.0.201906102020: missing requirement [org.openhab.binding.network/2.5.0.201906102020] osgi.wiring.package; filter:="(osgi.wiring.package=fr.bmartel.speedtest)"]]
I have no addons defined in the addons.cfg file.
I removed the latest ipcamera binding again, cleared the cache and tmp once again, and rebooted. But still the same.
It seems like it´s most of the binding from PaperUI. The manual installed bindings seems to work fine. Without beeing able to enter PaperUI, I can tell for sure, that the old ipcamera binding and IHC binding are running. (those are manually added to addons folder). But zigbee, z-wave, Unifi, Velux are not running..
I have cleared cache and tmp many times, also with the M1 build 1575. But this has never happened before. And I have no idea how to solve this. So I really appreciate any help I can get. :cry:
EDIT - Small change I did before installing the latest ipcamera binding. I installed ffmpeg, cause it was supposed to be used together with the latest ipcamera binding.. Could that be the reason?
I´m not sure how to uninstall it.. Just to make sure if it´s the cause? purge ffmpeg?
EDIT 2 - I think I managed to remove ffmpeg.. But stil the same issue.. :rage:
Just tried entering openhabian-config to upgrade all packages..
It failed too.. HMPRF!!
[01:29:18] openhabian@openHABianPi:~$ sudo openhabian-config
[sudo] password for openhabian:
2019-06-12_01:29:30_CEST [openHABian] Checking for root privileges... OK
2019-06-12_01:29:30_CEST [openHABian] Loading configuration file '/etc/openhabia        n.conf'... OK
2019-06-12_01:29:35_CEST [openHABian] openHABian configuration tool version: [master]v1.4.1-466(0824b76)
2019-06-12_01:29:35_CEST [openHABian] Checking for changes in origin... Updates available...
2019-06-12_01:29:41_CEST [openHABian] Updating myself... OK - Commit history (oldest to newest):
cbcc285 - Add option to delay loading rules for optimum startup performance (#566) (5 weeks ago) <Markus Storm> N
 functions/menu.bash            |  6 +++++-
 functions/openhab.bash         | 11 +++++++++++
 includes/systemd-override.conf |  6 ++++++
 3 files changed, 22 insertions(+), 1 deletion(-)
1afc578 - Ensure /etc/systemd/system/openhab2.service.d directory exists (#571) (5 weeks ago) <Markus Storm> N
 functions/openhab.bash | 7 +++++--
 1 file changed, 5 insertions(+), 2 deletions(-)
openHABian configuration tool successfully updated.
Visit the development repository for more details: https://github.com/openhab/openhabian
The tool will now restart to load the updates...
2019-06-12_01:29:43_CEST [openHABian] Checking for root privileges... OK
2019-06-12_01:29:44_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2019-06-12_01:29:44_CEST [openHABian] openHABian configuration tool version: [master]v1.4.1-468(1afc578)
2019-06-12_01:29:44_CEST [openHABian] Checking for changes in origin... OK
2019-06-12_01:29:53_CEST [openHABian] Updating repositories and upgrading installed packages...
$ apt update
Ign:1 http://repos.azulsystems.com/debian stable InRelease
Hit:2 http://repos.azulsystems.com/debian stable Release
Get:3 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Get:4 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Get:6 https://repos.influxdata.com/debian stretch InRelease [4,732 B]
Ign:5 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable InRelease
Hit:8 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable Release
Get:9 https://repos.influxdata.com/debian stretch/stable armhf Packages [930 B]
Fetched 46.0 kB in 2s (18.4 kB/s)
Reading package lists... Done
Building dependency tree
15 packages can be upgraded. Run 'apt list --upgradable' to see them.
