Share Z-wave dongle over IP (USB over IP using ser2net / socat ) guide
I have just found the references to the comments about removal of a functionality that I have misread to mean removal of support for RFC2217 in the ZWave binding: [SOLVED] [Zwave, Zigbee, ...] RFC2217 remote serial port HowTo? - #4 by chris
I stand corrected by @chris that the functionality is present in the current ZWave binding, albeit no one has reported it as working, while there are 3 of us, @dastrix80, @vossivossi (who got a bit further that I and could see something in the logs) and I, at least, reporting it as not functioning.
Just found also this comment by @curlyel “For the Zwave I have to stick with the socat stuff anyway due to the reverted implementation. Thanks Chris for pointing this out!”. Based on the comments from @chris I assume this must be factually incorrect as there was no reverted implementation of the RFC2217 support. I hope I am getting this right!
We can see in the code that the ESH serial port abstraction classes are used, and not the NRJavaSerial, or any other library (directly).
So in theory, the ZWave binding should be able to use any serial abstraction that is implemented in the ESH (now OH) serial abstraction layer. I understood from the original PRs on ESH that this included RFC2217, but I have never personally tested this.
https://github.com/eclipse/smarthome/pull/5560
I hope that clarifies this?
Thank you, again, @chris, for taking the time to patiently explain how things are. Would I be right in thinking, then, that when I specify “rfc2217://ip:port” as a port in your ZWave binding this is not handled using nrjavaserial. However, when I specify “/dev/something” it does get passed to nrjavaserial? I wonder what generates the “Port does not exist” error message string that I am seeing.
That would be my expectation. I would expect that the ESH abstraction does some sort of check on the “domain” of the port and decides where to handle this. However, again, I’ve never looked at this code so I can’t confirm this.
@chris, could you point me at the code file/folder that deals with this, and I will see if I can figure out anything? I am not familiar with the OH codebase, I am afraid, so any pointers will jump start me. Or is it just “org.eclipse.smarthome.io.transport.serial”?
Yes- if you look in the OH2.5 branch in the core then this should be the folder I think. As I’ve said, I’ve never personally looked at or for this code, so I’m not really able to help with any level of knowledge. Unfortunately I don’t really have the time to spend trying to work this out right at the moment.
I have tried recompiling openhab-core with the new nrjavaserial-5.0.0. I can see that rfc2217 URI in the ZWave binding port config is now behaving differently. It still does not work but it gives a different error. See this Github issue for more detail, please feel free to make any suggestions that could help move it forward.
@chris, in case you are not following the two threads on the nrjavaserial repo, I have a quick update. Indeed, the issue with the lack of RFC2217 support was in nrjavaserial. It was missing the logic that checks for the URI and it was never trying to instantiate rfc2217 serial port, ie. it was always treating it as a “real” port. This logic is now in place in the master branch, hopefully it will be in a release soon.
As for the issues @MrRusch and my system has in opening even regular ports under FreeBSD, this is still an open case. I am running out of time due to low Java skills (maven scares me), but I will try to help if I can.
My bad. I have just re-run the test, using the freshest version of nrjavaserial (5.1.1+) and I can confirm that as long as I do not use OpenHAB, ie. I am only using a simple test harness in Java to open the port it is now working without errors and remains so for up to 2 minutes. I have not tried for longer.
Once the new build is in Maven I will rebuild OH 2.5 to see if it fixes our issues. I would have tested it locally now, but I lack the skills to reconfigure the Maven pom.xml files to use my locally built nrjavaserial. I also lack the skills to do what OpenHAB needs and to use a new jar, it seems. Hopefully I will know more tomorrow or in the next few days.
I’ve made some changes to the ZWave binding that should help with resolving some of the rfc2217 issues. Maybe some of you can test them?
See: [SOLVED] [Zwave, Zigbee, ...] RFC2217 remote serial port HowTo? - #28 by wborn
I will test this weekend. Many thanks for your work, @wborn!
May I ask how the reliability is? Even in the event of a power failure or reboot of the server or client?
I would like to pass my Zwave Stick to OH on Proxmox and hope that this also works if OH changes host.
