Setting up a TV with Google Assistant Integration
Hi everyone,
I saw that it is possible to use ga tags to control a TV with google assistant.
I tried it for my TV but it doesn’t show up in my google home app.
Group TV_LG "LG" { ga="TV" [ volumeDefaultPercentage="20", levelStepSize="10", volumeMaxLevel="100", roomHint="Wohnzimmer"] }
Dimmer   TV_LG_Volume2                    "Lautstärke TV" (TV_LG) ["Point"] { ga="tvVolume" [roomHint="Wohnzimmer"] }
Because this didn’t work I tried it simpler
Group bcd "bcd" { ga="TV" [roomHint="Wohnzimmer"]}
Switch cde "cde" (bcd) { ga="tvPower" [roomHint="Wohnzimmer"]}
But this is also not working.
In the documentation it is described as follows
Group { ga="TV" [ volumeDefaultPercentage="20", levelStepSize="10", volumeMaxLevel="100", transportControlSupportedCommands="NEXT,PREVIOUS,PAUSE,RESUME", availableInputs="hdmi1=xbox,hdmi2=settopbox", availableChannels="1=Channel1=NBC,2=Channel2=CBS" ] }
Switch { ga="tvPower" } as part of TV group (optional)
Switch { ga="tvMute" } as part of TV group (optional)
Dimmer { ga="tvVolume" } as part of TV group (optional)
String { ga="tvChannel" } as part of TV group (optional)
String { ga="tvInput" } as part of TV group (optional)
Player { ga="tvTransport" } as part of TV group (optional)
So I am wondering what I am doing wrong with my config. What I saw in GitHub maybe @michikrug could help as he developed it
Sorry for the confusion. The code is unfortunately not yet deployed and publicly available.
As there is no release process for the documentation, this is already live from the unreleased state.
So please be just a bit more patient until the release is announced.
Ah ok. Thank you for your information. I was wondering because it was merged in october.
So do you have an idea when it will be ready to used? Is the implementation finished and just the deployment is missing? So is it possible to download the latest jar file from somewhere?
Well that is not really correct. The code was merged last week. But yes, the implementation is complete but just not deployed.
There is no jar file as this is not an addon for openhab but an external integration.
There are ways to host you own. Please have a look hat the GitHub repository. GitHub - openhab/openhab-google-assistant: openHAB Google Assistant: Actions on Google for openHAB
The Smart Home Television Guide also shows a trait “AppSelector” for starting apps like Netflix or Youtube. Is this also included in your implementation? Asking because it is not in the example Item configuration…
Oh sorry, you are right. I just checked the commit.
But when it is now merged it should be hopefully available soon. Will it be in the next openhab release ( currently it looks like the releases are at the end of a month) or is it completely different because you mentioned that it is external. Is there a way where I can check if it is now available without hosting it on my own?
To be honest, I think there is currently no way for the user to check what code is released. :confused:
The release for this integration is completely independent from any openHAB release.
We for now completely depend on @MARZIMA to deploy it manually.
But I am working on an automation and actual release flow so that users are more aware of what is when available.
Not for now.
Would you mind adding a feature request here: GitHub · Where software is built
I think we will soon deploy. I am waiting to make the announcement. Maybe we do it without @michikrug ?
@MARZIMA was there a deployment? I am not sure for me it looks like the new TV item is still not there
Why is it necessary to wait for something?
Just let people here know that there will be a new version on a date of your choice and tell them the impact and do it! :slight_smile:
@MARZIMA are there any news?
Now that the new release was announced, is the tv working for anyone? I tried with the simplest setup (just the group and tvPower) and i am not able to turn it on or off
Same for me. No tv for the moment in my google home app
@MARZIMA @michikrug should it already be available?
I tried the latest snaphot. Seems that it is still not included.
No. We had multiple appointments in the last weeks to bring all this stuff live, but Marzima seemed to have time issues…
We are patient, no problem. Google integration works very well with all new traits. I remember the 2019 conversations what were very unpolite for some reason when new traits were introduced an GH integration was redesigened by you at the end.
@michikrug
It looks like it is now available. But I have a question:
availableChannels
I tried to control my tv by saying: Put on ARD on LG
My availableChannels are setup like this:
1=Kanal1=ARD,2=Kanal2=ZDF
But google says he doesn’t know ARD. If I say Put on channel1 this is working.
So i changed it to ARD=ARD=ARD but also nothing happens. Is it only possible to use numbers to control the channels?
First, cool to see that it basically works!
Unfortunately, I can not answer your question. The code and tests look properly and also the names should be usable in the commands.
I will do a manual test in my setup in the next days to find out more about the behavior.
Could you please try: 1=ARD=ARD