$ apt --yes upgrade
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  libaacs0 libass5 libasyncns0 libavc1394-0 libavcodec57 libavdevice57 libavfilter6 libavformat57 libavresample3 libavutil55 libbdplus0 libbluray2 libbs2b0
  libcaca0 libcairo2 libcdio-cdda1 libcdio-paranoia1 libcdio13 libchromaprint1 libdc1394-22 libdrm-amdgpu1 libdrm-freedreno1 libdrm-nouveau2 libdrm-radeon1
  libebur128-1 libegl1-mesa libfftw3-double3 libflac8 libflite1 libgbm1 libgl1-mesa-dri libgl1-mesa-glx libglapi-mesa libgme0 libgraphite2-3 libgsm1
  libharfbuzz0b libice6 libiec61883-0 libjack-jackd2-0 libllvm3.9 libmp3lame0 libmpg123-0 libogg0 libopenal-data libopenal1 libopencv-core2.4v5
  libopencv-imgproc2.4v5 libopenjp2-7 libopenmpt0 libopus0 libpgm-5.2-0 libpixman-1-0 libpostproc54 libpulse0 libraw1394-11 librubberband2 libsdl2-2.0-0
  libshine3 libsm6 libsnappy1v5 libsndfile1 libsndio6.1 libsodium18 libsoxr0 libspeex1 libssh-gcrypt-4 libswresample2 libswscale4 libtheora0 libtwolame0
  libtxc-dxtn-s2tc libva-drm1 libva-x11-1 libva1 libvdpau-va-gl1 libvdpau1 libvorbis0a libvorbisenc2 libvorbisfile3 libvpx4 libwavpack1 libwayland-client0
  libwayland-cursor0 libwayland-egl1-mesa libwayland-server0 libwebp6 libwebpmux2 libx11-xcb1 libx264-148 libx265-95 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0
  libxcb-present0 libxcb-render0 libxcb-shape0 libxcb-shm0 libxcb-sync1 libxcb-xfixes0 libxcursor1 libxdamage1 libxfixes3 libxinerama1 libxkbcommon0
  libxrandr2 libxshmfence1 libxss1 libxv1 libxvidcore4 libxxf86vm1 libzmq5 libzvbi-common libzvbi0 mesa-va-drivers mesa-vdpau-drivers triggerhappy
  va-driver-all vdpau-driver-all
Use 'sudo apt autoremove' to remove them.
The following packages will be upgraded:
  base-files java-common libpng-dev libpng-tools libpng16-16 libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 openhab2
  python-cryptography raspberrypi-bootloader raspberrypi-kernel rsync unzip
15 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 146 MB of archives.
After this operation, 1,652 kB of additional disk space will be used.
Get:1 http://archive.raspberrypi.org/debian stretch/main armhf libraspberrypi-doc armhf 1.20190517-1 [31.4 MB]
Get:2 http://mirrors.dotsrc.org/raspbian/raspbian stretch/main armhf base-files armhf 9.9+rpi1+deb9u9 [67.5 kB]
Get:4 http://mirrors.dotsrc.org/raspbian/raspbian stretch/main armhf java-common all 0.58+deb9u1 [13.6 kB]
Get:5 http://mirrors.dotsrc.org/raspbian/raspbian stretch/main armhf libpng-tools armhf 1.6.28-1+deb9u1 [130 kB]
Get:6 http://mirrors.dotsrc.org/raspbian/raspbian stretch/main armhf libpng-dev armhf 1.6.28-1+deb9u1 [232 kB]
Get:7 http://mirrors.dotsrc.org/raspbian/raspbian stretch/main armhf libpng16-16 armhf 1.6.28-1+deb9u1 [263 kB]
Get:8 http://mirrors.dotsrc.org/raspbian/raspbian stretch/main armhf python-cryptography armhf 1.7.1-3+deb9u1 [173 kB]
Get:3 https://openhab.jfrog.io/openhab/openhab-linuxpkg unstable/main armhf openhab2 all 2.5.0~S1608-1 [72.8 MB]
Get:9 http://mirrors.dotsrc.org/raspbian/raspbian stretch/main armhf rsync armhf 3.1.2-1+deb9u2 [356 kB]
Get:10 http://mirrors.dotsrc.org/raspbian/raspbian stretch/main armhf unzip armhf 6.0-21+deb9u1 [149 kB]
Get:11 http://archive.raspberrypi.org/debian stretch/main armhf libraspberrypi-dev armhf 1.20190517-1 [404 kB]
Get:12 http://archive.raspberrypi.org/debian stretch/main armhf raspberrypi-kernel armhf 1.20190517-1 [35.1 MB]
Get:13 http://archive.raspberrypi.org/debian stretch/main armhf libraspberrypi-bin armhf 1.20190517-1 [332 kB]
Get:14 http://archive.raspberrypi.org/debian stretch/main armhf libraspberrypi0 armhf 1.20190517-1 [839 kB]
Get:15 http://archive.raspberrypi.org/debian stretch/main armhf raspberrypi-bootloader armhf 1.20190517-1 [3,567 kB]
Fetched 146 MB in 2min 26s (996 kB/s)
apt-listchanges: Reading changelogs...
