Here’s mine (I have a more elaborate file in case there’s previous stuff important, but it looks like attachments are impossible):
shelly_notification:163 Status change of switch:0: {"id":0,"aenergy":{"by_minute":[0.000,0.000,0.000],"minute_ts":1706558939,"total":49589.837}}
21:09:00
shos_rpc_inst.c:355 0x3ffe2b00: duplicate id 'shellyplus1pm-d4d4da7df89c'
21:09:32
shos_rpc_inst.c:230 Shelly.GetStatus via HTTP_in POST 192.168.1.9:52218
21:09:32
shelly_bluetooth_rel:91 ADV 3c:2e:f5:69:4b:59: mfd={"0ba9":"AQEACwIACllLafUuPA=="}, svc={"fcd2":"RAAuAWQFAAAALQA/AADwAgLxAAkAAQ=="}
21:09:33
Uncaught Error: Cannot read property 't' of undefined
21:09:33
at _value = this.getBufValue(_bth.t, buffer);
21:09:33
21:09:33
in function "unpack" called from ...ice_data[BTHOME_SVC_ID_STR]);
21:09:33
21:09:33
in function "getData" called from ...ShellyBLUParser.getData(res); // skip if parsing failed
21:09:33
21:09:33
in function called from system
21:09:33
21:09:33
shelly_user_script.:397 error: Error in EjsCall
21:09:33
shelly_notification:163 Status change of script:1: {"id":1,"errors":["error"],"running":false}
21:09:34
I now for two days had an issue with a Shelly Plus 1 not being reachable from OpenHAB.
The Thing showed “ERROR:COMM”, and in the log file I can see this error:
2024-01-31 09:46:04.636 [WARN ] [y.internal.handler.ShellyBaseHandler] - shellyplus1-7c87ce64f858: ERROR: Unable to process command ON for channel shelly:shellyplus1:4cbd683cd4:relay#output - API Timeout for POST http://192.168.0.27/rpc
During the time this error was shown, a ping to the IP address worked and I could control the Shelly via the Shelly app. After I restarted OH, also OH showed the Thing as “ONLINE” again and could control it. Any idea what could cause such a timeout, when the device is actually reachable?
With this change the script definitely runs longer. But it was finished last night and again this morning.
But I don’t have an error message about it yet.
The log only seems to be written when the browser is open and you are still logged in.
Deactivate “BLU Gateway Support” in your openhab thing configuration of your shelly plus device, after you modified the script. This option keeps overwriting your changes.
Your shelly BLU things will still work in openhab as long as the modified script is running.
the binding checks the current script during thing initialization, if it differs it gets updated
once you have something stable I could update the script and build a new jar
I tried creating a pull request, but I have another pull request (on another matter), and haven’t yet figured out how to have two parallel pull requests…
I managed to add blumotion according to documentation with autodiscovery (a lot of button pressing on device was required). Thing appeared in inbox, I was able to add channels.
And now, channels are updating without problem (if you additionally modify oh-blu-scanner script on shelly gateway as mentioned above) but blumotion thing is in state: "ERROR:COMM).
The events.log look as follows:
2024-02-03 07:41:00.967 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyblumotion:e8e07e944880' changed from OFFLINE (COMMUNICATION_ERROR): Unable to connect to device - BLU Device not yet connected(class org.openhab.binding.shelly.internal.api.ShellyApiException) to UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode.
2024-02-03 07:41:00.969 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyblumotion:e8e07e944880' changed from UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode. to OFFLINE (COMMUNICATION_ERROR): Unable to connect to device - BLU Device not yet connected(class org.openhab.binding.shelly.internal.api.ShellyApiException)
2024-02-03 07:42:00.973 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyblumotion:e8e07e944880' changed from OFFLINE (COMMUNICATION_ERROR): Unable to connect to device - BLU Device not yet connected(class org.openhab.binding.shelly.internal.api.ShellyApiException) to UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode.
2024-02-03 07:42:00.974 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'shelly:shellyblumotion:e8e07e944880' changed from UNKNOWN (CONFIGURATION_PENDING): Initializing or device in sleep mode. to OFFLINE (COMMUNICATION_ERROR): Unable to connect to device - BLU Device not yet connected(class org.openhab.binding.shelly.internal.api.ShellyApiException)
But if I manually add blumotion as blubutton everything seems to work ok nad the thing status is ONLINE not ERROR:COMM