At the moment I’m using USBIP, but it doesn’t reconnect automatically when the USBIP server is gone.
Actually rock solid, when the openHAB server reboots, remote serial ports are reconnected again and when I reboot the satellite running ser2net the connection is obviously lost but immediately reconnects and the connected devices are online and reporting again as can be seen from below log. This is running on the latest stable (2.5.9).
2020-10-20 08:12:30.062 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:173f800265d' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Controller is offline
2020-10-20 08:12:30.063 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node5' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-10-20 08:12:30.065 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-10-20 08:12:30.066 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node3' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-10-20 08:12:30.067 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node4' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-10-20 08:13:17.978 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-10-20 08:13:17.979 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-10-20 08:13:17.983 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 2: Not initialized (ie node unknown), ignoring message.
2020-10-20 08:13:17.988 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 2: Not initialized (ie node unknown), ignoring message.
2020-10-20 08:13:17.992 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 2: Not initialized (ie node unknown), ignoring message.
2020-10-20 08:13:17.997 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 2: Not initialized (ie node unknown), ignoring message.
2020-10-20 08:13:21.302 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:173f800265d' changed from OFFLINE (COMMUNICATION_ERROR): Controller is offline to ONLINE
2020-10-20 08:13:21.307 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node3' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-10-20 08:13:21.309 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-10-20 08:13:21.315 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node5' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-10-20 08:13:21.315 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:173f800265d:node5' has been updated.
2020-10-20 08:13:21.316 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node4' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-10-20 08:13:21.316 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:173f800265d' has been updated.
2020-10-20 08:13:21.331 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node3' changed from ONLINE to ONLINE: Node initialising: PING
2020-10-20 08:13:21.342 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node5' changed from ONLINE to ONLINE: Node initialising: PING
2020-10-20 08:13:21.351 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node2' changed from ONLINE to ONLINE: Node initialising: PING
2020-10-20 08:13:21.362 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node4' changed from ONLINE to ONLINE: Node initialising: PING
2020-10-20 08:13:21.392 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node3' changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2020-10-20 08:13:21.547 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node5' changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2020-10-20 08:13:21.937 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:173f800265d:node5' has been updated.
2020-10-20 08:13:23.600 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node5' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2020-10-20 08:13:23.836 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node2' changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2020-10-20 08:13:24.140 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node3' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2020-10-20 08:13:24.438 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node4' changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2020-10-20 08:13:24.514 [vent.ItemStateChangedEvent] - PoolhousePM25 changed from 18 to 15
2020-10-20 08:13:25.800 [vent.ItemStateChangedEvent] - PoolhouseLoudness changed from 60 to 57
2020-10-20 08:13:26.399 [vent.ItemStateChangedEvent] - PoolhouseTemperature changed from 8.4 °C to 8.5 °C
2020-10-20 08:13:27.587 [vent.ItemStateChangedEvent] - PoolhouseVOC changed from 0.006 to 0.008
2020-10-20 08:13:28.887 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node4' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2020-10-20 08:13:35.406 [vent.ItemStateChangedEvent] - PoolhouseCO2 changed from 437 to 441
2020-10-20 08:13:35.417 [hingStatusInfoChangedEvent] - 'zwave:device:173f800265d:node2' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
Hi all, Thank you for this very usefull discussion.
I achieve to get my openhab docker hosted in a NAS communicating with a remote zwave controller (Razberry) using ser2net and socat.
But like some of you, the controller will stay offline when the connection between the docker and the razberry is lost. A restart of socat solve the problem. As there is no systemctl on my docker i cannot achieve to monitor and auto-restart socat. May be I haven’t found the final solution in this long discussion, but have someone get a stable solution in a docker environment to maintain socat connected ?
I’m trying to solve the problem using the following rule :
rule "maintain zwave"
Time cron "0 0/1 * * * ?"  // every minute
var Status = getThingStatusInfo("zwave:serial_zstick:3233e118").getStatus()
            logInfo("b_zwave", "serial_zstick " + Status)
            if (Status.toString() == "OFFLINE")     {
                    var retval = executeCommandLine("/usr/sbin/service socat-zwave restart",5000)
                    logInfo("b_zwave", "Restarting socat ("+retval+")")
but openhab has no right to restart the service. So i’m still block on that way and at the limit of my knowledge with docker (no sudo, no systemctl, must not make change on system side as docker should be updated easily (no change outside /openhab folder…)
Any help ?