(Reading database ... 43853 files and directories currently installed.)
Preparing to unpack .../base-files_9.9+rpi1+deb9u9_armhf.deb ...
Unpacking base-files (9.9+rpi1+deb9u9) over (9.9+rpi1+deb9u8) ...
Setting up base-files (9.9+rpi1+deb9u9) ...
Installing new version of config file /etc/debian_version ...
Preparing to unpack .../00-java-common_0.58+deb9u1_all.deb ...
Unpacking java-common (0.58+deb9u1) over (0.58) ...
Preparing to unpack .../01-libpng-tools_1.6.28-1+deb9u1_armhf.deb ...
Unpacking libpng-tools (1.6.28-1+deb9u1) over (1.6.28-1) ...
Preparing to unpack .../02-libpng-dev_1.6.28-1+deb9u1_armhf.deb ...
Unpacking libpng-dev:armhf (1.6.28-1+deb9u1) over (1.6.28-1) ...
Preparing to unpack .../03-libpng16-16_1.6.28-1+deb9u1_armhf.deb ...
Unpacking libpng16-16:armhf (1.6.28-1+deb9u1) over (1.6.28-1) ...
Preparing to unpack .../04-openhab2_2.5.0~S1608-1_all.deb ...
/var/lib/dpkg/info/openhab2.prerm: 65: /etc/default/openhab2: Syntax error: Unterminated quoted string
dpkg: warning: subprocess old pre-removal script returned error exit status 2
dpkg: trying script from the new package instead ...
/var/lib/dpkg/tmp.ci/prerm: 65: /etc/default/openhab2: Syntax error: Unterminated quoted string
dpkg: error processing archive /tmp/apt-dpkg-install-owUSmo/04-openhab2_2.5.0~S1608-1_all.deb (--unpack):
 subprocess new pre-removal script returned error exit status 2
/var/lib/dpkg/info/openhab2.postinst: 65: /etc/default/openhab2: Syntax error: Unterminated quoted string
dpkg: error while cleaning up:
 subprocess installed post-installation script returned error exit status 2
Preparing to unpack .../05-python-cryptography_1.7.1-3+deb9u1_armhf.deb ...
Unpacking python-cryptography (1.7.1-3+deb9u1) over (1.7.1-3+b2) ...
Preparing to unpack .../06-rsync_3.1.2-1+deb9u2_armhf.deb ...
Unpacking rsync (3.1.2-1+deb9u2) over (3.1.2-1+deb9u1) ...
Preparing to unpack .../07-unzip_6.0-21+deb9u1_armhf.deb ...
Unpacking unzip (6.0-21+deb9u1) over (6.0-21) ...
Preparing to unpack .../08-libraspberrypi-doc_1.20190517-1_armhf.deb ...
Unpacking libraspberrypi-doc (1.20190517-1) over (1.20190401-1) ...
Preparing to unpack .../09-libraspberrypi-dev_1.20190517-1_armhf.deb ...
Unpacking libraspberrypi-dev (1.20190517-1) over (1.20190401-1) ...
Preparing to unpack .../10-raspberrypi-kernel_1.20190517-1_armhf.deb ...
Adding 'diversion of /boot/bcm2708-rpi-0-w.dtb to /usr/share/rpikernelhack/bcm2708-rpi-0-w.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2708-rpi-b-plus.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-plus.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2708-rpi-b.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2708-rpi-cm.dtb to /usr/share/rpikernelhack/bcm2708-rpi-cm.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2709-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2709-rpi-2-b.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
Adding 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
Adding 'diversion of /boot/kernel7.img to /usr/share/rpikernelhack/kernel7.img by rpikernelhack'
Adding 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
Adding 'diversion of /boot/overlays/3dlab-nano-player.dtbo to /usr/share/rpikernelhack/overlays/3dlab-nano-player.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
Adding 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/adv7282m.dtbo to /usr/share/rpikernelhack/overlays/adv7282m.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/adv728x-m.dtbo to /usr/share/rpikernelhack/overlays/adv728x-m.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-digione.dtbo to /usr/share/rpikernelhack/overlays/allo-digione.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-katana-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-katana-dac-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/applepi-dac.dtbo to /usr/share/rpikernelhack/overlays/applepi-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audioinjector-ultra.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-ultra.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audiosense-pi.dtbo to /usr/share/rpikernelhack/overlays/audiosense-pi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/balena-fin.dtbo to /usr/share/rpikernelhack/overlays/balena-fin.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/bmp085_i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/bmp085_i2c-sensor.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'..................]
