- Platform information:
- Hardware: Synology with
- OS: DSM > 7
- openHAB version: * OpenHab 3.2 (from Docker) using this installation: Synology DiskStation | openHAB
- Issue of the topic: I added custom binding by coping jar from (GitHub - wildcs/oh3_compiled-addons: OpenHab3 Compile Addons by wildcs) into mounted addons directory here:
I removed the standard tapo binding (by deleting it twice)
I added the cloud bridge and entered the username and password and received:
Also, after this was successful, OH identified my first P110 plug
I added it and now I see:
This error message appeared some moments later. Meaning that initially OH identified automatically the tapo device (with all its attributes, like on/off switch, energy control etc.). Thus I think, some communication should have taken place.
Now I wonder what this error message means and how I can redeem it.
I already found this about the error:
But I don’t know if this can help as I don’t have a unify binding but a custom tapo binding?
Please post configurations (if applicable):
- Items configuration related to the issue
UID: tapocontrol:P110:b305cd4052:54AF977CB69A
label: Stereoanlage
thingTypeUID: tapocontrol:P110
configuration:
pollingInterval: 30
bridgeUID: tapocontrol:bridge:b305cd4052
I set cloud discovery to true (on the cloud bridge)
Services configuration related to the issue
If logs where generated please post these here using code fences:
openhab.log:
2022-05-15 09:05:43.688 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tapocontrol:P110:b305cd4052:54AF977CB69A' to inbox.
2022-05-15 09:06:22.523 [WARN ] [l.structures.TapoDeviceConfiguration] - tapocontrol:P110:b305cd4052:54AF977CB69A error reading device-configuration: 'null'
2022-05-15 10:54:29.223 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tapocontrol:P110:b305cd4052:54AF977CBAB8' to inbox.
2022-05-15 10:54:43.619 [WARN ] [l.structures.TapoDeviceConfiguration] - tapocontrol:P110:b305cd4052:54AF977CBAB8 error reading device-configuration: 'null'
I tried to investigate “error reading device-configuration …” but only found this [TapoControl] - Control Tapo Smart WiFi-Devices with Openhab - Official Support Thread - #88 by Kaoth
There is says
But it is about other tapo devices and it seems to have no impact?
events.log
2022-05-15 09:05:42.284 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:bridge:b305cd4052' changed from UNINITIALIZED to INITIALIZING
2022-05-15 09:05:42.343 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:bridge:b305cd4052' changed from INITIALIZING to UNKNOWN
2022-05-15 09:05:43.570 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:bridge:b305cd4052' changed from UNKNOWN to ONLINE
2022-05-15 09:05:43.688 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'tapocontrol:P110:b305cd4052:54AF977CB69A' has been added.
2022-05-15 09:06:22.522 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery Result with UID 'tapocontrol:P110:b305cd4052:54AF977CB69A' has been removed.
2022-05-15 09:06:22.526 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:P110:b305cd4052:54AF977CB69A' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)
2022-05-15 09:30:50.182 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Stereoanlage_OutputSwitch' received command ON
2022-05-15 09:30:50.187 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Stereoanlage_OutputSwitch' predicted to become NULL
2022-05-15 09:30:52.390 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Stereoanlage_OutputSwitch' received command ON
2022-05-15 09:30:52.391 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Stereoanlage_OutputSwitch' predicted to become NULL
2022-05-15 09:30:55.497 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Stereoanlage_OutputSwitch' received command OFF
2022-05-15 09:30:55.499 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Stereoanlage_OutputSwitch' predicted to become NULL
2022-05-15 09:31:07.049 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Stereoanlage_OutputSwitch' received command ON
2022-05-15 09:31:07.051 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Stereoanlage_OutputSwitch' predicted to become NULL
2022-05-15 09:31:07.852 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Stereoanlage_OutputSwitch' received command OFF
2022-05-15 09:31:07.854 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'Stereoanlage_OutputSwitch' predicted to become NULL
2022-05-15 09:31:28.105 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'P110SmartPlug_OutputSwitch' received command ON
2022-05-15 09:31:28.107 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'P110SmartPlug_OutputSwitch' predicted to become OFF
2022-05-15 09:31:31.830 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'P110SmartPlug_OutputSwitch' received command OFF
2022-05-15 09:31:31.831 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'P110SmartPlug_OutputSwitch' predicted to become OFF
2022-05-15 09:31:33.098 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'P110SmartPlug_OutputSwitch' received command ON
2022-05-15 09:31:33.100 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'P110SmartPlug_OutputSwitch' predicted to become OFF
2022-05-15 09:31:34.117 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'P110SmartPlug_OutputSwitch' received command OFF
2022-05-15 09:31:34.118 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'P110SmartPlug_OutputSwitch' predicted to become OFF
2022-05-15 10:54:29.223 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'tapocontrol:P110:b305cd4052:54AF977CBAB8' has been added.
2022-05-15 10:54:43.618 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery Result with UID 'tapocontrol:P110:b305cd4052:54AF977CBAB8' has been removed.
2022-05-15 10:54:43.623 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:P110:b305cd4052:54AF977CBAB8' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)
Being a newbie I am completely lost now