You can’t do that from within Docker. The command must be run on the host. One of the main points of containers is to prevent software from doing that sort of thing. You will have to create some sort of service or script that runs outside the container that you can send a message to (e.g. MQTT) and that script will execute the command. Or you will have to install openHAB on the host and not use containers.
I’ve been trying to extend zwave coverage into a steel outbuilding and have finally had some success. I need to summarize some of my findings for the next person trying to piece together what I’ve done and maybe for others to chime in with improvements I could make. I’m choosing to post to this 4 year old thread rather than a new thread because a lot of info and search results consolidate here.
  1. OH rfc2217 support.
    It will take you most of this thread and parts of others to confirm (i.e. buy into going down the path): OH3 supports rfc2217 natively, seems to work really well. This means you likely won’t need socat unless you have special requirements.
'Controller Thing - Controller serial port:'
rfc2217://extendzwavepi:3333
  1. ser2net yaml.
    ser2net has updated to yaml for config, with deprecation warnings for the conf file configs. Here’s a working example so you don’t have to bounce through threads to piece together:
#add this to /etc/ser2net.yaml
connection: &Zwave
  accepter: telnet(rfc2217),tcp,3333
  connector: serialdev,
    /dev/zwavestick,
    115200n81 local
  1. ser2net systemd service definition
    Still experimenting with this but it seems ser2net tries to start a bit too early and will have errors if you check it’s status, when it’s in this state the controller Thing in OH will show an error/disconnected state.
sudo systemctl status ser2net.service
Cannot confirm this is a fix but I’m attempting to have the service wait until all networking is up:
/usr/lib/systemd/system/ser2net.service
[Unit]
Description=Serial port to network proxy
Documentation=man:ser2net(8)
After=systemd-networkd-wait-online.service
Wants=systemd-networkd-wait-online.service
You’ll need to make sure those units are enabled in systemd:
sudo systemctl enable systemd-networkd.service systemd-networkd-wait-online.service
Reload the systemd manager configuration after enabling the units and updating the ser2net conf:
sudo systemctl daemon-reload
  1. Getting results.
    Here’s where I’m unsure of my end result - seems janky but works :man_shrugging:
    Factory reset my secondary zstick with zensys tools and put it in inclusion/learn mode while starting discovery through OH with the primary controller. Secondary zstick is now both a controller in OH and a Thing belonging to the primary controller.
    jank: all primary devices show in the Inbox a second time coming from the secondary controller. (at one point I thought I could ignore these secondary devices and the secondary controller would just be acting as a repeating node, inside the steel building, for the primary (only) zwave network.)
  2. Add secondary things to items.
    I started to realize my idea about the secondary controller just being a repeater must be incorrect. So I added the “secondary Thing” for the steel building zwave node to the steel building Item that has been problematic to control. Instant result :grinning_face_with_smiling_eyes:
    It may be a bit cleaner Thing-wise if I just created a second zwave network but I do have neighboring nodes that can and do reach the steel building node and that redundancy may be valuable at certain points.
For extra fun, my rpi running the secondary controller is on PoE making it easy to power cycle from unifi if everything needs to get bounced. I also had to solder a new resistor on my old gen5 Aeotec stick in the middle of all this so my rpi4 (wanted PoE) would recognize it (https://olausson.de/news/2-misc/26-aeotec-z-stick-gen5-raspberry-pi4-mod).
Again, not trying to resurrect the thread but Rich points to it from several “out building??”-type threads and this thread does have tons of info but it spans so many posts it gets hard to gauge the current state of things. I feel like I’ve covered all the things I couldn’t directly piece together from old posts.
An alternative to ser2net is USB/IP. RUDY wraps USB/IP in a Docker container, maybe interesting here.
I think I heard that OpenHab 3 has built-in support for achieving the same end result without having to use USB over IP? Is that true? If so, where can I find information on that. Planning to upgrade from 2 to 3.