Adding 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/draws.dtbo to /usr/share/rpikernelhack/overlays/draws.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/exc3000.dtbo to /usr/share/rpikernelhack/overlays/exc3000.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/goodix.dtbo to /usr/share/rpikernelhack/overlays/goodix.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-fan.dtbo to /usr/share/rpikernelhack/overlays/gpio-fan.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir-tx.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-key.dtbo to /usr/share/rpikernelhack/overlays/gpio-key.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-no-bank0-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-bank0-irq.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-no-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-irq.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-shutdown.dtbo to /usr/share/rpikernelhack/overlays/gpio-shutdown.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hd44780-lcd.dtbo to /usr/share/rpikernelhack/overlays/hd44780-lcd.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-dacplusadc.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hy28b-2017.dtbo to /usr/share/rpikernelhack/overlays/hy28b-2017.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i-sabre-q2m.dtbo to /usr/share/rpikernelhack/overlays/i-sabre-q2m.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-rtc-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c0-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c0-bcm2708.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c1-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c1-bcm2708.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ilitek251x.dtbo to /usr/share/rpikernelhack/overlays/ilitek251x.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-codec.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-codec.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/jedec-spi-nor.dtbo to /usr/share/rpikernelhack/overlays/jedec-spi-nor.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ltc294x.dtbo to /usr/share/rpikernelhack/overlays/ltc294x.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/max98357a.dtbo to /usr/share/rpikernelhack/overlays/max98357a.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mbed-dac.dtbo to /usr/share/rpikernelhack/overlays/mbed-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp3202.dtbo to /usr/share/rpikernelhack/overlays/mcp3202.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp342x.dtbo to /usr/share/rpikernelhack/overlays/mcp342x.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/media-center.dtbo to /usr/share/rpikernelhack/overlays/media-center.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/midi-uart1.dtbo to /usr/share/rpikernelhack/overlays/midi-uart1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mpu6050.dtbo to /usr/share/rpikernelhack/overlays/mpu6050.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ov5647.dtbo to /usr/share/rpikernelhack/overlays/ov5647.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/papirus.dtbo to /usr/share/rpikernelhack/overlays/papirus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pi3-act-led.dtbo to /usr/share/rpikernelhack/overlays/pi3-act-led.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pi3-disable-bt.dtbo to /usr/share/rpikernelhack/overlays/pi3-disable-bt.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pi3-disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/pi3-disable-wifi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pi3-miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/pi3-miniuart-bt.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pibell.dtbo to /usr/share/rpikernelhack/overlays/pibell.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/piglow.dtbo to /usr/share/rpikernelhack/overlays/piglow.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pwm-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/pwm-ir-tx.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rotary-encoder.dtbo to /usr/share/rpikernelhack/overlays/rotary-encoder.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/rpi-cirrus-wm5102.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-dac.dtbo to /usr/share/rpikernelhack/overlays/rpi-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-display.dtbo to /usr/share/rpikernelhack/overlays/rpi-display.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-poe.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-proto.dtbo to /usr/share/rpikernelhack/overlays/rpi-proto.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sc16is752-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-i2c.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sdio-1bit.dtbo to /usr/share/rpikernelhack/overlays/sdio-1bit.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sdtweak.dtbo to /usr/share/rpikernelhack/overlays/sdtweak.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi0-cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi0-hw-cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-hw-cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ssd1306.dtbo to /usr/share/rpikernelhack/overlays/ssd1306.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/superaudioboard.dtbo to /usr/share/rpikernelhack/overlays/superaudioboard.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sx150x.dtbo to /usr/share/rpikernelhack/overlays/sx150x.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/tc358743-audio.dtbo to /usr/share/rpikernelhack/overlays/tc358743-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/tc358743.dtbo to /usr/share/rpikernelhack/overlays/tc358743.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/tpm-slb9670.dtbo to /usr/share/rpikernelhack/overlays/tpm-slb9670.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/uart0.dtbo to /usr/share/rpikernelhack/overlays/uart0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/udrc.dtbo to /usr/share/rpikernelhack/overlays/udrc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/upstream-aux-interrupt.dtbo to /usr/share/rpikernelhack/overlays/upstream-aux-interrupt.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/upstream.dtbo to /usr/share/rpikernelhack/overlays/upstream.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-kippah-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-kippah-7inch.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
Unpacking raspberrypi-kernel (1.20190517-1) over (1.20190401-1) ...
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.14.98+ /boot/kernel.img
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.14.98-v7+ /boot/kernel7.img
Preparing to unpack .../11-libraspberrypi-bin_1.20190517-1_armhf.deb ...
Unpacking libraspberrypi-bin (1.20190517-1) over (1.20190401-1) ...
Preparing to unpack .../12-libraspberrypi0_1.20190517-1_armhf.deb ...
Unpacking libraspberrypi0 (1.20190517-1) over (1.20190401-1) ...
Preparing to unpack .../13-raspberrypi-bootloader_1.20190517-1_armhf.deb ...
Adding 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
Adding 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
Adding 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
Adding 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
Adding 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
Adding 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
Adding 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
Adding 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
Adding 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
Adding 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
Unpacking raspberrypi-bootloader (1.20190517-1) over (1.20190401-1) ...
Errors were encountered while processing:
Updating FireMotD available updates count ... 2019-06-12 01:33:40,768: FireMotD: Error: Template folder doesn't exist. Upgrading from an older version? Please run make again or run the install function "FireMotD -I -v".
E: Sub-process /usr/bin/dpkg returned an error code (1)
FAILED
[01:33:40] openhabian@openHABianPi:~$
Is it related?
EDIT - Seems like this is a serious issue. I cant really do anything, neither reinstall, uninstall (go back to previous snapshot, release or anything). I end up ind the same deadend loop which seems to be related to this part of the log:
I have no idea how to solve this one. Any advice, help or anything is much appreciated.
I can think of three things to check:
  1. Did u delete the tmp and cache folders or only the files in the folders? What command did u use?
  2. Sometimes after clearing the folders contents you will get errors until openhab Re-creates the cache. Just wait 10 minutes and then if you restart the errors will not occur any more.
  3. Did you play with fstab? Did you create a small tmpfs at /tmp?
It is very hard to comment if you have done other things and don’t post the commands so we know what was done. Please stop entering things into the terminal. Let’s diagnose what is wrong before mashing it up more.
  1. I enter my ssh (winScp) client, and delete all files in the two folders. Not the folders. I always stop openhab first, before clearing cache and tmp.
  2. I have waited hours.. Something has gone totally wrong somewhere. I have cleared cache and tmp many many times before without issues.
  3. Ohh.. Yes I did, just the way you descriped when installing the ipcamera binding. (forgot all about that part :frowning: ).
I will.
In short - I followed your description for installing the latest ipcamera binding with ffmpeg as well.
I did not get any errors when installing ffmpeg, neither when doing the change to fstab or creation of the tmpfs..
I did NOT cleared cache and tmp at this point, only tried reboot due to the new ipcamra binding wouldn´t activate. (ofcouse cause I was missing the last 8 jar files).
When I realised I should have copied all 9 .jar files from the ipcamera archive, I copied the rest 8 jar files to the addons folder.
Then I cleared the cache and tmp, (as you also descriped) and rebooted.
From there, the issue started.
What is very strange is, some manually installed bindings are running just fine. These:
IHC binding
Unifi binding
Ipcamera binding (older version I went back to to see if it would solve the problem).
Tail log is running fine.
But all other bindings (from the error log) as well as PaperUI, BasicUI etc is not running.
I think u may have two issues.
First remove what was added to fstab and reboot. The logs from you trying to do updates show they were unpacking updates to that location and they would have run out of space and failed. Sorry I should have chosen a better folder name. As u have an ssd don’t use tmpfs just leave that out…
After reboot type in
Sudo apt update
Sudo apt upgrade
And hopefully it all upgrades smooth and then reboot. If it fails copy the output.
Second issue I may have seen it before and if you search the error u may find a thread with a post from me saying I fixed it and how. When ever you change what is in the addons folder you should clear the tmp and cache, so if u want back to the older binding u need to do it again. As mentioned the first time u boot up it may give some errors and they can differ and my guess is it depends which parts of openhab start up and in which order. Openhab does not have a set order it starts itself.
I´ll give it a try in a coupple of hours when I get back home.
I did clear the cache and tmp again after copying the old ipcamera binding. Infact I have cleared it quite a few times since last night, in hope to solve the problem.
I know openhab oftens gives strange error after first boot, when having cleared the cache and tmp.. It´s quite annoying, but usually I give it some time to settle, then I do a new reboot, and things is working.
Thats how I usually do this. But in the last few months I have tried avoiding to reboot or even restart due to the serial driver issue which breaks the connection to my z-wave and modbus USB dongles. Specially z-wave is a total mess every time i reboot or restart.. I have to wait untill openhab startup has fninished, then I have to manipulate my z-wave things file, (without actually change anything), save it. After that, it can connec again.. This is also the reason I havnt had much changes lately.
Anyway - I hope the above will solve it.
Just to make sure it’s all done cleanly, it would be a good idea to ssh to the machine and use sudo openhab-cli clean-cache instead of using WinSCP to delete the files manually. Also, if there are other folders that need to be cleaned in the future, that command will be updated but you might miss the announcement.
In another thread I found Matt using this command line:
sudo service openhab2 stop && sudo rm -rf /var/lib/openhab2/cache/* && sudo rm -rf /var/lib/openhab2/tmp/* && sudo reboot
I guess it covers both cache and tmp folder, as well as rebooting?
Thanks alot Matt.. Seems like my system is back running again.. Had a few framework errors at first reboot, and again the serial port driver messed up zwave as well as my modbus dongle.. But most the bindings do start now..
Rebooting it probably overkill. The “official” approach is Clear the Cache
But, does clean-cache also clear the tmp folder?
Seems like I still have quite a few issues..
I can´t seem to get rid of the framework errors when openhab starts.. And after aproxy 20 minutes, things are running in slow motion. Some sensores dont even respond. Other stuff seems to run smoothly though.. Pretty weird.
2019-06-12 18:14:10.446 [ERROR] [org.openhab.core.model.script       ] - FrameworkEvent ERROR - org.openhab.core.model.script
org.osgi.framework.ServiceException: Exception in org.apache.felix.scr.impl.manager.SingleComponentManager.getService()
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:222) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:86) ~[?:?]
	at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1805) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:435) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:325) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:294) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) ~[?:?]
	at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) ~[?:?]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) ~[?:?]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:338) ~[?:?]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:382) ~[?:?]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
	at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
Caused by: java.lang.NoClassDefFoundError: org/eclipse/smarthome/core/ephemeris/EphemerisManager
	at java.lang.Class.getDeclaredMethods0(Native Method) ~[?:?]
	at java.lang.Class.privateGetDeclaredMethods(Class.java:2701) ~[?:?]
	at java.lang.Class.getDeclaredMethods(Class.java:1975) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObjectAssignableMethod(BindMethod.java:469) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BindMethod.doFindMethod(BindMethod.java:180) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.findMethod(BaseMethod.java:173) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$400(BaseMethod.java:41) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod$NotResolved.resolve(BaseMethod.java:602) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod$NotResolved.methodExists(BaseMethod.java:626) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BaseMethod.methodExists(BaseMethod.java:528) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:659) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.prebind(DependencyManager.java:1154) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1568) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1029) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:935) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:900) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) ~[?:?]
	at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) ~[?:?]
	... 64 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.smarthome.core.ephemeris.EphemerisManager cannot be found by org.openhab.core.model.script_2.5.0.201906120308
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:484) ~[?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?]
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?]
	... 64 more
2019-06-12 18:14:10.723 [ERROR] [org.openhab.core.model.script       ] - FrameworkEvent ERROR - org.openhab.core.model.script
	... 64 more
	... 64 more
2019-06-12 18:14:10.979 [ERROR] [org.openhab.core.model.script       ] - FrameworkEvent ERROR - org.openhab.core.model.script
	at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[?:?]
	... 55 more
	... 55 more
2019-06-12 18:14:11.165 [ERROR] [org.openhab.core.model.script       ] - FrameworkEvent ERROR - org.openhab.core.model.script
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.prebind(DependencyManager.java:411) ~[?:?]
	... 72 more
	... 72 more
And more:
2019-06-12 18:14:15.511 [ERROR] [org.openhab.core.model.script       ] - FrameworkEvent ERROR - org.openhab.core.model.script
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1045) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:999) ~[?:?]
	... 133 more
	... 133 more
Yes.
The ClassNotFoundException should be fixed when the following PR is merged:
Ahmm..
Either build 1609 suffers from some serious problems or my system still have seriuos problems..
Few seconds ago, this happened:
2019-06-12 18:43:24.629 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while handling, caused by java.net.SocketException: Broken pipe (Write failed)
2019-06-12 18:43:28.761 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while reading, caused by javax.net.ssl.SSLException: Connection has been shutdown: javax.net.ssl.SSLException: java.net.SocketException: Broken pipe (Write failed)
2019-06-12 18:43:28.768 [WARN ] [su.litvak.chromecast.api.v2.Channel ] -  <--  null payload in message
2019-06-12 18:43:28.761 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while sending 'PING', caused by javax.net.ssl.SSLException: Connection has been shutdown: javax.net.ssl.SSLException: java.net.SocketException: Broken pipe (Write failed)
2019-06-12 18:43:42.145 [WARN ] [ing.ipcamera.handler.IpCameraHandler] - !!!! exceptionCaught could not locate the channel to close it down
2019-06-12 18:43:44.329 [WARN ] [ing.ipcamera.handler.IpCameraHandler] - !!!! exceptionCaught could not locate the channel to close it down
2019-06-12 18:43:44.337 [WARN ] [ing.ipcamera.handler.IpCameraHandler] - !!!! exceptionCaught could not locate the channel to close it down
2019-06-12 18:43:46.483 [WARN ] [ing.ipcamera.handler.IpCameraHandler] - Can't find ch when removing handler 		URL:/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=openhab&password=xxx
2019-06-12 18:44:23.523 [WARN ] [ing.ipcamera.handler.IpCameraHandler] - Can't find ch when removing handler 		URL:/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=openhab&password=xxx
2019-06-12 18:44:57.824 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while sending 'PING', caused by java.net.SocketException: Broken pipe (Write failed)
2019-06-12 18:46:11.278 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while sending 'PING', caused by java.net.SocketException: Broken pipe (Write failed)
2019-06-12 18:46:15.931 [ERROR] [ab.binding.ihc.internal.ws.IhcClient] - New controller state change notification wait failed...
org.openhab.binding.ihc.internal.ws.exeptions.IhcExecption: Encoding error, unsupported data
	at org.openhab.binding.ihc.internal.ws.datatypes.WSControllerState.parseXMLData(WSControllerState.java:63) ~[207:org.openhab.binding.ihc:2.5.0.201904021522]
	at org.openhab.binding.ihc.internal.ws.services.IhcControllerService.waitStateChangeNotifications(IhcControllerService.java:133) ~[207:org.openhab.binding.ihc:2.5.0.201904021522]
	at org.openhab.binding.ihc.internal.ws.IhcClient.waitStateChangeNotifications(IhcClient.java:349) ~[207:org.openhab.binding.ihc:2.5.0.201904021522]
	at org.openhab.binding.ihc.internal.ws.IhcClient.access$5(IhcClient.java:347) ~[207:org.openhab.binding.ihc:2.5.0.201904021522]
	at org.openhab.binding.ihc.internal.ws.IhcClient$IhcControllerStateListener.run(IhcClient.java:508) [207:org.openhab.binding.ihc:2.5.0.201904021522]
2019-06-12 18:46:22.151 [WARN ] [ding.ihc.internal.handler.IhcHandler] - Error occurred on communication to IHC controller: Encoding error, unsupported data
	at org.openhab.binding.ihc.internal.ws.IhcClient.waitStateChangeNotifications(IhcClient.java:349) [207:org.openhab.binding.ihc:2.5.0.201904021522]
	at org.openhab.binding.ihc.internal.ws.IhcClient.access$5(IhcClient.java:347) [207:org.openhab.binding.ihc:2.5.0.201904021522]
2019-06-12 18:48:09.273 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while handling, caused by java.net.SocketException: Broken pipe (Write failed)
2019-06-12 18:48:09.280 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while reading, caused by javax.net.ssl.SSLException: Connection has been shutdown: javax.net.ssl.SSLException: java.net.SocketException: Broken pipe (Write failed)
2019-06-12 18:48:09.291 [WARN ] [su.litvak.chromecast.api.v2.Channel ] -  <--  null payload in message
2019-06-12 18:48:56.023 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Received unexpected BINARY message
2019-06-12 18:49:28.026 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while sending 'PING', caused by java.net.SocketException: Broken pipe (Write failed)
2019-06-12 18:49:56.886 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while reading, caused by javax.net.ssl.SSLException: Connection has been shutdown: javax.net.ssl.SSLException: java.net.SocketException: Broken pipe (Write failed)
2019-06-12 18:49:58.972 [WARN ] [su.litvak.chromecast.api.v2.Channel ] -  <--  null payload in message
2019-06-12 18:49:59.003 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while sending 'PING', caused by javax.net.ssl.SSLException: Connection has been shutdown: javax.net.ssl.SSLException: java.net.SocketException: Broken pipe (Write failed)
2019-06-12 18:50:36.418 [WARN ] [ing.ipcamera.handler.IpCameraHandler] - Can't find ch when removing handler 		URL:/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=openhab&password=xxx
And it keep going in slowmotion with errors now.
I get a similar error when building a binding via mvn clean install:
[ERROR] Failed to execute goal org.apache.karaf.tooling:karaf-maven-plugin:4.2.4:verify (karaf-feature-verification) on project org.openhab.binding.airquality: Feature resolution failed for [openhab-binding-airquality/2.5.0.SNAPSHOT]
[ERROR] Message: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-binding-airquality; type=karaf.feature; version=2.5.0.SNAPSHOT; filter:=“(&(osgi.identity=openhab-binding-airquality)(type=karaf.feature)(version>=2.5.0.SNAPSHOT))” [caused by: Unable to resolve openhab-binding-airquality/2.5.0.SNAPSHOT: missing requirement [openhab-binding-airquality/2.5.0.SNAPSHOT] osgi.identity; osgi.identity=openhab-runtime-base; type=karaf.feature [caused by: Unable to resolve openhab-runtime-base/2.5.0.SNAPSHOT: missing requirement [openhab-runtime-base/2.5.0.SNAPSHOT] osgi.identity; osgi.identity=openhab-core-model-script; type=karaf.feature [caused by: Unable to resolve openhab-core-model-script/2.5.0.SNAPSHOT: missing requirement [openhab-core-model-script/2.5.0.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.core.model.script; type=osgi.bundle; version=“[2.5.0.201906120308,2.5.0.201906120308]”; resolution:=mandatory [caused by: Unable to resolve org.openhab.core.model.script/2.5.0.201906120308: missing requirement [org.openhab.core.model.script/2.5.0.201906120308] osgi.service; filter:=“(objectClass=org.eclipse.smarthome.core.ephemeris.EphemerisManager)”; effective:=active]]]]
Edit: solved now
@Kim_Andersen
What exactly has changed with this system since it was last working fine? Is 2.5 milestone 1 new? What else has changed. When at the Linux terminal you can press the up arrow to step through your history of what was run.
Two points to make.
Look for the first warning and error in your logs when it was starting up fresh, work on that first as often 1 error causes others so think of the first as the root cause.
Second point is often it is faster to load a backup if you have one. You can take a full image of a ssd with the method I posted to you a few days ago. You can write the image onto a second ssd or back onto the same drive. When this is running nice again consider a second ssd you can copy the drive onto for testing. Five minutes having a coffee and the system thinks it was only rebooted.
Well it never actually worked fine after I removed the fstab changes and did the apt update and upgrade..
It did work, bindings started to run after that, but the system ran like in slow motion, without actually showing any errors. After aprox one hour running, errors (like the latest showen above) started to appear, and it went totally dead..
Status right now..
Last night I simply gave up trying to fix it. I thought I could go back to my latest backup, but things had changed too much. Insted I started all over with a fresh ssd drive and a fresh new openhab installation.. (still got the old ssd). Struggling with some new issues though, but I´m getting there, (I hope).
In another life I was a field service engineer.
Sometimes, this would require turning up at a site where the customer was weeping over a smouldering machine, because his business was stopped.
Greeting: "It’s ALL YOUR FAULT because it’s YOUR MACHINE broken and I want it FIXED yesterday!!!’
My gambit …
“Okay, I’ll get on and fix it, while you get your backup ready to restore …”
I never, ever got the response “It’s RIGHT HERE waiting for you to FIX it!!” - it was usually stony silence instead, followed by a disappearance in to the back office.
